PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. stumpted and out of ideas
  2. ITR 22mm Rear Sway bar w/ ASR kit rubbing on exhaust?
  3. RS TYPE COILOVER CONVERSION KIT
  4. ex and dx brakes
  5. Adjusting ride height with Ground Control coilovers.
  6. EG control arms on integra
  7. GC/KY setup on DB8
  8. turbo crx Shaking
  9. any with progress springs
  10. *Ingalls camber kit - opinions and experiences?*
  11. Post your suspension set up that you're currently running.
  12. Need advise on set up rear swaybar 19,21 or 24mm?
  13. suspension setup on ej1?
  14. need help guys
  15. HardRace compliance bushing
  16. stocks + egay = death
  17. 07 Civic with 1.5 drop and 215/45/17 Tires?
  18. Integra Strut Tower on EK
  19. stripped out eg civic; which suspension?
  20. Anybody have any idea what setup this is?
  21. 00 Civic Si oem shocks compatible with 98 Civic LX and 91 DA?
  22. Spoon Caliper Issue - Brakes stuck ?
  23. Help! Too Low!
  24. 6pot brakes will not stop
  25. Traction Bars
  26. Koni/GC Noise Issue
  27. I need a good DA slammed setup
  28. Sway bar compabilities with 96-00 Civic ASR subframe brace
  29. Spring Rates Determining Ride Height, and Interchangablilty
  30. Typical GC + Koni Yellow setup questions - CRX
  31. Car making screeching noise!
  32. Short Bodied Strut?
  33. Ebay Strut/Tie Bars
  34. removal of rear struts...
  35. ebay coilover sleeves V.S. megan coilover sleeves
  36. modified ps rack rebuild and loop.
  37. BLOX tuner series FULL coilovers
  38. Anyone Runnin F&F Type 1s on a DA?
  39. Good struts for around $200?
  40. megan springs?
  41. drag crx suspension opinions
  42. function & form can it go any lower?
  43. Ebay coilover sleeves and camber kits
  44. How are dropzone coilovers?
  45. Koni Yellow Perch Adjustment Question
  46. 1996 EK Civic front driver squeaking/clunking sound problem
  47. Need a corner ballance in central NY
  48. Spring Frequency Calculator
  49. Civic Front suspension geometry
  50. PIC, KSport, or D2 Coilovers?
  51. If I were to buy...
  52. nsx caliper question
  53. booster or master cylinder?
  54. help with gc/koni
  55. Hardrace front camber kit?
  56. Buying new Struts need Help
  57. Can I replace bushings with a bench vise?
  58. suspension question.
  59. Is this a prop valve? *PIC*
  60. camber adjustment question...
  61. K-Speed Racing Suspension *HELP PICS INSIDE*
  62. previous owner cut stock springs to lower the car...
  63. Budget suspension for an eg?
  64. WTF...fitment issues??
  65. 2004 Accord Lowering Springs & Camber Kit
  66. Problem with new Koni race!
  67. Complete Bushing Kit Questions...
  68. Need some help, Brake Caliper Piston Stuck
  69. ABS not working EG Civic
  70. going up?
  71. 5 lug conversion advantages?
  72. Ksport coilover softer springs?
  73. Existing EK PIC coilovers owners!!
  74. master+booster+prop=?
  75. Suspension Gods answer me this
  76. 2 questions about spoon and mugen brakes
  77. how to adjust coilovers?
  78. arp extended wheels studs vs blox intended wheel studs
  79. 96 cx and 98 dx brake caliper question
  80. issue bleeding brakes searched
  81. Help indentify these coilovers
  82. newborn coilover compomise?
  83. Caliper Leaking Issue. AP 3307
  84. Skunk 2 coil over spring rate
  85. bleeding problem
  86. Master cylinder 95 accord
  87. Integra painted caliper. NEED OPINION
  88. Ef9 suspension question
  89. Front Control Arm / Camber Adj (EF Hatch)
  90. Choice of Suspension ((((((ek hatch)))))
  91. Rear Disc brakes on ej1
  92. Would like to hear from D2 owners
  93. coilovers
  94. Booster problem?
  95. Hardrace or OEM RTA bushings?
  96. GC top hat question.
  97. Were to buy GC Tophats
  98. KYB AGX and Tein S-Tech
  99. would tokico shocks fit a em1
  100. Traction bars create understeer?
  101. Question about Smoged and Suspension
  102. Miracle Cross Bar Problem
  103. Ive just fitted discs all round, how can I get ABS to work? EG civic
  104. Leaking on new coilovers?
  105. Tie-rod clearance HELP!
  106. Problem with rear brakes 95 accord ex
  107. Ground Control srping rate + Tokico Blue
  108. onsoku wi-cos-3
  109. i came up!!! free skunk2 suspension.
  110. Spoon Calipers wheel clearence.......
  111. benefit of using EG forks on EF?
  112. Need help with EK Front Swaybar Endlink install
  113. em1 lca length?
  114. welding to shock housing
  115. Worn out Skunk2 Front Camber Arms
  116. eg6 tein suspension on Si CRX 90.
  117. ASR + Skunk2 LCA"s + Install Woes
  118. Cutting Performance Springs
  119. Do prop valves go bad?
  120. are these lca's good?
  121. New Product: Blox EG/DC/EF/DA Rear **Polished** LCA
  122. 2nd Gen Legend.. I want a Smooth Ride. like Lexus
  123. Skunk2 Coilover Help
  124. Torn/Blown CV Boot
  125. kg/mm to lbs/in
  126. Quick tein lowering spring question
  127. Tanabe vs GC
  128. Control arm annd spindle question!!!
  129. big brake kit
  130. Alignment Specs with toe adjusting?? Plz Help
  131. Can someone id these coilovers?
  132. subframe??????
  133. Top hats
  134. Brake upgrade?
  135. Prelude camber adjustment... chassis tech adjustbale UCA
  136. interchangeable strut bars?
  137. Best Pricing for PIC Selects?
  138. Authorized and recommended Wilwood distributors?
  139. Squeak coming from rear of car
  140. EBC yellowstuff
  141. SPOON CALIPER ?????ive searched
  142. bad negative camber on one wheel only? HELP
  143. ITR springs/skunk2 shocks on EG ?
  144. What does a Brake Rebuild consist of? (NSX caliper)
  145. h22 runners suspension choices
  146. will gc extended top hats work with skunk2 pro s coilovers
  147. ef swaybar on eg???????
  148. GC's and what struts?
  149. h22 ek vibration when turning
  150. Left suspension clunking -searched!
  151. shocks + springs
  152. top hats increase like of shocks?
  153. ST rear swaybar adapter kit #55360 for 99-00 civic SI model.
  154. Cheapest place for Koni Yellows?
  155. bushing kits .. are they worth it?
  156. Will I need a full camber kit if I purchase upper pillow ball mounts?
  157. 1993 del sol sway bar question
  158. rear sway bar on integra
  159. Wanting opinions on my calipers before I start
  160. HR race springs.
  161. NEW TO HONDA-TECH
  162. How to do EG/DC rear shocks on EK the right way.
  163. gc top hats
  164. F&F Type2 w/ front camber kit
  165. Koni Yellow's
  166. Wanting to upgrade brakes on 97 DX coupe, suggestions?
  167. Difference between Alignment & Balancing?
  168. lcas and rear sway bars
  169. wobbly
  170. Quick question about allignment
  171. civic ex 11 inch upgrade?
  172. helper springs for my hks hypermax 2..?
  173. H&r race + koni yellows :)
  174. bigger front disc, stock drum question
  175. Will DA coilovers fit my DC integra, Skunk2 Pro S
  176. 2000 civic suspension help
  177. What Brakes?
  178. brake booster/master cylinder leaking
  179. Struts....which ones?
  180. brake recommendations for integra
  181. squeaky suspension
  182. Nervous handling, after changing wheels/tires.
  183. suspension shops in hawaii...
  184. SP FAB traction bars??????????
  185. How low should I drop my eg. Dont want to look slammed but I dont want to look stock
  186. CR-X Suspension question
  187. Wilwood Fastbrakes Kit Question.
  188. Tokico/spring help....
  189. GC coilovers, p/n for springs?
  190. Opinion about the Eibach Sport System
  191. Quinton Hazell Parts?
  192. camber question????
  193. 4 pot brake kit that clears 15" rims
  194. Benefits of a larger Master Cylinder?
  195. 96 sedan lowering
  196. Fuction&form type2
  197. function form type 2 coilover
  198. Help a Suspsension Newb w/ a GC set up!
  199. Do I need new shocks? CRX with Neuspeed springs/Tokico blues
  200. Are these Ground Control coilovers? **PICS**
  201. Will it fit?
  202. 2000 civic no brakes!
  203. Low Cars
  204. obx subframe reinforcement???
  205. Bending the Knuckles
  206. K-Sport coilovers
  207. rx7 calipers on our cars??????
  208. Do i need camber kit for stock wheels+follwoing mods ?
  209. Spring rates for Honda Prelude (H&R)
  210. who has blox adjustable end links?
  211. DA booster and master cylinder on an EF.
  212. Broken damper adjustment knob
  213. lowering integra need advice
  214. coilover question?
  215. just got alignment done now 1/2sec delay
  216. i hear clicking noice when i turn the wheel
  217. Wierd Drop!! Skunk 2 PRO-S Help??
  218. 96 4 lug ITR Rotor replacements...
  219. AutoX brake setup on my CRX
  220. Recommendations?
  221. lowering my civic... need instructions
  222. Sway Bar Silicone Grease?
  223. Alignment question...
  224. skunk2 sport shocks for CRX.
  225. 95 civic/integra Suspension Price?
  226. Abs problem Code 7-4
  227. Brake Booster and Master Cylinder compatability. I want to make sure Im wrong... :-P
  228. GC Question
  229. bouncy suspension...
  230. quick ITR sway bar question
  231. C-pillar bar in EF
  232. What brand suspension and why><????
  233. Difference in Koni Yellow Shocks?
  234. integra suspension
  235. Alignment Before or after new tires... Does it really matter?
  236. Camber Kit
  237. integra da pad clip question
  238. Replaced calipers, all fluid came out, do I need to bench bleed?
  239. Noise when turning steering wheel left or right
  240. sway bar question
  241. tieing up brake lines...
  242. Is there 2 different 97 Type R Master Cylinders??
  243. Extending my top hats on my 91 rex...
  244. LSD question
  245. Warranty Information. Rebuildable Information.
  246. Lost Coilover Keys
  247. Matching masters with brake caliper size/rotor.
  248. Skunk2 Spring Issue
  249. Is there a right way to slam your car?
  250. anyone have ct 5lug conversion on ek hatch? need some awnsers.
