PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Brake cooling
  2. Shock Mount Bushing Lower Control Messed up
  3. Bench Bleeder Kit: Can I make one?
  4. Integra Lower Control Arms
  5. Question about Roll bar and Subframe brace
  6. civik ek 96-00 bilstein to EG2 Del Sol??
  7. NO $$$ ButI need new shocks 2000 civic turbo Daily Driver
  8. Need help with coilovers and spring rates.
  9. Which ABS ring for CircuitWorx Stage 1 Axles?
  10. Road race chassi prep.
  11. 4040 install?
  12. Suspension ????? 25" slicks fitment
  13. function form type 2 question
  14. Rear Camber kit for em2 (05 civic)
  15. dc2 abs delete help plz!!
  16. need a little help doing my disc brake conversion
  17. Passenger Side of car is higher then driver
  18. integra with high spring rates and it still bottoms out, what spring rate do I need?
  19. need help with suspension
  20. swar bar question
  21. Anyone use brembo blanks and axxis deluxe pads?
  22. Stock Shocks + GC Sleeves + Custom Top Hats
  23. The point of rear brake conversion?
  24. Rear lower tie bar brace
  25. a little confused about koni/gc pricing
  26. High Speed braking, brakes heat up and car wont slow down
  27. Brake mystery of three lifetimes
  28. Easy Q: ITR coils on 00 Civic?
  29. Coilover help needed please.
  30. Annoying squeak sound coming from wheel bearing?
  31. HardRace sway bar end links
  32. integra radius arm bushing?
  33. caliper replacement 98 Civic EX
  34. question on bleeding brakes?
  35. d2 springs??
  36. 98 Accord 3.0 2DR
  37. Strut Bearing
  38. what should i use ?
  39. DB7 suspension help
  40. Godspeed vs. Yonaka
  41. shortened shock absorbers
  42. camber kits
  43. Car squats, pitches, and sways...
  44. lowering springs raised my car? please help.
  45. What shocks to get for my EF/Tokico or kyb??? Thanks
  46. I did need a alignment right?
  47. Brakes hanging up after ABS delete
  48. Dual Rate Springs
  49. Moog experience...LCA bushing too small for bolt
  50. FINALLY getting my HardRace bushings installed!
  51. 10k/8k = ?lbs??
  52. dc/si the same?
  53. H&R Sport vs Tein Stech
  54. bendix CQ series?
  55. Question regarding adjustment of Koni Sports
  56. Quick alignment question...
  57. suggestions on spring rate
  58. Stripped Stock Ek Strut HELP PLEASE!!
  59. Rear Disk Conversion
  60. Ek Eg top mount difference
  61. Shim caliper brackets vs. Machining caliper brackets
  62. installed eibach sportline on kyb 5 way struts. CAR IS TO LOW any fix
  63. CAN YOU ID THESE COILOVER SLEEVES
  64. just got my fake ASR!! =)
  65. d2 coilover?
  66. DC2 Springs
  67. 1" to 15/16 adaptor?
  68. Brake Master Cylinder Questions
  69. Help indexing Eibach Pro-dampers
  70. will 01 civic tein coilovers fit on 00 civic?
  71. Godridge SS Lines Crack....
  72. Rear Disk Conversion
  73. Switching suspension?
  74. 2000 civic si suspension
  75. how to adjust GC coils?
  76. Question about my GC upper mounts
  77. Do the front struts have a rubber cap on the srings?
  78. anyone in the n.y//c.t area that can allign a drag car?
  79. Loud Brake Squeal
  80. Does anyone need a 1" master cylinder?
  81. Koni Ground Control RIDES LIKE CRAP
  82. Time for some new suspension stuff
  83. b18b1 swap first time questions
  84. Koni shock ? the diff.....
  85. Best strut/spring combo for smoothest ride
  86. big brake kit for del sol
  87. Innovative 60a motor mounts vs 85a
  88. Who do I trust for an alignment? NTB? Firestone? Honda?
  89. energy ball joint dust boots (clip?)
  90. Function 7 LCA replacement bushing???
  91. Struts Shot
  92. How do you test if shocks are good?
  93. 94 integra HELP!!! PLEASE
  94. Which do you recommend?
  95. Image needed: Rear disc e-brake cable connection to caliper
  96. Best OEM Replacement shock: 96 Integra LS
  97. Swapping to a 1 in master cylinder?
  98. Painting suspension components
  99. Quick question for suspension gurus
  100. Total Noob GC/Koni Yellow Help
  101. I need suspension help badly
  102. honda wants 70$ for one bushing?!
  103. Help I know NOTHING!
  104. What kind of rear sway bar should I get for my 95 honda civic 4dr EG sedan?
  105. wheel fitment NOT aesthetically appealing
  106. EF: Unsprung Mass of Suspension
  107. wats the difference
  108. ***ATTENTION! Corrected Koni/Ground Control information!***
  109. poly bushings in front sway bar d bracket
  110. Skunk2 Pro S Vs. Koni/Ground Control
  111. Help with Tie rod end
  112. Ground Control locking bolt
  113. rear lower control arm bushings?
  114. blown strut. skunk 2 pro s
  115. del sol suspension components
  116. DROPZONE GEN2 STRUTS EXPERIENCEd reviews ?
  117. 99 si mc/bb on abs dc integra?
  118. AXle hubs where to get
  119. blown omni drag coilover - what to do next
  120. Question About KYB AGX Condition After Accident
  121. Solid Poly Rear Trailing Arm Bushing OK for street?
  122. wheel bearing question
  123. Need to replace brakes
  124. What struts w/ S2 sleeves.
  125. Question regarding sway bars and strut bars
  126. rear strut bushing 86-89 teg/84-87 civic/88 crx
  127. 4x114.3 JDM ITR front wheel bearing or hub Replacement Parts?
  128. squirlly suspension on 97 civc ?
  129. 16" with 12" Tenzo Big Brakes
  130. Camber Kit
  131. some brake Q
  132. Brakes groan
  133. new to the camber and toe issue
  134. Compensator arm bolt seized! HELP!!
  135. S2000 - got rear wheels replaced, now a jerk?
  136. Full coilovers for a 2010 Odyssey
  137. 96-00 front sway bar mounting non-si/ex
  138. ??? help someone. i just installed my 4x114 .
  139. Question about front subframe and handling
  140. rebuilding neuspeed coilovers?
  141. knowing newb alignment question
  142. neuspeed+koni ? will it work
  143. brake booster ?
  144. Coil over question....
  145. Ground control height?
  146. Sealant- for steering rack guide screw
  147. what's the difference in DX prop valves for 2dr/3dr vs 4 dr?
  148. *******PLEASE HELP! Calling ALL Coilover Experts*******
  149. koni yellow snap ring failure
  150. Sinking pedal
  151. using ground control on tein
  152. anyone have silkroad coilovers??
  153. Coilover suspension questions
  154. Question about ES bushings being pressed out?
  155. quick brake questions.
  156. USDM ITR sway bar end holes
  157. ground control coilovers adjustments
  158. best coilover sleeves for around $200?
  159. z10,mfactory,blox,initial d,what next?
  160. what is the best suspension set up
  161. Coilovers
  162. Quick Question.
  163. Tokico HP question
  164. Apexi WS Coilovers. Need thoughts?
  165. camber kit
  166. HPDE track day suspension?
  167. Carbotech and HPDE track events?
  168. cd7 bump stop question
  169. My brakes suck! Help!
  170. positive camber
  171. Legend Calipers with 23mm Disc - Shim or not?
  172. Function7 end links clicking normal?
  173. Suspension Torque Specs
  174. Suspension problem, tires being eaten up
  175. 5 X 114.3 with 5 x 115 rims
  176. Suspension Advice
  177. CUSTOM SPRING RATE HELP NEEDED FOR TRACK CAR!
  178. (PART # 59370)(GC150.64.66) will fit 99 civic?
  179. Eibach and Ichiba wheel spacers
  180. swaybars
  181. Need help choosing Coilovers
  182. Question on full coil-over systems
  183. What springs to get for koni yellows
  184. Blacking out 'ASR' on brace
  185. D2?
  186. spherical bearings for upper control arm on a ef
  187. 85 prelude suspension help!!!!
  188. 85 prelude suspension help!!!!
  189. Spherical bushings kit?
  190. Civic EG6 suspension settings?
  191. EF Full coilovers Ksport vs. FF type 2
  192. GC sleeves from a em1 on a ef ?
  193. Coilovers/suspension?
  194. Brake Difference ??
  195. disc brake swap abs?
  196. suspension choices
  197. need help picking suspension
  198. what gc springs to get for my koni yellows
  199. Trailing Arm Bushing
  200. Dissasembly/Refinishing of Tein Coilovers
  201. No Air or Fluid from Caliper Bleed Valve
  202. NSX Brake calipers on my 4x100 gs-r
  203. Omni 1 piece coilovers wont go any lower
  204. Vibration issue on lowered car
  205. Counterfeit Tein full coilovers
  206. need help with coilovers .
  207. Camber arms hitting top of strut
  208. New guy asking for thoughts on lowered accord.
  209. CUT my shock towers now problem HELP
  210. ef7 brakes(question)
  211. Suspension question... i cant find it in search
  212. Can GSR brake rotors fit my 95 LS?
  213. LS to ITR to NSX Caliper conversion
  214. da coilovers on an eg?
  215. Eibach Sport System
  216. Quick generic brake question regarding the rear piston
  217. Creaking When I Turn?? HELP!!!
  218. integra brakes for my eg
  219. Handling w/ 22mm front and rear sway bars?
  220. Which brake lines for DA rear disks on EG?
  221. Cutting bump stops affects ride height?
  222. brake hose replacement
  223. s2000 brake swap on eg question. what rotors?
  224. Brake pads to thick??
  225. civic brake calipers
  226. Installing ITR rear sway bar
  227. SHAKING UNDER LOAD
  228. koni sale end date
  229. want front sway bar 94 civic hatch dx....
  230. Help! Broke bolt in front Fork/Shock Absorber
  231. Weird stance with ITR springs/shocks on eg
  232. Have 1990-91 Civic EX 15/16" master cylinder, what booster to get, help!!!!
  233. buddy club N+
  234. 50mm vs 40mm hardrace alu LCA
  235. eibach full coilovers vs function
  236. ***Suspension!! HELP!***
  237. upper front control arm on eg
  238. How To - Skunk2 Rear Camber Kit Gen. 2 Install
  239. extended wheel studs and muteki lug nuts
  240. ITR 23T bracket milling question for dc2 application?
  241. wats the difference
  242. wwhtd? (broken lca bolt)
  243. ST Rear Sway Install Issues-RT4WD C.Wagon owners chime in!
  244. tracktability of my setup
  245. LCA Bolts type?
  246. 88 civic steering rack
  247. Need help on spindles
  248. what suspension parts are compatible with my ej8?
  249. Megan Racing LCA's ??
  250. which hole to mount swaybar in...Function 7
