PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. s2k rear struts
  2. The "Right Height"
  3. Ground Control fitment question
  4. Newb here. Lowering question
  5. how to clear out dot5?
  6. lower arm bar question
  7. Can someone help me.....
  8. Mugen 24mm Swaybar
  9. Poll about dropzone shit
  10. Worn out bushings in my OmniPower forged front LCA: Replacement options
  11. in need of coilover sleeves
  12. question about tein springs
  13. Suspension set-up advice needed
  14. gc/koni vs skunk2/tokico (del sol) ?
  15. Springs Poll
  16. HELP: DA suspension: commuter
  17. 5 Lug Converion
  18. Need some good stopping power!
  19. alignment specs needed
  20. Wilwood 11" kit on EF (pics)
  21. ef springs on eg - will it fit?
  22. trailing arm bushing tool dimesions?
  23. Camber clarification needed.
  24. Alignment specs
  25. 5 lug conversion probelm on EK
  26. suspension qustion?
  27. ground control upper mounts
  28. Sway bar endlinks???
  29. Raising height and alignments
  30. strange noise coming from 00 civic suspension *video*
  31. Omni Adjustable UCAs - Opinions or Experiences
  32. Random while driving.
  33. h&r race
  34. 9clp14s rear caliper questions
  35. what bolts size do i need to connect password jdm 3pt bar to firewall???
  36. gsr brakes on eg hatch question..
  37. ASR Brace with ABS lines?
  38. DC2 owners!! Need good advice on a Combo for lowering my gsr.
  39. 8'' vs 7'' ERS for rear GC setup ???
  40. Prelude Suspension Setup Q
  41. Tein s.tech lowering springs
  42. Need help!
  43. EF8 Subframe/ lower tie bar???
  44. spoon caliper on 4 lug?!
  45. EK Suspension. Front higher than rear, why?
  46. After I dropped it now it makes noise, help
  47. EG upper C arm on EK?
  48. Koni, bumpstops
  49. si/gsr line
  50. Itr LCA question
  51. brake lines?
  52. Camber Kit Question
  53. Question about civic lowering springs
  54. Why does my steering wheel shake? (Was: help!)
  55. Koni/GC or Koni/H&R opinions..................
  56. Lowering cheap
  57. Rear LCA help please...
  58. Horrible suspension problems
  59. question: difference between springs and coilovers?
  60. Humming sound at 50 mph and above
  61. Front 2000 si disc conversion on my ef.
  62. Accord 2000 SE,Brakes ( vibration problem)
  63. Measure ride height
  64. Wilwood 6 piston kit installed on ITR w/pics
  65. NOOB QUESTION: welded spring perches
  66. fast brakes ???
  67. D2 coilover blown?
  68. What brand coilovers should I consider?
  69. DC steering knuckles on EF????
  70. coilovers vs. shock/spring combo
  71. Suspention swap, Will it work?????? Need to know ASAP!!!!
  72. 99 gsr vs Tein springs?
  73. Other Lowering Springs?
  74. ASR Swaybar Problem
  75. Bilstein or Illumina, GC or H+R Race?
  76. Alignment ?
  77. Koni Yellows - How to check if they're still good?
  78. Spring rates
  79. need advice
  80. rotor too close to bracket
  81. lower tie bar
  82. Coilover help on my DC
  83. gc camber adjustable plate
  84. tophats
  85. hmmm......wierd gsr strut bar question
  86. What works
  87. help me identify eibach pro-kitline 91424
  88. any spray lube safe for polyurathane?
  89. ek9 swaybar
  90. rear hardlines leaking
  91. Ground control and agx problem
  92. brake pads
  93. disk swap without trailing arms
  94. ken's kustom's booster delete kit?
  95. why is my front suspension higher
  96. spring rates question
  97. brake problem
  98. Abs modulator noise.
  99. matrix coilovers
  100. rear disc brake conversion
  101. Extended top hats.
  102. CRX Suspension Help
  103. Civic Omni coilover sleeves on Koni yellows
  104. Do I need new shocks with H&R Sport springs?
  105. any lower springs
  106. cutting bump stops
  107. Control arm replacement
  108. Do BLOX rear lower control arms use OEM size bushings?
  109. 99-00 civic si em1 front sway bar question
  110. suspension help for my dc2
  111. Springs for a 94 civic hatch with b16 swap
  112. How to adjust ball-joint type front camber kit???
  113. upgraded brakes, needs prop valve?
  114. not sure whats wrong with them
  115. Civic EK DC2 1' Master Cylinder Swap
  116. 23T bracket and prelude rotors question
  117. How do you install ES swaybar endlinks? DC2
  118. What is going on here?
  119. H&R Race... struts??
  120. Ground Control "ride feel" order option
  121. Need help: Skunk2 Sleeves n Tokico Illumina!!!
  122. 89 crx si front lower control arms?
  123. Skunk2 EF Front Camber Kit
  124. 92-00 fitment question regarding koni/gc
  125. EG steering rack went out EK fit(i did but new search SUCKS)
  126. rear knuckle
  127. Did Tein ever make the SS for an ITR?
  128. coilover help
  129. Stamped steel LCA vs. Cast LCA
  130. trailing arm bushing?
  131. Bad wheel bearings?
  132. Anyone using/used Hardrace rear sway bar end links?
  133. integra tein basic
  134. Da rear trailing arm on a eg
  135. Quick question regarding camber plates...
  136. Civic - Integra suspension Question
  137. How To find the Spring Rate on my SKUNK 2 PRO S ?
  138. Brake pad differences (Axxis & Hawk)
  139. suspension guys help please
  140. warped rotor!
  141. skunk2 coilvers/ground control question
  142. Motion Ratios
  143. cut springs um ya, I asked
  144. 02 Civic DX front end vibrating/wobbling
  145. camber kit
  146. Stuck Slider
  147. Replacing struts/shocks and springs on daily driver - good combos?
  148. question about setting Dampening on coilovers
  149. Best Full coilovers for 90-93 accord? not much selection...
  150. Slammed.. camber kit?
  151. Megan Racing = Hardrace ...?
  152. Need help installing GC on my 98 EK!
  153. Tokico Illuminas + Ground Contol?
  154. front wheel bearing
  155. Koni Reds And lowering
  156. Opinions on BLOX RACING Full Bodied Coilovers - Drag Pro Series
  157. koni yellow's/ GC bottoming out?
  158. teg to coupe
  159. rear disc brake question
  160. 94-01 integra suspension work on my 99 EX
  161. Endlink question (vertical or angled?)
  162. strut suggestions??
  163. Omni Power Rebuild Question
  164. help with em1 drop!! :X
  165. d2 vs k sport
  166. em2 coilover install
  167. eg springs on 96 coupe.
  168. Kyb agx
  169. for ej8?!?!
  170. Setback 15mm
  171. Adjusting my suspension
  172. 5th gen suspension to 6th gen?
  173. No sway bar ..?
  174. Koni/GC Spring Rate
  175. tokico vs. koni
  176. ST 22mm swaybar/tie bar setup + Function7 LCA (EK)
  177. Blox Lca
  178. alignment idea
  179. Lowering springs 93 eg
  180. ?Leaking Break fluid?
  181. Air suspension question
  182. 97 Accord springs for stock car
  183. Are my new pads ok?
  184. Suspension setup for a dc2
  185. Drum brake upgrades
  186. HELP!!! no brake pressure
  187. Nissan Sentra SE-R Spec V Brembo Calipers
  188. replacing the right axle
  189. Are H&R Race Springs going to be too LOW?
  190. Help! SS brake line install???
  191. stiffer springs in the rear?
  192. Street Driven Coilovers
  193. FF Type II vs. Koni/GC - Whats your take?
  194. Springs question
  195. VGX Qualitee brake pads....
  196. eibach sways on 95 civic help
  197. Fixed stoke damper preload
  198. Shock help-Drag Racing
  199. i lost my old post. si i made another
  200. Wut camber kit n control arms i get on my EK hatch??
  201. T1r bmax coilovers for ek
  202. Honda CRV 2001 Knuckle assembly
  203. suspension setup?
  204. Suspension Help
  205. Dear PIC:
  206. NUB camber question
  207. Skunk2 coilover need help to install....???
  208. Pic request on Skunk2 lowering springs.
  209. spring rate question
  210. Welded nut stripped
  211. Switching to OEM springs... which goes where?
  212. axle boot
  213. Car pulls under hard braking
  214. I'm learning, shocks bottomed out
  215. intro/ trying to be dumped/ pitchars!!! 56k take a nap
  216. im buying a drum brake civic. i already have a rear disc civic. i wanna trade brakes
  217. koni yellow w/ stock springs
  218. skunk2 pro s v. pic apex
  219. strange noise coming from my left tire
  220. Anyone using these coilovers.
  221. smoked the curb, help and advice please
  222. skunk2 pro s coilovers?????
  223. function and form type I, do they slam the car?
  224. need help form and function coilovers which collar u use to adjust?
  225. buying used koni's;how to inspect them for proper operation.
  226. pic request of ground control kit
  227. Rattling noise from rear of car
  228. quick question
  229. A bit confused...
  230. SPORT MAX 002... if u have a set... HELP!
  231. oem problem (noise)
  232. Ej8 H&R Race Springs.. (suspension setups)
  233. Brake Lights don't work please help
  234. ABS Removal?
  235. Tokico D-Spec Coilovers on EM2
  236. Race a WRX, Blow a SHOCK?!
  237. cut brake lines
  238. need adivce on what to do!
  239. 99 civic swaybar
  240. Lines from MC to prop valve
  241. h22 crx....
  242. Spoon and Mugen shocks
  243. Front lower control arm replacement q's on 93 Prelude
  244. Tein springs, the difference between S Tech and H Tech
  245. crx vs civic shocks
  246. which springs should i run
  247. coilovers either or
  248. Will it swap?
  249. .
  250. Shocks what do you got?
