PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. alignment issues please help
  2. Hit the curb(help)
  3. 1997 Accord Suspension Setup
  4. omni power coilovers
  5. function/form coilovers
  6. Carbing lower rear tie bar...
  7. si swaybar on ej8
  8. best place to order KSPORT Coilovers
  9. OEM Shocks
  10. Used G/C
  11. 5 lug conversion question
  12. Need help finding rear strut to take out springs???
  13. civic shocks/struts
  14. kyb/omni or gc worth it ?
  15. ATTACK RACING SUSPENSION !!
  16. How many GC top hats do you really need for a set-up?
  17. tokico d-specs coilovers or tein flex coilovers??
  18. My omnipower coilovers blew after 5 days of going to work and school(pictures)
  19. HELp------CTR 5 lug conversion and Brake Pedal!!!!!HELP!!!!!!Help!!!!! please
  20. sway bar question
  21. Favorite Setup For 96-98 EK Coupe
  22. Control arms
  23. tokico illuminas vs. HPs (blues) vs KYB GR2s
  24. camber kit recommendations...
  25. tokico and h&r help on crx
  26. Alignment Question!!
  27. Type r brackets machined to fit a civic ex (98)
  28. different shock setups
  29. D2 VS OMNI ??
  30. GC/ koni Vs True coil over
  31. More GC/KONI install questions...
  32. Upper control arm help!!!!
  33. track R or DR20
  34. NEWB Question. Again......
  35. spring perch (cup)
  36. Lowering Springs
  37. Ebay coilovers or not?
  38. Skunk2 vs. Koni/GC
  39. Toe curve
  40. tokicos and omni powers
  41. Ground Control
  42. Grease flying from good CV boots...
  43. Will an Integra Master Cylinder help a EG with a stock setup?
  44. NEWBIE NEED HELP WIHT SUSPENSION EG to EM1
  45. Help Needed with Shocks
  46. Can someone confirm this for me?
  47. What dust covers to use on Koni/GC setup?
  48. ksports or illumina's
  49. Rota Slipstream 15x8 - What offset for EK?
  50. labor question. ANYBODY
  51. i need ek inner tie rod ends but i dont have a power steering rack..
  52. more bang for my buck
  53. Your thoughts on Taiwan-brand coilovers
  54. Is it just Me or do Ksport Suspensions in the Rears Just blow???
  55. Suspension for '03 WRX, opinions.
  56. that is the difference between 96-00 and 92-95 civic rear struts?
  57. tire size DROP
  58. omnipower adjustment tool
  59. Tein Mono Flex
  60. comments on skunk2 pro series c/o
  61. springs that give the most drop,but comfortable?
  62. H&r Race springs
  63. ingalls/dropzone camber kit question
  64. I have really bad wheel hop
  65. Strut Mount
  66. H&R sport spring rates for 92-95 civic hatch
  67. steering wheel twitch issues...
  68. h&r springs
  69. Bought used ITR front and rear sways -- What do I need to get this puppy mounted?!?
  70. EK Suspension HELP! Please
  71. a skunk2 lowering spring thread.
  72. Mix and Match Bushings?
  73. Don’t know if my suspension is rebuildable ??? help
  74. Cursed with rare problems
  75. Best shocks to go with Tein S.Techs?
  76. Si front forks for my ek hb
  77. Help me tune my new EG equipped with Tein-s tech Street Dampner
  78. Camber Kit!! Suggestions .
  79. Bilstein SP install problem (Shock fork related), please help!!!
  80. Question about Air Struts...
  81. help on torsion tube removal...
  82. 99 civic springs ona 89 rex
  83. Traction help!?
  84. 215/50-15 on LS Mesh on EK Hatch
  85. springs for tokico illumina's
  86. gc top hats
  87. I NEED INFO!!!!
  88. rear wheel stud replacement
  89. Koni Install Help
  90. Steering wheel shaking while punching gas...
  91. Tokico D specs anybody?
  92. alignment help QUICK!!!!<><><><
  93. Tanabe
  94. Suspension suggestions?
  95. wat suspenssion fits best for me?
  96. EK Sway bar options.
  97. Ground Control questions for my EK HB
  98. Neuspeed Koni Yellows - were they always SP3?
  99. what g's are you guys putting out with street tires?
  100. ST rear sway for non oe eg civics
  101. clank in right rear when cold
  102. Camber kit slip.
  103. ksport suspensions
  104. Stripped rotor screw...what to do?
  105. HELP ASAP!!!!!
  106. help with CTR 5 lug abs
  107. koni red + GC
  108. skunk2 pro series
  109. HELP! Broke off strut bolt!!
  110. racing seat questions???
  111. fitting ek rear shocks on a dc integra
  112. Rear disc brake problem 1993 civic sedan with 94-01 teggy brakes
  113. Another Tein SS question.
  114. help lowering crx.
  115. Civic 92 vx hb rear disc brake conversion
  116. My suspension dilema
  117. new rims/tires, do i need an alignment?
  118. need advice on lowering my car
  119. daily driving rates?
  120. Camber Kit Info Needed
  121. Koni 1150 - What's the range of height adjustability?
  122. crx with kyb agx
  123. Toe at -7.00º WTF!! help
  124. Experiences with BLOX LCA's???
  125. Which suspension setup for my needs?
  126. bad shock?
  127. Critique my suspension plan! For an EG.....
  128. question about Spoon N1 damper
  129. Skunk2 Pro-C coilover kit
  130. ITR Suspension Question ~
  131. New shocks, rough ride??!!
  132. Eibach Sportline for 97 hatch..BUMPSTOP question
  133. steering wheel pull
  134. best for your money...
  135. spring Lb.?
  136. just installed K sports..not happy
  137. autocross springs
  138. Need to know Tein S.tech spring drop.
  139. 380 front / 250 rear ERS springrates ok for EG hatch 100% daily driver
  140. ???spring height ???
  141. how to lower?
  142. Need new upper ball joint...got some questions.
  143. ITR 22mm sway with 18k omnis?
  144. 8" rear springs on koni
  145. Eibach Sportline question? 1995 Honda Civic 2dr Coupe
  146. tein basic VS. Koni/h&r 2Qs
  147. 5th Gen Hatch Ride Height?
  148. Rear disc question(searched)
  149. Need help! H&R vs. Apexi Coilovers
  150. 4" Drop
  151. what is the purpose of the PillowBall Mounts?
  152. STANCE coilovers
  153. drag suspension
  154. DSS vendor @ HT?
  155. what suspesion is the best for 1/4 mile
  156. shocks out, safe to drive? any effect on toe camber?
  157. shocks out, safe to drive? any effect on toe camber?
  158. GC top hat question
  159. Tein vs Cusco....?
  160. WTB COILOVERS for 2000 ITR
  161. Certain BUMPS make "CLUNKS"? [Omni's on EM1]
  162. Need Help: Apexi WorldSport?
  163. EG suspension advice needed
  164. skunk2 shocks
  165. springs for project rally beater
  166. HELP!!!! alignment off the charts!
  167. Eibach Sway bar kit for '06 Civic Si
  168. Can I get a factory height out of Omnipowers?.
  169. '96 DX Ride Height Help
  170. Problems after shock install
  171. Supension Poll
  172. Best Handling Civic
  173. eg suspension
  174. H&R springs
  175. k-sports how long? for dd
  176. JDM rear swaybar bushings
  177. KYB AGX QUESTIONS - 1996 Accord (sedan)
  178. Rotor won't come off
  179. wuts the best setup on an eg
  180. CUSCO Roll Cage -> Topic not covered.......
  181. H&R Sports with KYB GR2
  182. ravespeed springs?
  183. tein vs omnipower
  184. why does one side sits lower?
  185. Does adding a strut bar do anything?
  186. CRX B16 - Suspension advice for Daily Driver/Auto-X
  187. camber kit question
  188. CIVIC SITTING LOW ON ONE SIDE
  189. best integra suspension set up for the money
  190. Rear disc brake conversion/camber problem...
  191. ground control/ koni
  192. H&R Sports with OEM shocks?
  193. Help with suspension!
  194. Spring and shock set ups
  195. Anyone have experience with D2 Coilovers for Civic EG/Integra DC2
  196. coilover question
  197. ASR Brace, JDM ITR 23MM swaybar, and JDM ITR LCA's......HELP
  198. i need to lower my coilovers but i dont have the coilover tool.
  199. What Grade Bolts for Swaybar Install?
  200. Dynamic Caster
  201. Skunk2 Suspension? Tein S springs? Force motorsports?
  202. S2000 brakes on eg
  203. Signs of bad rear upper arms?
  204. Norcal- where did you rent your springs compressors for lowering springs ?
  205. ITR 5lug on 96-00 EX Sedan
  206. F2 spring rates for EG
  207. Blows shocks?
  208. Ksport vs AMR full coilovers
  209. What are your Ground Control Spring rates ?
  210. Suspension Drivability
  211. front wheel bearings play tolerance?
  212. New drums
  213. BRAKING PROBLEM HELP!!
  214. VW jetta spring install?
  215. Should I drop my car now??
  216. How do Neuspeed Race springs compare with H&R Race springs (eg hatch)?
  217. high spring rate = bad for tires?
  218. coilovers: megan vs. omnipower
  219. Can you use stock 94-01 integra springs in a 95 civic sedan?
  220. da/dc shock spring question??????????
  221. feedback on buddy club N+ and other goodies
  222. need help dilema lower my ek hb
  223. i hope these r good
  224. Dual strut bar setup
  225. Best brake set-up for gsr with 15" wheels?
  226. do i have to tune my car???
  227. omni power adjustable coilovers
  228. tightening up stock steering rack
  229. how to fit da sway on ef ?
  230. Best non adjustable, "no after market coil over" setup/package?
  231. Will this fit???
  232. brake conversion
  233. k-sport or ommni ?
  234. do I need a spring compressor to put stock springs back on?
  235. GC/KONI quick question.
  236. Used springs and shocks?
  237. Koni SP3 durability issues?
  238. Good street setup on a budget?
  239. squeks coming from Omni power upper control arms..
  240. vigor set up
  241. My Da Crossmember??
  242. Need help with suspension for civic h22
  243. ITR tophat question
  244. GC springs on skunk 2 sleeves??
  245. Quick, easy question
  246. Cool Eibach video...
  247. Favorite coilovers????
  248. Itr 1.114 suspension ??
  249. d2 26 way Coil overs OR F2 AUTOLIFE TYPE II??????????? HELP!!!
  250. "poping noises from the front sus"
