PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. trade koni/GC for SilkRoad coilovers?
  2. EK to DA suspension?
  3. Can slotted rotors be re-surfaced?
  4. koni yellows. what coilovers fit other than G/C????
  5. sage coilovers?
  6. Accord rotors
  7. skunk2 coilovers
  8. Another conversion quest.
  9. street suspension question, suspension gods chime in
  10. EG6 SiR brake help!
  11. inexpensive springs for my car
  12. so i hear itr springs will fit my 00 si
  13. Changing spring lengths and weights in Tein SS
  14. are my skunk 2 coilover sleeves reusable?
  15. brake disc question
  16. rally suspension
  17. what suspension is most like stock
  18. coilover sleeves or full coilovers?
  19. Putting Urethane in Trailing arm bushing..bad idea?
  20. 2.5" helper springs
  21. Any input on Tokico Shock/Spring kit for a 2000 Si
  22. suggestion's on my setup
  23. Need help with AEM big brake kit
  24. Will 10.3" front rotors fit on rear?
  25. strongest suspension for heavy weight and road bumps?
  26. soft brake pedal after legend conversion-- dunno what else to do--- help!
  27. function & form type II
  28. Can i put eg tein flex on ek with no problems????
  29. Brake Rotor sizes?
  30. Ksport settings>>help
  31. 4x114.3 swap on EG; any USDM rotors fit??
  32. is honda brake line steel or alluminum?
  33. ITR swaybars ore ek9 swaybars
  34. 92-95 civic and 94-97 teg supension
  35. Buddy Club Racing Spec Dampers...good or meh?
  36. SKUNK2 sport shocks and Stock springs?
  37. Super lowered cars
  38. Has Any1 Ever Used Gab Strut bars? *Pix*
  39. Question about Ground-Control
  40. KONI YELLOW BLOWN! after only 4 months..
  41. Problem after installing Tein Pillowball mounts
  42. Powerslot Rotors+EBC Redstuff=bad combo?
  43. Civic EG coilovers?
  44. Bumpsteer driving me nuts (any advice from the pros?)
  45. Cleaning spoon calipers.
  46. EM2 lower tie bar help!
  47. Steering Diagnosis
  48. oem or remanufactured steering rack?
  49. koni VS tokico
  50. So...what's wrong with my Koni/GC's? suspension n00b here
  51. New suspension - What all do I need?
  52. Tein Basic ?uestion
  53. Do I really need a camber kit?
  54. SPOON STRUT BARS/TIE BARS AUTHENTICITY
  55. What Calipers Do i have
  56. length of DC2 rear strut bar in inches?
  57. need suspension advice?
  58. good brake pads for 97-01 Prelude
  59. quick question on rear sway bars...
  60. Wilwood on Stock brakes?
  61. Something isn't right
  62. HELP! Putting Stock Spings back on
  63. bad alignment
  64. tie rod ends
  65. installing traction bar with...
  66. Ground Control Spring Rate Confusion??
  67. Want to put some rear disc brakes.
  68. What suspension should i put on my ef9?
  69. just got my Koni yellows
  70. which steering rack should i buy?
  71. Koni SP3 limits?
  72. NRG Coilover??
  73. illuminas shocks won't compress. Plz help
  74. Ground Control Coilover
  75. Eibach Prokit
  76. Blox Adjustable Endlinks
  77. Ok.. so my omnipower coilovers SNAPPED
  78. Mugen Bushings
  79. I want to go lower
  80. 5lug conversion on my db2
  81. need to find out what springs I have....
  82. Best Front Camber Kit?
  83. good suspension set up for a dd?
  84. 89-91 Civic Si Suspension Geometry
  85. Squeek and knocking noise from drivers front
  86. d2 caliper breaks anyone
  87. no coilovers for my 97 prelude sh
  88. camber kits
  89. Hawk HPS pads and squealing?
  90. drag coliovers
  91. eibach springs 0600.250.0500? what lb/in?
  92. Best set-up for a 98 EX DD
  93. Squeaking front struts
  94. Will stock automotive paint work?
  95. Accord brake problem- please help!
  96. ceramic brake pads, is it worth it?
  97. Best drop for 16" wheels?
  98. what about this
  99. OEM upper control arm bushings?
  100. Spring advice for rough tarmac
  101. 1-Rear Koni yellow making a Clunking noise..?
  102. GC Spring rate for the 95 Accord
  103. Where to order parts from for Koni struts
  104. Susepension Help.
  105. Bottoming Out
  106. difference rear caliper rsx-R vs rsx-S
  107. Tein S. Tech VS. Skunk2
  108. Ripped cv axle boot on new axle, safe to drive on?
  109. Disc Swap - E-Brake Stuck
  110. paintin
  111. PIC vs Tein/ silk road
  112. Correct me if I'm wrong.
  113. Shorter stock replacements for a crx?
  114. steel braided lines in place of hard lines on abs pump????? help
  115. OMNI wont give me a strait answer!
  116. anybody using stock cx booster with gsr m/c
  117. How screwed am I? Major $$?
  118. M/C to prop valve, which line went where?
  119. bumpstops
  120. Ideas for $1000 budget suspension build
  121. 96 itr brakes
  122. Clicking when turning - only under load?
  123. Need a little help with ej8
  124. ap2 coils
  125. Function & Form coilover problems
  126. I NEED HELP WITH DRAG SHOCK COILOVERS
  127. Koni Yellow Installation
  128. Koni Yellow Perches
  129. DA & EF Coilover compatibility
  130. I can't seem to find a good answer, how are AGX & GCs?
  131. brake problem help please!
  132. 89-91 crx suspension compatible with..? (tried search)
  133. Koni Yellow Adjustment
  134. torque specs for crossmember???
  135. Should brake lines be replaced after a couple of years?
  136. Mugen Shocks?
  137. New Bushings on Blox LCA's
  138. E brake problems
  139. remove bushings
  140. DC2R/EG6 coilovers on EK4 - Rear LCA
  141. coilovers
  142. brake conversion question
  143. Forgot backing plate on front brakes
  144. Tien EDFC owners Picture request
  145. eg and ek
  146. Where could I buy Koni suspension?
  147. Broken Bolt on FLCA!! Help needed
  148. Where did the SLAMMED Thread go?
  149. Which Honda knuckle for double wishbone project?
  150. pros and cons between adjustable ball joints vs camber kits
  151. Brake problem
  152. Lost a ton of brake charts and data
  153. 98 Civic Ex with drum brakes swapping to rear disc & keeping ABS **Questions**
  154. Race Coilovers - what works?
  155. 92-00 civic front lca
  156. Similarities between, 88 Civic/CRX Rear LCA'S and Integra Type R Rear LCA's
  157. NEED HELP: 97 Ex Suspension
  158. top hats? can you explain this to me?
  159. EF h22a suspension
  160. ef/ek interchangability?
  161. KONI yellow VS APEXI N1 damper
  162. rear type r sway bar on ej8 coupe
  163. Brake setup for summer
  164. I got some suspension goodies to put on my EK
  165. suspension setup on eg
  166. no time pls help
  167. Where to find EP3 rear caliper brackets?
  168. Suspension issue? Car bottoms alot.
  169. GC coils w/KYB AGX struts: Which extended tophats fit?
  170. what are the best traction bars for a 91 crx?
  171. ABS light
  172. Which car is my rear disc conversion from.
  173. Daily Drivable Spring Rate // Koni/GC
  174. Stumbled across these trailing arm bushing for 92-95 civic on Ebay
  175. just bought a replacement shock illumina for front left, STIFF?!?!?!
  176. 93 civic brake question
  177. ef/eg differences.
  178. Suspension still squeaks after attempts of fixing
  179. Rear SRR LCAs Replacement Bushing
  180. Springrate Calculator/Determiner?
  181. Need help!
  182. suspension fitment? help
  183. endlink bolt broke into LCA, what to do?
  184. C PILLAR? B PILLAR?
  185. e brake sticks
  186. Suspension Compatibility
  187. T1R B52 Coilovers for S2K
  188. drilled and slotted? or powerslotted?
  189. Coilover and Bushing question!
  190. i can haz bumpstops
  191. how should i adjust my struts.
  192. Steering rack and pinion clunking?
  193. H&R
  194. springs
  195. Gsr 4lug suspension on 98 civic ex
  196. gsr suspension on 98 civic ex
  197. Spring Rates or not ???
  198. Curious on coil-overs
  199. 4x114 itr on crx
  200. Help with a part number for wheel speed sensor
  201. Alignment ride height Help....
  202. Resurfacing crossed drilled and slotted
  203. H22 EG + Omni Coilovers --- kinda crap
  204. Q's before purchasing Koni Yellow.
  205. Rear sits lower than the front.
  206. 1995 Prelude ABS
  207. suspension 101?
  208. Function & Form vs megan racing coil over
  209. Negative Wheel Angle issue. Help and Suggestions Please.
  210. tein pillow ball upper mount???
  211. installed right or wrong? need help
  212. just bushings?
  213. springs swtiched around?
  214. EF Sedan question !
  215. Ej8 Suspension info needed
  216. Will DC2 brake hardlines front and rear fit an EG Hatch?
  217. megan racing ciolovers help..................
  218. Ground control coilover,,
  219. EG brake upgrade without going with bigger rotors/calipers
  220. uneven e-brake
  221. Apex'i N1 99 Spec coilovers
  222. H2B w/ Rear Disc Conversion
  223. how do you delete the abs unit from a 90 integra GS?
  224. trick to raise the rear up even higher?
  225. tie rods
  226. dumped ef's out there
  227. Neuspeed Sport or H&R Sport
  228. What springs to get with skunk2 springs?
  229. front suspention fork
  230. Question on suspension 00 prelude
  231. what calipers will fit
  232. spoon brake setup on crx
  233. stock struts with springs
  234. Koni/GC Setup on EJ8 (Searched)
  235. CAMBER / TOE / CASTER
  236. DELSOL TOKICO SHOCKS .................PLZ HELP
  237. suspension noise help
  238. Backyard way to test springs?
  239. is there a coilover spring trade topic out there?!
  240. Del sol Big brake kit
  241. need some help on skunk2 coilovers
  242. Rear Prelude Progress Sway on Accord
  243. camber and snow
  244. Question about suspension
  245. KW Variants and Ground Control question???
  246. is this normal?
  247. Ground Control sleeve bolt stripped
  248. looking to get a little feedback on skunk2 shocks
  249. Psychotic Brakes
  250. someone please measure the length of your non-adjustable strut bar? DC2
