PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. oem tophat difference in model years?
  2. Suspension/Wheel Advice Needed
  3. D2 for DC2
  4. One small 5 lug question
  5. EG upper control arms?
  6. Swaybar preload
  7. h-techs vs s-techs
  8. Neuspeed STB and Tein SS-P Coilovers
  9. eg koni's on ek??
  10. ITR shocks/tein springs, on a eg
  11. Skunk2 Pro-C coilover kit
  12. What Koni shocks do I have? I have NEVER seen these!
  13. Is Ground Control and Koni or tokico good for daily driver,help!
  14. lowering springs?
  15. What to look for when buying used koni's??
  16. coilover question
  17. Harsh vibration turning right.
  18. Need help on selecting a good shock and strut kit!
  19. Tein ss Damper kit For my dc ????
  20. HELP!!! correct camber honda accord 96
  21. Civic Tie-Rod replacement suggestions
  22. Lowering Springs Bump Stop Q
  23. Will your brakes break?
  24. skunk2 pro-s spring question for 92-95 civic
  25. godspeed coilovers ???
  26. HELP! Uneven tirewear even after alignment!
  27. NEED HELP FOR DA LCA's
  28. Very unstable EJ8?
  29. How to get the best smooth ride?
  30. what suspension should i get for my 2008 Civic Sedan?
  31. i'm a noob!! need help with my EK
  32. 3 Questions- Help?
  33. steering issue(hard steering etc)
  34. 92-95 coilovers on 96-00
  35. Brembo blanks vs Powerstop dimpled and slotted
  36. skunk 2 pro s questions......
  37. Daily driver...Does toe/camber really matter?
  38. Stiffer springs with stock ride height, can it be done? What spring rates to choose?
  39. traction bar settings
  40. what to check (buying used)
  41. bent subframe need some help
  42. Help Needed
  43. want to add sway bar to civic...what parts do i need???
  44. help on Ek 98 hatch
  45. Front lower tie bar
  46. ? asr sway / subframe brace kit w function7 lcas ... endlink questionq
  47. rear shim kit
  48. Ground Control Spring/Sleeve Combo - Part #'s
  49. break upgrades
  50. Do I need a camber kit for the wheel setup I want?
  51. I've never seen this camber kit before... Any good?
  52. Acura RSX Suspension Install HELP - Koni Yellows and Ground Controls ( searched )
  53. asr brace and suspension techniques swaybar
  54. rear subframe replacement
  55. DC2 suspension on an EM1
  56. who are the main eibach distributors on this site?
  57. GC Coilovers Tokico Blues to Koni
  58. 01-05 EM2 QUICK question on coil overs
  59. 92-95 Civic vs. 90-01 Integra Camber kit
  60. Front subframe reinforcement?
  61. GC and Koni Yellows
  62. Quick Question about D2 Coilovers
  63. Need Help Picking Out GC's For EM1 Please
  64. HELP!!! H&R springs way too low!!!!!!
  65. SQUEAKY NOISE COMING FROM FRONT SHOCKS
  66. 00 Civic Tein S-tech lowering springs
  67. aftermarket struts... help!
  68. Suspension Setup on my dc2
  69. I just got my Tein Flex in and my EDFC unit for the fronts says an EE
  70. What kind of shocks?
  71. Eibach Helper springs: Size for GC-Koni setup and anything else needed?
  72. koni yellow with cut stock springs
  73. Inner tie rod problems
  74. Kyb Agx For DA Rear
  75. d2 coilovers?
  76. Do I need to change brake booster after rear disc brake convertion?
  77. Best place to buy swaybar with 2 day shipping
  78. Opinions On Weapon R X Brace
  79. function form type 2 sqeaky springs?
  80. 2003 Civic Ex- Rate your coilovers! Price, Performance, rideability!
  81. TEIN SS heavier spring rates ??? Where to get
  82. Done my research, anything else but Tein Basics?
  83. rear disk conversion problem
  84. suspension problem
  85. ride height; where to measure???
  86. What Springs a Struts?
  87. Tein Coilover install....what about camber kit?
  88. thicker sway bar questions
  89. 91 civic fork
  90. Front Suspension Clunking
  91. Installed coil-overs car feels unstable
  92. tein s tech
  93. rear disk conversion problem
  94. Suspension Setup
  95. Lowering 2000 Honda CV-R (Need Some Help)
  96. civic coupe front suspension options
  97. Sprint Coilover sleeves? How do these install?
  98. my ground control are JAMMED (pics)
  99. Stock spring/ Aftermarket struts
  100. mugen strut bar? real or fake?
  101. bent Avid traction bars?
  102. Power Steering??? Not sure if in right section
  103. how much will i gain with sway bars?
  104. NEED HELP? SKUNK 2 PRO-C
  105. KYB AGX vs. tolico illumina
  106. grade of rear lca bolts
  107. Good suspension setup for EK
  108. NSX Caliper on 11" rotor clear a 15" rota rim?
  109. ITR LCAs on EG, what shocks am I limited to?
  110. what suspension for 90 crx?
  111. 96 rally car project
  112. Skunk2 Sport shocks and lowering springs
  113. Coilover Options
  114. Is it really a must to get an alignment after lowering a car?
  115. How much dampening for koni's with Ground-controls ?
  116. What's going on here? Problem?
  117. GC Coils
  118. Which coilovers for 08 TSX?
  119. I'm a trial user and I need some si wheels!!!!!
  120. ok i have stock suspension but i wanna lower my car..but....
  121. Aftermarket Suspension for an 88' Crx
  122. aftermarket or oem rear lca's
  123. How to add rear neg. camber?
  124. 96-00 civic steering rack replacement
  125. lowering and better handling
  126. Rlca bolts
  127. Chassis bracing questions; sharing loads and increasing understeer?
  128. Question about non GC Konis, getting race prepped and working w/ GC's; 92 Prelude
  129. Upper rear strut bar.........suggest one
  130. Benen question
  131. Does anyone use Buddy Club coilovers?
  132. Best Suspension For the EF Chassis Poll!!
  133. EK lca's and coilovers on EJ
  134. Help! with installing DC2 rear sway on EG6
  135. Camber off on stock suspension?????
  136. EM Racing measurements
  137. Quick Question! Installing Koni red and need some help!
  138. DD suspension set up 95 civic ex
  139. Tein Mono Flex and more....
  140. Question: Installing GC coilovers on KYB AGX
  141. Any tips on how to secure a rear endlink nut?
  142. How do you read spring rates on GC coils?
  143. 22mm rear sway bar w/ no front sway bar
  144. Skunk2 LCAs Bushings Replacement..
  145. How do I adjust my coilovers.
  146. crossmember/steering rack bracing...
  147. power steering fluid leaking please help
  148. eibach pro kit/SPRINGS
  149. Skunk2 Pro S Coilover: Strange Question
  150. suggestions on a suspension set up for a 91 crx hf?
  151. Interchangeable suspension parts for crx
  152. DA traction bar problem
  153. Help me choose the "right" suspension for my 99 cl'
  154. 99 ex pro-kit and pro damper
  155. GroundControl | Top Hats | Camberplate | Questions | 06' RSX
  156. lowering springs
  157. koni yellows/ ground control. locking nuts fell off while driving
  158. taking off the rear shock/spring assembly...
  159. Clunking sound on my axles...98 civic...
  160. lowered in winter
  161. Trouble installing suspension. Need some help...
  162. suspension ?'s
  163. Omni power on h22 civic (EG)
  164. Good street setup...shock stiffness?
  165. ground controls question
  166. eg chassis full coilovers fit on ek chassis?
  167. xtended top hats
  168. Koni Yellow Ground Control for CRX writeup?
  169. Recommendations to buying OE suspension parts...
  170. Suspension question
  171. ASR 24mm rear sway bar kit for DC2 ITR...
  172. Question about suspension
  173. Strut adjusting
  174. Front brake shake after new pads/rotors all around - '95 Civic VX
  175. bushing kits
  176. rear alignment problem
  177. Strut Bars
  178. eibach pro street s coilover kit vs H&R street coilover kit
  179. Ground controls spring rates on right??
  180. ?????REAR Struts with Kens Customs Spindle mount ??????
  181. Couple suggestions needed
  182. Suppension help...
  183. Does ASR Subframe brace work with Function7 rear control arms?
  184. Caster
  185. Alignment Question
  186. KONIS WITH GROUND CONTROL HELP???
  187. ef suspension help?
  188. Changing Front Swaybar: Alignment Req'd After?
  189. spring rates!
  190. I have skunk2 adj. springs on stock struts, after 20k mi, are the springs....
  191. T1R B-MAX Coilovers
  192. Coilover Set Ups? What To Get?
  193. integra wheel bearing issue, new bearing is too small
  194. lifetime warranty coilovers/spring and strut combo
  195. the infamous koni GC questions..
  196. High Performance Outlet - Tein?
  197. Camber issues
  198. ITR front sway on a 99 EK hatch?
  199. teins for an EK on a DC?
  200. 00 Integra w/Koni Yellows and ITR springs --> Passenger side sits higher thatn Driver side, WHY?
  201. integra suspension question?????
  202. CIVIC LCA'S AND COILOVERS. HELP****
  203. Koni Yellows; will they fit from a 94 civic Si Hatch to a 99 integra GS Coupe
  204. bumper stopper???
  205. tire rub questions
  206. A headache shock install....
  207. quick ? for you sespension guru's
  208. PIC discount
  209. Autocross Suspension for my B20 Integra?
  210. Strut adjustment for bigger Rims & Tires.
  211. low eg
  212. Checking VIN's against cars... need some help
  213. Need a Camber for TEIN S.TECH in an EG?
  214. FUNCTION AND FORM
  215. Installed 2.5" Sprint drop Springs only to have my car lifted to stock hieght. PLEASE HELP!!! ( I HA
  216. asr + beaks lower tie bar?
  217. [DC2R] GC + KONI Yellow, Spring Rates?
  218. Need help with my wheel bearings?
  219. coilover fitment?
  220. Spoon/Showa N1 coilover questions, etc.
  221. Considering which suspension
  222. Passenger side suspension shaking after 5lug installation
  223. TEIN SS+EDFC
  224. [Help] What are the best COILOVERS for stock crx struts
  225. how to install gc's with koni yellows??
  226. Thoughts on H&R Race Springs???
  227. Stuck Coilover Sleeve...
  228. knocking front right
  229. Help me drop my car!
  230. Lower spring question
  231. damaged frame affecting alignment?
  232. HELP accord car uneven!!! left side is 1inch higher than rigth!!!!
  233. New Alignment Spec.
  234. adjustable coilovers
  235. Lowering springs
  236. UCA Ball joints not removable?
  237. Is this a bad wheel bearing?
  238. looking for coilovers
  239. GSR suspension on EG hatch (Bushing ?)
  240. whats SAI on alignment sheet?
  241. Pics included, which oem parts are needed for a koni/gc install???
  242. Koni Suspension setup.. sucks.. or just my car?
  243. taking off ground control sleeves
  244. lower rear control arm bushings
  245. Energy Suspension Civic/Integra Q
  246. 90-93 teg coils on my 94 teg?
  247. God awful suspension squeak, Koni/GC setup, please help
  248. Neuspeed softsport spring & kyb gr2 or agx....please advise
  249. Alignment Question
  250. suspension question
