PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99]
  1. Type r sway bar
  2. suspension setup help
  3. Spoon/Nissin 4pot calipers
  4. suspension limiting straps?
  5. suspension noise
  6. question on 5 lug set up????????? HELP!!!!!!!!
  7. Omnipower slip-on coilovers & Camber kit
  8. Suspension Civic Type R EP3 (Civic Si in the states)
  9. got my omnipower coilovers!
  10. speedtech
  11. Omni power for drag?
  12. How much$$$$ does the average coilover install cost???
  13. eg/dc rear sway bar on a 6th gen?
  14. trailing arm bushing! are they worth the money??
  15. [FAQ] Koni Shock Install
  16. need camber kits, which is most reliable?
  17. Itr aftermarket suspension pieces on gsr?
  18. Suspension Noise
  19. Lowering Me
  20. Sway bar swaps
  21. 99 ex rear sway bar
  22. i am going to get coilovers they have eibach and koenig parts
  23. 00 Prelude SH Suspension Crisis!
  24. drag lunch springs or full coilovers?
  25. spring install
  26. EG Cornerweights???
  27. 5-bolt suspension questions
  28. Coilover's help plz....
  29. Street/Autox car: how much toe out is too much?
  30. Spring compressor for install
  31. ST Rear sway bar endlink problems and solution maybe
  32. About to order a GC/Koni Yellow set up. Few Questions???
  33. Air
  34. rear suspention makes a big thump when compressing around a corner
  35. Track Suspension Thoughts and ?
  36. WTF MATE? CUSCO Coilovers+ITR LCAs+EK HATCH=NO WORKY!
  37. OMNI SUSPENSION PICS?!
  38. Omni power slipovers....
  39. Loud suspension after ground control install
  40. wierd scrapping noise
  41. Allignment Question...
  42. HELP: knuckle stuck
  43. Are there any new Koni Products?
  44. Gab Revostroke 1 peice coilovers
  45. ground control help!
  46. sway bar & tie bar installed, now weird "thump" noise.. help
  47. BUSHING INSTALL?
  48. steering is too lose on 1995 Civic CX
  49. Drag suspension Setups
  50. suspension setups and components for 92-00 civics
  51. Omnipower suspension... good or not ?
  52. suggestions on height difference??!!
  53. Good street/autoX spring/shock combo? (NOT coilovers)
  54. Stock R susp. vs Tein Flex. a question about swapping the 2.
  55. I want my car to ride better, right now it's a rattle box.(Bushings)
  56. [FAQ] Shock Dynos
  57. Are SPC camber ball joints pre-greased?
  58. Do my eyes deceive me?
  59. Koni /GC H22 spring rate IS it enough
  60. Suspension Travel? (DC, EK, EP)
  61. RSR Springs
  62. Basics for better handling on the street - Strut Bars... front upper, lower, etc.. - Brands to use?
