View Full Version : Suspension & Brakes
- Problem with Blox Front Camber Kit.
- Full coilovers
- Air Ride with Cylinders or Coilovers for my Civic?
- nrg coilovers
- Bilstein BTS kit????
- compatability question
- Has anyone ever used these?
- Help with spring/wheel fitment please!
- camber kit for 91 crx
- i need help with height difference from front to back
- FORK TRICK????
- Traction Bar
- Is anyone using a drag coilover kit on the street?
- Top hats - Question
- SKUNK 2 PRO-S COILOVERS
- n00b suspension questions
- Alright, Opinions Needed!
- function & form type II Q's
- CTR suspension question
- 2" Drop
- Coilovers Q.
- Question about spring/shock removal
- skunk2 vs omni
- another what suspention thread
- koni yellow/eibach sportline install on 94 accord
- toda fightex damper??
- eibach pro kit
- ASR subframe with stock dc2 gsr swaybar?and skunk 2 lower tie bar
- noob question top hat
- Repairing Cut lowering springs?
- Integra LCA question for my ef9
- Tanabe sway bars? Hollow but made with SPECIAL metal?
- Question about washer trick
- where to get shocks for cheap & some opinions
- Will a 94-97 DOHC del sol rear sway fit a DC integra?
- K-sport coilovers?
- Integra rear LCA on 94 ex Civic??
- Ground control perch too small for springs?
- GC Spring Rate you reccomend for an EK
- Hello!
- installed dc front spindles on my ef
- DC/EG Compatability Question....H&R Related
- Which is better lowering springs or coilovers?
- Thoughts on my new setup? ITR/ springs/shocks/ GSR bars
- got a ?
- TOP FUEL SUSPENTION FOR A DA QUES????? :thumbup:
- question about front sway bar on eg6
- D2, F2, Megan, or slipover coilovers with shocks?
- 2.5 drop?
- Anyone track their DC's or auto with the BSQ kit? Anyone use the washer in behind?
- ? for sway bar experts... ITR/CTR rear bars
- Lower Control Arm Bolts
- koni sport and pre-load on lower perch setting with ITR springs
- suspension question
- stuff to replace
- i wonder if u suspension guys can help out
- car is clicking after lowered?!
- which endlinks for ITR sway bar 23mm & Blox LCA's ?
- del sol rear lca
- Help with Function7's
- 4x114.3 conversion parts list - brake tech thread
- OMNI Coilovers SPRING RATE
- Alignment Question
- Tein Flex
- Wanting to learn how to properly adjust suspension - camber/toe/spring rate..etc
- Traction Bar Issues. Same with all Brands?
- car pulling left.
- H&R race springs?
- How To Install Lowering Spring for an 95 Honda Accord
- Best suspension setup for 04 Accord with 18" wheels ??
- Need some coilover suggestions please
- Good shocks for stock springs
- Coilover suspension setup
- Concerning ASR & Comptech Swaybar setups and exhausts
- Help~ T1R coilovers raising my ride height automatically...
- traction bars?
- Opinions on dampers...
- Who here does there own alignments??
- rebuildable suspension
- Ned advice Tein vs D2
- koni yellows and ________
- best coilover for under $1000
- 93 EG with 2000 SI discs (brake cables needed)
- 92-95 Civic Rim Problem Involving Tein/Skunk2 Suspension Setup
- Coilover Input?
- Brake upgrades help!!!!!!!!!
- lowering springs?
- new bolts for rear LCA?
- Alignment specs (front & rear)
- Ksport Vs. Function owners chime!
- sway bar size?
- type r rear lower control arms + civic 92-00 illumina rear shocks??? fit?
- Function & Form Type 2 coilovers........How well to they perform.
- Spring rate for gc on stock shock?
- Omni rear lcas
- innovative mount warranty?
- Weird Question....But what are these for?
- ksport problem
- Skunk2 sport shocks....YOUR OPINIONS????
- seperating rotor from removed control arm
- mk3 supra brakes
- OEM coilovers
- Need honest opinions about skunk2 pro series coilovers!!
- nrg chasis braces?
- Hiper Suspension Up ! ASR, PIC , SPC, NRG, ST, Mugen, Tanabe, Energy Suspension, & more
- rounded bolt head
- steering knuckle
- On kyb gr-2: tein stech, h&r sport, or eibach sportlines...
- Some questions
- alignment on lowered 94 accord
- Metal on metal sound. Brake squeal indicator, blown shocks, or neither?
- Question about KYB AGXs
- car swirves under acceleration
- These Coilovers any good>?
- ASR with Beaks
- Some rants about suspension mod's....
- ksport coilovers, how exactly do you adjust the height?
- My alignment, What do you think
- Brake pad question
- EG bumpstop questions!!
- Question about coilover set ups
- ?? Suspension Question ??
- for 98 ex civic which is better
- Koni Sports vs Race? What is the difference?
- for people who have or had the kyb agx shocks....
- brake flush
- coilover help
- rear lower control arm
- H&R spring problems
- 0.7"/0.8" or 1.3"/ 1.4" drop? I am a newbie
- tein flex vs Function & form coilovers
- Prelude coilovers on a da
- noise from my buddy club racing spec
- Any input into these would be great Tokico strut/spring combo???
- got allwheel drive?
- is alignment necesary when changing rims/tires?
- ghost eg suspension walk HELP
- Brake upgrades?? Neccessary or Not???
- ground control coilovers for 06 rsx type s
- Steering Wheel Issue/Problem Not Straight
- this setup..
- front strut top mount? broken?
- GC Extended tophat fitment question.
- strut bars for del sol
- Koni shocks and coilover sleeves
- is this an ok setup
- Swaybar Bushings Loose on Swaybar?
- Clamping springs
- Brake rotor question.
- blox lca bushings shot...replace with poly units?
- Camber Kit Problem
- Question on EG bumpstop..
- How much heavier is an LSVTEC engine in a 93 hatch
- dumb bearing Q?
- suspension suggestions?
- cusco
- Ksport Control Coilovers???
- rear suspension?
- ***PLEASE HELP ME*** Wheel Bearing Knuckle/Spindle Replacement
- One wheel sags lower than all of the others need help!
- eibach springs...
- ASR Brace & CTR Swaybar Installed
- Tokico HP Kit spring rates for the DC
- 92 eg coil overs onto db
- what pounds should i torque this stuff?
- tanabe
- f2 coilover need help and tips!!
- rebuild strut
- SCREECHING
- changin cv/joints
- Installing Torque Dampers??????
- toe kit question
- kyb agx or skunk 2 struts?
- Custom top hats
- quick question. about lowering springs
- TEIN EDFC how to make work on non pillow ball mounts 96-00 civic
- Car pulling to the left, alignment specs
- Which would you prefer?
- Tokico Illumina's and which spring or sleeved coilover?
- 96 civic lowering springs onto crx
- seized camber bolt into traling arm
- Help choosing rear sway bar (upper vs lower)
- TEin SS civic into integra
- rear LCA
- Question regarding the rear lower tie bar.
- Integra GSR/Type R OEM Front Tie bar on EK.
- DA shocks into 95 EJ1...would it work?
- Coilovers question
- Function 7 endlinks ???
- Neuspeed Race or Tein Stech?
- New Vs. Old sway bar
- how to take off airride suspension???hlp plz!!
- pic request: How do Ground Controls fit on KYB AGX?
- apexi n1 install issues - normal?
- wilwood bbk question???
- Restoring my stock height
- SLAMMED... Suspension Setups.
- full coilover vs. spring strut combo
- Lowering a 95 gsr
- Tein H-Tech - EJ8
- Skunk Pro series full coilover does not have brake line brackets?
- Front Sway Bar/Autocross Car
- Energy Suspension on 91 4dr DA
- Race Car Suspension
- what is a good spring that is lower then tein s tech
- Reasonable price to install shocks?
- Where are eibach dampers made?
- Spring Rate
- Honda Accord 98 Rear on a Civic Coupe EJ8
- n00b needs advice
- 96 hatch suspension
- BOSE suspension?
- tein-kyb
- Will Ground Controls For Koni's Fit other shocks?
- Eibach Pro-Damper Kit?
- Accord camber kit
- 88 civic lx suspension problm
- does honda civic 92-95 shock fit del sol?
- Conversion: leaf to coil spring
- ground controls
- ? about omni power 6way adjustable coilovers
- S-tech problems
- Would adding a front GSR 24mm sway make a good difference?
- durable shocks
- 92-95 civic coilover on 99-00 civic??
- Integra - Omni vs. Koni
- another da gs suspension question
- drop kit for 94 accord
- 97 civic dx suspension upgrade?
- help choosing rear lca's
- EK & ITR suspension overhall
- Suspension set-up for street.
- extra welding to reinforce chassis?
- need help choosing coilovers please
- tokico blues
- Skunk2 Pros
- poorman itr suspension?
- 88 crx, koni sports (yellows) question
- How can I fix my toe angle
- spring rates on a 91 hatch
- newb suspension question
- Stiff springs + soft shocks.
- NSX caliper legend rotors
- Messed up my Koni/GC Install, Please Help
- JDM ITR 5 Lug on D-series Axles
- Search for big honda tuning part dealer
- 91 CRX suspension question
- Vogtlan/Eibach Spring Rates
- Do i need a camber kit or just alignment?
- Lowest Drop
