View Full Version : Suspension & Brakes
- Brake line size
- Adjusting rear coilovers on 8th gen civic.
- Help, ebrake question
- Crx suspension q's
- Skunk2 coils/Koni yellow issues
- 4 door eg manual steering rack
- Eg 4 door rear disc conversion
- Crx bounces everywhere
- 92 Civic caliper bolt size? (Did a search couldn't find anything)
- Ridgeline drifts direction of turn
- EF sedan no brakes
- Tein coilover strut replacement?
- Brake pads for Brembo big brake kit
- 99 integra ls type r 5 lug conversion help!
- 99-00 Civic Si/Sir/EM1 Front lower control arm bushings(sleeve removel)
- Dash brake lights
- Pad options for an 02 EX 1.7L
- Save My Back: Best EK Lowering Suspension
- junkyard parts worth grabbing?
- Braking noises on my CRV 2004
- Lowering my cg6
- Front Passenger Side CV Axle boot replacement
- Koni Yellow + Coilover system
- PIC, GC or Progress
- Would these work to lower my teggy
- Help!! Megan coilovers
- Swift springs
- Em2 suspension on rsx
- 949 6UL Wheels not clearing brakes near hub...?
- replacing bushings in omni front lower control arms
- Odd Sus Theory Q Regarding Civic Wagon - RTA, Bushings, Arms
- bilstein shocks on civic si 02
- Front camber kit, Ingalls vs Hardrace
- Coilover installation
- Need advice!
- Broken Lower strut bolt, rear passenger side
- Lowering gen5 Accord
- Rear Brakes cold
- Preload Lower Control Arm?
- AMR Engineering Coilover Review
- Need help with Rdb conv.
- Accord coilovers 94-97
- SRR LCA Bushings
- 04 accord.
- TEIN vs Truhart Coilovers
- Thinking about suspension.
- Coilovers for EG Hatch
- Condiering 2 different suspensions
- A few questions on rebuilding suspension: G3 teg
- Thump on left side when I accelerate heavy
- Hard rubber vs spherical on street use.
- Omni Drag Shock
- Upper ball joint not tight to knuckle.
- Having Loud suspension noises
- 95 accord abs codes
- I think i did some damage on my rear brake caliper
- Opinions For Shock/Strut '94 Civic EX
- New Wheel Bearing Play itr 5 lug
- happy medium Koni GC
- EK and DC/EG front uprights different
- 2006 Civic Si coupe
- Rear suspension issue
- Steering wheel shake when braking? New rotors?
- Fox Coilovers?
- Fox Coilovers?
- Toe Alignment?
- Proportioning valve question with pictures.
- Progress CS III???
- 93' Civic DX Suspension Rebuild - Sanity Check
- Ground control spring rates
- Which size sway bar for my setup?
- Car bouncy PLEASE HELP!!
- LCA/trailing arm woes (1998 Civic)
- Front Brake pads opinions?
- Trailing arm bushing alignment
- Pricing for new KYB Struts and TEIN Springs
- 1 Caliper ? and 1 Suspension ?
- cv boot worth replacing?
- 242 to 262 brake conversion problems aftermath
- 89 civic
- Eg forks using function and forms
- Wheel rubbing fender/frame wall question
- 94+ integra trailing arm VS CRX trailing arm
- Why is my car so low (Koni Yellow/H&R sport)
- Coilover system for 99 Civic Si
- HardRace bushings in Skunk2 front Upper Control Arms?
- 94 Accord new axle vibration
- CRX brake booster size?
- Parking Brake Replacement
- What MC cap to use when making a pressure bleeder?
- 1998 civic lx (4 door) 5 lug help
- DC2 shakes and steering wheel vibrates randomly on freeway
- Big Brakes question. master cylinder and servo
- Mfactory Modus Agile Coilovers
- Replacing Captive Nut - Compensator Arm
- Cutting bumpstops on H&R Sport install?
- Rear Brakes
- 05 rl clunk and vibration where to start checking?
- 99 civic Ex non lowered shocks
- Strut brace/bar 2002 civic
- How to correct the negative angle in my wheels?
- What is this large bolt at the base od my BC coil. TSX/CL9/7 .
- Coilovers too small for fork
- 03-07 Accord Coilovers same as 04-08 TL?
- 98 honda accord
- Wilwood DPHA calipers for 400+ HP car
- Shocks and struts for a dx sedan
- Bent LCA><14 Rotor Changes
- coilovers
- Stuck Hub on Axle-Need Some Help
- Broken Trailing Arm bushing bolt
- 600hp Civic EK Hatch what suspension parts to replace?
- EM2 rear drum WITH 5 lug, is it possible?
- ABS Light On
- Alignment for Best Traction
- oem shocks and lowering springs
- Calling all Honda rally guys! Suspension question
- What springs would be best?
- What springs are best?
- Got rims that dont fit NEED HELP!
- Coilover for honda civic ek 2000 sedan 4 door
- 92-95 honda civic drop spindle front
- Can't find the correct hub for my rear spindle
- lowering springs 99 civic si
- Bump steer issue
- What parts fail faster and need replacments quicker after driving a very low vehicle?
- Sway Bar Sizing
- 2002 Honda Insight ABS Delete, proportioning valve question.
- Function7 subframe asr rear sway bar with brackets
- Strange noise on Honda Fit...rubbing?
- 04 Honda Accord....any mods suggestions
- Soft brake pedal
- 98 civic to 88 crx suspension swap?
- asr sway bar help
- High pitch squeaking with accelerating?
- Ej1 with rear discs
- Please help me determine the best course forward with my wheels and brakes
- Any difference between pillow ball bushing and sphericals bushing?
- Wheel Hub or Alignment?!
- Brakes
- Alignment on low del sol
- 2000 EK civic scraping badly in elevated turning!
- bushings (which ones)
- [DC2 / EG6] Spoon Twin/Mono-block pads
- My coilovers are too low and won't go higher..
- Front passenger wheel isnt lined up
- *Best* Alignment Specs for modified DC2
- Fortune Auto 500 vs Pic select vs D2
- Problem with DNA Motoring Shocks and struts
- ILX on air?
- DC knuckles on EF
- Karcepts top hats! Thoughts? Reviews?
- Crx Shosck on ITR
- Floor mounted pedal box...
- New OEM suspension question on my EG2
- 1992 Accord Rear Ride Height Too High
- WHAT OTHER COILOVERS WILL FIT MY 01 ACCORD
- brake booster eliminator necessary? pros and cons?
- Trailing arm to LCA threads stripped, what to do.
- Track Coilover Choice - SCCA ITA 90 EF Hatchback
- Need help with brake booster asap experts only
- Coilover sleeves with to tokico blues?
- Which Coilovers to get?!?!
- Koni Yellows - Leaking at the adjustment "knob"
- -Where to go?-
- UNITY Suspension
- Big Loss of Power while Braking
- Tein springs sitting wrong !!Help!!
- Ek3 vs ek4 springs
- 99 EM! brake suggestions
- E brake cables for 2002 acura el
- Brakes for B16 turbo
- Brake pedal sinks an inch at traffic lights. Should I be concerned?
- Best coilovers or strut/spring combo under 1k for 98 civic coupe
- ABOUT STRUTS......
- 1997 honda civic amazon coilovers help
- intermittent directionals
- Mixing innovative mounts
- 95 Civic DX need coilover advice
- Ground Control Coilover max height issues
- 98 CX Hatch converting to Si Rear Discs.
- calipers and forks
- New Squeaky Brakes on 2010 Honda Accord
- New civic, adjustable coilovers {basic?} TOO LOW!
- Wilwood Dynapro Help on EF8 crx
- Camber & EDFC issues
- Recommended settings - Coilovers ('07 si)
- Ohlins or KW V2?
- ep3 smashed front end help!!!
- Booster for ITR MC
- Front upper control arms
- Front, Inside Wheel Lifting on Hard Corners
- PCSII VS Koni/GC
- asking for advice on power vs non power brakes
- TEIN Control Master Type Flex possible issues...
- Vms control arms and subframe brace
- Rear Disc Caliper Issue / Parking - E brake cable
- DIY: How to Remove and Lubricate Disc Brake Sliding Pins (VIDEO)
- 95 sedan rear disc
- Top Hats
- Got a Weird Spring Rate Quote?
- Brake line question
- Ball joint cost advice
- 1991 honda ef coilovers on a 98 integra gs
- Questions on 03 civic Brakes
- best coilovers to run on a prelude
- Lower control arm question
- Truhart Streetplus Coilovers
- Rear sway bars for DC2?
- Koni/GC Riding on bumpstops?
- Suspension has me confused
- Function /form type 2 coilovers issue
- Drag Alighnment Questions *HELP*
- Low Drop
- Rear brake imbalance
- seam welding vs strut bars
- AMR Front Camber Kit for DC2 Reviews/Experiences?
- first suspension set up and I need help
- junk yard find. help me identify them
- Blox Drag Coils 18k changing to 10k
- Coilovers
- f&f type one ride height
- E-brake question....help please
- 00 integra suspension set up for heavy audio equipment?
- AutoX suspension for a 2008 civic SI sedan
- Dc5 5lug with Brembos on ep3?
- Truheart coilovers
- EF - EG front upper control arm bushings
- Wilwood DPHA Calipers - Reviews/Opinions/Experiences
- Function Form 1's vs Progressive CS-II's
- Blue coilovers
- Koni Yellows + OE Shock Collar (or lack thereof)
- wilwoods
- Wilwood DPHA and 9.4" calipers
- Legend brakes- Help!
- will nsx calipers fit 15 inch cp sprint harts
- Ordered from THMotorsports.
- 5lug to 4lug conversion
- Inner tie rod removal - completely round, no flats
- 96 Itr brake help. Where to find 25t bracket?
- Lowering springs and shocks vs coilovers
- Ultra Racing Side Lower Floor Bars...thoughts?
- Can i clear type r calipers with 15" cobalt steelies? I doubt honda 14s work
- spring rate ratio vs. weight distribution ratio
- swapping ITR master cylinder
- Skunk 2 Springs on Kong shocks
- Help Selecting Rear Camber Kit
- Anyone run the Tein Street Advance?
- Legend ka9 brakes to civic EK
- Drum brake and shoe replacement
