View Full Version : Suspension & Brakes
- what full coilovers can go super low
- Integra H&R sport springs with kyb agx shocks on an EG
- question: how good is this setup?????????
- tokico illumina + Tein stech?
- Tokico Illuminas & '90 LX w/non-stock setup
- Traction Bar - VS - Stock Front Crossmember
- 92-95 and 96-98 civic knuckles the same?????
- Tein S-TECH Lowering Springs??
- ***Pic request of ITR LCA's on the Car..as well as questions I have....***
- DA and DC forks
- help. my car sways side to side
- suspension help
- Need help with CRX koni/GC setup
- Difference between 92-95 civic and 90-93 integra shocks?
- Problem with comptech swaybar
- I NEED HELP WITH TYPE R SUSPENSION BRAKES!!
- Tokicko Illuminas or Koni yellows.....?
- Megan Racing fully adjustable coilover system
- Technial Questions : AGX vs. Illuminas
- when to get an ALITMENT
- tire wear
- Omni Slipon Install ?
- Looking for a brake guru on the topic of EGs
- 96-00 tein basics on 92-95 hatch?
- TEIN H vs. S
- How low can I go???
- Understeer and oversteer and braking
- CRX Suspension
- ej coils on ef?
- Alignment before or after traction bars ?
- swaybars......... anyone
- Coil over spring compressor that uses straps... can't find.
- Tokico Illuminas
- Need help with suspension / removing bolt suggestions (Big Pic)
- question about koni reds and gc's
- looking for some input!
- PLZ HELP>>> MY 94 Si IS TOO BOUNCY AFTER MY COILOVERS!!!
- 4x114.3 integra type r brake rotors
- Rear Adjust Links Necessary With This Package?
- Tein SS vs D2
- Anyone have info on this wilwood rear caliper??
- what size spacer is safe with stock studs
- Simple Spring Compatability Question!
- H&R - civic race springs on integra
- es bushing install help
- car lower on 1 side
- need help!!
- Prothane bushings, or all new OEM?
- Neuspeed Bilsteins installed
- Tokico Illuminas with Skunk2 Springs
- civic/EL suspension
- legend gs twin piston big brakes, any one familiar and have feed back!
- Installing full suspension, have a tool question
- Longevity questions.....
- suspension recommendations
- Understeer/Oversteer question
- Eibach front sway bar install ?
- koni yellows and h&r race springs.. how long has it last?
- Every seen these camber kits
- Lower Balljoint EKcivic
- H&R sports
- DIY Alignment?
- helper springs for koni/gc setup?
- Complete integra rear suspension into Del Sol
- Help meout with my daily driver. Springs or coilovers?
- Rear brake caliper problems
- Unbelievable
- bouncing BAD! any fix?
- Where do I get the Koni Yellows?
- Prothane steering bushings (Integra)
- what size brakes do . i have ?
- Getting ready to do a suspension overhaul
- Quick koni yellow question
- tokico's
- susp. tech rear swaybar work with comptech
- can you tell me wrong with this?
- EK Sedan suspension setup
- Searching for a 24mm Progress adjustable rear swaybar ???
- 92 si going to manual rack
- Power steering?
- EG susp. problem
- What would you recommend? 95 Civic DX
- jdm spec rm coilovers are they any good?
- Suspension ideas for my 93' civic?
- SI front springs progressive?
- Good lowering springs w/o replacing shocks
- SCC Suspension tech articles
- sprint perf
- where can i get custom springs for GC coil-overs?
- Help me?
- tanabe suspensions?
- Tire Rack Camber Bolts
- 98ls shocks on 2000si will it work?
- *****zeal b6 14k 10k is it streetable?*****
- HELP Install stock Shocks
- DC SPORTS strut bars
- ride feel with H&R race springs
- ground control coilovers with tokico blue?
- busted tierod ends on 2001 civic
- Upper Control Arm Mount to Chassis Torque Spec????
- comptech tie bar install
- Suspension help for '98 civic 4dr - B&G VS TEIN FLEX VS GC/Koni Yellows
- Omnipower slip-over spring rates
- shocks & springs choices (crx)
- Which is proven to be better-Omni Power or D2 dampers?
- type r and gsr lower control arms
- Suggested Spring Rates
- godline lowering springs and other MISC> noises
- SUSPENSION DELIMA PLEASE HELP!
- tein coilover
- did search......koni /gc....custom spring rate
- Losing control of my integra
- Comfort ??????????
- someone answer quick!!!...sportlines
- SCC Suspension Geometry Article, What this means to Hondas
- Swaybar bushing install question???
- 1993 civic front lower control arm question
- Koni yellow and H&R sports install... cut bumpstops?
- Check this out!!!
- Stock Springs with KYB AGX Shocks
- Car feels unstable
- integra shocks/springs fit on 96+ civic?
- when is wide too wide?
- Recommend a Good Susension Combo To Reduce Understeer(CRX)
- Autox/RR: D2 Coilovers vs Everything else
- Sprint Springs spring rate
- Theory behind why camber doesn't affect tire wear?
- Front end noise increasing with speed
- RWD
- carbon or semi-metallic
- Aftermarket LCA's and ITR Sway Bar Install Question
- H&R OEM SPRINGS....???
- Need some help
- Where can I get a single shock?
- knocking sound!! Need HELP BAD!
- Which type of Dampers are recommended for daily driven/drag/track.........
- TENZO R COILOVERS?
- Another dumb suspension question.........
- SKUNK2 and OMNI
- need tips for my EG rear suspension
- 450p spring ?
- Sportlines or Pro Kit
- lowering springs
- 95 honda civic steering
- Looking for Rayne Motorsports
- D2 vs. Tein Flex
- SRR Rear lower sway/tie bar problems?????
- Adjustible end links
- Suspension Guru's How do I get more negative camber with these camber plates???EP3
- 10X84 bolt
- Coilovers or Lowering Springs?
- teg front\rear D brackets the same?
- ****car feels like its sliding****
- need help with my omni
- How much do LCA's improve handling?
- EG6 Rear tie bars and strut brace????
- 1,xxx,xxx Spring Rate Question: CRX
- Slammed, how long has your suspension and tires lasted?
- people with sportlines
- after market rear sway bar end links?
- Couple Questions
- Neuspeed sway bar hardware kit??
- What size rod ends to get?
- Rough ride. Bilstein
- Mounting 16" rims to car question??
- coilover suspension ques??
- how do i get top nut off shock
- D2 Coilover Install ..... in progress
- Eibach Sportline question....
- Please help with Tokiko HP set.
- trailing arm?
- rear sway bar bushings
- what spring rate?
- Noob question about lowering a CRX Si..
- skunk2 pro-series coilovers.
- Adjusting GC/Koni Ride Height... Some insights please?
- Traction Bar setups and pictures needed.
- Will my Tein S-Tech springs from 92 civic, fit a 96+ civic?
- anyone heard of lightspeed rear sway bars
- CRX Rear sway
- back to the accord dropped on d2s acting funny
- searched.. explain benefits of cold/hot formed springs
- About to order GC's, a few questions, please.
- spc or ingalls?
- Tokico?
- Question about ITR shocks/springs on EG9
- KYB AGX/Sportlines: Opinions
- quick question
- align now or later?
- 4th gen prelude wheel rub
- GC Tophats compatibility problems with OEM Strut Bar: What Bars will fit?
- Koni Sport(Red's) Question
- Slammed, should I adjust to full soft or full stiff or middle?
- alignment spec
- Need Help with Omnipower Coilovers!
- brake pedal way to low
- Koni full adjustable kit
- Front Sub frame
- Upgrading to gsr brakes
- REALLY messed up
- help build my ek!@
- rear strut and sway bar opinions wanted
- ep3 springs
- Need to buy some stock shocks + Springs for EG Civic
- dc omni power coils for an ek
- Calling all those who have Progress Coilovers (dust boot?)
- aftermarket wheel bearings
- [pic request] your lowered civic + some questions
- tein ss max drop?
- Air Ride on 5th gen Lude?
- Clicking noise while making right turns
- Steering Problem, what should i check out?
- Bad idea for using Omni Drag Coilovers on dc2 for daily use??
- how do you measure your coilovers?
- stupid question but instructions on lowering springs
- whats this bushing called?
- caster adjustment hardware??
- A few questions about my Koni Yellows...(CRX Lee Please read)
- Function7 LCA's work on 95 gsr with comptech swaybar/tie bar combo?
- tein ss height adj / camber
- how to stop the BUMP!
- lude 5lug on 95 si hatch?
- confussed about tanabe gf210
- recommended spring rate
- Want rear disc on my 93 hatch
- omni
- 2000 honda prelude suspension question
- Installing Password 3 point bar
- 91 dx hb brake conversion problems
- Koni Yellows
- broken bolt stuck in front subframe...HELP!
- PLEASE help with Custom Ground control spring rate, setup inside
- Clicking while turning left hard
- Just bought 23mm ITR rear swaybar, what else?
- Did 5 lug conversion on my 95 integra gsr and now all shocks are bottoming out?
- When Buddy Club is not enough....
- where to get ground controls with custom spring rates?
- Coil-over alignment change with ride height change?
- changing shocks on coilovers
- Where to get koni yellows and GC's?
- Tein strut bars?
- Bilstein Sports Length? Shortened?
- Tokico Illuminas w/GC coilovers 02 accord
- KYB AGX & Pro-Kit Installed, a few questions?
- ENERGY SUSPENSION for 4th gen prelude
- A shop to install Springs?
- omnipower full coilovers $650 or koni red shocks and koni springs $460
- tenzo R coilovers good or bad??
- those with L-con traction bars. I need basic adjustment help. clunking sounds
- 92 integra suspension transplant on a 93 del sol (searched)
