PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Do OEM Civic lower ball joints come greased?
  2. Willwood 11" 4pot brakes
  3. brake lights won't turn off
  4. 2013 civic si on skunk2 springs!!!
  5. Wilwood 6 piston 11.8 Rotor Fast Brakes
  6. Brake Guru's need a little help with which prop valve to use.
  7. 94-01 integra front lower control arms?
  8. brake caliper and caliper piston question
  9. brake bleeding question please help
  10. Questions about alignment, tire wear, toe and other things
  11. Tokico, bump stops ?
  12. Lowering springs raised my car
  13. Super High Temp/Racing Brake Fluid?
  14. Caster issue
  15. Brake pressure issue, can not lock up the wheels
  16. bump stop
  17. cb7 suspension
  18. Loss of brake pressure, help
  19. inches of drop for the look i want.
  20. Tein coilovers for 96-00
  21. lowering civic
  22. Need a little help, Integra springs on a 99 EX, which struts?
  23. Replacement Shocks/Struts 99 Civic
  24. poormans 5 lug swap with k series question.
  25. 96-00 springs on a 88-91?
  26. adjustable endlink issue
  27. rear brake line help 98 civic
  28. KYB AGX+H&R springs question, uneven-ness ! DC2
  29. Adj upper "a" arms. Stamped steel or tube design
  30. Lowering Springs vs Coilovers help.
  31. Please help with identifying these coilovers
  32. Quick Question
  33. coil overs vs springs
  34. Shock Dyno --- Professionals chime in with opinion
  35. Front Suspension Forks
  36. Excessive wear on inside of tires
  37. Blackworks Coilovers problem/shake
  38. Taking advantage of Free Alignment checks. DiY Alignment @ Home.
  39. Civic EJ8 2000 Brake Disc Convertion
  40. Raising her back up -- Big Tires Rubbing:
  41. help with setup on daily turbo delsol
  42. Koni Yellows with ground control ?
  43. Spongy brake after ABS removal
  44. Neg camber on passenger side and not driver?
  45. spoon monoblock caliper 4x100 setups
  46. Car sat for 8 months, excessive slop in steering ever since.
  47. Real skunk2 coilover sleeves or fake?
  48. Inexpensive spring/strut combo for DD CRX beater
  49. 2013 CR Rear Camber Question
  50. WONT SHIFT OUT OF PARK & NO BRAKE LIGHTS
  51. Raceland Coilovers
  52. ITR/Prelude Front Brake Conversion - Contact with Rotor Issue
  53. what offest wheel to use for a flush look?
  54. spring color question
  55. Rebuild Apexi N1 Coilovers?
  56. brakes will not bleed!
  57. Perch height: Tokico Illuminas vs Koni YELLOW Sport
  58. How do I align my toe
  59. Quick question about Ground control CRX
  60. Photos of rear suspension horror
  61. lower control arms. ep3.
  62. JDM 5 lug conversion
  63. 2006 CRV front Lower Control Arm Removal
  64. EM1 rear shock replacement question
  65. GSR caliper bracket/ hx rims?
  66. Jam nuts GC/Koni Yellow
  67. Koni on eBay?
  68. Centric Premium Rear Rotor Fitment
  69. Calipers are seized(?), are the new brakes garbage now?
  70. Polymatrix A brake pads?
  71. Wilwood dynalite BBK help
  72. Prelude 5 lug on a CD5????
  73. Problem with ABS 1995 Civic
  74. coilovers for my hatch
  75. Front driver wheel can't be aligned (.3 degree caster)
  76. AEM brake pads
  77. Need advice 95 civic complete brake & hub conversion
  78. broken lca to control arm bolt
  79. Difference b/t subframe brace and reinforcement brace?
  80. skunk2 lca new design???
  81. Largest Brake Upgrade under 15" rim
  82. im having a confusing situation on abs delete. help
  83. Rotors Rub On Caliper
  84. I would like power steering
  85. Quick Ratio Steering Rack?
  86. ARP wheel studs
  87. Koni Yellow leak
  88. Eg hatchback coilovers what do you like?
  89. ball joint question
  90. 06+ coilover help
  91. 91 CRX rear brake caliper trouble
  92. Alignment help
  93. Full strut & outer tie rod replacement - now steering wheel play
  94. What is the Lightest Front LCA made for EK? EG?
  95. What is the Lightest Rear LCA made for EK? EG?
  96. Acura EL Koni/GC Issue
  97. Camber plate bearing's GONE. How do I replace and where do I buy new ones?
  98. EG to EF suspension interchangable?
  99. Wilwood Brake Setup + 15" Rota
  100. Prothane bush kit civic 96-00 front control arm kit
  101. Still having trailing arm trouble
  102. Steering rack assistance
  103. An amature that wants to rebuild his suspention.
  104. ABS 1" master cylinder questions???
  105. ASR subframe brace question
  106. ASK: meaning of 12x1 BBL & what type of flare is this pipe?
  107. Help! Suspension Squeaking!
  108. 96 Accord Front Upper Ball Joints
  109. What type of Brake booster is NM-290V-2?
  110. Sorry RonJ - Trailing Arm Welded Nut
  111. LCA to traling arm bolt.
  112. Abs
  113. legend dual piston caliper which rotor?
  114. 99 EK Coupe Disc Conversion
  115. Seized rear strut bolts got the best of me (noob)
  116. Coilover question
  117. Whining noise in front suspension
  118. koni/gc rates
  119. Tie Bar
  120. Hawk HPS or Ceramic???
  121. abs controler
  122. Omnipower V3 LCA
  123. Ground Control coilover identification?
  124. Do aftermarket shocks using ITR LCA have a rear bushing pressed into them?
  125. New brakes, new noise.
  126. Aluminum fittings in brake system?
  127. J2 Engineering Coilover (32 way adjustable) Review
  128. What's the proper tool needed to torque hard brake lines?
  129. Loose steering at high speeds!!!
  130. Decisions Decisions
  131. Will Spoon Calipers fit on a DA
  132. Koni/gc assembly question
  133. ABS removal on 98 GSR
  134. Best place to buy Hyperco?
  135. How to fix those squeaky aftermarket pads
  136. Wilwood 12.19" kit
  137. Brembo 111.5002A kit on 16x7-4x100 TE37's?
  138. Dc5 brake swap to audm dc5r help
  139. Which bushings for blox rear lca's?
  140. OEM lower control arm.
  141. Was installing my toe arm and this happened...
  142. Resurfacing Slotted Rotors
  143. Help identifying part # - front LCA
  144. So, I'm curious... X bar vs PWJDM 4pt rear brace
  145. Ask: Upgrade for Honda Fit Master Cylinder and Machine Shop info
  146. Tein suspension question
  147. Master cylinder
  148. coilover sleeves and blown shocks
  149. 96-00 rear camber arm bolt size
  150. Back on H after several BMWs
  151. 1G CRV Front UCA on EK?
  152. Lowering springs or coilovers?
  153. Another SWAY BAR Question
  154. Del Sol coilover suspension. Please Help!
  155. Ask: Upgrade for Honda Fit Master Cylinder and Machine Shop info
  156. Skunk2 pro s II
  157. Can prop. Valve be above the master cyl?
  158. DA9 brake caliper HELP!
  159. Ground Control tophats claim
  160. D2 coilovers ?
  161. Function and Form Shock Bushings Worn
  162. GC/KYB install question!! I searched for days and cant find an answer!!
  163. Spring rates for EF hatch
  164. Lowering/Camber kit question
  165. Want to get all new suspension componets before lowering
  166. Big difference between left and right weight
  167. do you need front camber kit on ep3?
  168. Alignment
  169. Help! Installing AMR Engineering Coilovers!
  170. How long did your aluminum lug nuts last?
  171. MFactory Extended Ball Joint Question
  172. Bump Stop Tech
  173. Rotor and Pad upgrade options
  174. skunk2 pro-c make softer?
  175. 32mm & 36mm ITR 5 lug - Same Caliper/Bracket?
  176. Spoon Brake Rotors
  177. Lowering springs bad for your car?
  178. HELP! EK REAR SUSPENSION ALOT HIGHER THAN FRONT!
  179. Upgraded Suspension, What Next?
  180. Lowering/Camber Question
  181. broken bracket on rear trailing arm??
  182. Suspension question
  183. Ghetto stiffen
  184. Help? Debating on coilovers set-ups
  185. New coil overs strut is poking through once installed *PICS*
  186. Alignment/suspension approaches to prevent non-loaded wheel spin
  187. Control arm question
  188. My first disk swap
  189. another coilover question
  190. i need prof Help on my lowered ek.
  191. Want Coilovers. Have $500-$600 to spend. What should I get?
  192. Mugen Nissin Brake Calipers
  193. Help me identify this coilover...
  194. Spring perch groove.
  195. 4-piston RL calipers & 350Z brembo rotors installed on my TSX
  196. why are Neuspeed coilovers never talked about?
  197. Skunk2 pro-c problem
  198. EJ1 - Eibach Prokit or Sportline?
  199. *NEW* AMR Engineering Front and Rear Camber Kits - Got mine!!!
  200. Cutting the LCA off?
  201. Eg/DC bushings???!!
  202. BLOX Strut Problem NEED HELP
  203. GC coils identification
  204. EF hatch, brakes start locking after 10-15 min of driving
  205. 99 Civic Pedal ratio?
  206. *click* noise when turning wheel on right side + loose grommet on axle
  207. Gc sleeve issue
  208. Balljoint pushing rotor dust shield into rotor
  209. 1995 Del Sol S knowledge needed for next upgrade/repair
  210. Problems lowering 02 civic lx
  211. Endlinks and ASR
  212. 88 Accord lxi project
  213. ITR antirollbar on EG, endlink problems
  214. *Function & Form Type 1 Full Coilovers: Good or Bad???*
  215. 93 civic sway bar install???
  216. Running Enkei RPF1's, want to do brake upgrade...
  217. 5th Gen Prelude Difference Between SH and Base?
  218. which to buy...
  219. trailing arms
  220. Brakes wont lock up, little stopping power...
  221. Integra pushrod adjustment help
  222. GC perch issue.. need help
  223. trailing arm bushings that dont require clocking
  224. Can someone explain braking to me?
  225. How do you like your Tein springs? Pair with what shock?
  226. Need help figuring what I need
  227. Correcting camber . Longer upper arms vs camber bolt kit
  228. Hard Race Lower Control Arms
  229. 74 Rear Abs Solenoid Code??
  230. lowering, aligment for 96 integra
  231. big baller over here looking to buy coilovers, wanting opinions on raceland or emusa
  232. Lowered rear than front
  233. 2002 adjustable lowering spring fit for 1999 civic?
  234. Should I replace these rotors?
  235. Powerslot/AEM Big Rotor Brake Kit
  236. jdm itr 5 lug replacement axles
  237. Weekend/Street Car/Auto-X Springrates - 12/10 vs 10/8 ?
  238. help! dot 5 qestion!
  239. Rotor & Brake Help
  240. Work done to suspension, now front end is humming...
  241. Anyone know about Eibach Pro Dampers?
  242. koni/GC installation question
  243. legend caliper,11.1 rotor ok with just 15/16th mc?
  244. 93 Honda civic bushing
  245. Cusco coilovers ID
  246. PIC performance HRB kit help
  247. Alignment done, but still pulling to the left (2000 Integra)
  248. What Calipers are these?
  249. Best Brake Kit - Wilwood - StopTech - Ksport - Baer-?
  250. Brake Fade. Ive got it bad. Need to upgrade. Stock Crx si 4 wheel disk
