View Full Version : Suspension & Brakes
- Switching Front / Rear Springs?
- shocks/springs decision
- Shock Question
- **Coilover descision**
- i have an idea?
- *Heads up* Counterfeit Tein springs
- custom camber kit?how
- need new struts?
- Quick question about shock travel and coilovers! Rides smoother when slammed.
- Ground Control w/Koni "Perch Settings"
- Building Sway Bars for SAE-Need Help!
- omni sleeve coilovers
- DA Owner that needs HELP!!!!!
- Rear swaybar, no front swaybar.... bad idea?
- Traction bar/crossmember concern in a EF
- cutting strut towers to access camber adjusters
- New Konis, springs now sit loose at full extension - anything I can do?
- BUSHINGS
- tein problems plz help
- skunk2 full coilovers: ride stiffness
- typical question
- AROSPEED REAR CAMBER KIT... link inside
- gc w/ agx okay?
- ITR LCA
- c pillar bars for coupes
- 5 lug vs 4 lug
- 87 civic si
- Ur opinion on Suspension Combo!!!
- Coilover with shock 101
- megan racing coilovers. any one have experience??
- Cheapest place to buy H&R sport springs
- Replacing shocks and springs - True or False?
- it's a waste money?
- Do the Tein SS for a 94-01 Integra fit on a 1992-95 Civic coupe ?
- Rear end springs too soft?
- coilover kit
- Dumping
- Can I but spoon brakes on all 4 corners of my Ek
- front camber problems
- Tire Wear Problems... Alignment/Ride Height?
- Skunk2 Full Coilovers for road racing???
- Sway Bar Endlink/bushing Questions???
- Considering H&R Sport
- Will 195 55 15 tires fit on 15 X 7" Wheels on CRX HF?
- How can I cut my springs?
- help for 03 civic
- does EK coilovers fit EG?dooable?
- ek supension question
- what do you think of used coilovers?
- crx/itr rear sway
- Springs/car keep squeeking
- ground control coilovers with stock delsol struts???
- Problem
- lower control arm
- Fuction Form coilovers.? anyone heard of these guys??
- OFFICIAL: Daily/Track/Auto-X Spring Rates
- HELP ME CHOOSE MY GC SPRING RATES.
- Anyone know these GC spring rates?
- 96-00 Civic Rear Subframe Failure and Sway bars (?)
- Spring rates
- Koni/GC snap ring?
- good shocks
- do i need a camber kit?
- itr rear lca on ej8 will it work<<<<<
- Need Help with omni power drag
- my suspension squeaks
- Intrax Springs Question
- tire question
- Eibach Sportkit vs Eibach Pro-Kit
- suspension?
- strut question
- Calipers for EG6 , which?
- need help with lowering springs
- Pictures of dropped eg's
- Camber kit questions
- Camber kit?
- brake and knuckle help...
- Teg Suspension help
- CAMBER IS WAY OFF!!!!!!! which camber kit well fix this ???????????? BEST CAMBER KIT OUT THERE??????
- omni camber kit(help)
- 89 Si Hatch
- Lowering CG by Lowering Motor???
- tein stech springs (searched)
- comptech tie bar
- Weird noise... including video (from fenderwell)
- how hard is it?
- vibrating after installing new axles
- how to get stripped shock off
- Suspension Question.. Help Lowering
- Alignment Results
- who makes a better kit
- stock axles
- SO CAL: Recommend me mechanics for Bushing install
- cant get jackstands under car :|
- air noise when i hit bumps
- Suspension Help
- -- Post your spring rates ! --
- What is.....
- Upper Ctl. Arm Bushing causing SHAKE?
- c-pillar bar have any purpose?
- whats wrong with my DA????? rapidly shaking and clickin noises??
- 92 Civic Bumpstop help!!
- Adjusting Camber
- camber kit $
- ta bushing fill...
- tranny end of axle loose?
- upper control arms interchangable?
- For your viewing pleasure ASR Subframe Kit w/ Omnipower LCAs on EK
- DA Rear control arm parts diagram
- another traction bar question
- ? about coilver
- 96-00 civic Koni Struts parts list?
- bad tie rod ?
- Trying to diagnose a suspension prob... Tie rods...
- I'm wondering, how many inches should I....
- what else do I need?
- Koni yellow with 400front/500rear
- ARE THESE GOOD?
- This is the best lowering method
- H&R Cup Kit For EH2 on EM2*?* (Hatchback)
- Front wheel bearing noise? Or transmission bearing?? please help!!! 97 Civic DX hatch
- my first rsx axle job - question
- compliance bushing- pls identify
- HELP: Weapon R x brace bar... fitment
- what else do i need?
- Suspension gurus please look!
- Please help, changed axle, changed tires and balanced them.....now weird vibration under acceleratio
- ground controls + stock struts??
- Endlink Problem, PICS: Please look
- how to install lowering springs
- 92-95 Civic Springs on a 99-00
- Anyone have any experience with Bilstein monotube shocks???
- Spring??????
- omnipower full coilover's. paint has peeled away.
- lowering springs used on GC perches
- opioin on this set up
- Lowering wrenches needed to adjust omni full coilovers?
- Alignment question?...
- power on power off steering probs
- car is sagging on driver side
- Changing Rotors
- Bumpstop setups with koni yellows - Post em up! Also DA/DC shock conversion q's...
- omni coilover help plz!!!!!
- RS Racing coilovers and KYB AGXs
- suspension too stiff, how to adjust?
- drop zone
- Koni 1150 coilovers, anyone running them?
- omni power slpiover coilovers?
- Identify this sway bar
- BALL JOINTS...removal and install
- how are skunk2 springs?
- TEIN EDFC
- D2
- H&R Race springs with Koni Yellows
- need help ASAP! self lowering 89 civic hb. please !!!!!
- Where to find M10 x 1.25 x 80mm 10.9 hex cap socket screws?
- OMNI DRAG.
- Where to find a good deal on Full ITR Suspension and wheel setup
- Tanabe Sustec Pro SS Type II
- Brembo Rotors
- Weird Noise
- Tanabe Precedeo Springs
- how do koni red and koni yellow compare?
- prelude upper mounts
- This has probably been covered a million times
- CRX '91 VTEC racing suspension problem - WHAT SUSPENSION DO YOU GUYS USE ?
- EFs on tein s tech..neuspeed..h&r
- what setup to lower my 90 prelude
- Better Balance... EG or EK?
- LSD traction bars..anybody used them or have any expreince with them?????
- Need some comfort info
- coilover sleeve?
- best setup for 94 sedan
- Koni yellows in the front and tokico blues in the back, will it work ok?
- 04 Accord Alignment Kit
- Suspension for my EJ1
- new hardware required for rear strut replacement?
- skunk2 coilover problem
- koni shock travel reccomendations
- Buddy Club Racing-Spec - removing pillow-ball mount
- simplest 5 LUGS conversion ever!!!!
- Need a camber caster kit
- Tein S-Techs or Tanabe DF-210 springs on CD5 Accord? Pics and Info PLEASE!!!
- anyone put an ITR rear sway bar on a DA??
- Shock/Strut question for my teggy
- lowering question?
- Accord Springs installation Help@!
- calculating center of gravity
- D2 Coilovers...can't even search it!!!
- ball joint help...
- Koni/GC Setup-- Ballpark $$$$ Figure?
- chromoly subframe
- Omni Power LCA bushing issue
- Bedding Brake Pads and Seasoning Rotors?
- Omni power coilover best price
- skunk2 springs??
- how the hell.... really help me.
- Bilstein HD or Koni Yellows for H&R OE Sport springs
- i need sum help wit my 99spec apex suspension... searched/please
- do i need tophats?
- Circuitworx Stage 1 Axle/Hub setup feedback please!
- fastbrakes kit!!!!!!!!?
- coilover noise
- hey i need suggestions?!
- A little handling help please
- $th Gen LUde Spring on ACoord coupe '97.
- EK suspension on EG... 00 SI LCAs?
- Wheel Hop
- Suspension for a CRX with a b16. What springs?
- Spring compressors - Does anyone use this one from Harbor Freight?
- Balljoint Boot Replacement.
- Alignment adjustments on a civic
- Tein phone number
- new rear sway bar need help!
- Springs Swap...Front to Rear...Rear to Front
- This look right?
- Swapped 91 CRX suspension
- Front and Rear maximum camber allowed for the streets ?
- Quick koni install question...
- How much negative camber should you have street vs track ...?
- USDM & JDM , itr swaybar question
- koni yellow on megan racing springs
- ASR brace and Suspension Techniques Rear Sway are COMPATABLE on DC Integra PICS
- JDM ITR End-link question
- How much can my handling improve (95 Accord)
- brakes?
- Koni perches
- Front end shake under power.
- Toms Motorsports Coilovers
- Will EK shocks fit my EF?
- I need to extend some threads on a sway bar piece.. ideas?
- Help! Car keeps going towards the left!!
- alignment specs for tein stecs
- coilovers or springs
- looking for camber/caster kit for 95 civic
- Sway Bar Bolts..
- Do i need anything else?
- Skunk2 question
- Upper A-arm bushings HELP
- lowering springs for my 01 ITR
- NEED HELP! rsx ground control coilover trouble...
- Running into problems with Koni Red installation on 88 CRX
- suspension kits for 96 3.5rl
- problem with ground controls, konis, and tophats
- Civic Coupe camber kits ???????
- Question on coilovers
- 90-93 integra GC's different than 94-01
- tokico illumina settings
- omni coilover/kyb combo question
