View Full Version : Suspension & Brakes
- BWR swaybar brace for an EG
- skunk2 lowering springs
- need some guidance on a full suspension kit for my civic
- what are these brake pads for?
- Acura Integra Suspension Noise
- Tricks for compressing springs???
- Question about clocking RTA bearings
- Buddy Club N+ Coilovers
- emusa coilovers anyone using them
- EJ8 rear drum to brake disc upgrade
- What does the V Spings suppose to do?
- Brake caliper bolt torque specs '09 Accord
- progress coilovers cs2
- Brake line flaring
- suspension question ! need help
- Is there a quick way of seeing if shocks are good??
- no pressure in the brake pedal
- EK coupe too much oversteer
- High Pitch Squeaky Noise....Please Identify
- Need help/ IDEAs..
- help with bushing replacements
- Self Adjusters - Long Story Start reading at LONG STORY SHORT if in a hurry
- Are YOU running Megan Racing Coil-overs???
- How low on stock suspension? :o
- Tokico Illumina issue
- Question about lowering my 96 Civic Coupe
- Question regarding compliance bushings
- Bump Stop question
- Which full coilover drops the lowest?
- Spacers ?
- My E-brake feels like it still engages
- brakes, pedal feel, and upgrades
- Air Bubbles
- What Brand Chassis Braces are These?
- Help with GC spring rates
- Installation help
- 96 Accord LX Rear Trailing Arms
- CRX suspension fit EG?
- Lowering suggestions on 98 4door
- What are all the parts that are highly recommend when dopping a car on coiloverso
- Lowering springs ON coilovers?
- Putting on a rear sway bar onto a 99 Civic coupe, what do I need?
- koni/ground control questions
- Sway Bars: Thicker=Better?
- Will CR-V coilovers fit Del Sol
- tips for suspension installment
- Alignment issue
- Right front side locking up
- clunking noise upon braking for the first time?
- Opinion for my strut choice for sedan
- h22 ej1, dont wanna drop, what springs?
- got a prob with my flex coilovers install on teggy
- Suspension advice for 95 coupe (ej1)
- yokana coilovers
- Suspension tuning
- Recommendations on suspension
- steering wheel locks up to the left or right after allignment
- blox rear toe kit
- Uneven droop
- 98 hatch spring rates
- blox and skunk2 ball joint replacements?
- eg/dc struts on da problem
- will oem honda 15" wheels fit the type r front caliper
- skunk2 519-05-1650 lowering springs how works??
- Tein S-Tech Springs on Skunk2 Sport Shocks?
- I need Spec's on Civic type R struts/springs
- lowering springs
- alloy rear lca - benefits and problems
- Nice design for a fender brace
- 96-00 civic lowring helpp
- 3/16 stainless steel brake lines
- Integra 90-93 suspension
- Bushing Tools
- Got my HAWK HPS, missing shims?
- Hypercoil Part # for 18k rear springs, for my EG coupe
- A basic lesson on wishbone suspension for newbs
- how can i tell how low my car is???
- What tools Will I need for Suspension Swap 95 Eg
- Wilwood vs S2000 brake upgrade
- ksport upper control arms? any good?
- Blue Springs?
- Used DC2 ITR Suspension OR Tein H. Tech & KYB GR2's?
- itr calipers on a gsr
- front coilovers
- i need pads and rotor help
- will koni reds from 93 si fit 95 si?
- 95 si disc conv. swing arms or not?
- Ground Control Compatibility
- Blox camber kit bushings? please help!
- Any other strut options? (and a bit of a critique)
- D2 Springs vs H&R Race springs
- shock body is rusting
- Suspension set up. Please advise. Thanks.
- Will Oem balljoints work with skunk2/blox upper control arm?
- Koni FULL coilovers
- vs..
- Strut replacement??
- F2 type 1 suspension vs. Eibach Sport System plus lowering kit.
- Slammed question
- 06 Civic Ex - Rotors/Pads
- Traction bars?
- My new Sponsor
- EK shocks on DC Megan LCA's
- What supension should go with?
- Are the Bilstein/Neuspeed coilovers still a good setup?
- Question
- Crazy noise under load!
- Bushings
- 96 ek hatch front disc brake issue?
- Lca/sway tuning
- Will KYB AGX shocks work with stock coils on a 99 dx
- Civic Coilover Question
- RoadRace/AutoX Spring Rates for CRX
- eg/dc rear shocks on da
- cheapest place buy koni and gc
- Steering wheel vibrates
- Double Flare vs AN fitting HELP
- CRV Caliper+Prelude Rotors in EG6
- Godspeed SS, KYB gr2 + Eibach, Koni Yellow + Stock Springs
- pic request coilover install diy for tein type flex
- best route for shocks???
- B&G S2 Lowering Springs...
- (can't find) civic oem spring rates
- My $20 TA Bushing Extractor
- godspeed coilovers?
- Ever heard of STAGG SHS shocks? Pretty cheap, but not sure of reliability.
- Strut Top Nut Ques.
- Harsh ride over bumps?
- Need help ID'ing my shocks
- 2000 Integra GSR. Getting Tein H Tech and Koni Str.t shocks..Expected Drop and Camber
- loud clank/ bang in my 98 civic
- Can I get some help from the civic crowd pls (measurements)
- Adjustable Height, Ride Quality, Budget > Performance
- rubber rings above or below my coilsprings??
- 40/40 proportioning valve install
- steering wheel turns left and right over bumps
- looking for es bushings that will fit onto skunk2 upper control arm
- Will extended top-hats drop your car?
- First time lowering my car, help.
- Wilwood Calipers
- Some Qs on dynoing and revalving OTS Yellows
- help with rack and pinion DA integra
- Koni Str.T vs. Progress CS-II
- Sway help
- Gen 6 Accord Fr. suspension noise
- Extended ball joint's AKA Roll center Adjuster AKA Zero bump steer !!!
- car is max out on one side
- wheel/hub maybe suspension issue
- dumb question of the day (for anyone that has rebuilt shocks)
- WHICH IS BETTER ON A DB8?
- Brakes Hard in the Cold Morning
- Rear disc swap throwing off rear toe?
- JDM EF 3 point on DA?
- DA Integra - Camber kit: Does anyone make this kind for DAs?
- DX Civic Ek model Sway bar options
- I need some help with my string alignment please
- Opinions please
- jdm car toys?
- Spoolin Performance Front/Rear Camber Kits
- I'm thinking about rebuilding the ABS in my DA teg...
- ITR lower control arm question
- What kind of grease do you guys use with ES bushings?
- ASR swaybar interferes with exhaust
- Tokico 'Spoon' dampers - Fakes?
- swerving/swaying issues
- funny brake setups
- ground control?
- Coilovers/struts
- ALIGNMENT
- ef shock help
- 91 civic hatch rear disc conversion questions
- correcting toe & weird noise
- highway swerves
- $200 prop valve
- Help! 97 TL suspension problems
- Question about outer tie rod and alignment.
- 89 CRX H22 swap. Exessive caster movement!!! HELP!
- H&R OE Sport Springs on stock shocks???
- How to Remove Rear Drum?
- Tein ss coilover help!?!
- Reduced body roll for daily driver
- need help looking for the rear itr 5 lug.
- Can you keep suspension in storage?
- noob question - EG civic wheel bearings - can i roll it without axles?
- Koni questions...yes I've searched...
- race ready. eg vs 300z
- Droop travel with extended top hats and Koni race dampers?
- Camber kit adjusted...steerings weird though??
- Proportioning valve life
- buddy club N+ coilovers
- 99 Honda Civic rear disc brake conversion
- ryane motorsports brake kit
- Eibach Springs, Uneven Height Issue
- Would like some help on lowering my eg!
- 91 hatch si suspension
- Struts!!
- Question on 91 hatch suspension setup???
- I know its a crime to touch the DC2R suspension but...
- Anyone using Blox Lowering Springs?
- What Rotors are best?
- roll centers
- 12mm Master cylinder fitting.
- Need help fixing strut/shock..a lot of stuff.
- ebay coilover sleeves-93 civic-need advice
- Are these Upper control arms/ ball joints worth buying
- eibach sportline springs
- Best upgrades using stock parts...
- IS THERE SUCH THING AS A CHEAP SETUP?
- Rear hub bearing installation
- civic big brake kit is it worth it?
- Wheel studs or Hub?
- Gen 1 Insight suspension options.
- Best way to raise 1" without having coil overs???
- shocks for an 98 coupe
- 99 civic si, ride is getting a little bouncy, suspension opinions?
- Is it possible to bend a subframe back into place?
- Got calipers and carriers, what rotors and pads do I need?
- enegy suspention question need help
- Question for Suspension Gurus: LS motor + 98 hatchback + JIC coilovers
- bilstein and neuspeed suspension
- Suspension upgrade???
- EJ2 Suspension setup
- Does a rear camber adjust change toe?
- Replacing Trailing Arm Bushing 97 Honda Civic - No special tools
- replacement for omni upper balljoints?
- Cut Springs what to do?
- Replacing suspension parts
- ebay top hats review?
- Brakes -> Honda Civic SI
- Convert Integra GS to ITR Rear Brakes
- For those who have Progress Coilovers CSII
- will ek struts and coilovers fit on a eg
- Camber kits all adjustable???
- 96 ITR conversion 4x114.3 rear wheel bearing replacement
- Car Drifts When Braking
- EK Civic sounds like its going to fall apart
- ground control cush ride
- How bad is this...?
- Cheap lca bushings question
- how to disassemble ohlins coilover?
- GC/KONI
- need help with coilovers/shocks/ springs.
- Will It Fit!!! (IM and Bar)
- Thinking of ordering some stuff from here
- Air Suspension?
- 5 lugged out...
- Koni/gc help?
- 2000 H22 Civic Brake upgrade
- Stuck proportioning valve? No pressure to RF/LR brakes.
- Koni specific Ground Controls compatible with stock?
