PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Best coilover >1000 for weekend warrior/track
  2. spoon monoblock calipers on ek
  3. Integra Suspention Problems
  4. Interesting brake question!?
  5. Endlinks Question?
  6. Break caliper refurbish
  7. EK front LCA spherical compliance bushings
  8. Will 92-95 Civic UCA Fit 96-00?
  9. Re-raising a honda civic
  10. Lowering a 94 Accord Ex
  11. Rear disc brake conversion question
  12. Rear end link FYI
  13. Front camber kit needed for circuit car - SKunk2 pro or ebay?
  14. Best coilover for a daily drive drop
  15. What's everyone running for drag suspension??
  16. Tokico blues or Kyb GR-2s
  17. Suspension Protection Advice
  18. Upper control arm, OEM or aftermarket? 94 civic
  19. 1997 Civic LX Improvements
  20. Coil Sleeves
  21. 23T vs 25T Caliper Brackets
  22. i NEED a camber kit... thoughts.
  23. EG Brake Lines Don't Fit GSR M.C.
  24. ek9 rear sway bar subframe brace needed?
  25. ek or dc subframe collar kit?
  26. Do i need new shocks
  27. Koni yellow question
  28. Identify this bbk setup.
  29. Honda Civic EK Brake Rotors
  30. Bouncy Ride
  31. Honda Civic EK Spring rates
  32. EH Civic Sub Brace Wheel Break Traction?
  33. Need help...Installed lowering springs but its not going down?
  34. Bypass 4040 stainless conversion direct to Master Cylinder
  35. Honda del sol
  36. how much should a set of Koni Yellows(new) go for?
  37. Wilwood brake pads
  38. EG d2 onepiece will they fit on a 91 crx
  39. EG/92-95 Civic D2 One Piece Coilovers
  40. Fortune Auto Coilovers
  41. Thoughts on BC Racing BR series for BB6
  42. GSR Brake Booster Fit EG?
  43. tein flex coilovers.
  44. EG9 GSR Wheel Hop
  45. FINALLY BOUGHT KONI YELLOWS, question on SPRINGS
  46. will 2000 civic si sway bars be compatible with ASR subframe brace?
  47. DA front brakes on a EG
  48. Wheel set back after collision
  49. coilover question
  50. Drop spring install w/o compressor?
  51. Suspension set up questionsss!
  52. F&F Type 1 Feedback?
  53. whats better.. less shock travel with high spring rate or more shock travel with lowe
  54. CRX Suspension Recommendations
  55. corner balancing whos done it
  56. when do strut bars become necessary??
  57. spoon brakes help
  58. LsVtec Turbo - Suspension Re-Vamp
  59. NEED HELP!!!! 95 civic non abs conversion
  60. BIG brakes?
  61. Rear ring? *pic*
  62. Frozen rear LCA to trailing arm bolt - any tips?
  63. Drum Brakes to Disc brake conversion using drum brake trailing arms
  64. Ground control/koni settings
  65. Seperating steering knuckle from wheel bearing
  66. oem ek9/4 springs strut build
  67. has any one tried these?
  68. Bleeding brake 2007 TL - electronically cycling through ABS
  69. Ground Control Custom Spring Rates
  70. Tein S or Eibach pro line?
  71. NO brake pressure
  72. EJ6 suspension kit questions
  73. integra fitting into brake mc size(passenger side)
  74. Somewhat typical coilover question
  75. Modest lowering kits
  76. Best affordable shock for autocross
  77. Big Brake Upgrade but thats inexpensive?
  78. Racing Calipers/Rotors
  79. I need some help ppl anyone heard of risky coil overs?
  80. How much $ to put your car on bags?
  81. Brake leak in 95 Prelude
  82. Ball joint choices!!!! Need imput
  83. what coilovers better?
  84. 11inch brake rotors 4X100 on eg hatch
  85. Rear sway bar issues
  86. Problem with gsr brake swap and Trailing Arm Bushings
  87. steering wheel shakes when braking + tires sound LOUD
  88. What Ground Control sleeves are these?
  89. Need input on rear supention set up
  90. f&f slamming problem on integra
  91. ground control suspension questions.
  92. Question about Integra brake upgrade
  93. aftermarket rear control arms question
  94. 94 civic hatch subframe brace instsll?
  95. MY PERSONAL AMR COILOVERS REVIEWS
  96. Tein SS perch remove
  97. GSR Master Cylinder Wire Question
  98. New road race track driver, need suspension help.
  99. anyone used Beck/Arnley Remanufactured Caliper
  100. Spirited DD alignment setups - share please
  101. lowering spring problem
  102. FEEL'S Brake Pad? Need help...
  103. Ebay LCA's + Energy Bushings
  104. Chumpcar Cheapo setup
  105. car sits higher after installing control arms
  106. to BUMP STOP or not?
  107. Need real answer for a stance setup
  108. spring rates for a eg coupe after market /stock att scca racers
  109. Rear brake hard lines
  110. Rear sway bar
  111. GSR Disk Swap Questions!!!
  112. spring rate help?
  113. 02 Civic - Replacing leaking OEM front shocks(struts?) w/ After-market question
  114. ek civics with eibach sport springs measurement?
  115. coilovers for 98 civic opinions welcome.
  116. Brakes and Idle
  117. Is my pilot safe to drive?
  118. ground controll coilover kits?
  119. ebay coilovers
  120. 98-01 JDM Honda Integra DC2 Type R Front Knuckle part numbers
  121. 94 civic si non abs knuckle compatibility? help!
  122. New KYB's blown
  123. Brake booster positive pressure problem.
  124. Progress RSB for Honda Fit GE8 issue and question, is this just a brace?
  125. just need verification if this is a 1"inch brake booster and master cylinder?
  126. Suspension set up for del sol.
  127. 05-07 Accord Wheel Spec
  128. part number for 40/40 valve eg hatch
  129. 94 Honda Civic Wheel bearing problem? HELP?!
  130. rear toe bracket
  131. Thread Size of Brake Line Male Tubing Nuts at MC > 94 Accord ABS
  132. Front End Noise!
  133. Another brake question
  134. i have ebay coilover sleeves need help adjusting.
  135. ASR subframe brace needed with ITR sway bar?
  136. weird problem with my brake
  137. Helper Springs for Ground Controls
  138. 15/16s master cylinder
  139. Are Type R calipers over rated?
  140. installing wider wheel studs
  141. help with my ASR sway bar end links
  142. good suspension for em1
  143. Front Upper Strut Bar - What are GOOD options, and look sexy.. *PICS*
  144. EM1. USDM IRT 5lug setup swap. MC/Booster question
  145. ek hatch rear disc brakes squeak
  146. max rotor thickness for oem caliper ?
  147. Wheel cylinders
  148. PIC still in business?
  149. Dc Suspension upgrades
  150. ground control top hats fit tein flex?
  151. 3rd Gen Accord vs. 4th Gen Civic Springs?
  152. Koni question?
  153. civic uneven height
  154. Will lowering my car with coils give me alignment issues?
  155. Koni springs. Help!!!!!
  156. Integra master cylinder issue
  157. Mugen replica front STB
  158. Ride Height of Stocks
  159. EP3 Suspension Bump Stop Tokico question
  160. Removing Koni Shocks, This Happened.
  161. Your opinion CAMBER KITS?
  162. 95 dx coupe-doin brake swap from 97 dc4 abs, what parts do i use
  163. Suspension swap...skunk 2 pro-c gsr to ek
  164. Coilovers questuon
  165. Bad Tire wear
  166. Bench Bleeding with Power Bleeder
  167. Want to Lower car
  168. Feeling The Road: Rebound Adjustment
  169. Soft brake pedal after prolonged park
  170. Hawk race pads
  171. cutting lowering springs?
  172. Are Porterfield R4-S shoes worth the price?
  173. "I AM THAT GUY"
  174. let's talk spherical lca bushings
  175. coilover help!
  176. gsr brake swap on 92 civic cx
  177. EK9 CTR LCA - eye type - where to buy???
  178. How long will stock struts/coil sleeves last?
  179. Refilling struts?
  180. question about Koni Sport
  181. How do you remove rear brake "cam" on the caliper?
  182. Phi Fifty lower tie bar
  183. Hawk pad thickness
  184. Brake Drag
  185. asr sway bar loose help
  186. Loose E brake cable after rear caliper install
  187. Front lower U bar *pic*
  188. Best Bang for Buck? Coilovers
  189. basic coilover question
  190. wheel tire and bushing help
  191. Ksport GT springs, help?
  192. help me with drop my ek9
  193. Raceland/rokkor coilover review.
  194. Any reviews on how it feels after installing top hats???
  195. Sleeves for Eibach shocks? EG Hatch
  196. anyone have a rear CRX strut that they can measure for me?
  197. Rubber Bushings w/ rear Spherical Bearings?
  198. Wheel bearing horror?
  199. Left and Right springs
  200. Function and form installation issue *REAR*
  201. Tein Type HT manual
  202. 93 Honda civic ex coupe w/camber issues
  203. Brake lines for rear disc brake conversion
  204. Car shaking while accelerating help
  205. Ek Hatch : ASR SUBFRAME + ASR SWAY BAR
  206. Function & Form Coilovers how long did it last you???
  207. Function & Form coilovers how long did it last you???
  208. need help installing bwr subframe and beaks tie bar
  209. TEIN Coilover Adjustment Help
  210. SCRAPPING AND RUBBING QUESTION
  211. Anyone ever tried these?
  212. end links question
  213. Grinding with braking, but now the car can't move! Please help!
  214. More brake questions
  215. Whats the proper way to bleed brakes on ef hatch
  216. hybrid front hub setup for Accord 5-lug conversion
  217. Ek coupe non abs front brakes same as 93 GSR?
  218. Rear LCA sway bar settings??
  219. strut ruber limiter/stop thing??
  220. What are your Koni Yellows set at? *Daily Drivers*
  221. EG Hatch Brake issue Please HELP!
  222. Suspension help
  223. Choices to make. Help please
  224. Suspension
  225. Just picked up!
  226. 98 accord keeps blowing balljoints
  227. GSR Disk Conversion for EG
  228. accord extended top hats?
  229. steering wheel pop and jerk in corners
  230. Car Squeaks in the Front Left and turns hard left
  231. what makes a car bottom out shocks or springs?
  232. I need help with springs
  233. what brake pads do you prefer advanced/nappa/zone?
  234. eg help installing extended top hats with sleeve coilovers.
  235. Steering wheel shakes badly when braking
  236. squeaks from he rear!
  237. Camber kit needed?
  238. Civic rear lower arm bushings ebay
  239. Brak help suggestions
  240. H&R Race Springs--> Shock setup?!
  241. D-series axle and CRV outer joint
  242. StocK set preload of Megan 32 way coilovers?
  243. Need different sleeves for Koni yellow GC setup?
  244. Rear LCA Install
  245. Am I missing hardware for my 21mm Blox sway bar?
  246. 95 Civic EX on 96 Spec ITR 4x114
  247. new to the honda thing
  248. tie rod doesnt look right?
  249. what is considered too low?
  250. 1994 Honda Civic DX Coupe Trying to get some info on suspension kits and brakes...
