PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 [98] 99
  1. Coilover Question?
  2. measuring height of car?
  3. ingalls engine torque damper
  4. suspension for eg hatch
  5. Tein S Tech
  6. Cup Kit?
  7. steering has a lil play after extended stud install
  8. 5 Lug Conversion Trouble
  9. How's the D2 Racing Coilover?
  10. does anyone here have Tein RAs on their daily driver?
  11. *HELP* Integra Suspension Problem
  12. omni coilovers/Koni Shocks
  13. optimum suspension settings for EK (HB) Civic
  14. Omni Power Rear LCAs installed
  15. 91 honda civic struts
  16. best tire for 15" wheel
  17. Putting H&R sport springs on the koni RSK kit
  18. what exactly is toe?
  19. Does Carbing make a rear lower tie bar for the 99-00 Civic?
  20. my suspension question....
  21. Koni RSK Suspension kit
  22. 300 for daily beater?
  23. Adjusting the locking perch on a fullcoilover
  24. Suspension question?
  25. Best 225/35/18 tire?
  26. spring rates of OEM springs
  27. Hub fits question
  28. 92 Civic Rear Wheel Bearings!
  29. Hard rubber VS. Poly bushings
  30. Swaybar tuning dynamics..confused....!
  31. Pick a coil over kit!
  32. Omni power ball joint...what thread for castle nut???
  33. I'm hoping someone can help my EF/ 5-lug suspension woe's.....
  34. i got the power i want...not the suspension
  35. RSX 5 Lug Suspension on EK, will it work??
  36. Civic Brakes
  37. Spring rates
  38. Koni Sport Kit Review - 2000 GSR
  39. How much for labor to change strut/shock on rear 2 / all 4?
  40. wheel hubs
  41. Help with preload on Omni coilovers
  42. tein springs on tokico blues
  43. NO WARRANTY from Koni with X Brand Coilover....
  44. Progress Technology
  45. spring height
  46. is there something wrong
  47. Mugen EP3/DC5 Aluminum LCA's on an EM2? & tire clearence question!
  48. Braking question....
  49. whats the best strut
  50. what springs to go with 99si w/18s
  51. tokico non adjustable hp series
  52. How do I fix my offset ?
  53. Tokico Blue longevity
  54. omnipower full coilovers out for DAs now?? got ?s
  55. spring choice for del sol???
  56. ne kfd rx7 help
  57. dropzone shocks/struts
  58. Question about camber kits??
  59. H&R OEM's
  60. Sway Bars or adjustible shocks?
  61. lowering question
  62. Crx lateral force specs? braking specs? JDM and US anyone?
  63. Skunk2 Full Coil-overs
  64. pix of coilover install NICE!
  65. my front drivers side sits lower than the passenger
  66. Koni perch sleeves vs Ground controls
  67. Advantage of running more front spring
  68. Cheapest Place to find Teins
  69. WTB Springs
  70. Skunk2 Springs
  71. ok i think i found my setup
  72. FRONT aftermarket LCA's for EK
  73. ****MY JIC story****
  74. omni heigh adj. problems
  75. Modifying a gsr manifold to fit a b16
  76. Suspension upgrade
  77. H&R race vs. Eibach sportlines
  78. problem!!!
  79. Spring Advantage
  80. Rear right noise on the car, I am lost. Please enlighten me.
  81. one last question before alignment..
  82. any good places online to order bump stops for 4th gen prelude?
  83. bushings?
  84. SanDiego HT Heads: What's Best Place for Alignment
  85. 5th Gen Prelude Question
  86. Reduced/No front sway bar
  87. swapped hatch - which springs?
  88. few questions about suspension setup(h&r sport, kyb agx, and top hats)
  89. Effects of Toe "IN" alignment settings
  90. Apexi N1 Type Pro Coilovers on a daily driver?
  91. Password JDM Strut Tower Bars
  92. Problem with new suspension setup
  93. KYB strutc/shocks
  94. Camber Kit, or alignment?
  95. spring ques.
  96. NEED HELP WITH CONTROL ARM
  97. Any used these KONI shocks before?
  98. How do i know if i have compressed the spring enough?
  99. Progress Competition Coil Over Reveiw for EM2 civic
  100. CTR/usdm ITR 5 lug question
  101. Turn wheel and get a squeaking, help please :)
  102. TEINS or JIC
  103. omnipower coilovers
  104. need to replace cv boot for alignment??
  105. What does 10k or K=?
  106. Camber settings?
  107. Alignment for lowered vehicles
  108. What's the best Website(www.?) To get suspesion parts?
  109. Acura RSX 5 Lug on EG Civic? Is it possible???
  110. Best Coilover Suspension
  111. Lowering my swap
  112. Sorry agian peeps but does this actually work?
  113. EF springs/shocks on EK
  114. replacing bolts
  115. the best suspension i can purchase for my eg hatch
  116. Cusco Coilovers on an EM1
  117. BIG strut problem
  118. front passenger tire wearing out more
  119. 96 spec ITR LCAs
  120. Does a DC2 Momo Hub fit an EG?
  121. Megan Coilovers.... Ebay Coilovers
  122. How do you all you guys measure the ride drop with GC's?
  123. Skunk2 coilover springs really DO suck.
  124. tool for racing hart rim ?
  125. Omnipower coilover owners
  126. Difference in Suspensions from 96 Hatch DX and Hatch CX???
  127. Tsudo Ground Command coilovers
  128. Diagnosis for suspension after accident
  129. help w/ omnipower coilover install
  130. Can the stock spring be decompress whil its still attached to the car?
  131. spring rates + tire size = tolerable? and other ponderings...
  132. look out for this
  133. Energy bushings how to questions
  134. Better summer street tire: Yokohama AVS ES100 or Dunlop FM901
  135. camber kit adj. ???
  136. medium strength swaybar options!??
  137. Apexi N1 Pro Coil Overs
  138. Reducing bodyroll
  139. strut bar questions
  140. help greatlyblade style swaybars??
  141. uneven ride height??
  142. car pulling to the left<<
  143. Preloading Omnipower Coilovers?
  144. Adjustable koni perches?
  145. Damper setting for less oversteer?
  146. What springs?
  147. 87 crx
  148. Raising the car?
  149. Spring Rates w/ 26mm Mugen sway
  150. where to buy?
  151. Does anyone want to start a suspension chart?
  152. Eibach Pro-Street Suspension (NOT GC's)
  153. Suspension choice question....
  154. HARD TIME CHOOSING LOWERING SPRINGS
  155. prelude type-s Strut bar
  156. Anyone have the Weapon R rear strut brace?
  157. Advice wanted . . . . rear anti-sway bar and no front?
  158. rough draft of my set up
  159. Where to rebuild Zeil B6?
  160. Skunk2 Pro Series Coilovers:thumbup:
  161. Omnipower - Marketing to the retards
  162. 88 camber kit help
  163. eibach springs
  164. May be a silly question-trailer hitches
  165. DIY [How-To]: Civic Type R brakes/suspension onto 96-00 Civic. ( CTR , 5-lug
  166. traction bar vs frame locks
  167. Preloading omnipowers
  168. Cars away for winter but....???
  169. How to read h&r springs
  170. lower ride height increases the - camber. What happens to toe?
  171. please,need suspension help before i kill my self
  172. SpeedTech competition swaybar/rear tie brace install *long*
  173. Type R swap on a Civic.
  174. Car hit on the curb – Rear upper & lower control Arms, Trailing arms bent – Aftermarket options fo
  175. H&R Coilovers and NEX Coilovers
  176. 4 lug to 5 lug civic
  177. does anyone have pics or diagram of itr sus. swap
  178. Koni Yellow snap ring failure.
  179. questions about my setup for my EK
  180. del sol front/rear sway bar ques???
  181. Settings for KYB AGX struts??
  182. Question for those with camber kits
  183. Tie Rods
  184. Hey...can we talk about tires in here???
  185. Drag suspension shock function
  186. omni power coilovers how they ride?
  187. Aligncraft Camber Kit?!?
  188. airbag suspension
  189. Tein HA on DC5, having a problem.
  190. Ground control coilovers vs skunk 2 coilovers
  191. Cusco Coilovers...
  192. JDM type R suspension swap problems
  193. Cheap, but decent setup?
  194. SPRING COMPRESSOR HELP..
  195. Traction Bars for DA....FR or Z10 pics
  196. Will 02 type s Eibach Coil over fit on my (98ek civic)?
  197. D2 coilovers....D2 is too small to search
  198. Skunk 2 Race coilover
  199. Removal of Broken Rear Damper Bolt
  200. 5 lug conversion !!!!!!Need Help!!!!!! Please list all parts needed
  201. but i'm lower than 1.5"
  202. rear shock installation
  203. Best handling = softest spring rate as possible
  204. JIC coilover
  205. shocks for H&R springs
  206. Crazy Question... ITR rear subframe VS. 97 CX subframe
  207. Koni Yellow SP3 stock perch location?
  208. oem bushings
  209. itr rear sway bars
  210. camber kit question
  211. question on sway bars?
  212. Just a quick Question.
  213. Looking to improve cornering a bit...
  214. removing top nut on tein ss
  215. 93 honda accord camber issue
  216. Thinnest 205 series tires!
  217. sway bar hardware source?
  218. HR Sports-Kyb Agx?
  219. Help preloading my omnipower coilovers (wrx)
  220. QUestion on Ground Control Coilovers
  221. daily drive shock/spring setup
  222. Shocks and height?
  223. Anyone find Teins rough???
  224. brake ?? for eg with 15" wheels
  225. CRX ride height
  226. Koni Adaptor for GroundControl setup
  227. Anyone have a diagram on how r1 coilovers are assembled?
  228. tein type s springs
  229. Rear wheel bearing removal
  230. under brace
  231. Old Ground Control coilovers...need help with spring rates
  232. TEIN camber plate compatibility with Progress Coilovers? EP3
  233. spring rate ques.
  234. Koni Threaded Suspension Kits.
  235. 92-95 Civic leans/lower on driver side.
  236. My Omni Sport Writeup
  237. adjustable sway bars and preload
  238. Lowering prelude with 17's
  239. PLEASE HELP ASAP! 16x8 +42
  240. Suspenion debate (my setup)
  241. what's the best camber kit?
  242. Stock swaybars... hollow or solid??
  243. eibach sportline
  244. strut bar better in compression or tension?
  245. Anyone use Newspeed race springs on an EF?
  246. suspension coilovers
  247. Car low and very bouncy - What kind of susp....
  248. OMNI coilover ride quality description from everyone that has them.
  249. Track guys what spring rates?
  250. Beaks kit
