PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Skunk2 Pro S or Function Form Type 1 for 4 door integra gsr
  2. What 4x100 spare tire fits 11.1" on all 4 corners?
  3. suspension help!! 92 Integra
  4. Brakeexpert
  5. Will crv axles work with ITR 36mm brakes
  6. Brake Balance/bias matter on a street car?
  7. What struts to use with skunk2 drag launch sleeve coilover kit.
  8. 06+ RL brakes on a 04-08 TSX
  9. Question about Koni/GC Install
  10. Getting my integra to slide better...
  11. Proper Drag Radial Chassis Setup...
  12. EK sway bars dont fit...
  13. 4x100 Spare Tire to fit over 10.3" fronts w/ NSX caliper?
  14. Baker Precision - Ordered Earl's & got China
  15. Steering wheel is crooked after sway bar installation
  16. Will EG civic lowering springs Fit EK civic ?
  17. Adjusting Tein Circuit Masters
  18. Tierod movement question..
  19. diy extended tophats on a crx
  20. DIY-Alignment
  21. Will my car pass inspection with mix march suspension?
  22. A Few Questions
  23. Shifter bushing compatibility question...
  24. GC spring length question 7" vs. 8"
  25. easy dumb question...
  26. carbing strut bar with gsr mc???
  27. KYB GR-2 Shocks
  28. 98 2dr civic ex spring rate??
  29. Need To Decide Which Springs
  30. Review: Power In Control Apex Coil Overs
  31. Soo, are my spoon shocks phucked???
  32. Sears Alignment FTL
  33. ABS reservoir/master cylinder overflows
  34. 1990 integra heavy duty shocks or air bags or whatever?
  35. front brakes stuck
  36. 94 GSR ABS Light and BRAKE light on, video inside
  37. Brake hardline compatability
  38. Cross Camber Problems
  39. Rear LCA Bushings??
  40. Function and Form Problems....
  41. 6th gen Accord rear disc conversion
  42. Ever heard of a company called "A+ Performance"?
  43. Tokico HP - warranty question
  44. Koni/GC or something else?
  45. need help with Brake line Questions
  46. Best set up for 99 DC
  47. Koni Yellow Question
  48. Wilwood calipers on EG and wheel clearance
  49. Ground Control sleeves split and mushrooming
  50. Opinion on KYB and Tokiko shocks
  51. CRX ITR rear disk brake conversion
  52. Where to buy koni bump stops?
  53. Installing a front sway bar
  54. which control arms and why?
  55. just installed skunk2 adjust. w/ koni yellows... possible problem
  56. Help..i need your help with my 93 coupe!
  57. trailing arm bushing thought. tell me what you think
  58. skunk2 pro coilovers???
  59. Slammed daily driven car, What Suspension?
  60. largest brakes for a EG that will fit under bogarts?
  61. OEM RTA bushing part number..
  62. Struts??
  63. Help with steering and alighnment???
  64. Skunk2/GC setup?
  65. Brakes worse after 40/40 prop install.
  66. getting an alignment..then changing ride stance with coilovers
  67. Rubbing Issues
  68. 96-00 civic front UCA, anyone have one to measure?
  69. HELP benen strong bar
  70. 98 civic suspention on a 93 delsol?
  71. OE pads for SPOON monoblocks
  72. Camber Help
  73. Beaks tie bar install DIY and review (no 56k)
  74. Really really need help quick
  75. Alignment Shops in SoCal
  76. Pic request?
  77. GC Adjusting tool?
  78. - TERRIBLE body flex / creaking sound on my EM1 -
  79. Function form coilovers - difference between type 1 & 2??
  80. Popping noise when wheels turn left or right
  81. Problem with shock side loads
  82. Buying shocks online
  83. Fitment EG Koni sport yellows with Megan kit.
  84. I'm thinking I might want to lower the rear...
  85. 96-00 civic stock UCA Servicable???
  86. I need help on a new setup!!!
  87. 99 Si, want to do suspension
  88. Tein SS Coilover Adjustability **Plz Help!**
  89. 2004 RSX (Suspension Question)
  90. warped rotors??
  91. How can I indentify this Prop Valve?
  92. can blox / function 7 / asr endlinks be used on front sway bar
  93. sf area shops
  94. used coilover ?
  95. Suspension gurus needed. Let's make a master write-up.
  96. PLay: tie-rod ends v. rack
  97. Water in steering rack
  98. i need some input from you guys...
  99. Brake pedal click
  100. is a 1" kit worth it? and 1.5" and snow driveability
  101. ground control top hats on d2 suspension
  102. alignment after clocking/reseting bushings?
  103. Problems with alignment kit
  104. Omni Power strut exploded in my face.
  105. whats a good way to lower my 93 civic hatchback?
  106. 00 SI rear disks fit 92 DX hatch?
  107. Question about 88 CR-X Lower Control Aarms!
  108. CTR 5lug vs. ITR 5lug
  109. help with id'ing Coilover.
  110. gc/koni questions and problems
  111. what to do?
  112. Cusco Zero 2r gas coilovers questions?
  113. shock and coilovers
  114. effectiveness of tie bars, tower brace, etc
  115. Braking problems
  116. >>>>>>>>HELP with omni powers!!!
  117. Tokico question?
  118. will these rotors fit on my hatch?
  119. Alignment issues
  120. Basic Tein Suspension
  121. Progress CS2 Coilovers
  122. camber kit install?
  123. GC Springs Q.
  124. need info on radius arms
  125. replace strut mounts? dust covers...
  126. Integra (DC) TEIN SS and edfc into EK questions!!!
  127. 5 lug questions
  128. Coilover Spring Rate Combinations..
  129. ASR Brace and Beaks tie bar question
  130. What is a good brand Strut Bar
  131. Upgrading the brakes with 15" wheels
  132. Help! I'm Confuse
  133. Odyssey suspension questions (was: **help**)
  134. Types of camber kits?
  135. EK Civic, DC2 Sway Bar, EK4 Drop Links - which Endlink Bushings??
  136. mcpherson front and back
  137. interchangeable suspensions?
  138. Koni red's/special proper way to adjust
  139. brake set-up for honda del sol?
  140. techno pro spirit coilovers
  141. 2000 SI - Looking for experienced advice
  142. Suspension Recommendation: H2B EG, close to OE ride height
  143. Ground control install
  144. Integra skunk2 springs/shocks
  145. No brake boost??
  146. Popping/Clunking Noise - Rear Suspension - Damper? Sway Bar? ???
  147. D2 Racing Coilovers any good?
  148. Bushing Kits
  149. Rough suspension/ride
  150. buddy club n+ with stock top hats???
  151. Suspension set-ups
  152. jank blox lca's
  153. When should I rotate my tires?
  154. 2" drop + EF Civic + other questions
  155. Ksport Air Suspension?
  156. Need new rotors
  157. Do i need a camber kit?
  158. Brake Pad wear
  159. Question reguarding Skunk2 Lowering springs (96 civic ex)
  160. wher to buy GC/KONI
  161. ITR 5 lug swap on 92 EG6
  162. empire flaring tool(sears)
  163. Which ES Bushings for OMNI First Gen Rear LCA's
  164. Size difference between DC2R and EK9R rear sway bars
  165. NEW KIDO EK 6 pot caliper 286MM
  166. Need some Insight on NSX brake setup. also wheel help
  167. coilover help
  168. Adjusting caster without having to buy stuff
  169. any one running rear sway on ef sedan?
  170. Help me whit 60-ft in Honda Civic SI B20Vtec
  171. Competch Sway/Tie bar setup installation instructions
  172. *OPINION* SPfab EG/DC/EK Traction Bar
  173. need your opinion..suspension for dc
  174. what strut bar to buy ? 95 Civic coupe
  175. Endlink choice & Preload problems with R swaybar
  176. other options suspension?????
  177. Help with camber?
  178. Can anyone identify these coilovers?
  179. Hey, help me out
  180. Coilover question.
  181. Camber okay on this much of a drop???
  182. upgrading to polybushes; what do I need? (eg6)
  183. [?] What aftermarket strut bar will clear the Y7 intake box?
  184. Rear drum brake adjusters not adjusting
  185. DC4 with skunk2 adjustables on stock shocks... need help
  186. All efers best full coilovers setup
  187. prelude rotors and break pads
  188. megan vs dropzone
  189. JIC Magic FLT-1 Coilovers vs the rest
  190. brake part # halp
  191. Remove OEM Dust Covers???
  192. Civic SI Can
  193. Which sway bars on a 94 Accord
  194. handling diagnosis required please after changes
  195. Anyone try VMAXX coilovers?
  196. where can i get an itr sway bar with end links and bushings??
  197. GSR Caliper Pin advice?
  198. Willing to trade tein tech lowering springs
  199. Camber Kit question
  200. itr style tein flex's, will any other cups work to change to ek?
  201. Dumb Camber Question...
  202. Uneven camber help
  203. Help Needed with KYB AGX
  204. Brake Pad Recommendations..
  205. Traction Bar?
  206. Suspension setup
  207. PIC Apex Adjustments? My ride is bouncy.
  208. Pic select's what spring rate?
  209. ASR and sway bar. good mod?
  210. GC/Koni vs. PIC Apex
  211. Any one knows where I can get a Top Fuel bar for my EK???
  212. gsr rear brake conversion on 99ek hatch
  213. GC suspension help!!
  214. caliper and rotor question help please
  215. Honda Patents a Strut Bar
  216. Do I need a reenforcement bar if I instal a ITR rear sway bar on a EG??
  217. spring rate ? help
  218. Integra suspension design
  219. Ground controls
  220. Brake lock-up
  221. Help. front brakes are bleeding & Drum Brakes don't seem to be working.
  222. Opinions/experience wanted on 00' si brake upgrade!!!
  223. EG Civic ABS Rear arms
  224. ES trailing arm bushing install questions????
  225. spring install without compressor idea
  226. 98-02 ....Best springs ..please help
  227. b pillar
  228. 99 SiR
  229. Anybody have pics of their car on h&r race springs?
  230. trailing arm bushings
  231. Lca's
  232. Question regarding Koni/GC setup
  233. C8 Sport coilovers
  234. Anyone with koni 3011/2812...
  235. Koni adjustment prior to install
  236. Best shocks for the money?
  237. coilovers on my 93 coupe
  238. help me drop this piece of ... art :)
  239. Brembo Blanks for 98DX
  240. ABS code 48?
  241. Manual Prop Valve?
  242. Questionable Play in Suspension
  243. Rotor Clearance
  244. Rear LCA question
  245. skunk2 and tokico hp
  246. drag/street suspension for ef
  247. prelude calipers/legend/crv?? help
  248. how to adjust koni yellows
  249. trade koni/GC for SilkRoad coilovers?
  250. EK to DA suspension?
