View Full Version : Suspension & Brakes
- looking for advice on suspension !!!
- Searching for best prices help!?
- 2000 civic cx 11inch brake and si rear brakes info
- nsx brakes fit type r wheels?
- Brake pad suggestions for 95 gsr
- Arospeed any good?
- 94 eg break swap.
- Eibach Sport + Koni Yellow Question(s)
- Kyb agx/ GC combo (Custom spring rates) stiff or soft?
- Tein Street Advance vs Street Flex?
- Need help lowering
- Coilovers or better yellow koni and ground control
- Koni/GC spring rate for a em1
- are truhart anything worth buying? springs/shocks/coilovers?
- Sometimes my brake goes down further than normal?
- Acura Vigor/TL/RL calipers on EG6 coupe?
- '86-'89 Accord springs on EF???
- need replacement strut mounts for koni yellow sport
- EM1 with TEIN S-tech // Koni STR's
- Accord Sway Bar Suggestions??
- Can not decide between these three coilovers
- 93 civic brakes sometimes soft
- Car VIBRATES, please help, shakes when reversed parked and stopped
- Fit GD3 Smaller front brakes for drag racing and vx wheels
- Lowered, vibration like driving over ridges??
- suspension making me crazy..HELP
- Need advice on picking the right rear sway bar setup
- New sway bar link tight?
- Wont boost over 10psi
- Hub bearings
- 99 ek b20b4 bearing issue
- New shocks/springs advice
- Teggy rear disk
- Rotors
- Hello help; beginer
- Brakes wont bleed fluid
- s2k brake mc swap on 95 integra?
- Front Swap Bar Opinions
- ITR master brake cilinder on EK4
- Add adjustable sleeves to coilovers?
- Rywire brake proportioning valve tuck w/ wilwood mc
- koni yellow/ gc?? bump stop.
- brake woes
- Looking to lower my ride
- loud pop noise when accelerating
- Koni 1153 or 1213 for EK?
- New brake issue after installing new parts
- new suspension questions
- Koni and gc help...
- Rear lower control arms help
- homedepot "frost king" duct insulation for sound deadening???
- Progress CS2 Spring Rate Inquiry
- Suspension ride
- hardrace LCA
- Spoon Springs EK9 Dampers
- Risk of getting air in brake lines through master cylinder under hard cornering?
- 96 civic dx hatch rear disc conversion
- Question about some nuts...
- Torque steer = broken torque mount?
- Question about alignment after brake conversion
- Replacing Brakes
- help...92 hatch weird brake problem
- Eg spring rates Ground Control coilovers
- Shock Side question
- 1995 Integra DC2 rear sway bar
- 96 EK Eibach coilovers on a 92 EG Sedan?
- 01 ITR suspension question
- What tools do i need to swap my coilovers?
- [share] 3D files to download - Brembo big brakes
- brake pads problem
- Rusted fast?
- Rear struts feel bouncy need advice
- Koni/GC spring rate for Integra
- Adjusting height on full body coilovers, dont touch the spring?
- Progress CSII with AMR oem style top mounts
- Tein EDFC active pro
- Moog control arm, any good?
- Removing Rotor Screws
- 01 civic ex sedan koni str t
- Sticky This: Camber kit TRUTHS
- Brake and clutch fluid constantly turning brown
- Noise from front right
- whats a good suspension to buy for a 400 hp civic
- Apexi n1 2000spec instructions
- rear UCA and compensater bushing replacment
- rear disk brake help
- Best value shock/spring or coilover combo
- rear drums ej6
- 99 honda accord lx 4dr 4 cyl rear tie rod problems
- willwood type r kit dc2
- My advanced design shock dyno results
- accord ebay coilovers on integra/civic
- Wilwood DynaPro H/A & 13inch wheels?
- Uneven Brake wear, opinions please.
- Bilstein B6 setup ?
- Just bought omnipower coilovers how to tell what gen they are
- What COILOVERS do i need to SLAM my EF ???
- Steering knuckle/spindle
- cant get my accords alignment straight
- PLEASE HELP 42mm fork damper.
- Koni/GC high vs low frequency imbalance
- Alignment needed after top hat change?
- Suspension *advice needed*
- Del Sol Suspension Adjustment Help!!
- NEED OPINIONS front and rear sway install hiccup on a 92 CX hatch
- koni and ground control
- Suspension
- DA integra build questions!
- EK rear sway 13mm (EK4/EM1) or 22mm (EK9/CTR)?
- PIC coilover spring size?
- megan springs spring rate
- help asap braking issue
- No brake pressure when turning
- ABS Light Stays On in CRV- 1998- Out of Options?
- JDM DC2 BRAKES VIBRATION WHEN TURNING LEFT
- 98 Civic EX - no ABS to ABS?
- Adjustable Rear ASB End Links for 97 accord
- Brake question
- Wilwood Big Brake Kit
- HELP, uncontrolled chassis movement BB6
- Front Hub Bearing Interchangeability?
- lowered 95 civic
- upper shock mount questions
- 97 civic rear cut spring replacement help please
- difference geometry of CTR vs ITR sway bar
- CTR front sway bar into ej8?
- 91 Civic Si upgrading to Koni/GC - suggested spring rates?
- Koni 1150-5010 coilovers
- What is this called?
- Best braking kits for a 2005 honda civix ex. Highest quality/performance
- Aftermarket parts - moog, dorman, mekovitch, beck arnley, ect
- Car making noise, Help!
- abnormal rotor wear
- ? about ASR SFB
- question about swapping 5 lug from another eg
- Need help choosing a brembo caliper
- Ground-control Strut brand interchangeability question
- Cutting through LCA bushing sleeve.
- Brake Experts Needed. See if you can figure this one out.
- Integra front coilover won't fit fork
- Ground Control vs Energy Spring Isolators
- Ultimate Low Dollar Air Ride
- JDM ITR BRAKES AXLE HELP
- pad failure during bed in?
- Si/SiR e-brake cables the same as DC integra one's ?.
- Skunk2 '96-00' Front Upper Control Arm Pro Plus Bushings
- Looking for the Brake Expert
- Odd Sensation/Noise When Making Hard Lefts
- suspension
- Shocks/springs
- Brake question/ intake
- EG JDM trailing arm swap to EK3 JDM (rear disc)
- Taking the Squeak out
- what would cause the tire-to-fender gap of one wheel to be shorter?
- Ebay springs on a ek?? Bad or good
- Eibach Sportline Plus Kit
- autoX suspension for an 01 G-SR
- Skunk2 Pro-s II or Pro-c???
- koni STR.T shocks
- F&F Type 1 for daily? NO TRACK EVER
- Brake locking up?
- steering rack ... valve body fittings pitch thread & flare?
- Koni/GC vs FA500?
- help choose rear sway bar size
- ISC N1 Coilovers - Anyone run these?
- function and form type 1
- NSX Big break kit
- Lowering Issues
- progress CS-II Coilover Spring rate
- Poor Man's Coilovers? 91 sedan
- Bushing Installation
- Rack & Pinion problems??
- RTA Suspension bushing advice for DD
- Coilovers - Whats Up They Are Seized Up?
- Buddy club rsd max damper spring rate
- Brake lines tuck. proportioning valve placement
- Heim Endlinks on Stock LCA
- Coilover questions
- Del Sol suspension woes
- Rebound and Compression, what's the difference?
- your opinion:Progress Technology or Raceland US?
- 04 civic lx sedan, stock springs w/ koni yellows or bilsteins?'s
- dc konis into ef
- Brake Problems
- Ceramic Pads Front Organic Shoes Rear?
- Wheel bearing question on a Civic
- ebay coilovers?
- WHAT IS GOOD SUSPENSION DROP FOR 2000 HATCHBACK
- DC2 with Spoon Sports springs
- EG alignment camber needed????
- 40/40 prop Valve leak
- New camber kit question
- HOW LOW CAN IT GO
- Integra springs on Civic?
- Konis or something else.
- air ride?
- Sway bars that fit on civic dx models?
- 07 Civic Si - Needing break suggestions
- flush fitment on my ek...
- Em2 and Dc5 aftermarket suspension
- gsr brakes into 00 dx quick question
- Disc Brake Conversion Ej8
- Front Susp. Help
- Doing some high high rates testing
- Suspension squeak with new struts
- whos running ISC coilovers?
- Acura Integra>Trailing arm bushing, tie rod, ball joint questions
- why am I having bad tire rub on turns? function forum type 1
- 94 Integra upper control arm question
- ksport or function form
- Camber kit on accord
- 91 integra spring rate help
- EK9 suspension
- PAC Racing Springs
- 91 integra slammed
- Which springs to get.
- 99 Civic - Ebay Camber Kit w/ stock suspension
- 2003 honda pilot
- Rear Wheels bent to the left slightly
- Integra sway bar mounts
- '05 CRV LCA Bushing Issues
- Volkswagen Coilover Bushing help
- asr sway bar eg to ek?
- Front brake pads 2010 insight
- Skunk2
- 90 hatchback frame measurements
- Ride height question
- DC2 suspension on EG?
- Disassemble coil overs need help.
- Suspension Advice
- Buddy club racing spec damper info
- Brake line fittings stuck in prop valve
- Camber kit or NOT?
- steering issue
- eg oem vs aftermarket rear lca length
- How do I convert my rear brakes from drums to disks?
- Stupid noob question: adjusting Koni SPSS
- Suspension upgrade help!!
- EG coilovers on EF
- ABS delete on 96 integra GS
- Inner diameter of ground control sleeve
- Has anyone ran full stainless braided lines from prop to calipers?
- 1980 Accord Struts?
- 1980 Accord Coilovers
- Integra 93 GSR Rear front cross member on 90 EF ???
- Anyone know what spindle this is from?
- Bushing deflection in control arms
- suspension setups?
- Write Up: How to Remove Rear Suspension
