View Full Version : Suspension & Brakes
- koni yellow question
- what would be the perfect suspension for a 91 crx
- Sprung weight to suspension softness/stiffness rates
- EM1 Civic Si... Lowering questions
- Oil leaking from top of Koni shocks
- Spring Rates and Damper Adjustabilty Question.... help please
- Help Me Plz
- Are GSR and LS rear LCAS the same????
- used omnipower full coilovers
- Teins not available for 88 EFs?
- Yellow's questions
- How To: Replace Rear Trailing Arm Bushing- Cool Tool I found Saves Allot of time
- SI swaybar help!!! (endlink)
- Koni/GC question...
- stock G3 integra ride height?
- typer R nuespeed springs
- best suspension set up for drag
- Swaybars on a EK?
- Adjusting indicators on shocks broken.. how to tell setting?
- RACTIVE SLEEVES WORK WITH EIBACH?
- 4x114 on eg
- Cheap but right way to drop
- Rear springs not being compressed
- Neuspeed?
- stiff suspension
- 94-01 Integra suspension interchangeable with 96-00 Civic???
- Eibach Pro Kit with 2 12" subs
- EDM 6th gen accord Suspension Q
- Who makes tokico springs??
- New Suspension for New Honda Owner
- Looking for a set of Del Sol bars (front and rear) in SoCal
- ?? on front camber kit
- opinions on shock\spring combo
- Are theese decent coilovers?
- best drag supension for my ek
- GSR suspension on a EK?
- Where can i find a del sol rear lower sway bar 1994
- Where to get my spoon n1 coilovers rebuilt?
- megan coilover
- LCA bars on 1992 Integra??
- rear spring rate
- can i use my c piller bar for my harness bar
- Question about Shocks/Struts for 95 EX
- SPC lower control arms
- Swapping my EG suspension and brakes with a integra
- Integra Springs on an SiR
- Sprint Extreme Series Springs (3 1/4" drop)
- skunk2 coilovers... good / bad?
- cutting a coil off H&R Race springs
- > EG suspension < WHAT KIND? DROPZONE? TOKICO?
- lowering/new suspension
- Question about used springs..
- Endlink Bushings Question!!
- Camber wear Tread? Poll.
- Sorry for the newb question, but what parts are these?
- ITR sway bar end-links bolt up to civic control arm?
- Tein S-Techs or H-Techs
- skunkworks sway bar endlinks??
- EM1: Need to remove this bolt to put in coilovers?
- How easy to install...
- Bump stops question....98 civic hatch...
- b20 vtec in a 88 hf crx ???
- which motor mounts should i get HASPORT OR ARIZONA RACE
- Identify Knuckles KR-14
- Need help!!
- air bag suspension questions (its not what you think)
- Front EF shocks vs EG
- Need advice on whether to change back to stock suspension or not on Integra Gen 3
- let me see those carbing bars !!!
- anybody on these?
- Neupeed or RSr
- Tein SS or Flex
- Alignment settings
- problems with ground control extended top mounts
- Need Help. I think Alignment queston
- GC adjusting collars
- help with strut bar
- update: pics of wheel damage :(
- 92-00 Coupe suspension fit 92-95 hatch back
- when do you NEED a camber kit?
- Searched....need some help
- Used Koni - Will They Fit?
- Tein Flex vs. D2
- Is this the ABS line? 94 Integra LS rear disc *1 Pic*
- anyone got these skunk 2 full coilover on there car yet??
- i need help lowering my car HELP A HOMIE!!!
- Koni Race Spec
- forgot about Bump stops....
- Please identify these springs for me....
- suspension on eg
- manual rack for 98 coupe
- Recommendation on lug nuts??
- Suspension Suggestions
- Best Shocks for a EK ?
- anyone heard of infinite auto suspension
- tein flex or buddy club n+ spec for drag racing?
- DA suspension onto a DC? need help
- ebay springs
- $500 to spend on DC spring/shock, get what?
- what do u guys think of BC N+ spec damper???
- GC Top Hat with a prelude?
- What type of front strut is better? CTR or one connected to the tower?
- wil the top ground control mounts (extended travel) work with stock strut bar
- TEIN Super street coilovers ? (EF's)
- Anyone ever heard of NEX suspension?
- Where can I get Whiteline suspension parts?
- thumping sound from rear suspension and shock question
- Rear sway bar with no front sway bar. Dangerous?
- H&R is best paired with what struts?
- Cheap and simple, can H-T do it?
- What kind of a drop can OTS Koni Yellows handle?
- think anyone would trade an exhaust for a set of lowering springs
- tanabe full coilovers
- a link to my other post about a accord coilovers springs....hope someone can answer
- omnipower vs neuspeed/agx
- EG front swaybar?
- susp ? with 25 inch slicks
- What shocks are these I got? GCs? couple big pics
- Omni-Power Drag Setup.>. Who's Running Them
- //Suspension Technique Speedtech sway/tie-bar and my Nutless Subframe!!!///????
- DC2 Teg, Longer Springs Rear? Shoter in Front??
- koni and omni
- Need your Opinions!! Please... wheel stud q?
- Tein S. Techs on Tokico Illumina adj shocks
- help me make choices! please
- need help with suspension planning to buy omni
- H Brace or traction Bar?????
- bumpstop install!?
- Alignment shop in south florida
- New upper a-arms are missing ball joint
- 95 Accord lower rear control arms???
- 88-91 Crx/Civic Skunk2 Full Coilovers ?
- Spring Compressor??
- Brake Cable StopTech
- @@@@ What's wrong with my suspension?????? @@@@
- just installed springs, one lil problem
- Alignment
- Compensator washer bolt missing?! HELP!!!
- Suspension help plzzz
- Will EK Ground Controls work on an 00 Integra?
- Mini Review: Tein H Tech
- Rear toe won't spec.
- eibach pro-system-plus vs Eibach pro-street-S(+eibach sway bar kit F/R)
- best riding suspension
- Best Shocks for H&R OE Sport Springs?
- EG hatch: 98% daily driver, 2% track car, set-up recommendations?
- Rear lower tie bar question [searched]
- goal: to eliminate wheel hop....will this do the trick?
- ITR Suspension Into 2000 Civic SI
- Car feels light and not sturdy enough.
- Will my buddys gsr suspensin fit my si susptension?
- Best Strut 4 Price w/ H&R
- gc/koni or tein super street
- heavy duty springs
- Rear swaybar fitment on EJ chassis... with aftermarket exhaust
- my D2 review:
- if u own a set of tein flex...road race guys help me out!!!
- do the 96-2000 civic front koni yellows fit on a 92-95 civic?
- neuspeed and eibach
- Wheel stud diameter?
- Upper control arms
- What if shocks are over damped?
- cheapest place to buy...
- Chassis brace? Will it work, or just another "perceived" increase?
- koni/GC help
- best sway bars and struts for a honda civic !!!!!!!
- springs or coilovers
- GC coilovers making clunking sounds, help!
- Volks lug nuts cross threaded. Do you know how to tap and die?? fix em?
- Can't raise GC's anymore?
- Shock issue im assuming.
- Ground Control Coilovers 300F 280R
- going to buy koni's, but gonna carry over my old coilovers. baby tubes?
- Switching out wheels. Just got new springs? Need alignment?
- TEG brakes on my wagon and now I have no peddle
- oem bushing set
- spring rate?
- Which Ground Controls should I run w/ Koni adjustables on my CRX?
- suspension question on coil overs progress vs others
- coilovers
- sprint springs
- Spring for Competition use, How do you pick a starting spring rate??
- 94 civic cx Suspension Options
- Quick question about GC Tophats...92-00 civic...?
- KONI YELLOWS
- Shock Question? Bottoming out Blown Shock
- DC Integra Subframe.
- Setting the camber correctly?
- Portable toe alignment machines/tools/kits: your opinion?
- Whats the smoothest ride?
- 97 Accord Suspension Options
- 00 Si lower control? or camber kit?
- Installed H&R Sport springs, now my right rear lookes jacked up...help!!!!
- Trackion bar for UKdm/SIR crx
- Recomandations on 9sec car suspension
- tell me about this dyno?
- Street/Auto-X CRX Setup
- skunk2 camber kit question
- BOUNCE BOUNCE BOUNCE
- GSR Steering Rack in EG Civic - Question
- Best non adjustable shocks for eg civic?
- gsr rear disc conversion...a little play in hub...y?
- weird shaking issue???
- DC5-R brakes on DC2-R?
- drop zone springs
- Ground Contol: Bilstein and ITR ???
- OE springs on 94 accord
- Need someone to install springs for me in Columbia, SC.
- whats the next suspension recommendation
- What grease for sway bushings??
- ball joint/ control arms question ?
- 89 crx si suspension setup help?
- D2 coilovers
- ride height 92 LS
- Energy Suspension vs. Prothane (Bushings)
- Help with Lcon traciont bar PLEASE!!!!
- Looking to install a rear sway on a 95 EX Coupe
- Will my toe be effected by H&R Sport Springs?
- Over 2" drop without rubbing?
- integra upper A arm
- help with rear swaybar/endlinks
- SPC Camber Kit? Anyone heard of em??
- Suspension Help
- what spring with koni yellow
- Alignment and camber are off.
- Question for Koni/Ground-control users.
- steering rack
- fittment
- Advice on a drop
- WIll ground control coilovers for ITR Koni Yellows fit Koni's for EH2?
- TIEN suspension owners HELP :(
- Running 16s on sport springs?? Rubbing issues?
- alignment specs, hooray for bent lca!!!
- ebay springs
- Fightex or buddyclub
- Ground Control koni yellow baby sleeves cost?
- What NOT to do when installing Konis (Idiot warning)-
- I have crappy ebay coilovers and have a question.
- EK suspension into EG
- No drill Direct Bolt On
- Going to the Shock Dyno...
- Camber kit with H&R Sport Springs?
- Ratteling in rear
- Sway bar suggestions
- Clunk...Clunk!!!
- camber kit needed?
- designing subframe reinforcement for EK
- Rear disc Conversion - 95 EG coupe
- Stock suspension ?
