View Full Version : Suspension & Brakes
- Stock Springs/struts....
- 4pt/3pt front/rear stru tower bars on an EK Hatch
- anyone here use tein s tech for their eg?
- Whats a good set up
- Omni coilovers: Need to re-use stock top-hats?
- Help Me With My Suspension setup
- KSport Question
- Ground Control question
- Eg spring rates
- I need a new front stabilizer end link assembly
- ksport or Function and Form Coilovers
- ABS Brake master on a non-ABS car ?
- Need help to get my ride quality better
- Eg springs on Ek?
- Suspension adjustment?
- Best coilovers for a 94 accord coupe ex
- T1R Coilovers
- getting ball joints out
- Omni Coilovers vs Yonaka's (question)
- crx shock settings
- Tein S-tech Springs in Tein Basic or Super Street
- Rocking Aftermarket Suspension in the Winter
- Tanabe Sustec Pro SS Type 2? How is it?
- how much does a shop charge??
- Tein super street coilover spring rate question.
- TEIN RAs on a EK vs. Flex
- WTB: INTEGRA TYPE-R 5 LUG CONVERSION
- Civic/Integra Prokit fitment
- buying coilovers, need dampening help and spring rate help.
- New Suspension, Tokico Illuminas and GC, setup and install questions
- Help with putting on suspension
- suspension installation question
- suspension kits for 96 3.5rl
- 91 Crx Owner looking for some opinions on coilovers........
- Si Spring/Struts!
- coil overs on my eg
- rear lower tie bar ?
- Is there a conversion for spings rates?
- need help with full skunk2 pro series coil overs...
- Which cv boot do I need??
- H & R Sport springs or Neuspeed Sport?
- Skunk2 Front Camber Kit Honda Civic 96 - 00
- Fitament Question: 92-95 Civic GC Coilovers on a 00 Civic Si
- ksport or omni coilover system
- omni power
- Which top to used with koni yellow?
- EXPERT ON COILOVER SUSPENSION FOR DC2 94
- KONI/GC coilover adjustment
- Easiest way to adjust camber and toe
- drop 94 teg... how much?
- UCA install question.
- suspension joints w/ rod ends and spherical bearings
- Neuspeed strut bar ?
- ebay springs
- Tokico Illuminas making a weird noise. Normal?
- H&R Sport Camber *Searched*
- tires get rubbed by rear lip????
- Good Suspension for me?
- DAMN IT! Broke a bolt!
- Alignment Results: Suspension Gurus... PLEASE HELP????
- 92-96 prelude suspension on a 2000 ex coupe?
- suspension squeaks - what to use for lube ?
- Price for a 5lug ITR conversion...?!?!?!
- Need some help: ID these Ohlins
- What is a good econo combo for a rear drag race setup in a 93 hatch?
- edelbrock full coilovers, any good??
- EIBACH SPORTLINE SPRING WILL FIT EG? will low 1.6 all around!!
- H22 in an EK.... can it handle?
- tein HA anyone have them ???????????
- What Energy Suspension Hyperflex kit do i need??
- this is kinda funny...its bout my coil overs...
- suspension issues
- 2.2CL using Accord Suspension
- DC2 Integra GC coilovers on an EK?
- koni yellows and H&R race application
- DropZone coilovers, feedback, reviews, experience...
- what suspension parts to avoid messing with to avoid changing alignment?
- Quick! Will this work???? 98 suspension on 93.......
- any one with ksport
- Suspension
- EF shock install help
- is anyone selling their after marts suspension for cheap?
- Innovative k-member for DA?
- Type R rear control arms on a EK... help
- ---i felt in a huge hole my car is now drifting to the right side in straight roads---
- which bushings to install first?
- TEIN TYPE BASIC COILOVER DAMPER
- O.E.M. sway bars
- Quick question about axel removal.
- strut supposed to be like this?
- camber kit options for CRX
- swaybar coating
- Do you do this in your Honda too!
- HELP URGENT SUSP GURU!?!?
- TEIN SS
- Better shocks vs. quality swaybar setup - which should be first?
- Ksport install question for EF
- how camber change effects toe
- RSR down spring rates ?
- Adjustable Shocks in cold weather?
- GC top Hats work With apexi WS????????????
- help me out for the ride comfort (street use average 1.4-1.6 drop)
- springs rates for 98 integra vs 99 civic Si
- adjustable dampning what dose it do
- i need reference regarding kyb agxs
- skunk 2 lowering springs?
- lowering question
- Ground Control Coilovers.
- Koni shock rod pushed through tophat....please help!
- Vibration under acceleration!!
- What suspension is on this car????
- Tein super street or Skunk2 coilover on KYB agxs or ground control on kyb agxs
- HEPL!!!! no manual steering rack exists for my what what do i do ????!!!!!!
- 89 honda 3dr. new struts/coils
- Alignment Issues
- T1R B-Max Damper
- Neuspeed Spring Question
- Questions about Acura Integra Type-R OEM Suspension
- Best suspension for a 94 accord???
- How to assemble ground control coilover & tophat /koni red assembly
- steering slop
- 95 civic, can I use....
- Japanese setups vs American setups...? Where should the higher spring rate be?
- K speed coilover
- what strut/spring combo would be good on a 91 crx , but i want to keep it stock height?
- steering problem.
- Steering wheel troubles!
- Asr subframe brace and 3 inch exhaust?
- Comptech Swaybar Exhaust Clearance??
- Changing Shocks and SPrings on 95 Hatch what buchins need replacing >?
- adjustable struts
- which Skunk2 front and rear strut bars will fit '90 Integra's??
- how do i avoid bounce with new coilovers?
- axles wont go in.
- vibrating when accelerating, why?
- Omni power stuff?
- street coilovers.... best choices?
- Need advice
- Koni Yellows with stop bump stops?
- 92 prelude front right help
- Yikes. 92-95 Hatch rear sway bar / tie bar / RLCA's problems with intermixing, etc.
- Recommend me some Full Coilover setups for IS300. Any Suggestions?
- ground controls
- civic chamber
- Uneven drop? Why? i checked everything..PLS HELP
- What advantages does the Tein Flex have over Tein SS?
- rear disk swap on crx: do i need to change the brake booster?
- Dust Covers
- ASR 32mm revamp...
- skunk2 top mounts for 90-93 integra
- dropped ride woe's
- This doesn't look right......
- AGX's or Koni yellow
- type r rear sway bar on em1 chasis
- New Omni-power 4-piston calipers?
- NEED INFO ON ADVANCED CRX SUSPENSION
- Looking for a cheap rear set of used '89-91 CRX/Civic rear LCAs
- Rear disk conversion on a 89 crx si
- looking for adjustability
- help!!!! with coilver intallation, was wondering what are the perches for
- Which other OEM honda springs work on my integra?
- ATE Superblue
- Help me decide on suspension for my DC integra..
- QUESTION USED TEIN SS
- Does anyone work at a parts store? Shock question...
- 4th gen help??
- 99-00 Si swaybar on an EX - worthwhile upgrade?
- For those who like to turn fast
- DA camber kit question
- coilovers- 96 ex
- Installing lowering springs?
- little insight please... appreciate it.
- Best street springs for ek hatch with b16a
- Which TIEN!?
- Koni Yellows & Skunk2 Coilovers.... CLINGING SOUND??
- Function and Form Coilover Owners
- wheel hop
- Gc suspentions
- the 499 dampers.
- GC , Tein, or these.
- Tokico Illumina Coilovers are great!!
- H&R Sports w/stock struts?
- So about these omni uca camber kit?
- 94 integra has rear positive camber...fix it with a camber kit???
- 96 ex civic
- Suspension Noise Getting Worse
- Camber kit......
- eh2 front suspension troubles..Turning wobble?
- would integra ground controls fit my EG?
- NEW NRG CARBON BRACES!!!
- Re: Spend My Money
- Suspension
- SPORTLINE SPRINGS.....QUESTION
- ITR Rear Upper Control Arm Q.
- Thumping Sound on my steering rack when I go over bumps???
- whats needed for the type r suspension?
- 2.5 inches too much???
- show i cut h&r sport springs
- strut problems???
- strut tower bars
- help i need some 1200lbs springs
- Would the Type-R suspension fit my EJ6?
- skunk 2 coilovers??
- H&R Coilovers, or any other ones with similar scenario
- EF Crossmember VS Traction bars
- ef 114 conversion
- rear camber kit
- NewB question
- Apollo coilovers
- Sway Bar Compatibility
- Installed Koni 1130 Kit (Yellows + Springs) and the front way to low
- Tein S.Tech Springs
- fitting polly bushes, well gonna try
- Humming noise
- skunk 2 lcas...?
- Alignment shop in long beach
- does 96 civic suspension fit on a DC2?
- Ground Control coilover question
- Rear lower control arms. Never seen these before, need info
- *searched* 88 crx sway bar ?
- KYB AGX w/H&R sport springs ride quality??
- Skunk2 full adjustable coilover?
- Omni Power Uca's
- 5 lug conversion
- how harsh are 1000lb springs on the street?
- how is this KYB exel-g SHOCK??(need your advice)
- spring rates dillema on a car
- 2.5"-3" drop what shocks to get?
- used roll cage question
- TEIN RA + EDFC + EG Hatch
- 90-93 LCA question
- METAL RUBBING?
- eibach sportline springs help
- About how much camber change can I expect
- replacement struts
- CTR/ITR rear sway bar owner need your help!
- Weak Rear End?
- Suspension setup opinions.......
- need help
- 88 CRX LCAs on EG with ITR shocks? Ive searched
- Are the H-Brace good?
- which one would you rather get ?
- Rear Sway Bar w/ Stock Suspension
- what's wrong with my rear strut?!!
- best shock/struts
- Bad front suspension??
- Suspension Question...(EG) which is best for daily-spirited driving???
- Lowering spring/shock combo sugestions for $300 or under.
- Shaky brakes(90 crx si)
- K-SPORT
