View Full Version : Suspension & Brakes
- Alignment Needed - Middle Tennessee
- Can't bleed brakes
- please help me out car wont drive straight
- Ebrake only engages on one side?
- noob, looking for a smoother ride
- Caliper rebuild/assembly help
- rear 5 lug!!!
- 23T Bracket
- Koni shocks and skunk2 coilover
- suspension for circuit racing
- buddy club n+ or d2 rs ... please help
- Skunk2 , 2.5/2.25 on EG , any pic ?
- Spherical Trailing Arm Bushing Brands
- soft pedal feel
- Skunk2 Lowering Springs
- im looking for the right suspension
- Skunk2 springs/struts fit 92-95 Civic AND 94-00 Integra???
- Should i clock the rear upper control arm?
- Camber kit/strut tower
- KYB AGX or Koni Str.t? Other suspension questions too
- Yet another camber question...
- How to tell if caliper is sticking?
- Progress Coilovers
- CRX EF8 HELP!!!!!!!!!!!
- blox bushing replacement
- lowering 88 integra help please!!
- Which of these setups would you recomend?
- suspension problem!
- Grease for Rear Caliper Piston Boot
- Side to side wheel play, rattle noise
- camber problem
- Drop Zone
- 90 Da suspension fit my 98 Dc?
- 2001 Honda Odyssey is making a knocking sound when braking. What is it?
- Skunk2 Suspension Experts
- Quick question, where does this clip go?
- Rubbing noise when taking turns fast
- 9Si LCA VS Non Si
- Need Help- Brakes Locking up
- Camber kit necessary in this situation?
- 96 COUPE SET UP? FIT ON 95 SEDAN
- sway bar and lca's help please
- Coilovers on 01 Civic
- Front sway bar / subframe question
- 1 peice coilovers
- PIC Coilover Re-assembly Issue
- OEM springs, which one goes where?
- suspension experts please come in!
- ABS REMOVAL 95 INTEGRA, HELP!
- interestingly delightful
- is there a cheap/junkyard 114.3 conversion?
- EG/EK front forks ?
- 91 civic caliper top bolt, wtf is the deal?
- Rear Trailing Arm Bushing X-TRACTOR rental
- help identify one piece coilovers?!
- Time for a rebuild?
- Tein HA's for my DC questions on how-to
- what spring rates should i use!?
- PIC Apexes or Koni/GCs?
- Ground Control Spring Rate for DD
- SE PA Alignment for non-stock suspension
- obx subframe brace and swaybar anyone?
- tein s techs
- a 2inch drop on cb7
- Function Forum Type2 dont fit on skunk2 lca????wtf fml
- REMOVE GC coilovers from stock shock
- help me?
- ASR subframe brace question
- need to know bolt size asap!
- DA springs on EF hatch?
- ek hatch 24 or 26mm front sway?
- extended stud help
- Tein basics noise
- pic performance
- EF Rear disc brake conver.
- Ground Control Problem
- foam to increse rigidty
- New to the H-T boards.... 94 Del Sol
- 98 integra replacin a rear caliper....
- Help me pick/suggest suspension set up
- koni/gc low in front?
- GSR front sway bar on EG
- Rear sway bar question!
- When do i need a 4040 prop?
- Alternative to Skunk2 Pro series front camber kit FOR AN EF?
- will my ride get better or worse?
- Measurement need ASAP!
- New Brake Rotor, Pads and Brake Shoes : Seeing Issues with Break pedal feel > HELP!
- Bad RTA bushings lead to wheel bearing failure?
- will tein basic for an ek fit a da?
- suspension set up help
- random noobie question
- You CANNOT ride slammed AND have a smooth ride!
- Best coilover setup for everyday use on my DC2?
- Brake pads.
- small annoyance in my car eg
- sk2 front camber kit
- What all do i really need?
- 98 teg. Lr caliper is hangin a lil bit!?
- 2000 EM-1 Front Lower Arm Bushing Part#
- suspension not fitting integra
- trying to find Suspension
- 99 suspension woes diagnoses
- H&R sport & KYB GR-2 reviews?
- crx lee??
- i am installing Skunk2 Springs on my 02 EP3
- want to know if i should be a camber kit or not???
- new suspension setup !!
- Bleeding woes ... expert techniques and advice wanted
- Buddy Club N+
- ABS sensor?
- civic shocks
- Front Sway from 99-00 Si -> 97 ex
- rear trailing arm bushing. hammer method won't go in.
- skunk2 springs w/ kyb agx?
- DELETE!!
- need help suspension set up for drag racing
- Rollcentre adjusters on civic EG?
- Need help on lowering springs!!!
- Omni power drag coilovers?
- Can I trim the base of my threaded shock body?
- F2 type 1 vs type 2 info
- Lowering rear more than front?
- Looking Into Buying New Coilover Kit
- I'm getting my HardRace bushings pressed in
- Rear hub to spring measurement
- Best brake option for a 93 DX auto with 15" rims
- strut mount question
- ground control with koni struts vs. tein basic????
- Accord air suspension custom project
- koni/eibach weirdness
- D2's coilovers lowering and raising the rear
- Srping rates setup
- Recommend me a sway bar for H&R OE springs
- Who has used Tein HA,why were they discontinued,NE1 had there teins rebuilt?
- Used Tein Flex Twin Tube Design for $850?
- Ceased Trailing Arm Bolt!!!!
- 90-93 integra springs to delsol
- squeal after rotor/pad change
- New suspension... broken struts after shop install!!!!
- EG Rear - JDM lca vs USDM sway bar
- Tien s-tech + =good ride? 93 integra
- SLAMMED!!! BETTER FOR PERFORMANCE??
- CTR VS. ITR 5LUG CONVO
- Front brakes locked up
- 91 DA ground control set up?
- Axle, Half Shaft Problem
- no brake fluid coming out when i bleed brakes
- 97 integra ls sway bar bolt directly onto 98 civic ex?
- getting an alignment done tomorrow
- ground control coilovers on eibach shocks
- sway bar brackets
- Rear Camber Kit Squeaking
- wheel has a wiggle.
- Stock DA spring rates?
- how bad is the squeaking
- Best springs for daily driver/drag setup
- koni yellow color code?
- Post pics of your buddy club coilover drops!
- GC/ koni yellow
- Sway bar question
- blox camber kit
- tesing tokico illuminas
- $5 ebay coils and adjustable shocks ?????
- Loud brakes when stopping,plus alot of dust.
- Brakes the same on Civic LX/DX '92-'95 as VX/CX?
- When lowering/slamming a car...
- EK Tein S-Tech Lowering Springs on a EG
- Slotted , drilled vs Oem rotors
- The best lowering springs. Lowest drop spring?
- c pillar bar
- Ek rubbing... Need help!
- help on rear ebrake cables
- THMotorsports goes to 24 Hours of Nurburgring w/ KW Suspensions: Story & Pics
- 98 Spec Integra Gsr sway bar in Ek
- how do you know when your break booster is bad??
- omnis/gc
- would like to cut my springs but need info on it
- wobbly steering wheel!!
- whos on air?
- Big brakes with small rims?
- new coilovers
- UCA HITTING SHOCK TOWERS EJ1 ANY IDEAS?
- Type R LCA Bushings VS. RS/GS/LS LCA Bushings
- springs sportline for 97 civic on a 91 crx si?
- Springs or coilovers
- can you use stock struts if you cut your springs to lower your car
- Brake Caliber Info
- What do you guys think of these??
- GC/Koni prices
- Wheel pushed back towards fender//Too much Caster?
- Arospeed brakes calipers & discs q's ???
- Sway bar help
- Orijin Spherical Conversion: Binding?
- prop valve question
- Aftermarket LCA's
- Wobble under acceleration, I cant seem to fix! HELP!
- coilover question plz help!
- brake prop or cable bias adjuster
- Honda S2000 Rear Suspension: hub, strut assembiles, control arm, ball joints and more
- Need advice badly! DC2
- Integra w/tein s-techs, too low?
- JDM 5lug 36MM question??
- Honda Civic 1992-1995 Disc and Drum Brakes: push rods, pads, calipers and more
- Honda Civic Suspension EG: control arms, assemblies and more
- Skunk2 Pro-C coilovers
- Tokico blues and gc coilovers
- anyone drive the koni str.t yet?
- how low.....
- B&G coilovers
- miracle x bar
- Tokico Blue bump stop question
- Lowering EK question
- Simple Green Safe for Bushings & Lines?
- mismatched lowering springs
- Dropping on a budget..
- Front is higher than the rear
- A few questions about pillowball mounts and LCA's
- monotube or dual tube shocks
- Legend brake mod v s2000?
- Car goes light in high speed corners?
- Not a "write up" "write up" SKunk2 on Koni's
- so i have about 900 for suspension, and im stuck on two ideas.
- NO pressure with Engine on.
- rear brake conversion can you make your own?
- Rotor discoloration.
- SRR purple or used to be purple lca question?
- JDM 5lug conversion. what LCA's to run?
- Eibach Springs appear higher at the rear?
- UNIVERSAL SKUNK2 COILOVERS (new in box)
- Front calipers fit on Rear?
- Brakes making beeping noise?
- cleaning up rotors...whats best?
- Are DC and EK rear trailing arms the same?
- kw variant 3 coilover question??? HELP PLZ
- Suspension gurus, need help! itr lca but itr shock dont fit. eg civic
- adj coilover setting question (civic)
- ride quality
- Koni Sports - Did I get ripped off?
- Sorry for another traction bar question...
- HELP!!! braking sucks....
- Prelude Type SH: GC/Koni SP3 set up?
- Coilover Maintenance
- Raised coilovers, now ride is harsh
- Coilovers on Koni Red's...?
- Pink LCA's?
- Front multi-link vs Double wishbone
- Koni Yellow perch
