PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Hardrace 6101 Bushings
  2. Rear Disc Swap.. ABS Question
  3. Coilover rebuild?
  4. DIY HELP, Springq
  5. koni STR.T's review
  6. What Shocks Are Good With H&R Sport Springs For A GSR?
  7. opinions and help please....
  8. adjustable proportioning valve? one that doesnt need "T" fittings?
  9. Motor mount hardness?
  10. ground stopped making 350+ lb/in springs??
  11. d2 coilover height adjustment
  12. lifting a crx
  13. diffrence between multi link and double wishbone
  14. EG REAR DISC BRAKE CONVERSION !!!!!!!!HELP!!!!!!!!!!!!!
  15. Rear feels loose while braking
  16. wasnt sure how to search this
  17. 92 civic Si brakes vs. 92 Integra LS brakes
  18. EG suspension noises? sqeak and rattles
  19. *****************HELP: CASTER PROBLEM******************
  20. Bigger wheels vs Upgrade Suspension?
  21. omni power spring rates
  22. what size torque wrench?
  23. vibration on accell at certain speeds
  24. will i have clearance issues?
  25. Brake Rotor/Pad setup. coupon codes/promotional codes
  26. AVID Motor Mount HELP!!!
  27. Running Illuminas + HR Race springs without bumpstops
  28. JDM 5 Lug Calipers and Rotors.....
  29. Crappy Riding Del Sol! What Coilovers Should I Buy?! What Do I Do?!
  30. comptech subframe brace? Anyone got pictures
  31. how can I shorten the part of the axle where the axle nut tightens onto?
  32. EG rear trailing arm bushing?
  33. what the yellow stuff on my proportioning valve?
  34. lowering 96 accord lx qustions...
  35. Spoon calipers and Carbotech pads, clicking?
  36. How would you fix this?
  37. My CRV brakes needs replacing: Sacramento
  38. question on shocks!
  39. question: ground controls
  40. bump stop
  41. 93 del sol (civic) front wanders and feels light at 80mph+ suggestions please.
  42. BRAKE LIGHTS DONT WORK
  43. ETD traction bar Failure!
  44. siezed bolts in bushings help
  45. Energy suspension bushings.
  46. ABS Light
  47. Spring rates / slammed setup
  48. 4x114 HELP ASAP
  49. Turning/vibration issue
  50. Traction bar squeeks
  51. drag suspension
  52. Whats the difference between Integra brakes and 96 spec ITR brakes???? (other than bolt pattern)
  53. blox or skunk suspension parts HELP
  54. What type of coilovers?
  55. EG hatch alignment
  56. rough suspension
  57. 2 inch lowering springs [97 coupe]
  58. Quick omni power coilover question..
  59. Tokico, Skunk 2, Bilstein shocks?
  60. ride height affecting handling?
  61. Whats the difference between Integra brakes and 96 spec ITR brakes???? (other than bolt pattern)
  62. Caliper rebuild question
  63. will adding rear sway bars make it harder to cradle up ramps??
  64. 2003 CL Type S 6 speed spring rates.
  65. strut fittment
  66. XYZ Racing Coilovers???
  67. Suspension Help.
  68. eg
  69. ABS problem
  70. Suggestions..
  71. Improving the suspension system civic EK 96 - Bilstein Or TEIN???
  72. DIY Brake Booster And MAster Cylinder??
  73. Need help on Susp. setup searched;specific
  74. question about my brake lines--- is this ok???? (pic inside)
  75. using eg ebrake on teg brakes
  76. 4x114.3 - is it worth keeping?
  77. Wilwood BBK 12" kit fit 16"s ??
  78. blox full coilovers vs function and form or perhaps g/c w/ koni
  79. H&R Sport Springs AND KYB AGX
  80. dampers middle nut
  81. gsr brake swap
  82. gsr sway bar help
  83. If i'm missing a wheel stud, will it hurt anything in the short term?
  84. Suspension maintenance - What is commonly needed to be done?
  85. is this stupid?
  86. Coil over question
  87. *URGENT* 1" dc2 master cylinder/brake booster into Dx Eg civic ???
  88. ef9 brake conversion
  89. Brakes question
  90. do DA OEM struts fit a EG??
  91. Coilover Kit adjustment
  92. What to do with GC top hat bumpstops?
  93. adjustable suspension 4dr integra
  94. Koni / Ground Controls - Which Rates Are For Me?
  95. suspensions help koni with sportline or new blox coliover
  96. anyway for me to go lower?
  97. alignment and susp
  98. Removing / Installing Integra bushings
  99. need suspension info plz help
  100. 2006 Civic front breaks
  101. RSX 5 LUG WORK ON 99-00 CIVIC?>
  102. suspension help
  103. Legend caliper swap on non-ITR integra question
  104. do not want to rub
  105. PIC VS Buddy CLub N+
  106. Brake swap now rear camber issue
  107. what Casting # are the front GSR Calipers 1999
  108. Hitting your Bumpstops? Extended Tophat rant
  109. Different brakes
  110. New rotors and pads, then calipers did not go back on
  111. Skunk2 Pro-s Coilovers, rattlle in rear.
  112. my civic sits highaaa to the floor
  113. Opinion on these two "Eibach" sets
  114. Broke something. Whats it called so i can replace it
  115. Lets have a discussion on Poly Bushings.
  116. left front tire locks on braking
  117. PIC Apex Vs Selects?
  118. 96 ex (rear) Drum - 96 LS Integra (Special edition) Disk Swap
  119. adjust strut rebound evenly
  120. H&R Sport springs on 96-00 Civic - Any good? Any pics?
  121. What would you recomend
  122. Spring install mess up?
  123. drop the em1, help!
  124. Raising DD
  125. suspention tech. sway bar
  126. anyone have issues with Hard Race Trailing Arm Bushings?
  127. recommended drop 4 a 01 integra
  128. Password JDM bar
  129. i can't get the damn rotors off!!! (i'm past the screws)-- help!!!
  130. S2K or ITR
  131. Skunkworks (old version) sway bar...
  132. ETD Racing or SpoolinPerformance Traction Bar?
  133. shocks bottoming out constantly. shorter life?
  134. Master cylinder was replaced; now no brake fluid...
  135. suspension problem
  136. 1999 Civic SI or 1997 Integra Type R Brakes
  137. My coilovers have two springs what is the function of the lower one? HELP!
  138. is there a difference in rear cailpers on all 5 lug???
  139. Noob question
  140. Suspension Technique HELP..
  141. Illuminas w/ H&R race springs
  142. need sway bar advice from suspension guru's
  143. anyone running on basic tanabe suspension
  144. Clicking noise, already changed both axles
  145. Si Brakes or Big 4's (4x114.3)
  146. Prop Valve for non-abs 92-95 civic disk conversions?
  147. Ground Control Problem
  148. tien ss vs skunk2/koni?
  149. What suspension set up is this??
  150. What brand brake master cylinder to buy?
  151. Tein basics-how do they ride
  152. Sway Bar.strut bar Questions for 99 Lude
  153. Removing ABS: Is There Ever A Good Reason to do It?
  154. Sway Bar?
  155. da integra rotors/brakes
  156. I have a question, I have a set of Form N function Coilovers {Can they be serviced!!!!!
  157. what percentage of handling is due to shocks/springs?
  158. Koni Yellow Circlip Question.
  159. Skunk2 Coilover + ?Shock?
  160. 94 gsr - Ground Control + Shock question
  161. My new suspension plans - do you guys think this would be good?
  162. ETD Traction bars for EG - are they good?
  163. HELP with Full coilover H&R suspension
  164. Blank rotors are better than cross drilled and/or slotted
  165. Proper xdrilled/slotted rotors direction?
  166. noob question...no pillowball upper mounts?
  167. Offtopic camry 1994 steering shake at 55 mph to 60 mph
  168. Would ASR help on subframe hole
  169. 94 gsr drop.
  170. Pro Ac'tive
  171. abs removal on a prelude 4th gen
  172. Spring question, some input!
  173. ASR setup????
  174. Any idea what coilovers these are?!?
  175. Blox Rear Camber Kit
  176. UHHHHHHHHHH WHAAAAAT Suspension for 94 ls teggy???
  177. Yonaka full coilovers
  178. proportion valve
  179. What Suspension setup do you suggest???
  180. Accord/Prelude 4x114 Hubs Press into GSR uprights??
  181. Lowering on KYB GR2
  182. Tokico Illuminas w/ skunk2 coilovers. Guy wouldnt align my car!!
  183. 2 Questions, cutting bumpstops & gap @ LCA
  184. When I push the brakes, somtimes nothing happens!?!
  185. si sway bar clicking noise
  186. need help with my DC2 bushings and shocks
  187. Valve job on a 89' civic hatch with a D15 SOHC non vtec
  188. Brake in procedure - for changing pads and/or rotors
  189. break booster evacuating break fluid through intake manifold?
  190. i wanna go lower
  191. Need your input****PLEASE****
  192. teins basic
  193. Rear Shock Bushing
  194. Vx rotors
  195. My car was just aligned and I am still having issues
  196. front brake pistons are stuck. NEED HELP! EMERGENCY!
  197. thicker coilover spring in front
  198. EBAY STRUT BARSSS
  199. Lower ball joint?
  200. Serious brake problems I need help
  201. Brake issue
  202. 3 o'clock and 9 o'clock slop, but with wheel movement?
  203. is it me, or do others think its kind of a rip off for ground controls?
  204. 88 EF HATCH COILOVER QUESTION
  205. Do you need to cut bump stops on Coilovers?
  206. Front brakes locking up
  207. Violent steering wheel shake on take off. Can't go pass 10mph!
  208. ?!help in adjusting coilover spring?!
  209. Bump Steer?
  210. Brake Booster Theories/Experience
  211. suspension for DA
  212. Lowering your car
  213. Front suspension for a one-off/kit concept.
  214. brake pad thread
  215. Does anybody have the Neuspeed/Bilstein Coilover combo?
  216. Pic request: Neuspeed race & Bilstein sport
  217. HELP!!! 12.19" Wlwood Dynalite Big Brake vs 16x7 + 42 Offset Volk CE28Ns [ Fitment Issues!!! ]
  218. aligment setup
  219. uneven coilovers
  220. Suspension Problem: A Little Help Here, Please...
  221. my BRAKES!!!
  222. Question about Koni Yellows
  223. Struts from a Civic to an Integra
  224. what would be the best way to lower my EG
  225. Toe
  226. For all u Koni Yellow and Ground control Peopl
  227. Skunk2 Pro-S Coilover owners/HELP ASAP! 06+ Civic
  228. Rotor Screws WON'T come out..
  229. What Works: suspension parts.
  230. What kind of shocks/struts are these????
  231. Legend front calipers weight?...?
  232. opinion on tanabe sustec pro s-oc
  233. Tein Htech on ek decision
  234. Disc Brake conversion on a 86 Accord
  235. know where i can get a set of omni coilover sleeves?
  236. SUSPENSION QUESTION
  237. Which grease?
  238. wheelspin???
  239. 00 civic suspension to a 94 civic ?????
  240. ek suspension setup advice
  241. please help! konis(supercup kit)&ground controls
  242. tein coilover swap??
  243. Understanding adjusting Yonaka Coilovers
  244. SS braided brake lines: worth it?
  245. Will a 3 jaw puller remove a hub with the axle still in the knuckle?
  246. aura legend gs calipers to jdm eg6 civic sir
  247. diffrence between double wishbone and mcpherson
  248. b16a1..which cv boots?
  249. Best place to get caliper rebuild kits
  250. rear disk conversion..... hub swap?
