View Full Version : Suspension & Brakes
- car too low hurts accelaration?
- 94 teg
- IPP I-Control Rear LCAs
- front or rear springs?
- Putting a washer in the Upper Control arm to Prevent hitting the tower?
- Blox adjustable end links. Length?
- 92-95 eg hatch skunk2 LCA pics please
- arp extended lugs
- Password JDM 3 Point Front Strut Brace w/ ABS
- 99 EK hatch stock spring rate?
- poly bushing help
- typical suspension noob
- Suspension Questions
- Strapping down the front end
- Exhaust too low?
- rear suspension problem??
- Best front sway for ef hatchs?
- anyone gone to Speedware Motorsports in Redmond for an alignment?
- subframe brace question
- Question on A-spec fitment for DC5?
- 2000 civic si rear shock/ coil assembly
- Spring sizes?
- buddyclub n+ or skunk2 pro-c coilovers? opinions needed
- is this calculation correct?
- can anyone help with JDM CTR strut bar pic also would help
- Orijin DA Spherical Bearing Conversion interest thread
- Loud tire squeel after suspension work.
- EG Hatch - Blox rear sway bar & Exhaust clearance questions.
- front strut bar on 92-95 hatch
- buddyclub?
- pic lca + itr 22mm + beaks kit = wtf.
- I need tips.
- Noob suspension confussion
- ef strut bar on an Ek?
- em1 front sway into ej8
- Expanding foam
- koni yellows and neuspeed race.
- looking for an aftermarket endlink replacement for my 22mm rear sway bar.
- Help: New front sway bar bushings...now the sway bar clunks....
- ITR rear sway into a 2000 Civic Si
- Question On Suspension Sagging
- negative camber?
- rear toe adjust bolt (where can I get it?)
- gc koni question
- extended top hats
- no gap accord
- help with traction bar install Ek civic 96-00
- Got my Koni yellows with GCs...now how about swaybars?
- omni power full coilovers
- 2000 honda civic si rear lower control arm/ knuckle bolt. (replacing shocks n coils)
- I need a help
- Boot clamp
- Spring Spacers ?
- Question regarding 96-00 coupe?
- how low can u go?
- toe adjusters
- KONI/GC ADJUSTMENT HELP!!
- blown shocks?
- 00 integra front subframe swap
- just did polyurethane in my 93 dx coupe
- 91 crx with all new suspension not sitting even on both sides!!
- Stock rotor size question...
- need some help finding springs
- PIC spring rate feedback!
- Rear Trailing Arm - Anyone use the Polyurethane in a tube to fill the mounts?
- Problem...help me find shocks...
- Help on 5lug conversion..
- wheel shimmy in front right tire 94 civic ex
- whats better? omni power or ST sway bar kit??
- c-pillar installation on an eg
- Suspension Ideas for my DB7 - 4 dr Integra
- Suspension set up for 94 hatch(post pics)
- Need some good recomendations for street/strip coilovers
- TEIN Pillowball Upper Mount Install Question
- EJ 96-98 EX front brakes on a CX?
- ES Bushings - Good or Bad? Started putting them on my car today, been reading mix opinions
- Need linear coil with sping rate 600 lb/inch
- rub or no rub?
- HELP H22a Swap!!
- Help with H&R Coilovers on a 92 Civic now bouncy!
- Suspension help for a 99 accord LX
- right shock for skunk2?
- LCA- no search results
- pic request for H&R race on EK
- coilovers?
- Pulling Problem
- EK to EG Compatibility?
- Ground Control tophats and Koni Sport shocks confusion
- Buddy Club N+ Spec Damper problem
- Suspension Setup for a DA
- H&R vs. EIBACH
- help on how to change lug nut studs
- Importance of brake pad shims?
- Blox LCAs on EF... Help!
- using skunk2 integra springs on 94' ex???
- OEM rear LCAs, quick question...
- GSR Rear Brakes
- ASR Subframe Brace
- Question on these rear braces
- Ground Control Bilstein
- Question about driveshaft or Halfshaft?
- Few quick questions for my suspension/brake conversion setup...
- 91 crx rack and pinion replacement
- Does honda sell a complete front hub/bearing assembly for a DA teg?
- coilover ??
- which axles would i need to run? let me know please!
- Do you think these springs rate are good for a daily driver
- Stiffer rear Koni's VS Thicker swaybar
- Megan Coilovers need some help
- spring tension on omni's
- Omni Power vs PIC
- camber kit question?
- running stock springs, is it a benefit to run a shock with more compression?
- Coilover Difference between 90-93 & 94-01 Integra?
- APC Coilovers yes or no?
- 5 lug to 4 lug conversion, somebody help me out please!!!!!
- Ever bought Suspension off TM Engineering???
- how hard is it to play with coil overs
- chamber kit or no chamber kit?
- TA bushing extractor problem
- best camber kit for 92 prelude
- looking for suspension any help????
- Dropzone coilover spring free length?
- rear springs on front?
- shock question
- 94 hatch, lowered 2 inches front/rear
- Non-Honda Warning... VW Suspention ?
- tein s tech springs
- Another noob asking for advice
- Who's has rear lower tie bars in there crx? (need help with next suspension mod)
- Suspension what i need
- Eibach For The WIN!!!
- ground control for a 95 integra
- Omni Power Coilovers...
- Height Adjustment of Tein Flex
- looking for coilovers
- 1994 civic vx with gsr brake swap.
- Do bilsteins raise the ride height? Itr spec on stock R springs.
- How do you install coilovers???
- ITR 5lug conversion question?
- tein ss from crx to ek coupe
- Dual spring coilover...
- washer trick, couldnt find grade 10 bolts...
- Will a rear swaybar be benificial on my setup?
- will coilovers off an integra fit a civic
- lookin for some help from the experienced
- Axle Problem?
- ? about installing coilovers
- PIC select vs apex
- prothane motor mount inserts
- Suspension Techniques kit work with a ITR rear sway?
- pro-kit and tokico blues Q?
- Questions on Blox and Megan racing suspension components.
- How to clean and revive coilovers???
- Miracle X bar vs EM Racing bar vs Password JDM or Carbing
- Suspension setup for 2000 ls
- AnyONE runnning this suspention..........Koni threaded 1150
- Ground Control front upper urethane mounts blow
- Suspension Noob! Need help on springs/camber kit.
- its time for a new setup on my 95 integra
- koni Yellow adjusting issues
- LCA and Sway Bar problem help!
- spring rate?
- upper control arm - DC2
- HELP!!!!!!
- How to tell when Tein Coilovers are blown
- ITR Bilstein sport users...chime in. Handling more or less neutral?
- Upper control arm sqeak
- Replaced tie rod boot, but what's this weird hose connecting the two?
- Calling all PIC coilover owners?????? A few Questions.
- 97 prelude springs in civic.....
- Problem, wheel shakes when I accelerate...
- need better suspension need opinions!!
- Is it better to have a shock with some adj compression damping to control understeer?
- choosing rates. . .
- coilover o-rings ????
- Aren't the eibach pro-s about the same as the Ground Control coilovers?
- EG EF LCAS
- Quick alignment question
- What year/model do these fit on?
- kyb gr2?
- Rear Suspension Help..
- EM Racing triangulated trunk floor bracing or Password X bar?
- fenders,wheels and gaps
- Final Suspension Tweaks (quasi-stock) - Sourcing
- rear disk brake conversion help
- what is/was your best setup on your 92-95 civic
- what lcas to get?
- Custom LCA's.. questions/comments/help
- Ground control...v.s....Function & Form.....v.s.....P.I.C coilovers????
- Cheapest refresh for CD5 accord OEM setup
- 97 Prelude SH - Tein S Tech's Back to Stock. How to??
- tein basic vs omni slipon + koni vs gc + kyb
- How To: Brake Line Tuck Guidelines..
- 96 accord setup
- question on da springs
- D2 coilover settings
- what i should consider for my 1998 integra type r
- Tokico Illuminas + springs > anyone?
- suspension techniques Sway bar
- front lca rubbing rotor!
- fuse keeps popping...?
- Civic/Integra rear integrated brake caliper leaking, WHY?
- Evolution Calipers on My Integra
- Help: Koni specific vs univeral GC sleeve
- camber kit, yes/no?
- tein spring switch (f2r)
- BEAKS subframe brace...
- ypw R LCA's
- Spring Rate v. Damper Valving
- I have a question about roll bars.......
- need help with strut bar
- KYB AGX
- Function 7, those guys ever answer there phone?
- MY CAR IS TRYING TO KILL ME... >PICS< TO COME DIAGNOSE MY SUSPENSION PROBLEM OR HELP WITH H
- the shock travel fork trick
- Rear Sway Bar Endlinks
- Brakes question?
- s-techs on stock everything
- skunk2 springs ok for my ej1 w/ 17x7 +45 wheels/
- Suspenion Help
- 98 ek suspension into a 2000 civic ex
- Where can I get all the Struts for my DA?(websites only)
- asr subframe... do i need after market rear lca's?
- Spring/suspension Setup Question
- extended top hat with lowering springs
- DC LCA's fit EG?
- omni coilovers
- Tein Type HR Coilovers
- Suspension Dilemma
- Got a q
- [FAQ] Blox/Skunk2 Camber Kit Install (DIY) Step-by-Step w/Pictures
- crx height adjustment mysteries
- koni yellow adjustment?
- I want a tighter handle for my suspension
- Wilwood Dynalite big brake front kit, with 11 diameter vented rotor (factory 240mm disc spindle civi
- megan racing springs
- GSR suspension on a 96 cicvic?
- Turbo H22 Swap. What Spring Rates??!
- Shocks for '99 Civic SI
- Tein Flex or Super Street for 4 Door EK4 euroi Model
- Buying single Tein shock
- Quick Q? Would a 96-00 EK Rear Lower Tie Bar fit 92-95 EG??
- HAS ANY1 USED TOP FUEL SUSPENSION
- Anybody have experience with the Cusco Lower Control Arm Braces????
- gabriels struts(autozone brand)
- b16 crx suspension recommendation
- ORDERED FROM JHPUSA STILL DIDNT RECIEVE
- Has anybody used Swift Springs.
- type r lca on a da
