PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 [87] 88 89 90 91 92 93 94 95 96 97 98 99
  1. gc question to those who have installed.
  2. Quick Question on Ground Control Install DC2 (searched)
  3. password jdm 3 point strut bar
  4. Suspension noises driving me crazy!
  5. will ek rear shocks fit eg?
  6. eg suspension question.
  7. SKUNK 2 COILOVERS
  8. Dayum I almost got Fu@ked!
  9. question about Tein coilovers (RA to be specific)
  10. help with integra sway bars on 92 4 door?
  11. KW Coilover Suspension!
  12. Replacing Rear LCA Fasteners...
  13. Squeeking suspension (Omnis on AGX on EG hatch)
  14. $800 to spend.. Best bang for buck?
  15. Anyone know if this noise comes from my suspension?
  16. non-adjustable shocks
  17. Where are Tein SS's serviced??
  18. Omni power Bouncin my car around
  19. Whats the stiffest LCA bushings available for a 2001 Civic?
  20. front and rear height ratio - roll center of car
  21. 99 si coil overs or koni's
  22. Koni yellow maximum spring rate.... ???
  23. ES bushing squeaks
  24. Suspension Review - Buddy Club Racing Spec Coilovers
  25. GC and Koni
  26. COILOVERS
  27. CTR wheel bearing for rear?!
  28. lower control arms?
  29. do i need camber kits w/ Eibach prokit? 1.5F/1R?????
  30. tanabe sustec soc-type2
  31. 99-00 Civic Si Sway Bar. Question about endlinks.
  32. coil overs on stock shocks
  33. 94 Integra to 90 civic H/B
  34. Honda Brake Hybrid
  35. anyone heard of an lsd not working?
  36. Ground control or Skunk2?
  37. Is this a good way to even out your car's stance as well as balance the weight?
  38. Ksport or equal fullbody coilovers question
  39. having problems finding 16" drag radials
  40. Blox Racing sway bar....any experience?
  41. X-bars in Hatches and Tegs?
  42. Tein S.tech on Illumina's?
  43. B pillar bar?????
  44. ? about fitment of GC / Koni setup with Billet upper Mounts and front Strut Bar (read inside)
  45. what size sway bar
  46. need some assistance..trying to find cars with 2.25 springs
  47. which type of sway bar?
  48. dc2 coilovers on eg6
  49. Need your opinions, please!!
  50. Tein RA in EK with EDFC
  51. collar siezed on my coilovers , solutions?
  52. how do i fix this??
  53. A-spec racing
  54. snapped head 14mm lower shock bolt...help plz
  55. What tha??? This can't be right!!
  56. tein basic vs tein ss
  57. Salt belt Question
  58. Swift Springs on Koni Yellows?
  59. Wheel bearing?
  60. DA crossmember
  61. jdm 5 Lug conversion w/o the the axles
  62. ummm....does anyone have an extra one of these???
  63. camber kits...
  64. Strut Bar Question
  65. Which Coilover/Shock setup?
  66. Three type of front camber kits i found
  67. about to dish out some money. need some quick help
  68. adjusting omnipower coilovers???
  69. bump stop??
  70. onsoku coilovers any good?
  71. UGR Full Coilovers - Dyno complete
  72. will i be okay?
  73. squeaking and turning radius after new suspension
  74. does anyone know the factory ride height in inches for a 96 integra 4dr ls
  75. I have a Comptech Front Strut Bar, are they any good?
  76. itr rear sway bar on ek hatch
  77. is this an ok set up????
  78. rear knocking noises
  79. help with suspension job... quick question
  80. Hos long does Stock Shock last with GC?
  81. Spindel problem?
  82. tein ss vs. flex
  83. replacing old bushings, can anyone help??
  84. Aligning the LCA bolts...
  85. brake swap for 94 hatchback
  86. kyb agx with h&r race
  87. coil over wrench
  88. Ned help w/my Ksport coilovers (theory)
  89. Looking at full threaded body coilover suspension. Post experiences.
  90. 93 SI HB Steering Funkynes
  91. pictures of suspension parts and names?
  92. wut break pads for 96 wide 4 lug type r?
  93. witch kit do you suggest?
  94. question abt a integra coil overs on a ef
  95. ACCORD 96-97 KYB AGX FOR SALE!!!!!!
  96. Track day with KYB AGX?
  97. omnipower coilovers on kyb gr-2 shocks?
  98. Negative camber request, alignment shop
  99. need help determining which part is shot
  100. Camber kits needed?
  101. Spring Rates.
  102. SpecRM coilovers
  103. do i need them or not??
  104. skunk 2 coilover help?
  105. 99/00 Si shocks into Del Sol
  106. Dropzone=Quality
  107. Where can I find some decent polyurethane bushings?
  108. what do i need to run a 4x114 +30 wheel safely?
  109. First time installing coilovers. is this correct?
  110. coilovers
  111. KSport/D2 initial setup questions
  112. im new to how suspensions!
  113. pro kit question
  114. Comfort and Cornering - 1990 Civic H/B
  115. Spring too small?
  116. AEM Shot Ram Intake and Strut Bar
  117. Civic Suspension Issues HELP!!!
  118. Question regarding getting a shell rolling again
  119. 5th gen hatch suspension
  120. Omnipower replacement for front collars
  121. I still can't lower my ride height on new Ground controls?!?!
  122. stiff suspension
  123. koni yellows help
  124. Best Springs for 05 Civic
  125. What are the best springs?
  126. Energy suspension master kit, need help with what bushing goes where
  127. Near stock height, stiff springs to keep good geometry on EG, what choices?
  128. H&R Integra rate Race spings on EG coupe
  129. Lower Control Arm Problems & GC Install
  130. suspension techniques front and rear sway bars!?
  131. which camber kit?
  132. LS brakes on a cx ?'s HELP!!!
  133. suspencion Trouble (help)
  134. how do you do a camber kit DIY install for civic si 99-00 ???
  135. uneven pad wear
  136. my next setup TEIN???
  137. extended wheel studs
  138. Eibach rear ek camber kit
  139. stupid question, please don't flame me
  140. suspension set up with a wheelie bar added to CRX..
  141. which lowering spring will give me the lowest stance?
  142. Megan H Brace
  143. Tien SS Coilovers
  144. How much lower in the front would a B16 swapped EG on stock springs be?
  145. koni yellows and what kinda springs??? are GC's really worth it?
  146. Eibach Sportline
  147. Can I buy re-enforced rear control arms?????
  148. 4 lug converions on 94 si. Is this an easier way?
  149. KYB AGX and tein Tein S-Techs question
  150. Installed GC/Yellows, did I do it right? (DC)
  151. Question on KONI yellow valving on my ITR
  152. My DIY front upper strut bar
  153. illuminas and eibach sportlines. HELP!?!?!
  154. installing ST rear sway bar on 89 CRX Si
  155. koni yellow w/ after market lowering springs vs tein basic coilovers
  156. My GCs feeling very soft!!!?
  157. camber kit do I need one or not??
  158. Any place that has springs/struts pre-assembled?
  159. Tein Basic Damper VS. Tein SS Damper
  160. so where works for koni in here?
  161. Best coilovers for CRX k20 EF6
  162. front wheel pushed back
  163. best spring rate for a eg hatch??
  164. explain preload.....too little or too much?
  165. adjusting toe at home?
  166. Bouncy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  167. SO WHICH ONE IS IT?!?!
  168. gc inner diameter?
  169. What to replace.
  170. Ride quality has suddenly gone to crap. HELP
  171. civic typr r set up for ek
  172. CV AXLE/JOINT probz
  173. eibach sportlines on 94 civic hatch what range camber kit
  174. 93 DX civic and 94 integra Shocks and springs
  175. Koni / Gc *Off the shelves?*
  176. SRR rear sway/ tie bar kit
  177. outer tie rod go in? or should it go out?
  178. ractive coilovers install
  179. ACCORD 96-97 Neuspeed yellow lowering springs FOR SALE!!!!!
  180. FRONT BRAKE CALIPER BOTTOM PIN STUCK!!!
  181. Omni Power Contact For Returns
  182. RWD Del Sol best way to make this control arm?
  183. parts needed for 5 lug?
  184. Whatchathink about this setup?
  185. Ground Control Spring rate?
  186. HELP ASAP PLEASE!!!!!!!
  187. Removing Rear Lower Control Arm Bushings?
  188. real suspension gurus help
  189. are tokico illuminas really worth it
  190. KYB AGX piston bolt question.
  191. Yellows make weird noise when holding upside down
  192. Sway bar: Front or Rear
  193. DC Knuckles on DA?
  194. Really need advice on D2 ..please help
  195. 96+ civic springs vs 94+ integra springs
  196. difference in hieght between civic and integra springs
  197. Will I lose ABS if I do a rear drum to disk conversion on a 1999 Civic EX Sedan?
  198. endless/zeal, anyone else using this set up?
  199. pic request: koni yellows with eibach springs
  200. 4x100 to 4x114 conversion on an EG
  201. stock vs. aftermarket
  202. 05RSX-s and 05Ep3 coilovers are same?
  203. Stripped Coilovers????
  204. LCA Bushings
  205. are all Coilover springs the same diameter?
  206. Stock ITR front shock vs Stock GSR/LS front shock?
  207. Civic hatch vs. Integra as far as handling goes.
  208. SWAYS ON 97 DX
  209. Rubbing problem
  210. how to loosen 19mm nut on omni coilovers
  211. 91 Civic Konis on 93 Integra????
  212. Megan Racing coilovers
  213. Washer trick
  214. what to do with stock springs? sell it?
  215. Question about suspension for 05 RSX S
  216. koni yellow vs. tein ss
  217. Anyone using Ground Controls and KYB, Tokico or any other strut than Koni`s
  218. Omni Power vs Koni Yellow
  219. Searched, I promise. UGR/Underground Racing slip on coilovers, any good?
  220. Suspension setup
  221. Koni sport yellows / ground control install help?
  222. strange brake swap...is it possible
  223. TEIN S.Tech's
  224. Brakes - Does it belong in these section ?
  225. Multi-piece strut bar, max lenghth or minimum lenghth?
  226. Car shakes violently under braking
  227. Front too low on koni/gc combo
  228. unstable and wandering on highway and under hard braking
  229. Tein S-Tech lowering springs with Tokico HP Shocks...good or bad?
  230. quick camber kit adjustment question
  231. Camber problem
  232. What is the best Brake kit for my car? Why such a price difference between them all?
  233. Steering problems
  234. Suspension Advice Wanted!!! TIA
  235. Beak ITR Swaybar kit installation questions.
  236. Skunk2 Proseries & Omnipower Coilovers
  237. Beaks EG Quick-Swap kit. Quick Help plesae.
  238. Duct tape method of fitting Coilover sleeves to shocks? Suggestions needed.
  239. What does everyone think of this setup?
  240. Adjusting Onmi power full coilovers
  241. 99 Prelude Coilover problem
  242. omnipower shock recall
  243. Ej suspension going on Ef
  244. tein high tech
  245. Koni distributor i pm'd a couple of weeks ago???
  246. Does anyone else's GC's look like THIS??!!!
  247. Resetting bushings.. need quick help please.
  248. Do you HAVE to revalve Tein's when using a spring rate other than suggested?
  249. Do I really need Koni Race shocks??
  250. question about traction bar for daily drive
