View Full Version : Suspension & Brakes
- rsr springs...
- Koni Yellow for 92-96 Prelude?
- write up on sway bars?
- Can I fit 235/50/16 on a stock suspension eg or do i need to lift car? help
- will 92-93 civic coil overs fit a 91 DA
- broken endlink on front sway bar
- EF struts on an EG
- CTR Strue Bar?
- Ebay Coilovers??!!
- How long to koni yellows last
- tokiko illuminas... why do they keep poping up?
- Bushing replacement??
- '96 Type R 114.3 conversion!
- Any sponsors got the Comptech tie bar / sway bar for sale? (searched)
- ground control
- 91 civic si, Omnipowers, 215's (tires). Rubbing in the wells?
- Omnipower Rear LCA bushing durability
- Turbo Suspension Setup
- m5 luggin help!!!
- 5 lug converiosn on a ep3 hatch ?
- DC2R Tein Flex spring upgrade
- DC2 suspension
- Toe Degree to Inches Conversion
- Preload Coil Overs?
- Need Advice/Suggestions-New Susp.Setup,Stricly Street Driving,Which?IveSearched!
- CRX Tie-Rod in innerchangale?
- TA bushings, Sphericals
- which prop value do i need
- corner weighting
- i'm a noob. can someone help me how to raise my car?
- Chamber Kit....
- Anyone have SPC rear toe adjusters/compensator arms?
- steering issues(93 dx coupe)
- DC5-R brembos on a DC2?
- Installing springs 2morrow for the 1st time....need some tips.
- broken end link, remove other side end link until fixed?
- eibach sportline vs prokit
- tiens suspension from my 92 integra onto my 1990 civic..
- Just installed my Koni/GC - major question
- Anyone run a GSR front sway bar on their EH2
- H&R Ultra Low Coilovers
- Civic stiffen?
- hey guys, what are differences between springs/coil overs..
- Wierd sound coming from the rear of the car
- Are 90-93 Integras susceptible to rear swaybar tearout like the 96+ Civics are?
- need some Omni Power help
- how important are dustboots (koni yellow/custom gc)?
- Does the NSX caliper fit on dc2???
- Koni Yellow vs Tokico Illumina
- Does Camber and Toe change if I add -1.5deg of caster?
- Summit Suspension ????????????????????????
- correct pressing procedure for bushings?
- Eibach Pro Kit - Do they settle?
- What size o-rings to use with Skunk2 coilover sleeve install??
- H R sport springs but stock shocks.. please dont flame
- 5 lug
- best rear camber kit 2 buy
- GC/Koni help needed
- Suspension question for all you hybrid suspension gurus........
- A-spec 32mm sway bar kits and spoon n1 exhaust
- EK.Rear suspension high after installing Lowering springs???
- Alignment after rear sway install?
- Dislike Avid Traction bars
- 3 point Strut Bars?
- tie rod end threads
- need help
- my back is sliding out
- any info on the new ADJUSTABLE omnis?
- does ground control shelf rate goes with agx rate?? help help help
- Tokico 5 way adjustable
- Steering Wheel Shaking?!?!
- gc and kyb agx(will it work)
- Function 7 LCA's
- Camber W/GSR LCAs on HB
- Omni or Tien Basics..? which one would u get..
- D-series power steering on LS swap
- Will sus. from a 1999 civic work on a 1995 integra GSR please help
- Shocks and struts
- gsr front knuckles
- 23mm JDM itr rear sway bar
- Squeaking Suspension - Tein Basic Coilovers
- Best place to order shocks
- coilover adjustment wrench?
- Eibach Pro-Street-S coilovers - install coming soon!
- Suspension question - 99 accord ex(4dr)
- why are my GC uneven?
- 89 civic camber kit
- Need new shocks/springs quickly! 94 Integra LS
- lower ball joint help??
- skunk2 drag coil over set-up
- Just got my D2's installed and...
- one side lower?
- A-Spec vs. beaks vs. comptech for 96-00 chassis
- Eibach Dampers
- CRX swap suspension ??
- my problems with caster/camber on a 94 accord.
- dude i just threw my civic on the alignment rack
- front camber kit 99-00 civic si installation
- ANYONE WILLIN TO HELP INSTALL? ILL PAY U HAHAs.. OC 714
- any SHOPS in OC/LA 714/626? (gettn springs/shocks installd). . .
- ADJUSTING A SET OF GROUND CONTROL COILOVERS
- st sway bar
- Lowering Help !
- D2 Coilover Spring Question
- Ground Control Clunking Issue?
- DA6 Sways badly at speeds over 80KMH
- slippery feel?
- Prelude SH 5TH generation suspension Advice Please!!!
- Looking for a pics of Comptech sway/tie bar (96-00 Civic)
- Help on how to install 99-00 Si Front lower Control arms onto a 98 Civic DX?
- Do after market springs get 'old' and need replacement? *Ground Controls*
- Want good handling but a soft ride??????????
- TEIN questions. trying to decide on suspension for my 05 TL
- help please problem with rear disc conversion on my 90 crx
- ...95 hatch..Stock susp save for Sknk2springs...blow shocks...suggestions?...
- st sway bar questions
- price quotes
- PLS HELP!! got Tein SS-P not impressed!!
- tein s tech question
- Do I need new CV Axles?
- radius rod steel bushings???
- rally suspencion .(crx)
- Dropzone Coilover/Shocks?
- Is Skunk2 full system coilover a good deal?
- traction bars??
- Where to get Koni's and Ground Control setup in the UK
- tie-rod help
- gc and koni instructions questions
- would this work
- need some advice.
- WILL THIS WORK!?
- Too Much Camber?
- Neuspeed sports or race???
- Worn Upper Ball Joints??
- 1989 Integra shock help
- Suspensions setup....
- Aftermarket civic springs on accord???
- best setup for bumpy roads
- rear DC shocks on my EK. What size washers and how thick?
- clicking sound when i brake
- eBay rear swaybar endlinks
- is negative camber ok for daily driven cars?
- Can you buy baby tubes for GC+Koni separately?
- SUSPENSION PROBLEM W/ TEIN COILOVERS
- question about spring part#'s
- prelude suspension HELP!>
- how much would pay for USED KONI Yellows?
- cusco zero 1 V cusco comp s V hks hipermax 2 coilovers
- jic?
- Stock Spring Rates 98 Civic DX
- do i need camber kit for eibach sportlines???
- Tokico Advanced Handling... yay or nay?
- Whats all this talk about GC spring rates and length?
- Did I order the right spring from GC?
- Econo rotors?
- Finally got my Koni/Gc's
- why do my tein's suck?! SS super street damper setup..help!
- HKS Hipermax II fitment help
- opinions please
- Konis + GC's...now what?
- Suspension Clunkes
- Is Wider Better?
- installed budy club full coils.....very bouncy
- ground control fitting question?
- How low can i go?
- BSQ or BEAKS??
- EG Suspension On Skunk Upper A arm (camberkit)
- Vibrating car & axle pops out?
- Sprint or H&R springs
- MC/Booster swap and Brake line modifications - Question
- Pull to the right even after alignments
- dose anyone know if the type r front knuckle same as gsr?
- Sway bar troubles
- Aluminum Box type LCA which brand?
- LCA pros and cons
- how bad is my car damaged?
- Vibration
- Big brakes upgrade crx
- tein ss owners....
- what tools i need to lower my car?
- H brace HELP...anyone experienced please help me out
- Rear Strut Bar mounting, EK Hatch
- AGX missing a knob
- getting rid of Tein ss for the Koni/GC is this a good move?
- Tein Flex or SS in the winter.....
- groundcontrols or skunk 2 pro coilovers....
- 00 Civic Si Bad shock?!?
- Question about adjusting my suspension on my 00' SI
- decided to go with ground controls
- Help!
- can't adjust coilover. need HELP!
- steering feels loose on highway
- 94 accord kyb agx's on 99 civic?
- Getting GC Coilovers to Canada?
- 7" eibach springs, anything wrong with these on civic hb's?
- gc/koni ? about swapping spring and price
- Another Koni and Ground control.Q??!!
- good deal for skunk2 coilovers?
- ground control coilovers will they fit my civic?
- Inner tie rod change on EG?
- Question from a newbie 2 the pros
- i just did my alignment.. now my car handles wierd (alignment guru's please)
- --Should be simple, pulling-I am lost!--
- Best price on tein basic?
- do i need to cut the bump stops for pro kit?
- 06 RSX S suspension options
- Having a Heck of a Time Removing Driver Side Axle
- who makes the most affordable coilover
- KYB AGX struts and coilovers, do they work?
- quick suspension question
- can da suspensoin fit on my ek?
- Tein Adjustment Knob
- what struts for neuspeed race springs on del sol
- Tien Suspension.. Hard or Soft
- Bad Bushing, bad!
- 88-91 Crx air-struts on a 92-95 Civic ?
- neuspeed springs on AGX's?
- tokico shocks
- coilover sleeve slap.
- Suspension help
- Koni Website?
- Suspension for an ej1
- SPC Rear Performance Adjustable Toe Link
- Suspension question....
- Do I absolutely have to change the LCAs on my DX to install sway bars?
- buying tein
- Need Suspension Help. Will this work???
- Best suspension to go with for a ej1?
- Koni Yellows vs. Koni Yellow SP3's
- kyb gr-2
- Ek Rear Disc Brakes
- which springs?
- CRX Lee: Koni RSK question
- Could I use 94-01 Integra Front LCA, shocks, springs on my 98 Civic DX coupe?
- which strut bars to get to enhance handling? front top/rear lower???
- 91 civic si, adjustable struts??
- 97-01 Lude Pro Kit
- tein suspension
- integra tein dc2 ss spring code
- 92 Civic complete suspension upgrade
- my car is pulling to the left, but my alignment is good? or not?
- I got my alignment checked today, got some questions too!!
- $100 alignment
- wheelspin cause/fix?
- Zeal coils....website??
- rear drum swap
- Hey, if you have Koni Yellows with Ground Control Coil-Overs I have a quick question!
- ES rear shock bushings
- EK having problems with koni shock install
- rear spindle prob
