PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Suspension problem... Suggestions please!
  2. Any thoughts on these top mounts?
  3. Opinions needed
  4. Front camber arm fitment/repair
  5. Suspension Setup, Please help!
  6. BLOX extended ball joint
  7. 96 integra subframe replacement
  8. Questions about upgraded sway bars
  9. ITR spring info
  10. Suspension Mods
  11. 94 integra busted hard line under car toward rear
  12. weird vertical line on brake rotors
  13. Decent strut for megan coilover sleeves?
  14. Has anyone used Function n Form?
  15. Are EK and EG/DC Front Knuckles the same
  16. Ground Control/Eibach ID ERS spring question
  17. 98 civic dx to 94 integra front brake problems
  18. 96 gsr brakes
  19. new coilovers
  20. 94 EX Sedan Rear Disc in 94 DX Hatch Wheel Bearing Question
  21. dc2 both front calipers seizing at the same time?? opinions
  22. 2000 Hona Accord Coverting From 4 lug to 5 lug
  23. Anyone use power stop evolution brake pads?
  24. mechanic playing head games?
  25. Sway bar and do I need one?
  26. Any body have reviews on the blox drag coilovers
  27. "Temp" Ground Control with Stock Shocks/Koni Shocks
  28. Popping or clicking when I apply breaks?
  29. ASR rear suspension question
  30. brakes locked up and abs light is on
  31. Need new bump stops...suggestions
  32. Possible to adjust brake bias with abs on EK4?
  33. Clicking sound when breaking?
  34. yonaka?
  35. POS Unity Struts - What would you do?
  36. camber kits????
  37. Will this sway bar fit EG civic?
  38. Spring Rates? Help me choose|Learn me
  39. Which coil over sleeves on Eibach shocks?
  40. 2000 Civic Si H22 suggestions
  41. 98 integra front camber help
  42. Brake problems
  43. Need help with replacement ASR 24mm Rear Sway Bar Bushings
  44. asr subframe with sway bar?
  45. trouble with brakes
  46. Help with seats!!
  47. 2000 EM1 Steering Rack
  48. Brake Judder - 1993 Honda Accord
  49. camber kits
  50. Gc top hat
  51. Rear ground controls?
  52. koni + gc questions
  53. extended top hat help
  54. installing new rack and pinion help!!!
  55. your input needed
  56. AC blowing warm
  57. 93 Civic Compensator arm
  58. Caster Out of Sepc 2013 Accord V6 4DR
  59. Caster out of spec on 2013 Accord V6 4Dr
  60. suspention on ek hatch
  61. Koni Orange/off brand coilovers
  62. ATR v/s Willwood v/s D2 racing
  63. Are these Bearings Safe?
  64. more balanced braking how ?
  65. 99 hatch rear LCA compatability
  66. 36mm Axle Length Specs
  67. Koni yellow w/ ground control vs kyb agx
  68. 08 tsx to a 02 accord
  69. One side of rear passenger brake not engaging
  70. Honda lover beginner
  71. 2003 Civic SI Suspension HELP! Car sags/pops in front?
  72. K-Tuned DC integra traction bar. Anyone running one ?
  73. PIC REQUEST: ef stock suspension on ek hatch
  74. d2 coilover torque specs ep3?
  75. Need help clarifying Integra upper control
  76. SHORTEST REAR CAMBER KITS
  77. Air Ride
  78. The mystery of the exploding axle. AKA I've destroyed four axles at the road course.
  79. ITR endlinks on after market LCAs and thoughts on hardrace
  80. SUSPENSION SETUP COMPARISON
  81. best coil overs for an fg1 07 Civic to get maximum dumpness with zero bounce.
  82. brake line help
  83. Whenever I turn left in my 98 Honda Civic DX there is a clunking/knocking
  84. Help
  85. Help can't tighten rear strut fully
  86. J2 Front Lower Control Arm
  87. Rear Toe Adjustment Bolt/Nut
  88. Koni Race Shock Diameter
  89. 1996 civic dx rack and pinion compatibility?
  90. subframe lca bolt snapped
  91. Need brakes for a 93 hatch drag car
  92. new suspension with r17" 96 civic
  93. Need help with LCAs
  94. dreaded Ep3 front strut travel.... options anybody?
  95. $20 for Ground Control coilover sleeves legit?
  96. Stock Shock specs
  97. Rear lower A-Arm Probs?
  98. hardrace camber kit replacement balljoints
  99. 96 coupe front end rattle
  100. ej1 with dc rear disk ebrake issues.
  101. Coilover Wrenches?
  102. HELP! replacing rear LCAs, 92 civic ex
  103. eibach multi pro r2 coilovers
  104. Could use brake upgrade advice for '93 Civic hatch
  105. Reducing Brake sensitivity Honda Fit
  106. extended top hats, help
  107. Troubleshooting Spring Install
  108. integra brakes on civic conversion
  109. 92 Civic EG Rear Suspension Review
  110. Seized caliper on rear brake
  111. Custom spring rate rec. on Tokico HP for 00 civic
  112. EG - Suspension techniques sway bar end links
  113. Upper A arm pivot bushing torque spec
  114. Wrong Master Cylinder Port Size
  115. my new homemade bbk 49mm 2 pots caliper!!!!!
  116. brake pedal pressure loss
  117. again, 91 integra slammed problems
  118. street car/ why ITR/legend brake swap?
  119. coilover help 91 integra
  120. slammed my eg !??👍😃
  121. stripped sway bar bolts on odyssey
  122. Aftermarket Replacement Brakes - 2008 Accord EX-L
  123. Excessive caster on one side
  124. Popping noise from rear suspension
  125. 4th gen Prelude full suspension upgrade inquiry
  126. 2009 Accord needs new struts?
  127. Odd binding issue
  128. Rear Caliper Acura RSX/EP3 and ITR differences
  129. What springs should I get?
  130. Rear ABS Rings
  131. LCA bushings
  132. Another possible new wheel bearing issue
  133. @003 Accord EX 4cyl Front Strut Question
  134. Running ITR size Hubs/Brakes & keeping 4X100 lug pattern?
  135. Loud clicking noise when breaking
  136. Kinda stumped.. brake issue after brake tuck/all new parts
  137. yellow speed coils?
  138. OEM EK brake upgrades
  139. Megan Racing Springs? Thoughts?
  140. 40/40 prop valve o ring where to get?
  141. Question about my suspension
  142. brake not fully engaged
  143. Apexi N1 Civic question
  144. looking for advice
  145. CTR brake calipers on a 98 ex?
  146. Honda Suspension Worries
  147. coilover help
  148. Stupid question.. Should I buy Koni yellows?
  149. Quick question
  150. Need help with steering
  151. which buddy club coilovers are these?
  152. BUMP STOPS CUT WHEN NOT SUPPOSE TO, causing harsh ride?
  153. Pics of my MILLED 25T caliper brackets, milled to much?
  154. Need help adjusting rear camber kit
  155. EF Suspension questions
  156. Alignment Caster off ...
  157. EG Si rear disc conversion on '90 Civic Std.
  158. 05 4 door suspension tightening
  159. Compliance Bushing Question
  160. Stoptech Stainless Steel Brake Line
  161. Rover MG ZR ZS rear brake calipers (262mm) on del sol
  162. 95 del sol abs remove wtf!!!
  163. legend caliper upgrade where do the caliper pins go?
  164. spacer advice
  165. Ridgeline vs Pilot
  166. lowering springs
  167. Lower Control Arms & rear subframe brace
  168. ATE Super Blue Racing brake fluid Banned!
  169. Suspension gurus: Koni/GC noisy suspension setup?
  170. Ways to decrease roll without decreasing height?
  171. Camber Kit skunk2 for my ek hatch
  172. Tein Flex help requested for 96-00 civic
  173. Blox coilovers "warranty sucks"
  174. 96-00 civic lower control arm/swaybar setup INFO NEEDED
  175. wilwood front, proportioning valve upgrade?
  176. Rear Control Arms Fitment
  177. rear hard line length
  178. Lowering Springs
  179. Nippon Piston rings
  180. Are Koni yellow sport shocks gas shocks?
  181. Allen head bolts destroyed/stuck in sleeve collar, ideas?
  182. wheel Hub, Trailing arm , ebrake question
  183. Best performance springs
  184. Help me pick a setup
  185. Honda brake bias calculator.
  186. 1988 Acura Legend Questions
  187. HUB/DISC BRAKES
  188. 95 Integra Type R Calipers
  189. Rear UCA to TA Welded Nut, What is it?
  190. Question about pressing in front bearing
  191. Tokico No Longer Making Blues???
  192. RSX front end clunking...
  193. Going big brake, where can you buy complete knuckles etc
  194. Don't know what suspension set up to go with
  195. Need help with car rotation - ITR
  196. Asr subframe chipping apart
  197. adjustable with non adjustable shocks?
  198. Anyone running Yonaka FullBody coilovers?
  199. Is my tierod bad?
  200. Brake spring pliers?
  201. Weird Bushing thing on Upper Control Arm
  202. @#$% Ordered the wrong brake hoses, Can I still use them?
  203. Legend Booster/MC same as ITR Booster/MC?? help
  204. front camber??
  205. Energy Suspension end links question
  206. Brake Pipes
  207. Springs, bars and load transfer...
  208. 10k-16k ft.lbs(?) springs
  209. CV boot kind blew up. replace axel or just boot.
  210. how to tell if I need new shock top hats?
  211. ITR Brake Upgrade: washers with track use?
  212. Moog EK front lower control arm quality
  213. Rebuilding an axle
  214. BEST/GOOD SPRING & STRUT COMBO, SUGGESTIONS!!
  215. Omnipower Rear lower control arm bushings worn 97 civic
  216. Torsion Release Bearing??
  217. Questions on LCA
  218. OEM rear caliper upgrade options - 02 Accord
  219. 1995 Honda Accord (Camber issue )
  220. Bought skunk2 springs... need few questionss
  221. Installed Comptech Subframe Brace with 22MM ITR sway bar & ASR backing plates
  222. 2010 Accord lowering info
  223. DA Brake booster into EG?
  224. H&R Race : Spring Rate Need GURU input!
  225. Wilwood 4-piston caliper?
  226. Need some suspension help
  227. 99 civic SI Koni yellow and Ground control - confirm fit on EG?
  228. Ichiban wheel bearing quality?
  229. susspension leveling
  230. Koni yellows / Neuspeed Race springs
  231. EG Hatch Stock suspension
  232. AP1, Koni Yellows and Ground Control..Questions
  233. Suspension Question
  234. 16x7 Regamasters + spoon calipers
  235. One Side higher than the other
  236. Rear camber question on dc2.
  237. oem bump stops for tokico's?
  238. Best suspension setup?
  239. Creating my own coilover setup.
  240. Rear disc conversion not 100%
  241. sub frame and front lca assembly help
  242. wilwood 4pots big brake kit under 15s?
  243. Replacement Bushings for Spec D Tuning LCAs?
  244. Help - can't get rear piston in
  245. techncl alignment question
  246. Factory replacement control arms/trailing arms
  247. prop valve for dual piston legend calipers
  248. question
  249. Rear coilover popping while driving.
  250. 22mm rear sway bar Q
