View Full Version : Suspension & Brakes
- Looking for Function & Form Type I Coilover Reviews
- ??TENZO R SPRINGS??
- Bilstein: HD v Sport: Visual Identification
- Suspension Rebuild ?'s
- oscillation issues... i've lost patience.
- which bushings???
- What kind of springs are these
- dead shocks?
- Function 7 endlinks
- swift springs with oem shock mounts?
- some cheap springs to drop my civic......(under 150.00)
- Is this suspension setup suitable for my car?
- ITR Disc sizing?
- B&G Coilovers (2006 Civic Si)
- What suspension to go with on this swap?
- Does Cold Weather Make For Worse Suspension Performance?
- Ground control installation
- Which one piece would you recommend?
- coilovers
- ground control spring rate
- Tein Basic Coilover System on Acura Integra's
- clamp it
- Lower Tie Bar and Sub-frame Q
- Skunk2 coilover on a accord 98-00
- Over steering / Under steering
- skunk2 pro camber kit vs skunk2 camber kit
- i have a question on swapping gsr rear brakes
- neuspeed spring rates?
- Ground Controls, will they dump my DA (I need wheel tuckage!!!)
- Strange oversteer question.
- Front Civic 92-95 front sway bar help?
- da sway bar
- 2000 ek suspension ideas
- shocks/spring combos vs. adjustable coilover kits
- anyone try skunk2 shocks yet?
- cant decide what to get
- What Kinda Of Suspension are these?
- Please Post Pics Of Your Ksport EG.
- replacing actuator and arm on td05 turbo
- ground control custom spring rates
- Shocks or no shocks?
- EK drop with pics
- Bottoming out?
- Bent rear trailing arm?
- Failed Motor Vech. Inspection
- need h&r parts
- suspension terms
- best setup for ef!!
- Megan in 4dr DB Teg anyone???
- accord toe problem need help!
- Koni yellows w/ H&R sport
- What are the best coilovers for a CRX?
- Help installing camber kit for a 92-95 civic hatchback!!
- Lowering springs
- 96-00 civic shocks vs 92-95 civic shocks
- good bushings
- ST sway bar(NON-equipped kit) Help!
- I think I got ripped off....question on Tein Coil springs!!!
- How long are your shocks.
- Type R Sway Bar
- IMPORTANT SUSPENSION QUESTION!
- lookin for a good street setup
- mixed impressions
- suspension opinions
- megan camber kit
- anyone using a beaks kit and DC lower tie?
- Who makes that sway bar kit again?
- H&R Coilover - HELP Need shock shaft/Top Nut thread pitch!
- Tokico Illumina Bump stop
- Alignment issues.
- Tein Custom Spring Rates
- d2 coilovers leaking..... but are brand new whats going on?
- will this rub?pics
- Ingalls camber kit
- Question of Shock and Spring/Coilover???
- which lca should i get
- Using these springs in the rear?
- good setup for ek under $700
- Extending aluminium aftermarket,top hats with spherical bearings how strong is weld
- how do you unstick a balljoint?
- oem gsr sway bar
- **Blown shock?**
- pic request: diy extended top hats.
- H&R Sport VS Eibach Sportlines
- Info on "N1" coilovers....
- im not cutting my springs now... but need help
- Has anyone upgraded their LS front sway to the ITR 25mm front sway?
- wheel studs and lug nuts??
- How to? drop koni yellow shock
- Hubcentric vs Non hubcentric for autocross/circuit...
- FS: Honda Acura Trailing Arm Bushing X-Tractor Tool (Mod approved)
- looking for a rear solid strut bar?
- Omni power lca bushings
- ASR knock off?!
- suspension setup
- PIC's Race-Ready LCA or New Omni LCA
- are caster shims only aftermarket or can i pick them up from the dealer??
- koni red vs yellow?
- Koni Hardware Kit
- ek 4 97
- TEIN E.D.F.C. on 2006 Si. Is it worth it??
- Non Honda Suspension Question (Jeep End Link)
- Spring long shot... See if you can help
- Daily Driver setup.
- lookin for a setup on my SI....
- HELP!!!! Suspension squeek
- alignment gone bad?
- Skunk2 + 5way tokico.
- Suspension suggestions....
- suspension suggestion for a slammed DD
- Putting back stock spring?/
- Need help, I just bought some Ground Controls and..
- Ok to run Skunk2 coilover sleeves upside down?
- blox vs. function 7 lca
- Suspension for EM2
- Rhino Front Upper Arms for 88-91 civic??? anyone used
- sway bar fitment
- gsr sway bar que
- koni yellows with neuspeed racing springs?
- Neuspeed Springs Sitting Funny
- coilover decisions
- what spring rates should i get?
- What's the difference?
- GC top hat only for civic&integras?? didnt find any for accords
- what does caster do??
- PIC Performance or GC/koni
- EG/DA springs
- Hub centric rings for 1989 CRX si to fit Corrodo G60 Rotors
- infinite atuo coil overs
- KORBACH frame locks
- am i doing any harm?
- Installing New Brake Lines
- Skunk2 pro full coilovers
- H&R spring rate 94-01 gsr race springs?
- I have heard about replacing LCAs and braces....
- question about h&r springs
- No brake pressure, help pls
- Help! Upper control arm hits strut tower.
- How stiff is 1,000lbs rear spring compared to, help???
- Who makes the best aftermarket rear camber kit?
- kyb gr2 w/ebay coilovers w/ 2 inch extended oem top hats ride quality ?
- Tokico blues or Koni Reds?
- Skunk 2 front camber kit Pro+ torque specs?
- Looking for a good alignment shop in So. Cal.
- sustec pro s-oc
- Linear (H-Tech) vs. Adjustable (ProKit) springs
- tanabe coilovers
- tein ultimate spec circuit master super racing
- Installed GC Coilovers/Tokico Illuminas...something strange is happening...
- EK with ITR
- sO Cal.. Name a good Shop that can install a Master bushing kit......
- any reason not to use a ITR rear sway bar?
- Beaks Vs ASR Question
- 96 acc. install uppr balljoint?? spc part 67340
- 96 acc. lowered on GCs n 17s.shock rec?? pic of car height.
- koni dealer in atl??
- spring rate for kybs
- tein ss coilovers
- Sloppy / Loose Steering -- All of a sudden
- Eibach Pro Kit and Koni Yellows
- Need some advice: kyb agx+ sprint springs vs. coilover 92-96 prelude
- what STRUT BAR / BRACE brand do you roll with...?
- what is the best suspension for db8
- Uneven height on GC/Koni setup? Need suggestions
- For the love of freakin' God. I need some help.
- omni front lca
- skunk 2 coilovers
- Tein S-Tech springs
- broken front end link
- where did you buy ure CO's at.......*
- GC coilover problem?
- KYB Struts?
- switching to 89-91 RLCA's in CRX
- blown ksports...
- 88 crx and itr rear shocks question!!
- EG/DC2 Rear LCA on EK chassis?
- What suspension is this?
- <<<<<<front sway bar endlinks ????>>>>>>>>
- Eibach Pro-Street-S or Tein SS Coilovers?
- removing stabilizer bar link
- ITR 4x114 conversion - what calipers?
- White Box Full Coilovers from jhpusa
- Where do I find OEM spring rates for '06-'07 V6 Accord?
- Question
- Integra DC vs. DB lowering springs
- just a question....
- need a setup under $600
- Apex N1 Suspension? Help
- upper ball joints
- help with suspension choice
- ITR rear sway bar
- KONI YELLOW SUSPENSION HELP HELP HELP
- Bushing Extractor
- Nuespeed Rear tie bar EG coupe
- Trailing Arm Bent? or Something Else?
- whats the main diffrence between the h&r sport and the h&r race?
- civic vx lower control arms from megan
- Semi Technical Question regarding shim stack size and their effect on valving on a monotube damper
- tokico coilovers
- Interesting article involving quality of shock brands and info on setups, etc
- ek4 rear swaybar onto ek1 sedan
- Circuit track A-arm
- Tie rods
- are these good spring rates?
- function form suspension
- Should I wait for an alignment?
- adjusting coilovers
- ASR Brace Bolts
- Tein suspension.. how come one side comes up and the other lowers?
- Ball Joint for Skunk2, Blox, Omni, control arms the same?
- itr or crvr crv
- Skunk2 or Vision Camber Kit???
- companies to stay away from....
- AMR Coilovers
- Del Sol VTEC vs. GSR vs. JDM '96 ITR (brakes)
- need some help wit my car
- megan full coilovers
- trailing arm bushings?
- Out with the old!!!
- Suspension Setup Question.
- kyb agx vs tokico illuminas vs koni
- why doesn't my type r rear sway fit?
- Why preload?
- 4x114 Conversion Questions!
- Eibach pro-damper, good shocks?????
- Full suspension overhaul and reviews. ASR, Ctr, Nrg, Password JDM Sway strut tie bar
- Camber Kits
- difference between full coilovers and sleeve style?
- Buddy Club N+ springs questions
- My Question
- ex or si front swaybar?
- ek to dc suspension swap??
- skunk2 and Koni Yellows "I searched"
- rear shock bolt head broke off...what to do?
- Slam that bia
- ksport help
- Identify this swaybar
- which should i use, best bang for buck? tein ss damper or kyb gr w/skunk2 coilovers?
- Just for laughs: Any one have any off the bomb a$$ Ksport, D2, F2, or omnipower dyno's
- need advice for my h22 eg suspension
- Ground Control Question
- broken trailer arm???
- vibration on the steering wheel
