PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99
  1. Shock Fitment???
  2. Integra Rear Disk Swap Problems...
  3. Installing Lowering Springs.
  4. can someone get a hold of TimeRacer for me?
  5. cheapest camber correction kit??
  6. old comptech swaybar?
  7. Daily driven 94 teg which is a good suspension
  8. camber kit
  9. how many threads on ground control sleeves?
  10. Omni EG UCAs ¿CRX?
  11. Help! Quick! Just Broke LCA Bolt!!!
  12. Camber kit install problem
  13. Recommended Springs for Daily Driven R on stock shocks
  14. Changing Spring rates in Tein SS?
  15. '96 Del Sol Si Rear Sway Bar - Will it fit?
  16. Koni Yellow questions.
  17. ACCORD KYB AGX SHOCKS for sale!
  18. Non coil spring set with firmer rear springs then front springs where can you get them?
  19. Confused on how coilovers adjust?!
  20. Helmp me order GC
  21. rotated tires, now steering wheel shakes at 70 and up?
  22. EP steering tie rod design. kinda cool.
  23. DC2 comptech sway bar/tie bar..?
  24. 26mm Mugen Rear Sway Bar Question....
  25. CRX Front swaybar?? Don't need it??
  26. Botteming out
  27. Yellow SP3 won't turn full 720
  28. does any know a good combo that would go with tein s-tech lowering springs??
  29. will a DC2 front LCA fit on an AK??
  30. Coilovers set uneven but stand even?
  31. Will this swaybar work on my car?
  32. Need list of EF, EG, EK, & DC weight ratios
  33. Lookin to have daily driver/track car......
  34. 97 suspension Q
  35. Spring rates
  36. Suspension Rubbing on Fenders
  37. itr suspension parts on ef
  38. recommended spring rates for D2?
  39. Tein S-Tech
  40. Suspension setup for a DA??
  41. NEED HELP with Tokico HP and GC coilover install...
  42. control arm problem please help
  43. CRX Suspension AutoX
  44. DC5 suspension/brakes swappable onto 01+ Civic (non-si)?
  45. ek stock sway bars
  46. Eibach spring #'s are they deciferable?
  47. Ground Contorl Coilover
  48. Need Help Identifying Bushing
  49. New setup too bouncy???
  50. coilovers fit on any car?
  51. need some help [sus]
  52. Buddy Club N Spec?
  53. Suspension problem
  54. look at what happened after i lowered the car.
  55. crx stud removal?
  56. New... need some help
  57. tein ss vs tein flex
  58. Installed a NRG Front Suspension Brace
  59. Need Help Quickly! Installing Coilovers on 92 Civic
  60. need help deciding
  61. Broke rear LCA bolt, can I drill it out?
  62. LCA's for 97+ Prelude
  63. CRX rear disc swap = horrible alignment...
  64. Stuck Balljoints all the time. Any tricks??
  65. 92 hatch.. suspension opinions..
  66. recommendation on suspension
  67. painting shocks
  68. possible to test coilovers without them being installed on a car?
  69. short shock koni?
  70. SPC forged arm for Civic's and Tegs.
  71. 99 si suspension vs Type R
  72. Do swaybar poly bushings really do anything???
  73. gsr vs itr swaybar endlinks
  74. Bought ground controls from mpactmotorsports.com
  75. do coilovers go 4"?
  76. does anyone have shocks/springs for sale?
  77. Ksport or D2 coilovers
  78. which shocks would you buy?
  79. Suspension gurus,do I need a camber kit,just an alignment or both?
  80. shock/springs or a true coil over setup?
  81. energy suspension master kit install?
  82. omni slips and illumina's vs. omni full coilovers ?
  83. Need some help/info about pillow ball mounts
  84. Places to get the MemoryFab X bar?
  85. Before I install my Skunk2 rear camber kit....
  86. Who sells A-Spec-Racing subframe braces? Can't find a vendor
  87. Question about Aftermarket Springs
  88. Anyone know a decent place to buy one Tokico Illumina?
  89. Stiffer Chasis, Traction problems?
  90. Would the size of the rear sway bar affect ride quality?
  91. Neuspeed Sofsport Rates Civic EK
  92. need some help
  93. My Z10 tracion bars..one is rubbing oil pan???Z10 didnt state that any mods required..any suggestion
  94. kyb strut mount
  95. grinding or cutting?
  96. ot: Job opening at Ground Control
  97. Rear control arm bushings shot, Help Please
  98. Where to check alignment?
  99. New/Improved Beaks kit for EK chassis?
  100. do omni coilovers go low
  101. Invidia Rear Sway Bar Kit?
  102. need advice on new suspension setup for my car
  103. koni and GCs
  104. need help!
  105. OEM Bushings are $$$$$
  106. will 88-91 ground control coilovers work on a 92-95 hatch?
  107. Need pics of front LCA and front strut.
  108. best integar bushing kit
  109. Adjustment range of 8041-RACE Konis
  110. Fastbrakes 11" Kit Rotors?
  111. What length ground control spring for street/hpde?
  112. ohlins suspension - worth $500?
  113. koni yellows are out of car.......how can i tell if there still good?
  114. coilover noises
  115. Pulsing noise from suspension when I roll
  116. HELP!!! About Type R suspension and brake conversion
  117. Proper way to adjust the height of omni power coilovers???
  118. 88-91 civic sway bar reccomendation?
  119. Few questions regarding Koni Yellow for Integra 4 doors.
  120. cant find a good camber kit for 90 integra??
  121. Where to buy OHLINS In the US?
  122. Traction bar Fitment
  123. jacking up suspension to tighten bolts
  124. Lowering springs question
  125. Tokico Illumina over KYB AGX...
  126. Springs interchangable?
  127. im pla
  128. 01 prelude 5 lug on a crx??
  129. Coilover adjusting, how should I do this?
  130. wtb suspension upgrage
  131. Ground Controls upper and extended upper mount tophat
  132. tein s tech
  133. Lower Conttol arm question
  134. Eibach Pro-kit sagging issues
  135. traction bar Q/dash vibrate during shift
  136. Springs for a DA
  137. Strut tower bar: Mounting on the tower vs. on the strut
  138. 3 point front strut bar
  139. Tokico Lifetime warranty?
  140. Max spring rate for Tokico 5 ways?
  141. disc brake question
  142. ground control install questions
  143. H&R OE Sport Springs or ITR springs??
  144. coil over spec adjustment
  145. Skunk2 UCA Durability Question
  146. Question about koni revalve
  147. LCA bolt won't budge
  148. ground control coilovers
  149. what is the best setup for me?
  150. koni dampening adjustment... how to find lowest setting o_O
  151. Advice on rear camber kit
  152. Help me with what sturts to get
  153. so how do i fix this?
  154. koni question, uneven perches
  155. Shocks for neuspeed springs
  156. strut bars
  157. Complete newbie suspension question
  158. rear traiking arm bushing question
  159. Neuspeed Springs Which is front and Rear.? Short front or long springs on front?
  160. A sneak-peek...
  161. ATTN EM2/EP3 Owners!!! Newly Installed Springs make Rattle Noise... Help Please.
  162. What happens to TOE when the rear is lower?
  163. Advantages to Honda rear suspension
  164. Suspension settings....
  165. Steering / Front suspension problem
  166. si brakes on dx - questions
  167. Minimal Drop For An Integra?
  168. Koni shocks
  169. To replace front lca bushings with es bushings or not to replace?
  170. Installed Koni Yellows with Neuspeed Race. Back is a little lower also a clunk sound..
  171. question regarding tokico illuminas
  172. I mght be getting upgraded 4 free...
  173. Exhaust hitting sway bar.. help
  174. I'm puzzled over this abnormal brake wear pattern
  175. SRR rear tie bar vs. A-spec Racing
  176. Ex brakes onto my cx
  177. Replacing wheel hub & bearing, estimated time??
  178. sportlines on my EK sits higher in front help!
  179. h&r race springs for sale
  180. 92-95 subframe and 96> subframe qs
  181. will these fit my ej8??
  182. EF vs EF Rear Upper Control Arm
  183. Accord Suspension
  184. Swift Tohatsu springs
  185. help with installing new suspension
  186. crx drag kit
  187. Inetgra Type R suspension
  188. My Alignment Specs
  189. Coilovers on stock struts
  190. Outer tie rod will it cause a clicking when braking?
  191. Tein: Another Ride-Height Question
  192. Ride Height
  193. Will 99 Civic Shocks fit 95 EG?
  194. KYB AGX + Coilover Sleeves....
  195. 91 EF9 trailing arms etc on a 2000 EK Hatch, need info
  196. anyone or any shops in norcal who can corner weigh a car?
  197. New springs - rear (Quick question)
  198. LOWER BALLJOINT REMOVAL PICS
  199. KYB AGX and RS Racing coilovers...
  200. Dspec tokicos with HandR sport springs
  201. EG suspension on 00 si
  202. lower or upper control arm?
  203. has anybody here actually tuned thier car for good rotation
  204. Suspension Techniques rear sway for sale (88-91 civic)
  205. best coilovers for crx?
  206. Dropzone suspension
  207. DA suspension advice/ideas??
  208. what springs for least drop 90-93 integra
  209. h&r ultra low coilovers
  210. 95 Civic EX, front Sway bushings, stock bar
  211. Off camber slow me down?
  212. 2001 Prelude upper control arm question!!!! HELP!
  213. Someone with a 99-00 SI front strut show me how it looks attached on a EG?
  214. Please help, Koni/GC setup
  215. Ksport?? preload ect
  216. Debating suspension products..
  217. Adjustable rear sway bar for '99 Civic Si
  218. power stearing fluid in break pump
  219. Cheap Sleeves + Nice Shocks + Cheap Springs = Good set-up?
  220. Upgrading to bigger OEM calipers with aftermarket Big Brake Kit on Integra ?
  221. Cusco comp s vs Tein SS vs Tanabe sustec
  222. 96-00 civic comptech tie bar
  223. omnipower slip-overs
  224. Need some help picking out suspension for my ef hatch - road racing and aggressive commuting
  225. Help! How to determine max shear load and stress levels?
  226. Any know where to get some dampers rebuilt in SOCAL?
  227. Requesting higher spring rates/valving adjustment when buying TEIN SS's?
  228. bolt head broke off....help!
  229. Tokico Illuminas With Skunk2 Sleeved Coilovers Advice
  230. Si springs installed, what to do?
  231. Camber Kit Install on 2001 Prelude S. Some pointers?
  232. d2 coilovers for ef
  233. Suspension Techniques Sway Bar Bushings
  234. Stock Front Shock brake brackets
  235. front control arms interchangeable?
  236. Tempted to put H&R coilover springs on my generic sleeves, is this okay?
  237. torque steer questions
  238. Making Neuspeed Srping handle (progressive rate)
  239. Koni Shock Supplement...
  240. KYB AGX - what springs? (90crx_si)
  241. Help Me Dignos This Problem
  242. ksport coilover vs. koni sport/spring combo
  243. H&R race springs with what shock
  244. KSPORT vs TEIN SPRING RATE - Check it out!!!
  245. Camber kits? Confuse me Help
  246. What bars?
  247. will koni yellow for my civic work on my integra?
  248. Mugen n1 suspension rebuild ??
  249. Which shocks should I go for?
  250. omni slip ons ?
