PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. What size is this bolt?!
  2. Are UCA and Compensator arms the same from DC2 to EK?
  3. 95' dx manual steering help.....steering wheel wont come back to center????
  4. mugen brake kit on 4 lug???
  5. crx si rear brakes....swap to Eg?
  6. Coil overs input
  7. 95 civic ex suspension
  8. 40/40 question, and rim clearance question
  9. 93 hatch rear strut bolt will not come out
  10. Is this the correct proportioning valve?
  11. 96 DC2 H&R spring Install question/comments
  12. What pads for my wilwood dynalight setup
  13. 90 integra constant squeaking/unknown cause???
  14. Right front brake hung up.
  15. Tell me what you think of this setup, Moog UCA/balljoints civic type-r struts/springs
  16. BRAKE JOB
  17. omni camber kit wit Ingalls Alignment Kit together
  18. honda civic ef sedan autocross/street suspension suggestions..
  19. Extended ball joint help!
  20. DC5 BREMBO ON EG/INTEGRA DC2
  21. Want to add some camber, how will it affect toe?
  22. Front Sway anti-roll bars questions
  23. camber kit question help!!
  24. Skunk 2 springs/ camber question need help
  25. Vibration Problem>?
  26. DC5 Form and Function rear coils won't go down :(
  27. Track / street suspension
  28. Password JDM 4 point rear strut tower brace VS. 2 point
  29. Coilovers
  30. coilovers
  31. Changing suspension...again! Need input.
  32. Alignment after disk swap?
  33. Looking for calipers and brake system
  34. Best Cheap coilovers
  35. ITR brake conversion for EG civic; brake lines
  36. need coilovers for a delsol
  37. No Pressure ?
  38. Soft Breaks?!?!?!
  39. Integra GSR Sway Bars on a Civic Coupe???
  40. polyurethane bushing kit questions
  41. 23t bracket question
  42. Do megan racing adjustable coilovers fit kyb agx for 99 civic?
  43. So im dropping my DD DB8, need some help!
  44. Koni yellow/GC combo help
  45. cut spring on 1piece coilovers
  46. Help me understand Tein's webiste
  47. coilover/suspension suggestions?
  48. Two questions..please help!!
  49. difference in spring heights
  50. Which springs should i use? Tokico 5049F or Neuspeed 55.20.20F
  51. Bushing install advice
  52. 22mm ITR Rear Stabilizer...Best Endlinks?
  53. Koni yellows Noob<<--- help?
  54. Civic Rear Disc Swap. Part list complete?
  55. CV Shaft not fitting.
  56. KYB AGX shocks, shopping for good springs.
  57. dragging/locked caliper
  58. Alignment Settings - What Do You Run?
  59. Da integra Suspension makeover
  60. Will ek forks bolt on my ef
  61. Master cylinder size, 7/8" good enough?
  62. Is the frame bent?
  63. should i go with integra coilovers for a del sol?
  64. Skunk2 Pro-S coilovers??
  65. Replacing Coilsleeve on Coilover.
  66. need BC N+ instructions for eg
  67. SPHERICAL BEARING-rear trailing arm-THOUGHTS?
  68. eg caster setup
  69. Tein flex coilover question
  70. 98 Ek suspension upgrade sugestions
  71. height adjustment question on tein coilovers
  72. Opinions on a full Skunk2 suspension Upgrade
  73. Replacing brake booster
  74. new brakes now rotor has a groove
  75. Do I need a DC2 Type R Front Lower Control Arms?
  76. Type R D-Link brackets and bolts
  77. Spoon or Buddy Club Ball Joint?
  78. X bar or rear strut bar(s)
  79. rear lower control arm HELP!!!!!
  80. M2 spring install and review
  81. Proportioning valve question
  82. ASR Swaybar
  83. Which coilovers to go wit?
  84. Question about bushings, please help!
  85. Brakes are dragging after new parts help!
  86. Alignment
  87. Buddy club coilovers??
  88. Front springs on rear shocks
  89. Soft pedal.. never had a honda with good brakes!
  90. Function7 Counterfeit Warning - how to spot
  91. Tein, Skun2, or Function Form??
  92. eg KKC wilwood master
  93. Subframe swap???
  94. setups recommendation
  95. Opinion, DIY EK camber kit
  96. car shakes at high speed cornering
  97. F&F Type 1's "Knocking"
  98. 2011 Civic SI alignment problem
  99. What knuckles do I have? SR-R-13 & SR-L-13
  100. TEIN ha rebuild?
  101. koni/gc, tokico/gc, or func. form?
  102. Looking for a firm ride without lowering
  103. Ground Control and koni yellow guestion
  104. Where to begin SUSPENSION WORK
  105. ebay lowering springs... advice?
  106. TEIN QUESTION
  107. 98 integra steering rack in 95 civic lx. will it fit?
  108. Gc/koni rear rattle
  109. KoniGC or Eibach prokit
  110. 93 civic hatch noise while braking
  111. Spring rates for Skunk2 Lowering Springs(94-01 integra)?
  112. Best dealer for Hardrace Suspension Bushing Kit 92-95 Civic
  113. 99 DC2 Eibach pro-system or sportline system
  114. Purchasing 328x28 Stoptech BBK, but rotor ring needs replacement
  115. 00 Civic springs on Integra?
  116. strut rod nut won't come off or tighten
  117. Hawks hps VS hps plus... Which ones??
  118. Tein S tech springs
  119. What size sway bar?
  120. weird squeaking sound..?
  121. Lower arm question. Please help
  122. lowered car now weird noise in rear end?
  123. Need some good rotors
  124. Name the peice that you turn when you bleed brakes
  125. hub centric rings for Corrado rotors?
  126. Ksports bottoming out
  127. which coilover's
  128. Cardone vs OEM Brake Booster?
  129. aftermarket rear sway bar w/ stock front sway bar?
  130. Koni/GC Installation Recommendation
  131. shock rebuild
  132. Completely Seized.. Out of Options
  133. Lower Control Arm bolts
  134. lost coilover tool where to buy one?
  135. ground control springs on ebay coilover sleeves
  136. Im looking for light suspinsion mod
  137. KYB GR2 sits lower than Tokico blue
  138. whats the difference between these two?
  139. Progress rear sway bar?
  140. Perches stuck
  141. Tokico Suspension
  142. suspension help
  143. Help going to softer spring rates / dampening on a low S2k AP1
  144. Caliper Upgrade for the AEM BBK?
  145. Solution for torque steer?
  146. Do springs really sag?
  147. Function n form type one???
  148. coilovers skunk2: passenger side higher than driver side
  149. how to install master cylinder and prop valve
  150. ksport gt lowering spring rate? 88-91 civic/crx
  151. Shocks that ride like stock?
  152. How to get a smoother ride.
  153. Good news from my alignment guy
  154. Advise on rotors
  155. inexpensive 6" race coil springs in 300lb/in or 5kg/mm rates?
  156. Which top hats with Koni sleeve kits?
  157. identifying rear and fronts springs
  158. Koni/GC Spring Rates
  159. 1995 honda civic dx front sway bar lca install question.
  160. Bsq kit with 22mm ITR S/B good enough for 92 Eh2?
  161. gsr brake conversion??
  162. Ek9 Civic type r Big brake kit?
  163. ASR Brace Question
  164. My 5 lug ek coupe.
  165. Spoon Caliper Twin Block Setup
  166. Alignment Problems
  167. 94 integra front LCA question?
  168. need help quick (PIC)
  169. Lost Tein Master Control Flex Keys.
  170. running turbo gsr with stock suspension...???
  171. Yellow Speed Coilover
  172. possibly a bad caliper?
  173. What happened to OmniPower? I need new rear bushings for my ITR-spec coilovers...
  174. Springs Sagging
  175. 03 WRX / STi springs and Tokico D-Spec
  176. Suspension kits..which to buy???
  177. 94 Civic DX -- 95 Integra GSR swaybars
  178. LCA bushings?
  179. GC mounts for the rear?
  180. Another daily driver suspension thread, help me make up my mind!
  181. Front Bushing Replacement
  182. ground control coliovers screw stripped
  183. 94 GSR Rear Brake Hard Line Replacement Question
  184. Apollo Coilovers Review
  185. Part location / I.D?
  186. **BRAKE GURUS... Enter here**
  187. Need advice on my suspension setup
  188. need some alignment specs for my setup
  189. Looking into new suspension for Ej
  190. Air ride suspension.
  191. do u have these on your car ?any regrets ?
  192. Reducing Strut Piston Length
  193. help naming and finding these springs
  194. Energy Suspension bushing kits
  195. Brake Caliper upgrade on GSR Integra
  196. Installation of non-coilover lowering springs
  197. 1995 Honda Civic shock suggestion Help!
  198. Question about lubing poly bushings, and spherical bushing endlinks
  199. 11.8" 300mm rotor brake setup
  200. Gen 3 Omni LCA bushing replacement?
  201. Help needed!! E-brake cable or ABS Sensor?
  202. Akebono Brake Pads
  203. Rear suspension help-excessive negative camber.
  204. Need Help with Coilovers (CRX)
  205. Need advice on lowering my eg coupe 93
  206. I need suspension, HELP!
  207. No Sign of Wear on New Rotor
  208. Help needed: rack & pinion???
  209. 5 lugs soft brakes help.
  210. what struts are good for 300 for a 92 integra
  211. Koni/GC VS AMR Engineering
  212. EK hatch rear disc conversion help.
  213. 5th Gen Lude bushing help
  214. tokico 5 way adjustable shocks
  215. Installing ITR Rear Sway on '93 Civic HB
  216. Use adapter plates for Skunk2 coilovers and Koni yellows!
  217. Alignment Issue
  218. 1994 EG EX sedan w/ PS Rack n Rods
  219. Outside edges of tires getting eaten up?
  220. Blown shock? Upper shock mount bushing?
  221. DGR Coilovers
  222. TOP HATS and there benefits
  223. omni or skuck2 coilovers
  224. Irregular brake pad wear
  225. 96 spec Integra Type-r caliper rebuild kit part#'s
  226. suspension mods
  227. Replaced rotors and pads, still vibrates. Help
  228. Couple quick questions regarding EG sway bars
  229. d2 coilover dampening adjuster
  230. springs with a equivilant drop to skunk2
  231. How do you lower your car without sacrificing ride quality?
  232. Shocks
  233. Buddy club N+ vs. Junior Spec
  234. Bent Shoe
  235. Sprint Springs 2.50-2.25 or 3.25-3.00 Help!
  236. ASR/BEAKS on EK
  237. 92 Civic Skunk2 coilover sleeves
  238. Koni Yellows/GC using OEM top mounts: Something VERY wrong!!!!
  239. new to suspensions, where to start?
  240. Type R caliper?
  241. Type r calipers
  242. 95 civic ex coupe front upper control arm question
  243. Where can I buy ASR backing plates only?
  244. Suspension Help!!!!!!!!!!!!
  245. disc brake upgrade
  246. Initial Impressions/Thoughts- Eibach Pro Kit (Spring/Strut) Civic/Integra
  247. brakes gave out yesterday
  248. What kind of Sussy is this?
  249. BWR vs ASR subframe brace...does the BWR SUCK?
  250. 95 ex suspension
