View Full Version : Suspension & Brakes
- dd with koni yellow what spring to get
- need help on wat to get
- JIC Majic Suspension Good or Bad
- Hawk HP Plus brake noise
- Are JDM ITR lower ball joints the same as USDM 92-00 Civic/Integra?
- Brake Help!!!!!!
- Spongy Brakes
- Rear brake conversion
- ITR Rear Sway Bar + Blox Endlinks on a 2000 Civic Coupe
- 1991 civic ef big brake kit??
- Question on specific coilovers
- Removing axle by taking off the UCA ball joint?
- Help me pick my suspension?
- Improving the front brake system in civic EX coupe 96 ??!!
- ITR rear suspension onto EK
- Is this Ground Control sleeve load bearing?
- Proportioning valve discussion.
- funtion & form type II's are they good
- type r rear sway kit from jhp?
- sway bar making car harder to steer
- H&R Sport Springs
- HELP PLEASEEEEE DRUM BRAKESSSSS
- Accord Tie rod question?
- Spacers between shock tower and body 92/2000 civic needed.
- H&R sports .. difference between applications????
- Good Del Sol Coil Spring Rate?
- Rust: What Has Better Rust Prevention...
- 2000 GSR brakes to 97 Civic Parts list help.
- STOPPING PROBLEMS!!
- Problem with springs/camber kit...
- front suspension issues.
- Illumina Leaking?
- Need some coilover/spring rate advice
- need some advice
- Suspension Max is horrible! Need help and advice on camber problem!
- Suja Motoring or Mugen hard rubber users?
- H & R Sport Spring Question
- well brakes still mechanically work if abs is unpluged wire harnes wise??????
- torque coilover
- Ebay 3 Point front brace (pw:jdm knock off)
- EG Suspension question
- coil over help please??
- '08 Civic Si Coupe Front Lower Tie Bar....
- Tokico Illuminas with 30000 miles - yes or no ?
- Comparing RIDE HEIGHT on EX and SI
- stock shocks with eibach sportsline CIVIC? HELP!
- tierod balljoint boot
- Clunk/bang from drivers front when making left turns?
- Annoying Squeaks from suspension whiile driving.
- DD suspension setup / future auto-x
- how to tell if tokicos are blown?
- '91 crx si performance alignment specs
- Cutting Bump Stop???
- Need Suspension tuner in LBC!!
- brake question have searched
- 88 civic sedan coilovers/springs&shocks
- Q about big brakes...and master cylinder
- Question about Koni Yellow
- How-to properly grease poly bushings?
- Brakes started squeaking, then nothing?
- Coilover sleeve specs?
- MEAGAN RACING
- EK Rear subframe help and questions
- Function Form Coilover's
- Suspension
- Strut bars
- Setting the TEIN SS coilover higher than the reference heigh
- gsr brakes
- Skunk2 Pro Series S vs. Function & Form Type 1
- 4x114 Adaptor
- Air Suspension
- jacking up car, wheel wont lift off ground!!! HELP PLEEEAASSEE!!
- Measureing rotor thickness
- HELP: tokico illumina's not dampening?
- Ground Control fitment
- ************2000 CIVIC SI SWAPPING SUBFRAME*************
- eg and ek knuckles/hubs the same?
- prop valve question
- brake booster rod seal replacement
- coilover question
- ITR sway bar with mfactory brace?
- asr subframe brace issue
- Budget = $800? WHAT?!
- Energy Suspension
- I want to upgrade my rear integra 2000 to 10.2
- Function and form
- asr with 22mm type r bar
- Rear disk question
- Help!! need advice on removing a strip bolt
- GOOD RIDE COILOVER SETUP?
- Anyone have experience with Tein Monoflex? Swaying toward PIC...
- Tucking 15x8's?
- wilwood big brake compatible pads
- gsr rear disc brakes. on 92 cx eg help
- Ground Control Coilover HELP!!
- Winter Project....
- Steering Wheel Shakes, have searched until my eyes bled
- Anyone familiar with 2004 G35x brakes?
- Anti-squeal vs caliper pin lube
- 2000 Civic Si Rear Brakes
- what size are the rear lower control arm bolts?? 1994 integra
- Piston Poped out?
- Just bought a 94 civic, and i dont know what kind of brakes i got
- flare tool degree for brakes n fuel HELP!!
- eg sway bars need ur opinion
- Integra breaks lolz
- Issues Installing front lower tie bar
- eg and ek on s-techs
- GC/Koni Combo Vs 'Full' Coil Overs (Tein, PIC, etc)
- Questions about Civic EK Front LCA Bushings.
- Steering rack + no fluid
- Question on F7 endlink install with CTR swaybar...
- koni yellows or tokico illumina's?
- DB7 dumped on 17x7.5s how can I do it?
- KONI YELLOW SHOCKS/GROUND CONTROL SLEEVES or full suspension??
- How-to: Front Lower Control Arm Bushing Replacement - LCA
- Increasing camber, new alignment?
- Question on Setup?
- My Suspension Is making Sqeaky noise.
- caliper bolt?
- Why remove ABS?
- APEX'i 99 spec full coilovers-Does APEX'i sell replacement bushings???
- cross drilled and slotted rotors
- spindle question
- EK Civic Traction/Front Cross Member Re-enforcement Braces? (Honda Tuning ~2003??)
- I need suggestions for better Rotors!!
- about to purchase some koni yellows.
- Opinions on which to buy...Coilovers
- 97 ek hatch
- EK9 Tein HA Coilovers into CRX?
- Koni yellow and H&R springs = comfortable/good ride?
- help with rack and pinion install for eg?
- da 3 or 4 point rear strutbar?
- 96' ITR 4x114.3 brakes - will 92-96 prelude rotors/pads fit?
- help ...trying to convert rsx 5lug on a dc
- KW Performance Coilovers Variant 2 .... what do you think?
- Traction bars and lowered suspension ??
- prelude bb1 and bb4 brakes, twin piston???
- brake upgrade on my 99 civic
- i need help ASAP!!!!!!!!!
- d2 racing coilovers
- AGX vs. Koni on GC Coilovers
- how hard to replace C and D lines on 98 Civic EX sedan?
- itr spec or gsr spec?
- ef set ups
- budget suspension
- Ball-joint differences between EF and EG?
- How to change SPOON Brake pads on a Type R
- Eibach scrunching sound in front end
- Question about alignment after drop.
- BBK Question
- problem with front brakes locking up!? need Help asap!!!!
- Help please!! Camber kit question!!
- tein edfc installation manual?...
- energy suspension bushing??
- what wheels for big brakes??? need large clearence space, inner diameter speace!!!
- Need shocks advice on my 94 civic cx hatchback
- Grease EVERYWHERE but no rip!??
- Beaks kit and sway bar for 92 CX?
- squeaking coilovers! help!
- Replace suspension components with aluminum counterparts?
- NEED HELP On Buying New Suspension For My DA
- Top Fender Rubbing Problem
- negative caster problem
- Storing Car
- camber kit
- not sure what brake line kit when buying ss brake lines
- E-brake cable not working after swap
- EK Upper Pillar bar
- Tein Blown Shocks?
- Quick 5 lug question..reguarding ABS
- ?camber kit question?
- !!! Washer trick help - bolt won't go all the way in !!!
- coilovers what kind
- Blox adjustable endlinks with itr sway
- ASR subframe brace on non a DX hatch
- GC + Tokico Illumina: Eibach replacement springs 98 Accord 4 cyl.
- HELP!!!! ground control adjustment!!
- Sway Bar Question
- 1994 Civic ex coupe- suspension help.
- Will a DA Sway Bars bolt on to a EF Hatch?
- civic abs sensor interchangeable with integra?
- PIC Performance Coilover ... Whats your take ?
- Messed Up Front Shock Bushings
- Preventing Clanking noise from progressive springs?
- Lowering spring settling time?
- gsr rear sway installed on 95 ex
- rear suspension noises?
- Is a 1 liter bottle of brake fluid enough for a flush?
- Help with me Illumina/Prokit?
- heading to CMP today.. need some setup advice!
- shock lenght and roll center adjusters
- buying struts, what kind should i get for a daily?
- blox full bodied coilovers?
- brake issue
- New drum wont fit into new shoes
- h&r springs for bb2
- Do i need just a Master Cylinder or the booster too?
- gsr sway bar help
- 94-01 integra illuminas fit a 95 ex civic
- another suspension help
- Broken adjuster
- subframe tearout
- How much would a shop charge...
- Big 4 setup on a DA
- Wheel hop
- omni power sway bar/brace
- Anone have pics of DA front forks?
- I need new struts. have a couple of questions please help!
- ASR Brace, 22m ITR swaybar, New style OMNI lca's, WHICH ENDLINK TO USE?
- ok suspension junkies...i need your help!!!!
- How to adjust tein flex
- Suspension, alignment or tires first? What is the correct order?
- general intro to spring rates/ lengths
- DA trying to install koni yellow/ground control problem plz help
- honda's scrub radius
- WHICH COILOVERS?!?! SO MANY CHOICES!!!
- 99 Prelude SH half shafts
- Raise suspension
- warped slotted rotors?
- i kno its been covered but cant find
- crooked wheel?
- quick question
- Honda coilovers on a 1984 Ford Temp?
- bolt stuck in bushing lca integra
- :: Why is my suspension clicking/rattling?
- When I get like this i don't think!!!
- Correct mounting location of traction bars on EG Civic ...
- Question about air ride suspension
- DC2 Integra Rack is Identical to the EG Civic?
- EK owner: For all Skunk2 Pro-C owners
- I NEED HELP CLICK ON TOPIC (Integra brake issue)
- Unsprung Weight and Brake Upgrades
- Seized brakes
- Cheap rotors?
- Need Your Feedback On This Setup I have In Mind
- Aftermarket shocks for the Element?
- best oem upgrades i can get fir an eg dx hatch
- 00 dx brake uprade question
- Groundcontrols w/koni vs. full coilover for a street DC2
- Cheapest place to get brakes bled?
- Suspension 4 door vs 2 door SI
- sloppy turns
- Buying used koni yellow?
- brakes holding me back after pad change
- Removing ABS pump from my 95 gsr?
- ABS going off for no reason slowing down 5mph to full stop
- Konis with GC...limited travel?
- Best sway bar setting with F7
- lca question(s)
