View Full Version : Suspension & Brakes
- B18b1 da9 axle question
- Tighter steering response
- Car sways/leans to the right
- Advice
- koni adjustables
- 2002 Honda Civic rear brakes
- Odd noise not sure if coming from tranny or wheel bearings???
- 92 EG civic cx rim and brake question.
- Another Progress CS2 Thread
- MOOG tie rods and ball joints??
- 2004 accord ex 4 cylinder dash brake light
- new struts and new noise
- Ball joints....nuff said...
- best money spent on suspension.
- Recommend any coilovers ?
- progressive springs with full coilovers?
- 10k/12k spring rates?
- H&R Street Performance Coilovers
- diy strut bars?
- Poly bushings with bonded design(to inner/outer sleeve)
- Best stockish EG6 shock upgrade?
- Complete/Correct EG Brake Upgrade (?)
- TruHart coilovers for 95 civic
- OEM Brake Upgrade Insight- Legend, ITR, EP3, Mini Cooper
- What are the thoughts on these control arms?
- Hawk PC Brake Pads: I Think I HATE Them...
- Help! Ordered manual HFP sport suspension by mistake!
- 97 hatch heavy steering shaking
- Mixture of both Polyurethane & Rubber Bushings
- Another Koni/GC Thread
- Cheap springs spring rate VS Tein spring rate.
- Broke new front wheel bearings while pressing
- Tender Spring selection?
- Cut into lower front control arm when removing bushings!
- spring and shock or coilover suspension?
- Caster question on ek
- lowering springs
- How to convert 242mm knuckles to 262mm on my 91 civic si
- Cheapest way to convert to 280mm
- Problem changing brake pads
- Honda eg3
- Hack Mechanic Ruined My '99 Accord
- "Soft" brakes
- 00 Integra vs 98 Ek Civic
- crx brake upgrade?
- Brake pedal going to floor after new mc
- Uneven ride height
- WARNING never buy fake lcas
- 96-00 Civic FLCA bushings?
- TA Bushing wrong. In or out?
- Brake caliper mounting bracket help!!
- Rear toe
- Hit Curb car pulling left and right
- Suspension Help!!!!!
- Coilover Help
- Best rates for coilovers
- koni question/ suspension advice needed pls
- Koni Yellow - Eibach pro kit - Extended top hats. PLEASE HELP
- Best tool or method for installing ball joints
- Question regarding first DIY brake pad swap
- Car jerks sometimes when braking
- Wondering if EG hatch suspension is compatible with an EF hatch
- 94 Accord Rear brake issue
- 4x114 300mm
- DC2 Integra Rear Brakes-what's wrong?
- SI Rear sway bar endlink bushing?
- Brake piston literally came out. Help please!
- Tanabe Sustec details?
- 2009 civic si - rear passenger brake issue
- Suspension setup for off-road?
- Rear Pistons coming out!!!
- Anyone here swap out the steering rack on an eg
- 95 Civic Hatchback - GC and Koni Yellow - Spring Rate Questions
- 95 civic coupe gc Mazda springs
- Rough/notchy steering feel in one direction
- ITR Rear LCA and Camber Arm PIC Bushing Install
- 4x100 to 4x114 Conversion Advice
- Camber kit
- What are these worth? (Used Koni SPSS3's with springs and sleeves)
- looking for some coilover help
- (2000 Civic GX) Low pitch hum/rattle, vibrating brake pedal when riding over pothole
- which chassis do these coilovers fit?
- 40 mph and below shake
- No brakes under boost
- Real Or Fake Skunk 2 Front Camber kit ???
- ISC Coilovers
- I bought the JHP itr master cylinder, now what?
- ~2 inch drop; what adjustments needed?
- '03 rear brake pad swap?
- Trouble installing ITR struts in EG. Halp pls.
- Can someone measure CRX/EF Function Form coilovers for me please?
- Coil overs 500 cash...
- Where Is Skunk2 NEW Ultra LCAs
- CV Boot Cracked..
- Rear Spindle Assembly Nut & Bolt Size?
- Returning to stock springs?
- OEM Part number for 1994 del sol vtec endlinks?
- Anyone an expert on BC coilovers?
- Aftermarket calipers
- Still on the my quest for my brake setup
- Brakes
- Unable to remount the lower control arms
- EF Hatch F+R Shocks On 2000 Civic Question.
- Proac'tive Coilover Sleeves? Any information?
- Tein Flex Z for EG2/DC2
- Reluctor / toner ring scrapped off Honda Fit
- OEM Rear Lower Control Arm Geometry Differences between 89-95 Civics
- Ordered my Koni/GC, couple ???
- Brakes locking up
- What could be causing "dog-tracking?"
- Suspension Shops near Richmond, VA
- Mystery Coilovers
- 98 civic, Is the upper ball joint replaceable?
- Ktuned traction bar adjustment
- Noise when braking at coasting/slow speeds
- Need help with my disc brake conversion
- Threaded Coilover Cartridge Replacement Source
- suspension travel koni yellow/h&r race
- Bilstein B8
- Skunk2 Pro-S II Coilovers
- 04 civic lx front brakes locking up and glowing red!!
- Old accord needs new legs
- project brakes
- 95 Accord Wagon suspension question
- Front Upper Control Arm 96-00 Civic replacement questions
- New to cars.... want to lower my car..... help!!!!!!!
- Ride height with EKK1 mounts.
- lowering springs on a ep3 in the winter help
- E-Brake...
- Spoon calipers 4x100 conversion
- K SERIES AXLES
- Clicking/popping sound when slowing down and on bumpy roads
- Acura RSX pillow ball vs Poly
- Squeal noise when I start moving
- Blox rear sway bar links, EG & integra
- Extremely uneven coilovers!
- what makes a sound like this?
- Stock Ej8 needs to stiffen up
- Coilover adjustment
- which coilovers will i need to buy?
- Video of Steering problem
- Koni Str.T vs KYB AGX?
- 1988 crx si suspension
- Newbie need brakes help
- crx dx five lug conversion not ef five lug ug
- Coilover causing scraping sound when turning right
- 2003 Accord V6 ABS Brakes
- Please help troubleshoot brake problem!
- High Pitched Brake Squealing When Not Braking
- Oversensitive steering after mounting new tires
- TEIN Control Master Type Flex
- Caliper Brackets
- Brake Problem
- 15x8 +20 offset
- Gecko coilovers
- suspension noise
- Budget Bilstein Coilover
- Brakes HELP! Setup is not stopping
- EK Rear Disk Conversion: 6-Port to 4-Port Prop. Valve Issue!?
- Honestly, how bad are my struts?
- NEED HELP ASAP PLEASE!
- 1st gen integra
- Questions about my setup..
- 01 integra power to manual steering
- Nengun
- EP3 HFP suspension repair
- Koni yellow and gc help
- Need advise choosing rotors for dc5
- Coilover making a noise
- EG wants to roll out
- Brakes going to floor after changing master cylinder
- Installation problem!
- Tein Street Flex VS D2 SS ??
- 2000 honda civic sedan rear anti-sway bar.
- Stiff springs used on stock shocks
- So how do you DIY guys do your own alignments?
- Coilover kits
- Hayame coilover spring replacement ej8/em1
- Bump stops
- itr master cyl in a eg
- Going rates for corner balancing
- Blox rear LCA bushings - Energy Suspension rear kit
- EK Springs on Skunk2 Struts?
- FA5 Front shock mount with skunk2 pro s2 coilovers bounce
- Rally car alignment - need recommendations
- NSX Rear brake swaP??
- Anyone riding on Eibach Pro Kit springs?
- 00 civic si flca question
- Ground Control stuck to Tokico Blues (no pun inteded)
- axxis ult brake pads
- struts vs coilovers
- Suspension 101
- Clutch and brake Master Cylinders
- Race valved Koni Yellows, bump stop
- Tie-rods for 94 Civic Hatch
- Need to stiffen rear suspension
- Left Front Shock Knocks During Full Clock Turns
- Suspension mods to correct geometry when lowered?
- HardRace Kit for 99 CRV RD1
- 99 civic EX with rear disc conversion will HX wheels fit????
- HX wheel fit 99 ex coupe with REAR DISC brakes.
- New master cyl for 95 Si w/ ABS
- DC5R Brembo Conversion EK...Which wheels work?
- GSR sway bar on civic DX: Not working / Issues
- Small Qs on sway bar on ASR install
- Rear LCA install Q
- Not bleeding the brake lines
- What is the best suspension bushing kit?
- Suspension 101
- Koni/GC bumpstop riding
- Civic CRX Scarebird Rear Brake Disk Conversion Review and Instructions
- Tire alignment Scam
- Best EG Hatch Time Attack Suspension
- Question on loose retainer ring on front LCA (Integra)
- Improve Dampening for High Speed Stability
- Air suspension or nah?
- fluid flush/new stainless brake lines
- lookin for a good set of dd suspension.
- Confusion, hubs for ROH conversion
- Legend calipers with RPF1's?
- 'Reclocking' bushings questions
- Measure what?
- Coilover DIY, review, and pics. KW ST's on TSX wagon.
- help
- massive inner tire wear
- 2010 honda pilot front hub bearing assembly
- Left and right front shocks different #
- Was the 8th gen dx/lx premature brake pad wear issue resolved?
- rear compensator bolt flange part number Chassis side
- Am I missing anything?
- 94-01 Integra/96-00 Civic ex front sub frame compatible?
- Brake Woes--Ever so minor leak? Or not?
- Who Makes GOOD disk brakes.
- Brake pads that don't suck, but don't squeel
- Integra brakes system
- 3rd gen prelude camber kit
- Camber adjust on coilovers
- Hfp suspensions
- Good suspension, curious questions
- NSX Caliper Swap
- Rear disc brake on ek
- PasswordJDM Rear Camber Links review/question
- Newbie brake job / flush questions...
- Noise after replacing suspension components
- Shock fork collars
- Disk brakes for 91 Civic
- ABS wiring help
- HELP 89 crx steering wheel pulls hard left.HELP.
- brakes only seem to be working on one side up front
- Accord wagon
