- spring rate?
- any word on the updated form & function typeII?
- Ef/EG bushings
- Invidia Rear Sway Bar Kit
- Broken Rear LCA Bolt
- Slammed guys HALP!
- recomend a good spring that is not too low? H22 civic hatch
- Will 95 integra shock/spring assembly fit a 97 honda civic
- Suspension setup opinions??...
- PIC Performance vs AMR Coilovers
- eibach springs for swap
- will a bolt in roll bar really help ? eg hatch content
- EF Suspension Question
- questions about rear discs on sol
- Which is a better handling chassis in the end? EF Si or EG Si
- Tokico HPK Suspension Kits??
- Strange sound from LF wheel area.
- slammed
- Suspension Question Again
- Is there something wrong wtih my spring? Pic included
- 95 coupe w/ skunk2 springs. What shocks should i get??
- eg Mounts from frame to motor
- Does the UCA swap work for the DA for more castor?
- question about skunk 2 lca's need help
- Poly replacement for the upper shock bushing?
- Ksport Coilovers - Kontrol Pro Kit
- Suspension question
- NEED: Suspension Technique front swaybar help.... for..EK without factory swaybar.
- Ground Control Spring Rate
- Suspension parts for 94 del sol
- Ground Control Spring Rates
- Can you just replace ONE worn shock?
- ground control (stock)
- Problem with rear Koni Yellow bolt threads!!!!
- Tokico illumina Rebuild?
- ef rear subframe brace
- coilover question.
- So...do I need a new front lower control arm? Bushing install gone bad?
- Aftermarket End Links, Blox Racing the best choice for value?
- are function and form coilovers good
- tokico HP/ illumina?
- DA poor handling, ideas?
- h2b eg suspesion?
- naual steering rack
- Shock question
- Buying my suspension
- question about p/s to manual
- DC to DA suspetion?
- koni yellows...help...help...please
- Skunk2 sport shocks & springs
- need help picking a suspension for my 97 gsr!!
- Question about swapping coliovers/shocks
- ksport springs
- SHAKE SHAKE SHAKE HELP!!! CHICAGO
- Suspension Suggestions
- Going through tires every six months. Helppppp meeee plssss
- Tein S Tech Lowering Springs
- how has gc/agx combo???
- traction bar issue
- 98-00 Acura 2.3CL Hub & 98-02 Honda Accord I4 Hub, are they the same???
- Boylan Performance Trailing Arm Bushings?
- Changing spring rates
- Alignment Shop in San Diego?
- How to raise without coilovers?
- IntegraDC2 Future Suspension
- Does anyone work for firestone or know someone that works for firestone? Have a question.
- Im stumped????
- eibach drag springs... whats the drop?
- shot peening control arms? wtfluff?
- Are my shocks blown?
- eg with dcr suspension
- D2 or PIC???
- Anyone use progress springs (#40-1003) on there DC2 or otehr cars? Help me out please.
- big ups to pic and a few questions.
- Will this work?
- EG hatch - Brake swap questions
- function 7
- skunk 2 sport full coilovers on ef??
- Are bump stops needed for Skunk2 full coilover?
- Help me set up my EG for the track!
- Question regarding civic si steering/ hub assembly compared to a civic cx with 240 mm rotor:
- Is this a good deal...?
- rear 99 civic si 4x100 spindles to 4x114.3 conversion
- Skunk2 Sport Shocks & Springs
- I change the ball joints but…
- searched: no answer found. question about camber setting. need advice. specs inside:
- looking to tighten up my suspension 2000 accord
- ek on da ?
- Omni lca's bushing problem
- Asr subframe brace interchangeable?
- upper control arm question
- Buddy Club Racing Spec Damper - 4dr si
- JIC Magic FLTa2 specs
- which suspension for my RSX???
- Progress Competition Coilovers (1 or 2) for 92-95 Civic | Tein HA Questions.
- lowering springs??
- GC spring rates for standard ride and cush ride?
- ef skunk2 springs on 4dr eg
- clueless da9
- skunk2 pro-s or omnipower sport?? need opinions
- I NEED HELP WITH TEIN FLEX COILOVER
- d2 or omni power???????
- purpose of adjustable endlinks
- Can I put new Drag Launch Springs on old style single perch GC?
- Lowering -- Coilovers -- Do I Understand Correctly?
- Kind Of lost what should i do?
- ITR spec coilovers on em1
- Adjustable Endlinks, purpose?
- antiJDM's AMR Engineering full bodied coilover coilovers review VERY detailed
- Ground Control or Neuspeed Sport?
- koni yellows/ground controls or TEIN Super Street?
- skunk 2 springs will i need a camber kit ?
- confused over EG4 and DC2 coilovers
- sk2 pro series + front camber kit on my integra
- Clicking Noise in the rear. Please help!
- gc tophat question
- northstar camber kits
- Back side of ASR subframe support
- Need help Casters off!!!!! Please!
- Where do i start?
- Back to stock UCA on Del Sol- removed camber kit
- lowering spring suggestions
- How to tell if ball joints and tie rod ends are bad?
- clear up some junk for skunk 2
- A little input needed
- skunk 2 or ground control
- c pillar bar for ek hatch, where to get one?
- Eg vs EK suspesion Can you swap them?
- 2 cars 2 suspension choices opinions please
- Any 01-05 Civics Lowered on Function & Form?
- Blown Ksport shock
- h&r sports + illuminas lowering problem
- question about gc tophat and koni yellow install
- Just thinking about a idea
- turbo suspension setup
- Problem with brake pad onto Caliper
- Koni yellow circlip/perch ?
- skunk2 pro s coilovers( any suggestions)
- Damper Mounting Washer...stuck
- Lowering Spring Problem
- install cost
- ¿¿Bump Stop??
- skunk2 pro series help
- front lower Ball joint help...
- ground control
- What's inside diameter of ITR springs?
- H&R race on Ek with 3" downpipe=disaster???
- Function Form Type II Users post here!!
- Skunk2 coilover Feedback
- Best OEM size Brake Rotors/Pads for 15" wheel for DC Integra
- When i go on and off the gas in 2000 civic i feel jerking and poping noise?
- question
- g/r springs rating 22 pounds in rear??
- 91 Civic Suspension
- kyb agx
- Installing H&R springs
- neuspeed bar help
- Not sure which bushings (P/N's) to order - '99 Civic front rear LCA bushings
- Omni Power Coilovers!
- ingalls upper arm ball joint question?
- stock springs + adjustable shock????
- New Skunk2 PRO-C "Test Drive" Try and Ride Program!
- Tokico Illumina / Ground control
- Which Company's produce for my make ?
- '96 Integra GSR Wiggles in Back End
- OEM end link compatibility questions
- skunk2 sport shocks w/ ground control
- Where can i buy Eibach ERS springs?
- Question about Tein and interchangabilty
- JIC Magic SF-1
- rear disc questions....help me...
- Bushing diagram? Please Help.
- Corner weighting - Has anyone done it?
- Swapping springs between Skunk2 and Ground Control coilover sleeves?
- Better route?
- Just put 23mm rear swaybar and JDM ITR Suspension my EG4
- Progressive Rate Spring Full Coil-Overs? Soft Threaded Body Coil-Overs?
- steering wheel rack problem need help
- Buying 'spec' springs? Ala Carte menu?
- Sway bar thickness question/inquiry on an EG
- Difference between F&F Type 1 and Type 2
- Are Top Hats Interchangeable?
- Ground control questions CRX
- Help!! Coilovers and alignment!!!
- Earl Brake Lines or Brembo slot/drill Rotors??
- manual steering rack
- Hard race bushing
- my car handles like I have 4 flat tires
- S U S P E N S I O N B A S I C S
- think i lost a shock or 2
- 95 accord rear disc conversion
- eg lower control arms on ek?
- sprint springs
- Omni power collar?
- Coilovers
- need to go lower on current setup. help?
- problem with washer trick.
- DA smooth suspension advise pls
- Hammered on stock springs
- Eibach VS H&R (2008 Accord)
- Front camber kit question.
- k sport spring rates
- blox camber kit problem
- Skunk 2 pro s coilovers
- Eiback sportline / neuspeed race
- Brake line Q
- how long will coilovers last?
- Skunk2 lowering springs raised the rear of my integ
- low budget coilovers
- crx darts on uneven ground
- need springs for ef sedan using kyb agx's
- Koni spring perch question
- poly bushings - squeaky squeaky....how to make fix?
- Can you retrofit a set of '88 Porsche-944-Turbo calipers on a Honda caR like the ITR?
- Front suspension problem
- HondaSport springs
- coilover opinions wanted
- koni yellow mileage?
- EG roll bar set ups
- $1,000 dollars to spend on suspension, how would you spend it?
- Need help deciding GC rates for my EF
- EG struts on a EM1?
- underground racing
- Ground Control Top Hat question
- F/R swaybars....is this safe for a daily driver?
- Which (front) strut bar fits with GC extended top hats
- Which sway bar is right for me?
- supension set up??
- Identifying knuckles
- ball joint help, i deperately need help
- Del Sol vs. Dc2 Springs
- Info on Password JDM rear trail arm setup????
- Anyone use JEQ axles before?
- 1995 CIVIC EG SUSPENSION ISSUES
- adjustable ball joint need help
- Difference in GC sleeves
- Rear disc converion
- integra rear strut issue
- So i got free coilovers..
- Suspension gurus - advice?
- HAS ANYONE HAD TROUBLE WITH THE DAMPER FORK THROUGH BOLT JUST SPINNING?
- tein h-tech springs
- suspension problem with my db7
- DRUM TO DISC BRAKE ON CB7.
- 4x114.3 conversion on my DC [QUESTION]
- geometry angle on ep3???
- Identifying GCs
- skunk2 coils
- 91 hatch- need help deciding what to go with!
