View Full Version : Suspension & Brakes
- KW spring rate and sway bar question?
- NOVA looking for reputable shop to tune suspension
- Adjusting Koni Yellow
- Apexi N1 Coilovers (2001)
- Strut?
- bent steering knuckle
- EM C-Pillars for Integra
- ONe side is sticking out?
- Anyone have Tein H Tech?
- 06 SI Pro Kit
- Shocks blown?
- TEIN suspension servicing/repair shops?!
- MY car is shaking!!!!
- traction problems and need advice
- Two questions: one about koni reds and the other about a beaks kit
- civic si(hatch, i think) front and rear struts and springs on 95 LS integra..
- New B here, need help
- Shock Question
- omni power drag coilovers
- GABRIEL - Are they a performance brand or OEM quality?
- did i noob my coilovers?
- tein s-tech with tokico blues?
- ebay suspensions???
- neuspeed sports?
- alignment problem
- koni yellows: how far into the fork?
- 4th Gen Prelude: Koni + OEM springs?
- Tein S-Techs/KYB GR-2...not low
- mono shock front end, anti-roll
- Spring Rate Balance
- Ordered N Received Koni/GC's...GC's came w/ no wrenches/adjusters?...what to do?...
- which springs is everyone running?
- omni sport coilover, with skunk2 sleves?
- What other parts do I need to bolt up my shocks?!? Quick question
- Camber Kits for EF
- Does anyone using this suspention? seems pretty dope!!
- Omni power suspension specs. what do they mean?
- got a quick question from my gc and koni install.
- diy rear camber adjustment
- My suspension is Balloxed :(
- dropzone are they good?
- Rear Bushings
- ITR master cylinder w/ stock BOOSTER?
- KYB GR-2 Gas Shocks - YAY OR NAY DAILY DRIVEN FUNBUCKET
- My Lude Slants
- 00 em1 rear camber question?(not about "do i need a kit")
- GC's with Koni Yellows
- Grant wheel
- 96 dx no sway bars
- KSport Coilovers - Mini review - Props to BodykitsNW
- track setup/weekend warrior
- NSX calipers with PowerSlot+ question
- 98 spec ITR suspension/brake conversion on EG
- 99-00 si sway bar on a 97 Hatch ?
- omni power camber kit ?
- looking for coilover length measurments? PLEASE!
- '92 Hatch. Handling sucks, need better. me=poor. ?
- EK Suspension on a DC?????????
- Need some serious help figuring out what these TAs are(EF\EG\DA\DC\other)
- suspension techniques = tear-out
- What Do H-Braces Do?
- Installing Skunk2 Full Coilver system help.
- tokico illuminas and ots ground controls
- alignment 101 : Lowering effect Toe also??
- Daily driver suspension: coilovers(ground control)vs springs(sportline, pro kit)?
- Thumping Noise? Help!
- eibach vs other brands?
- Ban the word "pre-load"
- Hit a curb! What could be bent
- Bought new rear wheel bearing\hub assemblies- Possible problem?
- who's running omni sports.
- Well... Omnipower has done it again! ..... failed that is.
- koni yellow rebuild
- Buddy Club N+ dampers
- Drop or bars
- ef suspension
- Coilovers - best bang for my buck
- top bolt cross threaded
- omni power full coilover sus.....
- sportcompactonly
- Spring rate..
- help needed it here
- handling with stock 21mm front and rear ITR swaybar
- Swaybars - What the best once.
- CRX Si rear arm bushings fit 94 Integra rear arm?
- OmniPower Problems
- damage from wheel hop? ?
- 2006 Civic Si Suspension upgrades?
- Need info on camber bolt.
- H&R OE springs
- Best Shocks on a Budget?
- Omnipower rear LCA's and alignment?
- Tokico blues, Neuspeed sports, and I'm too low for the new 16's!!!
- what size sway bars for EG hatch... AutoX
- Will a 94-up GSR swaybar fit an EG????
- Nuespeed race springs with what shocks/struts
- help me pick a spring rate
- New SPAX coilovers
- coilovers+shock combo
- omni power slip over coilovers
- single suspensoin
- Coilovers during the Winter?
- tein coilovers
- anyone use H&R OE SPORTS?
- Power Steering on CRV
- AXLE is driving me crazy
- rite up camber/ingalls??? help???
- Alignment specs?
- What are good Camber kits out there?
- Comparison Skunk2/Koni yellow VS Ground control/stock shocks
- correct install of ebay coilovers
- skunk2 coilovers fit over koni's?
- Best sub $700 coilover?
- Koni Yellows w/H&R Race, super bouncy ride
- what are y'all using....
- WANT TO SLAM MY CIVIC WHAT?
- NEED HELP with eg sway bar install???
- Buddy Club N+ Spec Damper
- question on omni power camber install
- Major fab questions for 94 EH2 (MUCH MUCH NEEDED HELP)
- Question about sway bars?
- is this safe?
- Cheap place in LA to drop?
- power slot plus system?
- does anyone know how to read an alignment chart?
- Will Koni Yellow Shocks from 98-00 Civic fit on 94-01 Integra LS/GSR?
- traction
- simple ? about tein
- car rides like a brick, looking for a new suspension setup
- only 2 spring manufacturers in the world?
- Tein-S tech or Eibach Sportline
- Suspension Pop?????
- Koni Springs?
- New set of Tien SS Coilovers!
- so is koni the best thing i can get or what
- cheap five lug?
- break-in procedure and torque specs (koni + g/c)
- What Shocks to use?
- replacing axles waht else?
- instructions for omni coilovers
- bad lower Ball joints?
- Will Ground Control's for a DC2 work on my DC2-R?
- Couple Questions about Strut Tower/Tie bars
- Alignment in So Cal
- quick application question
- How To: Raise car on Omni Coilovers ??
- 91 si swaybar to reduce body roll.
- whats a good cup kit
- Spring Help
- need help w/ supension...any suggestion
- EM Racing triangle bars VS. Autopwer Roll bar
- my tires rub
- Question about Koni shocks and ground control
- Why is it rubbing!?
- Traction Bar ?'s
- crx bushing combos?
- Master Cylinder Brace where?
- need buying help
- Tokico + H&R
- Omnipower front camber kit? No thank you...........
- BUSHINGS!!!!!!
- aftermarket bushings
- PIC Suspension
- How to put JIC coilovers on a DA
- 93 ls rear disks on an eg civic hatch
- How do I LIFT a Civic?
- blown buddy club coil overs...help
- tein vs eibeach.
- ASR and Comptech brace, which is stronger? FEA results inside!
- GC and tokico adjusting problem PLEASE HELP
- LCA SHOCK BUSHINGS size
- ES Front end link install?? DC2
- eg suspention on ef ?
- BRAKES LOCKING UP
- stock height performance
- Switching front and rear springs on Omnipower
- Question on GC intal and ride hide
- Quick question about kon/gc setup for DA
- WARNING: STUPID QUESTION!!!
- shortening stock springs?
- Squeaking Camber Kit
- koni and h&r
- Help...About to purchase new Koni/GC...Any sugg. where? Rep. sites? Sites w/ deals? Experiences?
- alignment question
- What springs/camber kit is recommended by fellow HTech members suggest for a 2000 Acura Integra 4 Do
- how much does spring rate effect ride height?
- when do u kno its time to?....
- effects of blown struts?
- H&R Race Springs
- BLOX sway bar
- Are the Ingalls Camber kits worth the money?
- For new suspension, am I missing anything??
- coilovers
- crx spring question?
- Coilover sleeve O rings
- coilover rebuild kit, is there such thing?
- Master cylinder for 96-98 civic hatch
- Ground control Top Mounts
- Identify unknown coilovers Plz
- Uneven stance, rubbing, shredding HELP eeek!
- 88 CRX, can i run ITR LCA's?
- Beaks ITR Rear Swaybar Kit on a EK???
- Testing struts/springs?
- Looking to get some new coilovers need some recomendations
- Need help! Need the rest of the pieces for my sway bars!
- suspension stock values
- best place to get es shifter bushings?
- NeuSpeed Coil Overs
- Need to understand . . .
- skunk 2 upper control arms
- 94 civic strut question.....
- Strut Bar for a DA9!!!
- bumpstops question
- how the heck do I get my ride height correct??
- type one racing
- skunk2 pro kit or ominipower coilover...
- need some help
- spring install?
- HELP PLEASE
- Brake swap
- Rear camber loose
- Import auto performance
- Upper arms and coilovers
- konis pushed in...how to release?
- coil over choice
- 96 hatch doing 99 integra swap
- Bolts need for swaybars
- My new Suspension....
- Best / cheapest online place to purchase Tein products?
- Best sub-$1000 coilovers.
- DC/EG to DA swap
- rear disc - swap hub/disc w/ drum
- KW SUSPENSION????!
- which coilovers to get for 98 civic??
- eg hatch rear lower tie bar question.....
- spring sizes
- troubles with pasword jdm 3 point
- New susp. bushings- preloading question
- Springs - 97 civic hatch to 97 del sol
- lopsided
- how low can my SI sit?
- In search of MY ideal spring rates/coil-overs
- Inherited some coilover sleeves, but rubber rings are missing....suggestions?
- RSR spring question
- JDM DC ITR Front and Rear Shocks & Springs
- Proper Coilover Adjustment? How to/ tips/ techniques?
- EK suspension techniques rear sway bar fit EG?
- narrowing down my setup...some advice would be great
