PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Quick 92' Eg Drums to Disc question
  2. what shocks to go with (non-koni gc)
  3. Suspension help......
  4. popping coilover springs
  5. blox lowering springs
  6. Weights & Measures: How Much Unsprung Weight Does A Racingbrake 2-Piece Rotor Save?
  7. STD R5 Coilovers
  8. ventilated vs plain
  9. Pleaseeeee guys, help me out with this. We want to buy this stuff already.
  10. New Rear Koni Yellows Won't Adjust but Fronts Do
  11. Koni Yellows Help
  12. Ride Height Help, Coilovers
  13. evo8 or STI brakes?
  14. suspension replacement
  15. Coilovers, Ground Controls or Skunk 2's for EK??
  16. springs/coilover sleeve for ride quality
  17. 13 x 6 et 15 fit an ef??
  18. benen lower tie bar. longer bolts needed?
  19. brake booster from ek4 fit dc2?
  20. Subframe Support from EK4 fit DC2?
  21. HP+ / Yellow stuff
  22. Wheel Gap. Coilover help?
  23. Why is my car leaning?
  24. Which Coilovers too get for my ek hatch?
  25. Brembo blanks are now made in China - alternatives?
  26. Mid-Range Coilovers Worth It?
  27. EK steering rack de-power + Integra Pinion
  28. Upgradin brakes help
  29. Installing Koni Sports...how to do the adjustments?
  30. strut to coilover conversions.. are bad for suspension?
  31. why has there been no mass marketing of lighter front lower arms?
  32. top hat question(s)
  33. EM1 SUSPENSION BUILD (doing it right)
  34. 96 spec ITR 4lug ? ? ?
  35. Ryane Suspension - Drop spindles
  36. Last upgrade of the suspension puzzle
  37. sway bar compatibilities...
  38. Are wheel Studs from a 92 interchangeable with a 99?
  39. suspension problem
  40. Need to know the name of this part
  41. anybody try these ?
  42. am I too low?
  43. Help chooseing spring rates
  44. Skunk2 Rear Camber Kit bushing replacement
  45. JUST installed Illumina/Ground Control (ek) and ride sucks ?!
  46. Itr rear sway on ek hatch endlinks
  47. ball joints on ej8
  48. Which engine mount/bushing/bracket with DC subframe?
  49. Sounds coming from the front driver side wheel.
  50. Sway/Tie/ C pillar bar for the rear question
  51. Alignment Questions
  52. StopTech, Brembo, or EBC?
  53. PLEASE HELP ME! IM BEGGING YOU, I AM DESPERATE AND LOSSING MY MIND HERE. PLEASE.
  54. What is the best suspension for NYC?
  55. Brake upgrade on 2000 civic si....
  56. want ur comment on DTM Sway Bar and ower rear strut frame bar
  57. serious positive caster in right front
  58. Seized Rear Camber Arm
  59. how to keep suspension from rusting??
  60. rear disc swap parking brake question
  61. Adusting Suspension height on 98 honda civic ex 4dr with tein adjustable coil overs?
  62. What sway bar and end links will worth with my setup?
  63. korbach frame locks
  64. rear disc swap and new mc, still spongy... help!
  65. How To Remove The Rotor Screws From Your Honda/Acura’s Brake Rotors
  66. Ek sway bar questions what to run
  67. Moog Suspension Component Quality?
  68. Adjusting ride height PIC coilover
  69. brake upgrade for 93 civic si non-abs
  70. inner tire wear on 94 civic
  71. question reguarding calipers, disks, and brackets
  72. Aluminum upper control arms by SPC
  73. need suggestions
  74. 1999 Integra GSR Disc Brakes onto 1993 Civic EX Coupe HAVE QUESTIONS!! HELP!!
  75. New Pitboard Posting: Racingbrake Rotors Break The Mold
  76. Track Pads - 08 SI
  77. ES1 drivers (civic 01-03 sedan) if you were to pick a lowering spring
  78. Can someone explain how coilover sleeves work
  79. ITR/94-96 Prelude VTEC caliper brackets same as 92-95 Legend single piston?
  80. swapping springs on my coilovers, can i do it?
  81. What is the best suspension for a dd?
  82. Ground Control lowering problem
  83. coilovers
  84. What size sway bar for my setup?
  85. Prelude VTEC rotors, what year?
  86. Steel braided brake lines from master cylinder? Length?
  87. Koni vs Bilstein
  88. GC suggestion needed.
  89. swapped DC knuckles into my EK and now 1 side has negative camber but other don't
  90. Non abs integra rs MC and Civic Si Brake booster
  91. drum brake wear problem
  92. 96spec ITR Brake Upgrade
  93. very bouncy setup...help
  94. need opinions and advice on strut/spring combo
  95. buzz spec kyb shocks and spring
  96. Setting up a eg sedans suspension..
  97. Color choice REAR LCA ON EK9
  98. 96 integra sitin on 15's need a idea for lowering spring height
  99. Suspension Opinions
  100. coilovers
  101. Brakes feeling weird
  102. Koni/GC: I Don’t Get the Hype
  103. Can unproperly seated springs cause this? (pics included)
  104. Possible MC or check valve problem?
  105. Race car brakes keep losing pressure
  106. tips on flaring lines with summit $40 37 degree tool...plz
  107. Rear sway bar help
  108. Very hot and strong smell from rear passanger wheel
  109. How did this guy do this? OEM MC w/o BB.
  110. Lowering Springs (HELP)
  111. crx suspension
  112. Does bleeder valve need to be opened?
  113. Do I need factory brakes?
  114. I need your blown or broken omni streets
  115. Can I use this proportioning valve?
  116. 00 DC2 proportioning valve delete
  117. JIC Magic JDM Integra Type R FLTA1 Coilovers?
  118. need some advice installing coilovers
  119. Sway Bar options??
  120. blox full coilover competition series
  121. my minty fresh set up
  122. 93 vx brake options???
  123. ITR rears on EK, hardware Qs
  124. energy suspension help
  125. full coilovers vs good strut and spring combo
  126. BLOX COILOVERS
  127. stock gsr vs itr height
  128. gc x koni
  129. Replace my setup?
  130. Brake rotors recommendation (94-01 gsr)
  131. Help would be appreciated. 96 civic dies out when stopped.
  132. ABS hissing during bleeding process.
  133. flare question
  134. EM1 GC/Koni Setup lowering?
  135. XYZ, D2 and K-Sport - the true story
  136. XYZ, D2 and K-Sport story
  137. Poly RTA bushings, again
  138. Del Sol race suspension setup
  139. civic front sway bar???
  140. lotek + GC
  141. Tein Super Street or Ground Control
  142. clunking sound from the rear right need some help
  143. info needed on ST Sway bars for 97 accord (52135)
  144. front camber fix??
  145. eg looking for a little 101
  146. eg ex lookinking for a good full setup to daily
  147. Best suspension for COMFORTABLE Lowered daily driver
  148. front looks higher than rear after lowering... not seated?
  149. Does Steering Rack from 99 Civic fit 99 DC2 ??doe
  150. Best setup for 17x7 +40mm?
  151. 96 type r brakes pad replacement help
  152. Post your ASR Brace Kits On Your DA Guys!
  153. ride too boouncy!
  154. invidia. or asr. sway bar kits
  155. Lowered Integra on 15s..
  156. Rear brake calliper rebuild
  157. tein basics help
  158. rebuild master cylinder?
  159. Rear Trailing Arm Removal
  160. EK...ASR rear brace + Si rear sway
  161. P/S Breather Problem?
  162. asr Subframe brace question 96 integra
  163. EG Sedan LCA Question
  164. So who is actually a helpful suspension company?
  165. How to increase my ride height? (Koni Yellows/Ground Control)
  166. Rywire/Chase Bays Brake Line Tuck Kit (Install Write Up)
  167. Wheel Bearing gone bad?
  168. Knocking in Rear Suspension at Low Speeds
  169. Rack n pinion question
  170. koni yellow/ground control ..wanna kno info on dem
  171. need help with koni shocks
  172. asbestos and non asbestos..
  173. Best Fullcoilover for 00 Civic
  174. Help with trailing arm bushings for 96 accord
  175. lookin for opinions on springs and have some questions..
  176. what type of coilovers are theses ?
  177. Slammed and flush questions!
  178. 91 civic wandering all over the road!!
  179. GSR sway bar into 96 dx
  180. brake bleeding problem... pedal is super soft
  181. Rebuilding front calipers HELP
  182. question for full race traction bars
  183. Integra rear wheel bearing?
  184. classic prelude struts
  185. helpp.!1992 honda civic eg.
  186. Thoughts on this shock tower bar?
  187. Want some new Suspention but only have $700
  188. Brake line, hardline fitting splice? Help!
  189. Tubular suspention
  190. function 7 lca vs skunk 2 lca
  191. skunk2 lca for a eg
  192. Trusted wheel spacer vendor?
  193. Spoon Brakes replacement pads/rotors/clicking issue
  194. DC2: ABS delete without using a proportioning valve?
  195. Good suspension for COMFORTABLE lowered daily driving
  196. $550 to replace one rta?! =(
  197. do I need a 40/40 prop valve?
  198. Whats the smallest diameter/ softest Front swaybar for 99-00 Civic SI
  199. 98 to 95 spindle swap ????????
  200. Buddy Club N+ Adjuster Broke...
  201. Caster issue on a EJ2
  202. rear lower control arm question
  203. .Ground Control w/ KYB Shocks
  204. ground control top hats
  205. annoying camber problem, bought camber kit still too much..
  206. How to go lower....EF questions.....
  207. ground control on skunks
  208. NA1 NSX caliper rebuild
  209. Suspension Problem
  210. Need help removing dust covers on stock shocks to access bump stops
  211. EDM EP3 Spindles on my EJ9?
  212. Pic Apex coilovers
  213. Do I need another alignment?
  214. koni/ground control vs tein basics
  215. Suspension problem.. help!!
  216. EG progress coilovers testimonials?
  217. Has anyone running PIC selects ran into this issue ?
  218. Good Coilovers?
  219. ITR 5 lug swap +koni & eibach !need help!
  220. tas auto cb7 ex accord rear brake conversion on a 94 cd4 ex acccord
  221. Car pulls left when acelling and moves right when decelling
  222. help new wheels r rubbin
  223. shorter EF shocks on EG
  224. HELP! F@#$%ED up wheel jerking
  225. tein S.tech springs on a 93-95 coupe
  226. help identify these dropzones....searched!
  227. Omnipower coilovers for EF fit on EK?
  228. trailing arm bushings
  229. wats a good dd coilover for eg bubble
  230. 03 RSX Suggestions
  231. Hawk HPS, I don't think this is normal
  232. Stripped Upper Control Arm Bolt Doing Camber (Washer) Adjustment 96-00
  233. gsr front sway bar on eg .too stiff or not
  234. endlink problem
  235. Will 90-93 integra coilovers work on a 96-00 civic
  236. cheap lca's worth it who has used them?
  237. J-Series Guys -Front Spring Rate Question?
  238. Weird Coilover Problem. Rides like crap and knocks.
  239. Alignment question (toe)
  240. EM1 sway bar bushings advice
  241. Braided Brake Lines for 96 Spec JDM ITR Conversion
  242. koni shock leak
  243. need help from ppl with experience on koni/gc suspension (front+rear hitting hard)
  244. Thumping noise front wheel
  245. pads/rotor replacement problem. What happened?
  246. Product WARNING: Do not do this to your Function7 arms!
  247. My Breaks Are Not Working Help Please
  248. control arms and mis
  249. will mid nineties coilovers fit on a 90 civic dx
  250. integra rear trailing arm bearings and bushings
