View Full Version : Suspension & Brakes
- want to upgrade coilovers, to KONI Yellow/xx coils
- CTR 5-lug Conversion vs. ITR 5-lug Conversion??
- Will I Still Be able to fit my 10lb NOS Bottle with a 4 point rear strut Bar?????
- which one...agx or gr2 for h&r sport spring??
- Neuspeed or H&R springs?
- KYB AGX vs. Tokico Illumina
- 94-00 Teg or 92-95 Civic Coilovers on Em1?
- I help need with parts
- buddy club spec 2 exhuast on a ef with b20 vtec???
- How do you further compress the spring on a GC coilover setup?
- Coilover setup
- CRX camber kits
- type r rear hub with 4lug lca?
- ASR reinforcement brace and CTR sway will it work?
- 5th gen Prelude owners with Tein SS
- LCA's and Bushings Q
- Lowering Spring Ideas?
- Lowering Springs question
- rear disc on eg6 install
- Brake question: Hawk HPS vs. HP+
- What are the spring rates and dampening rates on these......
- ball joints from a 97 gsr
- ground controls on stock struts?
- Tire Sizing with Traction Bars???
- Weight Transfer
- Function & Form coilover
- The Mystery of Double-Adjustable Dampers
- what else is a good upgrade for stability??
- H&R sport springs
- susension shops in new jersey?
- Revalving coilovers -- Manufacturer says Xkg's, but have you tried heavier?
- sway bar help please
- Koni/GC - Bilstein B16 PSS9 - Zeal Function X
- shocks/struts
- Using cut bumpstops for stock suspension setup...
- Best drag coilovers or spring/shock combo?
- SEARCHED: Another Tein SS VS. GC/Koni...NOT satisfied w/ SS
- what cusco coilover are these? with pics
- Anyone have a review/opinion of the buddy club N+?
- Positive rear camber problem (Searched)
- is this a good combo: tokico illumina with h&r race spring??
- looking for setup help
- shock bolts frozen
- konig Yellow adjustables/Neuspeed yellow springs or Omnipower Coilovers?
- Tein Flex or Tein SS or illuminas/stech
- integra DC2 front sway onto civic EK?
- Pic Request: Rear Sway bar on EK
- JIC MAGIC FLTA2??? top rated?
- Best Quality and bang for the bucks Full Coilovers?
- Megan Coilovers? and OBX LSD?! Junk or Worth it?
- D2 Coilovers + LCA = Bouncy ride ??
- ITR front springs, SI rear springs.. should i change the rears?
- H-Brace or Frt Stabilizer Bar SAME??
- My Konis are leaking at the adjusting pin....
- weapon r ciruit pro coilovers
- Suspension Advice needed
- KYB AGX bottoming out( WHY?) at highest damper setting.
- ASR Brace with 22mm rear Sway bar, and Greddy Evo exhaust?
- what is your favorite set of coilovers for DD DC2?
- tire hit traction bar when turn hard, any suggestion?
- Ride sucks now...what is a good ride/nice drop?
- Springs question
- Quick Suspension ?
- GSR rear sway bar onto a 96-00 civic... will it fit?
- How to tell what spring rates...GC's
- apexi WS coilover question
- My Ground Control/Koni Setup
- Whats the differences
- Type R Shocks?
- anyone has any experience with the NEX coilover system on their 5th gen!?!?
- Skunk2 Camber Kit Question
- How to fix positive camber ?
- What stock parts do i need for new shocks/springs
- apexi world sport coilovers
- Switching Spring Rates without Revalving Shocks?
- DA suspension question
- Suspension Questions
- Best Coilovers?
- Keep my springs and get rid of wheel gap?
- Installed traction bars and now i have an alignment question...
- 99 SI suspension, searched and read a lot.
- where can i buy this???
- i hit a curb today
- Suspension on my crx
- crown nut keeps slipping!!
- Neuspeed sport springs
- D2 coilover ?
- Suspension Settings for EF
- Any east coast 4x114 jdm suppliers?
- Question about sway bar
- omni power. How to adjust? HELp!
- GC and tokico blues. help
- Shocks
- used
- tokico illuminas and ?? springs
- Tried search, Koni Yellow perch specs
- chassis question
- tein basic or skunk2 coilover
- what's a good shock and spring combo for under $500??
- Tokico Illumina adjustable dials
- Question about koni yellows, integra rear control arms, beaks kit rear sway bar
- noob question?
- DA/DC suspension
- koni/gc adjustability ?
- goodridge brake line kit on 92 civic with 99 civic rear disc
- 94 hatch w/tokico blues--whats the allen/nut at the top??
- Motor Support Bar...?
- My Tokico Blues and Tenzo coilovers Review
- Brembro Rotors and Hawk Brake Pads
- Skunk 2 coilovers on a Del Sol?
- will these fit my car?
- koni yellow perch question
- apexi n1 ride hieght
- eg = da suspension?
- Has Anyone....
- 88 hf crx suspension
- NEED HELP ON SUSPENSION
- Stock S2000 suspension VS Koni/GC Integra
- What Coilover setup For my DB8 5lug gsr ?suggestions ?
- Front wheel bearings- which side out?
- 5 lug conversion on my ek
- password jdm 4pt rear strut brace for DC integra
- HKS Hiper Max 2 vs. Cusco Zero 2 vs. Tein Flex. Pros and Cons please :)
- Will a DC Integra suspension set-up work on EG?
- New Rear Toe Link or LCA: Help me Decide
- repairable?
- Lower Arm Bar
- 98-02 Accord V6 Front & Rear Camber Kit!
- Bent the so-called "Rear K-frame"
- rear strut question
- Eibachs/camber/17s
- how to remove a "ring" in the knuckle and ball joint
- anyone know where i can go to in OC to get my axel rebuilt or replaced?
- i stuck it to the man and bought something different
- Wheel Alignment & Steering wheel Alignment
- kyb gr2 + H&R springs = good ride?
- bilstein sport..
- eg suspension set up
- Is the KYB GR-2 struts any good?
- QUEStion
- Steering slop. Tie-Rod related?
- Megan Racing Street Coilovers
- EG Suspension ?s
- help picking out springs
- Eibach Pro-System for AutoX/Track Days
- Tein Coilover Overhaul
- struts/coilovers installation help?
- fastbrakes itr brake conversion=wrong directions
- ball joint is bad....new upp control arm needed?!?!?!
- suspension help
- Front Spindle Replacement
- different end links for em1
- Washer Trick ..LINK...
- Koni Sports Stock Stiff
- Integra brakes on an EH, Camber??
- Installing springs on 04 civic
- Shortening Koni Sports
- 88-95 Civic lower control arm bushing size?
- Koni yellows - Is there are different types?
- Subframe tear-out question
- are Tein STECH Spring any good
- suspension
- Physics Lesson
- koni g/c, agx g/c, agx neuspeed??
- is it bad ...
- Skunk2s and Tokico Illumina Question.
- 92 cx camber adjustment?
- positve tire wear?
- just wondering about strut bar compatability...
- Rear Swaybar Mounting?
- EF9'ers Poll
- Online Cambe Kit Purchase
- N+
- Suspension Emergency! Rear extremely low to ground....
- what spring rates are good for h22 in a dc
- buddy club n+
- OEM Shocks/Springs
- Clanking from top of rear coilover.
- Suspension set-up
- Info: Front Camber Kit for eg
- Rear Toe Can't Get To Spec
- what to install and not to install for 92 civic ENERGY SUSPENSION??
- kyb agx with H&R sport spring riding rough?
- Where to get Prothane D brackets/bushings for ITR rear bar?
- carbing 3pt. strut bar for eg..
- Break help
- skunk2 pro s full coilovers, ur opinion?
- What Zeals do i have?? *PIC*
- will stock shocks fit with lowering skunk2 springs
- Camber Issues
- Pic Request. Comptech sway/tie with itr LCAs. Integra DC2
- cheap place to buy KYB shocks ?
- Do you prefer Even drop or Angled drop??
- poss noob question
- keep the arospeeds, or buy ground control?
- Skunk2 Pro S Full Coilovers???
- Full rear disc swap on EK hatch?
- are ground control coilovers year specific?
- H-Bar>>>any one with Feedback on it?
- suspension problem: uneven suspension height
- Correct order of washers on suspension?
- MT 235/60/15 fitment on a Civic
- I've exercised the demons...
- Binding axles?
- shock travel
- Cost for Springs Installation
- Koni Yellows & Ground Controls during WINTER
- Anyone know the bolt size to get for washer trick to fix camber?
- Apexi Suspensio n1 pro dampers
- 4th gen prelude suspension tune-up help
- Between these 2 which should I get #1 or #2?????????????????????????????
- k sports??? input needed.
- rear trailing arm bushing replacemenet?
- Lining up suspension top hats? Resetting bushings? and some other questions.
- fender and wheel clearance
- Coil Over Question
- Negative caster? Alignment sheet inside
- Why we hate certain new coilovers that have become popular...
- Sway bar brackets
- dust sheild needed?
- JDM ITR 23mm sway bar question
- Rear Spring Stiffer/Harder than Front Spring?
- Koni Orange shocks
- Question about sway bars for my 99 SI.
- just wonderin
- Camber Kit adjustment.
- tie rod adjustment
- UCA and LCAs for a DA (90-93 Teg)
- buddyclub not JDM anymore?
- Fpb Em1 Si Kyb AGX Settings!
- Suspension Techniques SPPED TECH SPRINGS Q's
- need tech
- Keep the Ground Controls or go with Tein s-techs??
- How are the Skunk2 LCAs?
- Ground controls w/ worn washers and bumps...
- My alignment doesn't look right - *PICS of PRINTOUT*
- Sway Bar worth it with Eibach Pro Kit?
- Suspension recomendations for an ED9
- suspension noise from lowering
- Springs or coilovers?
- BRAKE UPGRADE 94 CX
- can i lower my sh without screwing it up?
- Ohlin''s Type R full susp. 24 way adjustable (with helper spring)
- Finally decided on getting the Koni/GC set-up
- Half Shaft Issue - Searched
- how low an an EG/EH??
- Which one? Struts, Bushings, Shocks, Mounts?
- omni power
