View Full Version : Suspension & Brakes
- 750$ to spend..
- Ep3 Full Coilover Systems
- tokico blue + S tech
- ITR sway bar isntall on integra help? urgent
- VERY VERY interesting read on shocks
- HELP! Legend dual piston calipers. What master/booster?
- signifcance of ENDLINK PLACEMENT?proper endlinks for setup?
- TEIN Super Street Coil Overs
- del sol suspension
- is this ok? GC set up
- help me decide
- Where can i get GC Coilover springs
- quick suspension question
- SKUNK2 PROSERIES SQUEEKING
- tokia illumina shocks
- Advice for sway bars for a novice
- courner balencing results
- jhpusa
- stock gsr shocks and NEUSPEED Race / H&R Race??! longjevity? drop? performance? rates?
- OBX rear swaybar/subframe reinforcement....anyone try these???
- can i switch the sleeves on my coilovers
- HELP NEEDED Oddball 23mm itr rear sway bar ( Help me identify it!!!)
- I can't get rid of this suspension noise.
- Which Spring Rates for GC's/Konis on EK ?
- Suspension crapping out?
- Ground Control extended top hats on Buddy Club N+
- Suspension related tire wear
- EG rear strut bar ?'s
- help with new full coilover kit setup
- da traction bars
- Sway Bar Function?
- More suspension travel. Front wishbone specific.
- Koni + GC question, i know theres a million, but i just need a few quick things answered
- welding more subframe to prevent oilpan/downpipe damage?????????
- Tokico HP (Blues) & Eibach Pro-Kit
- reputable opinion required!
- shock and spring question...
- spring rate?
- New Suspension and Wheels/Tires. Now a Front Right Wheel Shake!
- Alignment
- Integra Type R Eibach Pro-Kit spring rates?
- swaping brakes from DC to EG
- For those who buy used suspension parts
- NEED TO CONTACT BRAINGLOW ON H-T
- 5 Lug Question for EK Hatch
- Civic Si 99-00 prop valve, what lines go where?
- toe change after camber kit adjustment?
- How do you like your D2s?
- (searched) ASR subframe brace plus SPOON rear lower arm bar
- DIY alignment translation.
- under brace instalations:
- Need to spend so much on a camber kit? aka Skunk2
- Is (front/back) 380/250 lb/in a stiff spring rate?
- Anyone tried out Tein's Mono-Flex for their EG's ???
- anti roll bar bush dc5 type r
- Lowering 2006 Civic (4DR)
- Are all alignment shps created equal?
- settings on kyb agx's for daily driving?
- oem sway bar bushing require grease ?
- Tokico Shocks/Springs
- Rear strut and c-pillar only?
- CRX Suspension question:
- are these good rates?
- Tokico Gas Shock and Spring combinations on EBAY
- Adding negative camber...options...cheap options?
- what contributes to bump steer?
- just changed the front shocks on a 93 coupe...there is a weird sound
- Koni Help?
- need advice installing ksports
- suspension on hatch
- OEM Acura or Honda LCA?
- Getting CV joint off
- just need some opinions
- What are the best coilovers?
- Rear LCA Mounts
- Stupid n00b question about spring rates...?
- dc2 mugen spoiler
- Trouble keeping rear end planted
- Would I need a camber kit?
- increase clearance
- H&R sport limited edition.
- Ksport*Tein*D2*Yonaka
- Need help choosing an adjustable suspension setup for 00 Si
- Canuck Motorsports springs
- Making use of S2000 rear calipers... any help appreciated.
- SubFrame connection to body
- SHEARED OFF LCA BOLT NEED HELP
- proportioning valve noob question?
- Bad Tie Rod End
- Anyone ever used this LSD?
- Should I attempt myself?
- 91 EF Toda Fightex FS Coilover: has anyone used these???
- Koni/GC 450f/400r CRX received last nite...
- Help Please
- Polyurethane lube??
- Front and Rear Tow Hook
- Fits Civics 88-00 and Integras 90-01.
- Brand new.
- $45
Toda Fi
- help
- best suspension for aggressive drop?
- can't free up front lca's from balljoint stud!
- Suspension Tech Rear Sway Bar W/ASR Brace On DC2
- Skunk2 springs
- Koni/GC w tophats - bumpstops
- 96 JDM ITR 4x114 suspension conversion into 96 GSR. ABS Problem. HELP!
- clicking noise when braking
- koni/GC spring rates
- wearing out tein basics question
- does anyone have the gc sleeves for the koni's
- Installed SP Fab traction bar today, what do I tell the alignment shop?
- CRX Suspension Build-Up
- hks coilovers knocking
- JDM GAB COILOVERS
- Torque Strut Bar
- car sitting wierd
- front sway bar link
- Integra ground controls on EK four door
- Looking for a coilover setup...need opinions/advice
- Confused over alignment report
- EK suspension question
- Ground Control/Koni Set up
- Spoon Tie Bar
- I need a front sway bar that clears my large bore RH
- springs
- Anyone know what these spring rates are?
- Best Springs for a 92-95 hatch
- Brake question regarding bleeding...
- S-Tech vs H-Tech DD
- loose steering fix?
- Looking for a suspension setup
- Skunk2 Pro Full coilover
- front camber kits
- Question on steering?
- Omni power coil over for eg civic, good or bad?
- Question about bumpstops
- LCA replacement
- Question on traction bars
- Possible problem?-Coilovers
- Do i need a camber kit?
- installing nrg engine torque dampener on my ls vtec ek hatch ?
- Question About the Omni LCA.
- Anybody replace the bushing from their Omni LCA's with some polyurethane ES ones?
- tie rods
- Sagging front after installing h&r race springs
- need a spring compressor???
- 92eg suspension fit 96ek?
- f2 fuction/form type 1 need help with dampening
- Stock Shocks PWN ALL!!!~
- My car is stitting to high on coilovers
- wheel hop?
- how much to replace rack and pinion?
- Shock recommendation for a DD smooth ride/slightly aggressive handling
- suspension question for daily driver
- Alignment..how often?
- street or sport omnipower full coilovers for DA???
- i need help/writeup on install of Tokico HP suspension kit
- Rear lower control arms going badd!
- rear sway or shocks/struts? low budget.
- Need Opinion on Suspension?
- Wheel shaking.. help!
- H&R oe sport or sport springs
- What Can I do to get the front Suspension stiffer
- Is BLOX Racing crap parts?
- anyone run toser coilovers ?
- ASR subframe on 2000 si?
- Camber Kit....
- From Koni's to .. what??
- tein ss custom rate springs?
- koni question
- swaping suspension
- Can tokico blues handle skunk 2 springs??
- Opinion's on replacing rear lca bushes?
- Bumpy Ride help!
- sk2 or F7?
- race suspension ?
- Is t in my head?
- Prothane w/ D brackets?
- ASR
- Springs in the front way more then rated
- Question for you ppl interested in drag racing. (its suspension related)
- Koni Install Question - Brake Line Retaining Ring - 91 CRX
- struts from 93 integra to 00 civic
- Another koni/gc question thread.
- Full race suspension (for autox) on an EG/EK/DC. Cost?
- Konis vs coilovers
- lightspeed brand?
- aqcuired itr suspension
- MFACTORY rear sway bar and brace kit
- Need a suspension system for a 98' PRELUDE SH.
- DC5 Tein S Tech
- Brakes, quick question
- Master Cylinder ?'n
- suspension from a rsx into a ek? possible or not ?
- Rear trailing arm, bushing question
- Additional suspension components?
- <<><> SHOCK SETTINGS
- what happend to the how-to start your own susp thread
- Steering out of alignment? check your tire pressures
- wanna fit 22" spinners any lift kit ideas?
- Rear Shock Detached???
- Suspension for AutoX/DD on EF hatchy
- ground control sleeve sizes
- What anti rol bars F and R Del Sol
- will da wheel bearings fit a civic?.....
- spring rate?
- What to get?
- JDM KYB AGX
- Prelude rear upper control arm, stripped mount.. suggestions?
- koni no work with bilstien?!?
- skunk 2 coilover kit
- Nuespeed or TEIN
- will 92 civic sedan rear discs fit 92 hatch
- Do i need a camber kit???
- Suspension setup help
- help with spring rates
- Dyno'd my KSports, need input
- Noob question.... Shocks and struts
- Full-Race ProAm Traction Bars
- spring rate for a tolerable street ride.. 2" drop
- need advice
- does it make sense to do an alignment?
- Koni Yellows
- Rear Sway bar
- progress springs with kyb agx... 93 hatch... didn't lower 2"?
- fuckin alignment!!!!
- tokico illumina shock/spring combo
- Skunk 2 Lowering Springs for EP3 SI, Compatiable with other civics or rsx's?????
- H&R for GCC+KYB
- need your help PLEASE READ
- Addressing Bump Steer problems
- Lowering spring Q's
- Which route is better?
- Tokci D-Spec vs. Koni Sport... AND spring rates/drop combo
- brake conversion
- Quick GC question - size of hex key?
- TEIN type CS Damper...
- adjusting koni yellows
- Coilover Question...
- Quick question, Can anyone tell me what type of coilovers these ARE!??
- CRX coilovers on EK does it fit?
- Question about Koni Yellows
- installation question EG hatch. Please Help!!
- Ksport/D2/FunctionForm they look the same but are not?
- If you had to choose & why
- adjusting suspension
- bearing question
- Lowering without tha camber kit... is it possible?
- ksport's leaking...
- Koni Yellow spring perch setting (With Eibach Sportline Springs) Question
- Skunk2 strut bars
- OEM SI rear sway into EK sedan
- DIY: How to remove Control arm bushings, and Replace with Polyurithane
