PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. 99 civic 5spd project car.
  2. REVIEW: Raceland Coilovers 92-95 Civic on CRX
  3. Installing Ground Control.
  4. 94 civic brake swap
  5. ITR springs on Non-R Shocks
  6. Swapping springs on Tein suspension
  7. Ksport Kontrol Coilover install and pictures
  8. 4x 114 vs 5x114 brake offset
  9. '96 Accord Brake Fade
  10. Help on lowering springs
  11. cheap d2s worth it?
  12. 2003 Honda Accord LX V6
  13. Experience with eBay extended top hats???
  14. 2006 Accord with CV-R brakes?
  15. Wilwood brake callipers for em1
  16. whats the best suspension setup for the money?
  17. Tightening up the suspension.
  18. EK9 Stock Suspension
  19. 2013 civic si suspension set up
  20. Koni 8041 shocks.
  21. Sway Bar Sizing
  22. accord suspension help
  23. DIY ABS delete with Prop Valve and Double Flares
  24. 23mm itr rear sway bar on 95 ej2 with function 7 subframe brace
  25. 93 Civic Hatch Cross-Country Suspension/Brake Set Up?
  26. Skunk2 Pro Series Camber kit Noise
  27. broken trailing arm bushing bolt where to cut frame
  28. Help me with my coilovers
  29. front brakes dragging bad 00' ek
  30. REVIEW : progress sc2 coilovers
  31. 96 hatch suspension question
  32. koni suspension questions
  33. brake line tuck question
  34. Sway bar questions
  35. COILOVERS
  36. Civic EK Hatch Sway Bar Upgrades???
  37. Mugen struts DC2
  38. New brake and fuel lines
  39. extended top hats vs. helper springs
  40. tips on removing rear UCA to trailer arm bolt?
  41. spherical trailing arm bushings
  42. where to find parts!?!?!?
  43. School me about suspension travel (droop)
  44. 2006 Accord 6spd Sedan Brake options
  45. Upper control arm hardware
  46. I Have a 87 Crx and...
  47. 92/94 full coilovers
  48. Front Brake Caliper interchangeability
  49. Smooth ride? Coilovers? Lowering Springs?
  50. 94 hatch si what u auto cross guys using
  51. Alignment advice.
  52. Low speed grinding under braking
  53. Brake Pedal Is All Over
  54. Caster issue
  55. No tension on Springs when on lift?
  56. [HELP] Loud Creak and Clunk from steering
  57. 5 lug questions
  58. NSX Rotor on ITR 5 Lug
  59. confusing sway bar, 22mm on gsr no brace?
  60. ef damper forks
  61. Brake Booster Delete
  62. New Moog UCAs completely different?
  63. HOW TO REMOVE BRAKE CYLINDER/PISTONS
  64. ABS error code 68
  65. Integra tire wear pictures. Question for prior wheel alignment.
  66. JDM 36MM Five Lug, stock EM1 intermediate shaft?
  67. car rolls a little while parked in gear
  68. Has anyone ever seen this? Burnt Master Cyl Cap float
  69. 2004 Honda V6 Lower control arms
  70. eg trailing arm bushings
  71. Taller tire in rear?
  72. suspension bushings
  73. Lowering 1998 Civic Ex
  74. Blackworks Racing products
  75. stance coils, hardrace, function7 on ek hatch review
  76. accord brakes on eg
  77. Subframe brace
  78. 96 civic upper control arm/ball joint question
  79. FR-V EDIX Upgrade
  80. Axles for eg hatch
  81. brake upgrade for a 63 year old?
  82. Rear sway bar options
  83. 2001 Integra GS-R Sedan Brake Component Replacement Project
  84. Koni yellow/gc too extreme for daily? other setups have extended top hats?
  85. Best suspension setup to slam a 92 civic hatchback
  86. LR toe out of spec, adjustment maxed out
  87. E-Brake cabling issue after disc swap
  88. front wheel bearing
  89. Penske suspenion, DC2? Identification/experience help.
  90. wilwood master cylinder help
  91. TruHart StreetPlus coilovers.
  92. Squeaky new suspension.
  93. 96spec 288mm ek9 brakes same as Dc2 288brakes?
  94. 96spec 288mm ek9 brakes same as Dc2 288brakes?
  95. Fitment issue: Koni yellow sport & ground control
  96. Delsol , Which coils to make it hella slammed?
  97. tie rod angle?
  98. suspension logic : stiffness + dampening
  99. Wilwood BBK, brakes feel weak, which MC should i use?
  100. Lowering 93 Del Sol SI
  101. Hardrace LCAs quality?
  102. squeaky noise
  103. Brake mystery problem help !!!
  104. Odyssey Rattling Noise on Left Turn
  105. 1992 Del Sol, need some Coilovers
  106. will a wilwood dynapro 6 pot clear buddyclub 15x8 rims?
  107. What grease does honda use for their front upper ball joints?
  108. Happy 4th of July From CompleteStruts.com save 15%
  109. Progress ?
  110. Ksports with extended top hats
  111. Stiffer springs on ksports
  112. 1995 vtec brake bleeding
  113. Stainless hard line tuck questions
  114. Wheel and tire setup… need help
  115. Lower and Preload confusion
  116. Stiffer Suspension No Lower
  117. Lower NY Area alignment shop familiar with traction bars ?
  118. dead coils and coilovers
  119. Clicking noise coming from drums after installation
  120. NSX Mini t25 no milling
  121. What the heck is this annoying chirping sound?
  122. 1995 eh9 sedan front suspension HELP !!!
  123. Anyone have experience with "meisterR superlow" DC2
  124. 91 Honda Civic SI, daily driver, No More than $800..Suggestions
  125. PIC Performance?
  126. k-tuned traction bars.
  127. Aluminum Insight Drums on an EF: They Work.
  128. Vision Technica EK camber kit question
  129. Blown struts = knocking?
  130. Understeering - Need Help: Maybe it's me...
  131. 97 civic hb, pic hard rubber bushing kit compatibility
  132. Element Spring Seat
  133. Brake fade on only second aggressive stop... pads?
  134. Quick alignment question
  135. rear camber kit - brand choice?
  136. help! slammed civic hatch
  137. Good Grease for joints
  138. SQUEALING rear brakes
  139. amr control arm ball joint boot or placement
  140. BRAKE FAILURE! 2000 HONDA ACCORD! HELP!!!
  141. ITR Rear Calipers on DC2 with Front ITR Calipers/Mini Rotors
  142. AMR Suspension Setup FA5
  143. weird rolling knock noise EF hatch
  144. Got rear brakes replaced.. 1wk later whining sound and thumping when braking hard
  145. Tanabe sustec installed wrong?
  146. 00 EM1 LCA bushings question
  147. Can someone identify this clutch master cylinder?
  148. Progress CS-II Unboxing
  149. Weird tire wear
  150. unknown brakes - need help
  151. Where to get new bolts for rear lca?
  152. what suspension for my jdm itr dc2? apexi n1 exv?
  153. 4x114 Conversion
  154. F&F rear LCA shorter than OE ???
  155. Rear trailing arm bushing: ES or full unit?
  156. Looking to slam my EF...suspension suggestions?
  157. buddy club or hardrace: rollcenter correction ball joints/extended ball joints.
  158. Set up Suggestions for 97 Civic
  159. Noise on Bumps on the road
  160. another Koni GC spring rate help! (typical lol)
  161. Brake Fluid Types and Brake lines need help
  162. OEM diameter custom springs?
  163. Wilwood BBK help
  164. 1990 honda crx brake squeal.
  165. 91 civic coilovers on to 96 civic
  166. brakes and more brakes?
  167. KW V3 Civic EJ6 Review
  168. Traction Bars
  169. Koni Yellow Adjustment or || PIC Select||???
  170. 3°+ positive caster - is this to much???
  171. Diagnose dent/bend in upper control arm
  172. BC Racing problem Civic EP3
  173. Yonaka Coilovers review CB7 Accord
  174. Car is not braking!
  175. Honda Civic EK KW V1 coilovers review
  176. dc2 knuckle on ek
  177. Skunk 2 Upper ball joints = CHEAP GARBAGE
  178. Rear lights turn on after park
  179. Had alignment done, question on fixing caster.
  180. what brand/model coil overs are people using for rally racing?
  181. Koni + GC or Tein Super Street
  182. No brake pressure with car on and off
  183. Chronic soggy pedal 97 integra
  184. Inner tie rods
  185. 11.8" 300mm brake setup
  186. Coilovers to go the LOWEST? EJ6
  187. pOWER sTEERING PUMP VS rACK ?
  188. Hawk performance ?
  189. ES sway bar bushing install
  190. suspention weight capacity
  191. coilover sleeve comparison. skunk2 and megan
  192. Front left brake partially seized
  193. Typical ride height and other adjustments koni/ GC
  194. Suspension for my New Daily Driver?
  195. JIC COILOVERS TYPE R
  196. Rear disk break conversion. ej8
  197. 02-03 ep3 FRONT brakes on 94 integra?
  198. ride height mismatch?
  199. Stagg struts + omnipower coils
  200. Shocks and Coilovers?
  201. 96 ITR 4X114 hub bearing replacement
  202. DC2 Spring rate / damper travel
  203. Heavy Duty Springs n Shocks
  204. suspension
  205. Strut bar torque specs
  206. Review: EMUSA LCA (the good cheap ones?) ej8
  207. Review: From 3030 to 4040 Prop Valve
  208. Brand new coilovers won't adjust ride height.
  209. OEM/ Hydro e-brake DIY
  210. Coilover Kit replacement/installation DIY
  211. Da hubs
  212. KONIs + GCs 2000 Civic - help check my spring rate math...
  213. couple of questions. going koni/gc
  214. PIC Coilover rebuild
  215. brake pads for street & track
  216. rear negative camber problems
  217. Integra ground control coilovers..which is front/rear??
  218. EK <--> EG/DC Rear LCA bushings
  219. swap shocks on teins?
  220. control arms sway bars, spindles and more? i wanna upgrade my old crappy civic
  221. Em1 rear lca outer most bolt
  222. Tie rod end won't go back in.
  223. Shocks comparable to Progess Racing CS2
  224. 2007 Honda Accord Ex rear alignment problem
  225. How can i go lower?
  226. Quick question about perch positions on my bilsteins
  227. NSX CALIPERS 4X114 ITR
  228. Energy suspension front LCA bushing question.
  229. ITR 1 Piston vs Legend GS 2 Piston
  230. stainless steel lines 2000 ek
  231. eg hatch with b series suggestions
  232. will the dc2 race lands fit a 90 teg Da?
  233. Brake Servo Fail? (Honda Civic Hybrid 2009)
  234. will H&R sport from a eg civic fit 94-01 integra,part # 51864
  235. ep3 coilovers
  236. Weird tire wear pattern - LCA, struts, or both?
  237. lowering 97 accord
  238. Ek pinchweld probloms !!!
  239. Ground Control Rates
  240. Anyone running w/o the brake booster?
  241. can someone please identify the OEM suspension I have
  242. Can You Identify these pads? AK NS217H FF
  243. 4040 prop valve/ABS removal
  244. 1995 EG Si rear disc swap
  245. Teg suspension in EG-DX-2DR?
  246. DIY: No BS, direct bolt-on 11" Big Brake Kit for EF's!
  247. I don't kno what kind of proportioning valve I need.
  248. 2002 Accord with mushy steering and body sway
  249. eg popping front end
  250. PIC Performance
