PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Fitment of Koni Sport suspension kit on 1992 civic
  2. adjustable UCA's????
  3. Are my Ground Control coilovers switched? fronts on rear/Rear on Front
  4. can shity springs make a good shock bouncy????(not as noobish as the title sounds)
  5. dc2 sway onto eg
  6. DD Lowering ?'s
  7. Are my springs sagging?
  8. GC tophats interfere with OEM DC2 strut bar, suggestions?
  9. Need Help with my suspension on a 2002 Civic LX Coupe
  10. steering problem??
  11. Koni Red w/ Skunk2' Coilovers
  12. 1993 Del Sol Race Suspension Setup
  13. What to choose
  14. what the better spring
  15. Uneven ride height
  16. camber kit fitment
  17. results of having negative 2-3 degrees of rear camber
  18. h&r race spring rate
  19. shocks
  20. HAVING TROUBE WITH CAMBER ON MY EM1
  21. Megan Rear Trailing Arm Bushes
  22. Would switching collars on GC's solve my problem?
  23. Yet Another Trailing Arm problem
  24. Im having WEIRD suspension issues SOS!!!!!!!!!!
  25. koni yellows installed and now my car is a monster truck even with drop springs?*pics*
  26. thoughts on Skunk2 Sport shock??
  27. weird steering with grooves and bumps
  28. Lowering springs
  29. How to remove outer tie rod boot?
  30. Eibach Pro System Kit
  31. da spindle into db- will it swap?
  32. 02 Civic Lowering :scared:
  33. da or dc2 hubs?
  34. Function & Form Type 1 Coilovers
  35. want to set up a dc5 for dd and canyon
  36. NEED HELP! just changed my axles!!
  37. Camber...how much is too much?
  38. in toe question...
  39. end links
  40. Suspension question
  41. Suspension ideas for 98 integra GSR
  42. Need some coilovers to lower this hatch. No ebay stuff please.
  43. Installed new suspension...3 questions
  44. Mounting koni yellows lower on front fork.....(DA related)
  45. GC spring rates for a 4door EF
  46. eibach sportline springs on 99 SI.. work on 96 integra LS??
  47. Problems with CTR Rear Sway bar HELP!!!!!!!!!!
  48. Rota 16" slipstreams will wilwoods fit?
  49. want a cheap alrigth suspension that will slam my EF
  50. Noise coming from front wheels...
  51. ground control
  52. kyb agx and GC coilovers
  53. Funky noises after drop and alignment question
  54. Type-r shocks?
  55. struts
  56. eg help
  57. Looking for 12k and 18k springs
  58. coilover adjustment issues
  59. tokico hpk?
  60. Si front cross member?
  61. What Coilovers are there? HELP PLZ
  62. Omni Power LCA Bushing???
  63. !!!LCA bushing problem....
  64. Pic Performance Coilovers
  65. Stoneridge 2008 Friday July 10th 8:00pm
  66. CUSCO
  67. Koni Yellows - Question - pic included
  68. Body Roll
  69. em1 Struts on Ej1
  70. increasing ride height??
  71. Ground Control application question
  72. buddyclub camber kits
  73. just put on my skunk 2 springs.
  74. Review request: Tein Flex MONO-Winding Master
  75. Rebuilding Hayame V1s
  76. pros and cons of power steering...help!!!
  77. struts and springs /coilover
  78. will OEM endlinks work on aftermarket LCA's?
  79. ek suspension on dc?
  80. New control arm bushings gone bad???
  81. tein flex OR function type ll ???HELP????
  82. how difficult to replace struts?
  83. Omni Sport Coilovers * Problem
  84. Where to get replacment shocks for Ksport's?
  85. Skunk2 Pro Series Question
  86. Integra Five lug suspension
  87. ESP BB6 Strut bars!! WORLD PREMIER!!
  88. ??'s for koni yellow/gc setup owners
  89. aftermarket traction control arms - caster what's the ideal setting
  90. Setups for dumped Civics...?
  91. integra GC spring rates
  92. spring identication??
  93. Ebay coilovers on skunk 2 sport shocks?
  94. busted struts
  95. Do I need camber plates?
  96. 16" Slipstreams how many inches do I go to fit wilwoods
  97. Can I just swap rotors for type r rims?
  98. ***Need help on deciding suspension***
  99. Buddy Club N+
  100. Camber and Toe Question
  101. Just got new wheels, now i wanna lower it...
  102. camber
  103. 94 integra ls suspension ????
  104. koni yellow/gc
  105. jdm ITR 16 inch wheels rubbing on camber kit help
  106. suspension question
  107. lca bushing ????
  108. How stiff should I set my new Koni Sports
  109. best suspension for daily
  110. Takico
  111. H&R race spring for EK on DC?
  112. Koni + OEM bumpstop question
  113. Tein Upper Pillowball mount..?
  114. Lowering a 97' Accord
  115. HELP ME FIND NEW REAR axle SPINDLEs
  116. raise the ride with shim sitting on KONI circlip
  117. Newbie rear sway bar question.
  118. Spring compressor or....
  119. Omni rear camber kit
  120. camber wear
  121. Metal bar under fender on the frame?
  122. Help with dampening..
  123. where to buy hardrace bushings?
  124. Aftermarket Rotors...
  125. rear LCA bushing for EK (need help with cross referencing part)
  126. brake question
  127. Cheapest place to buy Omnipower Street full coilovers? (+ opinions)
  128. Rear sway bar Q
  129. Crx rear Cross memebr Issues
  130. when using xdrilled rotors....
  131. Camber arm hitting Shock tower and going through engine bay?
  132. CTR Brakes Question
  133. Which brake lines will fit my car?
  134. ASR swaybar endlink positioning question.
  135. Can camber kit cause caster to be off?
  136. ek and dc strut fork and RLCA interchangable????
  137. 1st Gen CRX Lowering
  138. coilover question
  139. DA balljoints...am I getting shafted??
  140. Shock mount trick...
  141. tein type HA
  142. AEM Big Brake Kit
  143. axle's for lowered civic?
  144. crx alignment question...
  145. Si strut fork on a hatchback
  146. function form type 1 adjusting question
  147. spring helpers for back same as drag springs?
  148. NSX calipers on Civic.........problem driving me nuts!!!
  149. Advice for '95 Civic - street use with occasional autocross
  150. Another Wilwood fitament question
  151. Wobble Woes after clutch install (Suspension related)
  152. gsr rear sway bar
  153. Big Rear Swaybar??
  154. koni yellows in a red special "d" box.
  155. Inner Fender brace..
  156. Good brakes for 15 inch rims.
  157. Anyone Heard From Andy @ AMR Engineering?
  158. best way to take off brake line bracket???
  159. NSX caliper bleeder screw.....parts #??
  160. subframe question
  161. Alignment Issues
  162. GC/koni Vs. tein. chime in guys need your opinion
  163. Suspension setup for NHMS
  164. Cornerweight Issue/Imbalance
  165. GC/Koni Install?
  166. NSX rear caliper upgrade? is it worth it?
  167. 4x114.3 hub question.
  168. HELP!!! HAVING MAJOR PROBLEMS W/ FRONT CAMBER KIT ON MY EM1
  169. what springs would be better fro my dc5 tein or tanabe??
  170. Looking for rally suspension.....
  171. Anyone have the springs rates on these coilovers? cant find em!
  172. does lower take you farther?
  173. rigid ride need some help
  174. Which drop for $cheap?
  175. spring and shock combo
  176. Front upper control arm which way to put the achor bolts back in??
  177. Where to buy rear eibach coilover springs?
  178. Tein S.Tech springs for EF fit DC?
  179. toe problem after megan lca's instaled
  180. asr subframe brace
  181. funtion an form type 1 96 civic
  182. Do 94-01 integra rear lower tie bars fit on 92-95 civics?
  183. c pillar bar...wtf?
  184. Write ups on Traction bar Install?
  185. What brand is the best for lowering spring on my 08 Honda Fit Sport?
  186. GC/Eibach spring rate # conversion?
  187. newbe with a rack and pinion question...
  188. stock vs. 6k/8k vs. 8k/10k
  189. i need help lowering
  190. Tein Flex vs Tein SS coilovers
  191. integra spindles on crx
  192. ebay set-up performance
  193. Honda-Tech Ground Control special kit password???
  194. Brake Pads interchangable?
  195. Koni Sports - Circlip location question
  196. NEW Function/Form Type 1 for 96-00 civic
  197. Tein HA rust (still drivable?)
  198. Tein HA Driving Master coilovers EF9
  199. When Installing extended wheel studs???
  200. ground control coilovers rate?
  201. Bump Stop question
  202. Sway Bar/Strut Bar Combination
  203. blox extended studs
  204. EXTENDED STUDS QUESTION
  205. Help Identify DC2 suspension.
  206. New to suspension stuff 93 del sol
  207. need GC spring rate help!?
  208. Skunk2 Pro S coilover opinions
  209. Tein S.Tech Too soft in front Da9
  210. 96-00 Hatchbacks with adjustable suspension chime in!
  211. koni shocks
  212. Tokico Illumina Suspension kit for 92 Hatch - Good or Bad??? Please help!
  213. My fellow Illumina users...
  214. Need help with trailing arm issues.
  215. st suspension coil overs
  216. Slammed for Daily Drving
  217. Rear trailing arm bushing tool. need size.
  218. SS BRAKE LINES
  219. Problem with rear trailing arms..need help!!
  220. Is there a cure for car leaning on drivers side?
  221. Time For New Suspension on the DA... Any Suggestions?
  222. how do i change springs on 91 civic si please help
  223. Integra Lower Ball Joint - will not spin.
  224. Which exhuast will clear ST rear sway bar?
  225. I need help with some swaybar measuremnts.
  226. Question About 99 SiR Susp in a 95 Coupe
  227. 1994 Honda Accord Squeaks!!!
  228. Buddy Club Racing Spec Damper fullcoilovers.....
  229. Any experience with these two Coilovers....Tien Coilovers & Megan Coilovers
  230. What endlinks work good with Function7 LCA 's?
  231. autox & dd spring and dampers
  232. Torn between Blues and Illuminas for my DD
  233. SF area shop for full bushing replacement??
  234. what springs/spring rates should I get? somewhat new to suspension..
  235. D2 coilovers??
  236. EF Civic Dail driver upgrade suggestions?
  237. For those who have replaced ALL there bushings, questions....
  238. Tein Flex coilovers or a list of other parts
  239. will JDM DC2-R rear LCA's fit EK's....
  240. help DIY extended tophats with Tein ss
  241. Upside down tie rod?
  242. Spring/Coilover for AutoX and DD
  243. rear crossmember
  244. 93 civic front sway bar with 97 civic front lower control arm?
  245. shorter steering knuckles for 92-95 civic
  246. Space b/e F7 lca & AMR Engineering coils
  247. 92-00 civic lowering springs?
  248. Stock suspension might be shot... looking to replace...
  249. do you agree with everyone?
  250. Spring of choice best handling?
