PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. accord tokico blues on crx???
  2. DIY CTR Strut Brace Install into a USDM EJ
  3. Brake NOISE!! =0
  4. ?? on how to go lower..
  5. uh oh don't know if this is alright or not.
  6. AGX Comparable struts for 88 CRX Si
  7. koni ground controls brand new but bouncy
  8. Rear Brake Disc Stuck
  9. need help on suspension
  10. Koni yellow/GC questions.
  11. Clicking noise
  12. Brake Pedal Travel adjustment can this be adjusted?
  13. Debating about which set up to keep
  14. Looking for a PIC dealer
  15. Braided Brake Lines: Difference between ABS & non-ABS for 92-95 Civic Si Hatch?
  16. 8k/10k, 8k/6k 10k/8k
  17. problem with front p/s upper arm
  18. Lowering spring perches on full body coilovers, ok?
  19. why is my back lower than the front?
  20. tein basic c/o for ed3
  21. Opinion?? Most comfortable full coilover?
  22. Will it really work!!
  23. suspension problems
  24. Suspension Suggestions for 6th Gen Accord [ '98 - '02 ]? Or anybody have one FS?
  25. whats a good spring and struts/shocks combo for smooth street use?
  26. alignment question on eg hatch
  27. opinions needed on blackworks suspension
  28. H&R Springs on Stock Shocks?
  29. Quesiton about lowered spindles and rear trailing arms
  30. Siezed Rear D2s ! >:(
  31. need coilover
  32. coilover springs, which in front which in back
  33. caster adjustment?
  34. Rear Sway Bar Sizes for DD/AutoX
  35. bout to saw my lowerball joint off, any suggestions?
  36. Idle suspension question
  37. Function and form????
  38. How to: replace upper control arm bushing [PICS]
  39. Tire wear help/how low can i go?
  40. New Skunk2 Version II Pro-S Coilover
  41. Skunk2 help
  42. Having a steering issue! Please help
  43. building end links from mcmaster
  44. Extended Studs
  45. Horrible sounding noise coming from front end! please help!
  46. So I'm ready to improve my handling
  47. coilovers wont work with lca's
  48. NEED SUSPENSION BUT WHICH ONE???????????????????????????????????/
  49. Endlinks... which are the best? v2
  50. quick strut question
  51. Picking a camber kit
  52. Please help with suspension!
  53. ground controls...which shocks?
  54. My first suspension kit, need last minute advice
  55. EG/DC vs CRX top hats
  56. Got an alignment but still pulls to the left- have print out
  57. Pic Apex P2 vs Ground Control + Koni Yellows which one?
  58. Installed Front, Help With Rubbing
  59. Noise coming from F2 coilover.
  60. Pic request; the lowest a EF Chassis can go with Form & function coilovers
  61. ebay extended top hats on koni/springs?
  62. can somebody name this part?
  63. front control arms?
  64. Which coilovers with 5 lug conversion.
  65. doing a lift on a civic? yup i am! need help
  66. i think my suspendion is bent or need alignment?
  67. strut bar
  68. 99 integra type R rear LCA's- 1990 wagovan
  69. Front Camber Kit
  70. Koni/GC dust boots
  71. DIY Front and Rear Suspension Replacement?
  72. Traction bar... made my own.
  73. progress springs
  74. extended top hats on TEIN basic coilovers?
  75. Should i add a washer to correct this camber?
  76. Vibration at Hwy Speed: Help, I give up
  77. Alingment Specs help
  78. KW Variant 2 on its way. Who else?
  79. bumpstops? which kind to buy
  80. Fastbrakes 12.2.... and 15's that fit?
  81. Progress springs with what shocks?
  82. Rotor offset question...Spoon Caliper related...please help
  83. 92 EG willwood fronts / stock disk rear (PART 2)
  84. Negative Camber
  85. Plz delete
  86. Help with brake disc + caliper!!!
  87. meghan racing spring
  88. New Master Cylinder: Brake Pedal Still Soft
  89. brake pedel clicking noise and have to push in pedel far to start braking
  90. oem replacement suspension but 1.5 inch shorter
  91. 92-95 civic front lca fit my 96 civic coupe??
  92. Tokico blues+ tein stech question?!
  93. swap bar??? for eg's
  94. Question about buying used Koni's
  95. can 94-01 integra springs fit 96-00 civic coupes?
  96. EG front upper mount diameter
  97. dropzone springs
  98. springs?
  99. Brakes dragging after master cylinder install
  100. Integra front LCA's fit EK?
  101. Wheel Bearing Part No. What is this from?
  102. Need help identifying coilovers
  103. '97 Accord DIY brake job, I need help
  104. where to buy overhaul kit for spoon calipers?
  105. General FWD setup for circuit racing info?
  106. Koni & Gc question
  107. The Right Coilovers
  108. EP3 Brake Problems
  109. help beaks bar and sway bar do not fit on my car
  110. New srpings for my EJ8
  111. Ef Srings on an eg shock?
  112. front upper shock rubber bushing shifted!!
  113. civicDxhatch front spring have pressure??nooob
  114. wheel alignment problems (00si)
  115. booster delete with wilwood master cylinder
  116. 13" rotor on integra? help!
  117. Suspension for Circuit Racing
  118. EBC yellow stuff vs. Axxis/PBR ultimate
  119. stripped Nrg hub bolts!!
  120. Lotus Exige ruined my day
  121. Weird steering symptom...
  122. swaybar?
  123. good suspension for my eg- less than 700$
  124. How long will gc/stock suspension last?
  125. EdelBrock IAS
  126. Tops hats with tein supersports?
  127. rear disc brake conversion on civic coupe help
  128. is the poly kit worth it for better et's???
  129. PRELUDE - EIBACH PROKIT**# 4008.140
  130. Getting Coilovers for DD....these are my options?
  131. Funtion & Form Camber Plates
  132. Brake Lines/Fittings '97 Accord What Size to order?
  133. rear brake calipers rubbing against my steelies
  134. Suspension ?s
  135. Will RSX-S Brembo rotors fiton integra?
  136. Function&Form extended top hat
  137. So, will I be able to change shocks/struts myself?
  138. Lowering Springs help "Db2"
  139. camber help
  140. Juicin' Fools
  141. tein question...
  142. 92 EG willwood fronts / stock disk rear
  143. 15x9 fit a DC2 and EG ?
  144. crv front brake to ef
  145. integra brake upgrade
  146. Help Alignment! How to remove Front Tension Rod on Civic?
  147. Subframe Support??
  148. "urban suspension setups"
  149. Needing ADVICE, subframe tearout recovery.
  150. Tokico blue struts with Ground Control sleeves?
  151. Why dose my civic sit so much on a slant?
  152. eBay suspension kit for daily...Good/Bad?
  153. Rear disk swap cause heavy e brake?
  154. EF Hatch : Neuspeed Sport Springs
  155. Rear Trailing Arm Bushing on 1988 Civic DX
  156. Hissing brake line?
  157. 92 Civic Si, DD, need new springs and shocks, Recommendation?????
  158. Brake fluid in brake booster?
  159. Slammed Questions, Top Hats?
  160. lowering springs for 09 civic ex ?
  161. EG with GSR brakes: retainer clip rubs
  162. question about spring rate/length - 95 hatch
  163. what cause wheel bearings to go bad?
  164. 98 Civic Hatch - Rear Sway/End Links Q
  165. blox front camber kit any good?
  166. Eibach Sport System vs. Tokico HPK Shock/Spring Kit
  167. Tein basic damper top nut
  168. Experience with Megans's or Function & Form
  169. DC5 (RSX) Sway Bar w/ Race Header Problem
  170. Brakes lock up easily
  171. extended ball joints rubbing rotor!
  172. Blox lowering springs?
  173. 5 lug and abs delete questions
  174. rear brake conversion
  175. JDM 5Lug Swap help
  176. Skunk2 bushing help
  177. allignment on civic ek
  178. 96-00 civic springs compatible w/ DA Integra shocks????
  179. Full suspension...
  180. DA Suspension On EF Hatch
  181. help! clunking brake noise?
  182. ep3/rsx rear disc on eg??
  183. Del Sol Suspension
  184. Arospeed Coilovers vs Skunk2 Lowering Springs
  185. Lower ball joint problem. 96 Civic
  186. type r suspension
  187. Opinions: Gab Full Coilovers
  188. looking for sway bar recommendation for a 93 eg lx
  189. What size rotors to use
  190. Please Help!!!!!
  191. Trailing Arm Bushing for 99-00 SIR?
  192. Installing integra sways in ej7
  193. Axle binding or rubbing somewhere what to do?
  194. Koni & ground control for my ITR
  195. EG-GSR F & R disc brake conversion ?
  196. What pad/rotor combo to get????
  197. Ksport vs Skunk 2 for ef
  198. Sprint Rate Question For Suspension Gurus
  199. BEST COILOVER SLEEVE ON THE MARKET
  200. Spindle hitting coil spring- Help!!!
  201. Do i need to drop the gas tank to replace the rear brake lines?
  202. omini power vs skunk2 camber kit
  203. Replacing Brake Caliper Seal
  204. Negative caster
  205. 98 civ ex B18b1 questions...
  206. Eliminating rear brake question
  207. What's causing???
  208. after alignment vehicle still pulls to right
  209. Alignment issues! Please help. Toe can't be adjusted any more..
  210. 4040 Proportioning valves
  211. Rear Toe and Handling
  212. Suspension got more bouncy after lowering it
  213. Where to get koni hardware?
  214. Brake Question.
  215. shock inputs
  216. Toe adjuster recommended by Firestone
  217. What brake hoses on 5 lug conversion EK hatch.
  218. alignment??
  219. Issues installing HardRace rear-trailing arm bushings?
  220. 1990 Integra GS Sway Bar Size...
  221. Polyurethan bushings?
  222. Ground Controls (non Koni) question
  223. bilstein shock corrosion problems
  224. car moves right when i hit dip..
  225. koni gc ?
  226. What diameter springs fit which coilovers?
  227. FS: Drag Racing Suspension (strange Engineering) All Civic/CRX and Integras
  228. M12 fitting for 1" MC
  229. Differences between EF, EG, DC rear lower arms [PICS]
  230. ground control spring kit questions?
  231. Koni ride height
  232. Figure this one out...
  233. RCA/Entended Balljoint and top hat conflict?
  234. Spring rates for a Daily/autox
  235. EF ksport question
  236. prelude camber help!
  237. brake line coupling?
  238. question about the comptech sway bar/subframe brace
  239. TSX/TL/ACCORD Peeps: “I don’t track my car, and I don’t want my suspension ‘bouncy.’"
  240. Eg rear conversion.....??
  241. Problems with Biddy Club USA
  242. Coilover sleeves without springs - Where to buy?
  243. replacing hardlines(brakes)
  244. New Brake Master Cylinder replacement(spongy pedal feel)
  245. Steering rack popping
  246. Fitment Q: Integra sway bar on ek civic
  247. installed springs. front sits higher than rear
  248. Bushing replacement tools
  249. Pls. help! need help with ride height adjustment
  250. omni coils not low enough
