View Full Version : Suspension & Brakes
- spring rate?
- Where to get Bump Stops / Jounce Bumpers?
- power steering rack w/ belt removed vs manual rack
- Hard Brake = Pop
- omnipower coilovers=teh rake! please help.
- koni yellow adjustment click
- Does anyone no about tanabe coil overs?
- alignment for auto x
- 95 integra suspension
- Anyone W/Dropzone Springs and AGX's?
- ef struts on eg
- 26mm front si sway on a dc2 ?
- NEED Opinion On THe Following Full Coilover
- what shocks/struts w/ground control
- Skunk2 Or H&R Race
- Ksport Coiovers on an Eg/Eh... from Bodykits NW.. 56K maybe
- help with strut bar
- 91 CRX rims offset
- CAN'T SHIFT WITH ITR SAY BAR ON
- tokico shokcs?
- Shock Replacement on A EG Civic (KYB AGX)
- Ebay dilema
- Edelbrock IAS coilover suspension?
- BEST Sway bars for an EK
- neWhiteline SUSPENSION FAQs and Tech Articles
- adjustable endlinks
- Is It my shocks or springs causing rough Ride?
- Installing Full-race Tractionbar
- DIY Camber Kit?
- Q with Wicked Tuning LCA's or any other aftermarket LCA's
- what kinda suspension
- Let the flaming begin!!!
- skunk2 vs. ractive
- clanking noise coming from my suspension
- about to order H&R springs...
- AREN'T ALL SUSPENSIONS THE SAME FOR CIVIC & INTEGRA 90-00
- Need Information on the Physics of a coilover system
- motion ratio of 96-00 suspension?
- loose steering wheel when hitting bumps???
- Subframe bolt holes not lining up
- Suspension clanking
- J´s racing suspension?
- rear knocking noise will not go away
- easy answers for someone, a couple quick Q's regarding Skunk2 camber install
- Compensator Arm Poly Bushings for EK HELP!???
- oversteer??
- Removing coilover sleeves from shock?
- Got into an accident.. now suspension is way off..
- can anyone explain?
- brake swap problem!
- replacing rear subframe
- SOS i dont like understeer
- civic Ex sway bar in DX?
- Best way to brace a EG hatch, Also brake/wheels questions(96 ITR)
- Mugen Sports Suspension Kit
- H&R OE sport springs
- side rear window bars
- GAB - need advice
- KYB GR2 - Good or Bad?
- Help Me Plz, 5lug CTR hub could be pressed onto a 96GSR Spindle???
- who makes purple coilovers?
- Omnipower Camber Kit?
- Type r sway bar on DB8
- ???? on Skunk2 coilovers
- Tokico Suspension Kit for a ek
- drag suspison what is the best set-up 600 plus hp daily driven.
- DG Industries Chassis Brace System
- why my car so bouncy?
- Omnipower/D2/KONI + GC
- What suspension to get real low??
- **5 inch drop**...
- just bought a basic damper kit for my 96 2 door TEIN what exaclty does a coilover system come with?
- eibach sportlines?
- need help just got kyb agx shocks with neuspeed springs!!!!!!!!!!!
- CRX lowering parts
- EM1 traction bars. Final thread?
- civic hatch suspension adjustments...AMAZING
- suspension mods...
- bumpy Suspension around turn...
- Sturt Mounts
- saggd springs pictures
- itr/gsr sway-bar end link
- TEIN SS damper settings
- LCA Stuck! 00 Civic Si
- Need some input on full coilovers
- lower
- a spec racing subframe
- alignment question after suspension change
- Am I missing anything from my Ground Control kit?
- ek springs and shocks
- Rear LCA kits & sway bar?
- Differance in RSR down springs, and RSR race springs? (height)
- Suspention ?
- Where to buy Ground Control Perches
- Drag racing suspenion set up???
- Koni Yellows + OIL???
- ST drop forks
- Quick question, really easy...
- What are your opinions on frankin-setups?
- Tein H Tech Springs
- How much camber adjustment would be needed?
- Neuspeed Strut Bar
- sloppy suspension after hard run
- Omnipower A-arms...any good
- car too low?
- are stock/oem struts/shocks that bad...
- Omnipower vs. KONI Yellow combo - THe Truth
- Neuspeed Race Springs... which on which side?
- Question about new strut install.
- UGR FULL COILOVER KIT same as (KTELLER) OMI coilover kit?
- quick question.........
- Do I HAVE to replace shocks in pairs??
- is omni too stiff??
- Help identifying sway bar . . .
- Lost on camber
- Does anybody have this?
- question about koni reds paired with omni sleeves
- spring/coilover/shock good medium for drag and autox
- Lack of sway bar question
- BUSTED STRUTS !!!!!!!!!!!!!!!!!!!!! HELP !!!!!!!!!!!!!!!!!
- Corner Weighting. ?s to be answered
- coilovers
- EK suspension on EG
- Camber Kit..etc.
- shock help
- Creeking Springs ???
- Need streetable suspension on my all motor EG hatch. Need suggestions?
- What wrong w/my suspention??
- Quick question about camber any info is welcome
- Double wishbone or trailing arm, which is it? Also, wheel rate vs spring rate
- What does Spring Rate mean....
- need help with suspension question
- camber how to adjust
- BC Pillar bar??
- tiens' or omni-power???
- PICS of V2 coilovers
- Ground control coilovers - 3 different kits
- civic Comptech springs
- D2 coilover fitment question for civic
- da sway
- Skunk 2 Threaded body Damper kit!
- Teg 95 Inner Panel Removal?
- Uneven drop in the rear?
- which suspension for dd/autoX H&R, Progress or Ground control (did my homework)
- which one would ya choose
- Tein coilover problem..
- Lowering Mugen Dampers...? Has anyone done it?
- Installing Strut Bar on DC2
- Strut bars with ground control upper mount?
- sway strut???
- do i still need spring compressor with eibach?
- are eg and ek tophats and front forks the same besides 99-00si
- Do you need a spring compressor
- Brake Line help needed
- front lower H bar....
- DA sway bar choices?
- oem sir 99-00 strut bar
- finally got my hands on some hardrace products. check them out. thoughts? comments?(56k owned)
- For those with adjustable dampers
- What seperates cheap strut/sway bars from expensive strut/sway bars?
- help.. omni powers not fitting?!?!? wtf
- another sway bar question
- Best struts under $500
- rear disc conversion for 94 del sol
- Lowering Springs-car sits lower on left side
- Omni power LCA's on 94 LS * NEED HELP *
- tokico shocks and springs?
- Replacing my Lower Ball Joints for Honda Accord, need HELP!!!
- help with the camber.
- HELP me predict how many washers I should use for the rear camber problem.
- Need Help
- HELP..HOW DO I GET THESE OFF...TRYED EVERYTHING
- Ksport coilovers & control arms ... pics & review
- civic sir 98 strut braces
- Koni yellows spring perch questions???
- Suspension for BB6
- Attn Mods: This forum doesn't show up in the forum jump menu
- I have Given Up
- which tools?
- skunk2 springs on kyb gr2 (any suggestions)
- tein NR question...
- lowering probs
- skunk2 pro series coilovers or omni coilovers?
- Full dampers...which ones?
- Cheaper way to do alignment?
- DO SUSUPENSION TECHNIQUE SWAY BARS SQUEAK
- DC2 lca's on EG chassis?
- Under sprung?
- Omni coilover sleeves plus Tein struts
- good drag suspension setup?
- energy suspension bushings rear lca install
- clunking and ticking noise after installing brakes
- bushing...
- ek owneers
- Installed Wicked Tuning LCA's...
- got my alignment done, check out my camber settings!
- help me pick out springs. searched
- sneak peak; Eibach Coilovers
- Q About ITR LCA's and the Suspension that would fit...
- Make sure i'm right for my english to metric
- Kyb Agx opinions?
- Bad bushings?
- Eibach sway bar compadibility?
- Sway Bar
- Best Exhaust for crx?
- Adjusting my Omni Full Coilovers...
- car too low for alignment
- Completed Custom Koni Road Race Suspension for ITR...
- 95 accord rear suspension help
- H@R race springs??
- Helper Springs on Coilovers
- Camber, Searched and nothing, need quick answers and websites
- 1993 acura integra front suspension question
- 96-00 EX Front Sway Bar compatible with 99-00 Si LCA's?
- Help! NON Honda Koni Sport Tech Info
- Brake Question?
- answer quick!
- lug wont come off just spins
- Benen X-member bar
- my brake upgrades...my take on a buget brake up grade
- ITR SUSP. ON MY EM1?
- KG/MM springs good/bad
- Need some opinions for a coilover set-up.. Omnis?.. Ground Controls?
- GC Koni Yellow Specific Adaptors....Do I have the correct ones?
- you guys think this should be good
- Will a H-Brace Be In The Way of A Front Sway Bar on an EG Civic Hatch ? ? ?
- know a good place that can install springs and shocks for cheap? (so cal)
- MOOG upper balljoint RECALL
- Restoring Stock Height on 89 CRX HF W/B16
- how to use koni warrenty?
- The dreaded broken rear Lca bolt through strut on 98 civic info for those who don't know
- what to use for shock oil.
- Changed my brothers suspension on his gti
- Bolt Size For OEM Front Strut Bar
- Seized Bushings
- Strut noise in rear right (riding on skunk2 springs)
- Bottoming out on small animals
- Spring Rate Conversions kg/mm - lb/in
- Help!! Skunk2 Coilover Kit
- Help on CHOOSING COILOVERS
- Racing Gear JTC N1 coilovers
- HELP! Wheel Stud's broke...
- Old School Apexi Suspension??
- itr shock + h&r in front, h&r + stock integra shock, good combination?
- n00b question: buddy club racing spec dampers. valving starting to go bad??
- Violent shaking problems
- spring question
- ** clunking on rear shocks
- what and where can I buy a tool to adjust my coil-overs
- EG / Tein RS Question...
