PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Function&Form coilovers
  2. touge/ mountain driving, springs?
  3. crx suspension questions
  4. lowering the front just a little more.....
  5. 99 hatch with rear disc swap
  6. Slip-on coilovers rattle
  7. Suspension Weight Savings???
  8. 1991 CRX suspension Questions and Camber Problems, help please
  9. Pink H&R springs
  10. Lowering / suspension work 96 del sol s
  11. Any Civics/Integras Using J's Racing Roll Center Adjuster?
  12. cheap coilover
  13. BLOX LCA's and Energy Suspension bushings question..EG
  14. any one using koni coilover set-up
  15. can't decide on which coilovers to get..HELP!
  16. higher after getting lowered...
  17. suspension info please?
  18. Pi sports springs
  19. ITR Swaybar on DA??
  20. Rear Toe Adjuster ?
  21. Help on route to take with my 01 Civic
  22. brakes
  23. How to raise car higher?
  24. T1R Tie Rod end??
  25. Question about independent suspension and steering
  26. 5 lugs conversion!
  27. noob question. Already searched.
  28. big problem driver side sits lower than passanger side with h&r race springs help
  29. bear frame & wheel.. socal??
  30. suspension swapp
  31. Skunk2 Coilovers with Springs likes and dislikes.......
  32. why do japanese tuners used staggerd wheels on ff cars? (searched)
  33. eg full coilovers with progressive springs?
  34. is there any shocks that go lower?
  35. Traction Bars: Helpful at the track, or Drag use only?
  36. coilovers?
  37. ITR rear swaybar on EK??? Does it work??
  38. H&R Race Springs question..
  39. Do I have ABS or non ABS axles..Pics!!!
  40. newb question about blown koni
  41. tokico assembly
  42. EM1 rear sway
  43. Blox Camber Kit
  44. tein coilovers
  45. skunk2 pro series plus camber kit
  46. FRONT SWAY BAR ??'S
  47. LCA Removal and Question
  48. Camber Kit Adjustment
  49. Driving Characteristics (sway bars)??
  50. Traction bars on damaged front end...
  51. Help??? Installed 99 Integra Front sway Bar Onto 96 Civic problem
  52. Best LCA?
  53. Time-Attack Style Tire/Wheel Setup Help
  54. alignment specs
  55. where to get a good deal on full race traction bars
  56. PIC coilvers... twin tube or monotube?
  57. Question about Tein Upper Pillow Mounts
  58. coilover question...
  59. Strut bars, sway bars, all the bars you could think
  60. What sway brackets for ASR bar??
  61. Which Shocks are the least likely to blow?
  62. CIVIC
  63. Shock
  64. rsx type s disk brake swap for 2004 civic coup?
  65. quick question about bushings
  66. Uneven ride height
  67. Custom made strutbar
  68. Picking up a vibration at 70 MPH
  69. Lowered Honda Prelude, Excessive Tire Wear
  70. Rear subframe braces
  71. Ride Quality
  72. suspension question
  73. Does a DC2 ITR Rear Strut brace fit an EK Civic 3door?? (or where to buy CTR bar?)
  74. Skunk2 springs and sports shocks installed: now problems
  75. Function7 Endlinks + ITR swaybar problem
  76. Tein SS
  77. CUTTING BUMP STOPS
  78. shocks?
  79. jam nut / cotter pin
  80. I need help with suspension setup
  81. I need info on spoon strut bar before I order
  82. Spoon rear lower arm bar
  83. tokico illuminas with tein stech
  84. Replaced stock susp. w/ Tokico Blues & Eibach Sportlines on CRX
  85. What are the best shocks?
  86. koni yellow/gc's 97 civic issues
  87. Alignment pulls after new transmission install
  88. camber kit
  89. Passenger wheel is shifted back
  90. worried about coil bind
  91. Clunking noises from rear
  92. CL7 Suspension on a CL1
  93. Drag race crx full Coilovers. Best for the money.
  94. 4 lug to 5 lug?
  95. what to do with front brake hoses on full coilovers?
  96. Rear tires wearing funny, "cupping"?
  97. 91 crx question?
  98. need 2 know if a 96 4-lugs type-r acura suspension would fit on a 96 hatchback civic
  99. questions: installed front lowe tie and and lower Xmember bar on 01 dc2
  100. Is this why my tire wore out in a year???????
  101. Si suspension?
  102. Coilovers for accord, Tein SS or Ksport
  103. AMR or F2 or D2?
  104. Will Integra Springs fit on my Civic???
  105. question about 'full coilovers..
  106. Alignment / Steering Problem
  107. To all Suspension gurus
  108. how far of a drop
  109. alright so i tired taking out my rear shock but couldn't
  110. Integra Springs on my Civic???
  111. Anyone running gc on there stock shocks?
  112. getting some hardrace bushings?
  113. Question About Ground Controls
  114. Koni/GC/top hats good setup for being slammed?
  115. What brake pad are you guys using?
  116. eibach sportlines or H&R sports?
  117. skunk2 drag launch coilovers?
  118. Best link for Tein SS......
  119. How is this possible.............Camber off by 0.5 on only one wheel??????
  120. Which camber kit is good enough?
  121. Help! My skunk 2 upper A arms didn't come with instructions!!!
  122. Lower Arm Bar
  123. video: custom struts. these guys are engineers. bahahahah
  124. Is Ksport made in the U.S ?
  125. shock dynos info? and stiff vs bouncy... I need help
  126. street/auto-x EH hatch with 23mm rear sway... opinions: 22mm front bar from teg LS?
  127. EK springs on DA?
  128. Upper Mounts (ground control)
  129. 4pt rear bars for eg9
  130. illumina vs oem shocks, differences?
  131. em racing ?
  132. coilover springs
  133. illuminas without adjuster? help!
  134. koni w/ GC or FF2 for auto X and drag
  135. missing parts on used konis. any dealers in here? crx lee still around?
  136. Lowering springs or Coil overs?
  137. removing camber kit
  138. Symptoms of blown shock
  139. best coilovers are
  140. Need Help Removing WHeels Studs..
  141. stock suspension
  142. DRAG SPRINGS WHAT DO U GUYS USE
  143. Sway binding shift linkage?
  144. Vibration at low speeds... help?
  145. Need Advice on Camber Kits....
  146. Question about error range in dampening
  147. top hat question
  148. Clicking or Banging Noise Under Braking
  149. what spring perch setting with neuspeed race springs and neuspeed koni yellows on 89 civic si?
  150. Another spring question
  151. How far can you slam your car without hurting your struts?
  152. help with koni's
  153. time for an upgrade
  154. omnipower street or omnipower sport
  155. weird sound
  156. help with bump stops!
  157. Grease for swaybar bushings w/ Zerk fittings?
  158. Which bushings in front LCA need to be replaced?
  159. tein springs
  160. Buddy club N+ & Racing Spec
  161. help with Kyb coils
  162. 5lug question
  163. alignment question
  164. A Tip for KONI Red Adjustable Userssss.....!!!
  165. Buddy Club Racing Spec w/ upper mount can adjust camber?????
  166. H&R or Neuspeed Race Springs??
  167. coilover problem in the rear.... HELP!
  168. Purchasing New suspension soon need some ideas
  169. Question about suspentions
  170. Tokico Illumina Shocks or Tokico D-Spec shock/strut kit?
  171. Skunk2 Camber kit balljoint ?
  172. lowering kits
  173. gsr brakes on eg
  174. OEM struts/shocks with GC top hats?????????
  175. Tein H or tein S
  176. Camber Kit needed for alignment?
  177. Which coilovers---PIC Apex or D2???
  178. Ground Control Springs Unidentified
  179. extremely frustrated ... vibration in steering wheel with proper alignment and wheels balanced
  180. Skunk2 shocks AND springs
  181. alright so i have a 99 honda civic dx hatchback with h&R springs help here
  182. Blown out struts
  183. what causes a car to buck /oscilate? my spleen is on the ground!
  184. lowering integra
  185. Suspension Upgrade, not sure what to do...
  186. Will you guys go mountain passes?
  187. What is this rubber piece called? Goes in between the spring and top hat.
  188. !HELP! Traction Bar For EG w/ H23
  189. Question about tein s-techs
  190. Need Some Advice **Need Reviews**
  191. H&R Race Spring question drop question
  192. Rally X suspension?
  193. Too much rear camber, which LCA could I buy?
  194. Apexi spring rates
  195. 99 si upper strut bar to 00 civic ex
  196. Koni Yellow/H&R Race..extended top hat available??
  197. Replacing axle
  198. Korbach frame locks
  199. DROP FORKS
  200. Function 7 LCA's for an EK...
  201. Couple of issues...
  202. em1 rattle/knock...?
  203. best place for coilover replacement springs?
  204. stripped wheel stud
  205. squeeking and shaking on DC4...need advice
  206. Control Arms, Short Shifter Adapter, Coilovers from Skunk2
  207. need stiffer spring?
  208. toe problem
  209. Need Help deciding what coilover/spring setup for my drag integra
  210. Megan Full Coilovers... need some help
  211. Integra sway bar question
  212. Rotor / Pad Question
  213. koni yellow SP3 question about directions
  214. camber kit adjustment?
  215. Neuspeed Drop springs?
  216. help on choosing new springs
  217. Anti/ Sway bar rear and front
  218. What are the dimensions of the rear wheel bearings Civic 99-00 si?
  219. h&r springs
  220. JDM DC5 sway on base DC5...worth it?
  221. tophat questions
  222. ARE THESES REAL OR NOT
  223. type r sway bar install help
  224. Drag suspension set up
  225. Apexi N1 Revalve?
  226. Hit a curb. Possible suspension problems
  227. Post pics of ur DA suspension setup
  228. Removing brake disks
  229. Buddy club N+ Spec
  230. need some opinon on suspenion
  231. Civic Strut Bar Question
  232. pulling negative camber? How to
  233. Rear threads on coilover are destroyed. What now?
  234. Tokico D spec or illunina coilover?
  235. Need help with TEIN FLEX coilovers
  236. Non honda related brake question (volvo s60)
  237. skunk2 lowering springs
  238. eibach pro kit
  239. stock spring rate??
  240. Omin power front camber kit
  241. what is the best?
  242. where to order LCA bolts?
  243. Good Deal?
  244. Quick question...
  245. best track susp. setup for 91 crx?
  246. Zeil 6 way ajustible coilovers
  247. OMNI POWER reputation: ARE THEY SRONG ENOUGH!!!???
  248. Tokico suspension spring rate?
  249. 95 teg suspension bolt up to a 92 civic?
  250. Tein SuperStreet question...
