PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Help, Tein Basic
  2. spring rate
  3. need a better set up
  4. Lowered EG coupe
  5. Omnisport question (spring swappin')
  6. coilovers
  7. Adjustable or strait drop springs?
  8. crx camber
  9. OPIOIN....best shocks for my eg hatch
  10. B&G Springs or Full Coilovers
  11. Full coilovers or ???
  12. Ground Control Koni issues
  13. Koni/Eibach Sportline
  14. realignment after coilover swap
  15. 2006 rsx type s lowering help?
  16. Ground Control settings on a EK (trying to tuck half a tire)
  17. F2 Coilovers
  18. Suspension Torque Settings
  19. H&R cup-kit suspension package for civic
  20. Skunk2 lowering springs on Kyb agx
  21. What to get in suspension??
  22. Suspension for sale!!
  23. tein ss??..owners need some input
  24. best spring rates for my settup
  25. anyone tried the tokico RAK 502 yet???????????how is it??????????
  26. what sway bar w/ asr subframe re. kit
  27. Shock question
  28. skunk 2 camber kit problem
  29. front camber kit EK
  30. integra front clip onto a del sol questions...
  31. H&R Sport Question
  32. 96-00 civic prokit on a 94-01 teg?
  33. sway bar kits for EG's w/o OEM swaybars?
  34. gab coilovers (searched)
  35. for stock shocks what's the best spring between H&R sport and tein S-tech for Daily drive..
  36. Energy Suspension Kit??
  37. Please help (frame question)
  38. Need help installing suspension
  39. picperformance.com suspension
  40. Which would be better for me, traction bar or front undercarriage brace?
  41. question about LCA's.
  42. Progress Coilovers?
  43. kyb agx for integra on civic?
  44. Best strut bar for 04 accord?
  45. KYB struts Unadjustable... Best way to raise...
  46. Omni Power Full Coilovers
  47. Lowering Springs Neuspeed vs. Tein???
  48. Installing Lowering Springs on 00 Civic
  49. Is this a standard ground control eibach spring?
  50. H&R sport springs on a 96 accord sedan with 17in rim
  51. questions on shocks and springs
  52. H&R integra/civic dilema
  53. tein s. tech vs. h&r race spring???? NEED HELP
  54. c-pillar bar the same for coupes and hatchback?
  55. Which Springs????
  56. Help Me! Koni Yellows Install
  57. Help: Rebuilding Koni Yellows
  58. any suggestions on omnipower drag coilovers
  59. buddy club racing spec preload???
  60. Koni Yellows and ITR H&R Sports EK hatch
  61. HELP!! my shock doesnt have a allen wrench hole!
  62. Please Help! Rear LCA install problem!
  63. Oil coming out of the shock tower
  64. Will a Suspension Techniques rear sway work with ASR brace?
  65. Koni SPSS
  66. Ball Joint press
  67. KYB AGX?
  68. Help: Tein Assembly
  69. where to buy suspension tophat or shock assembly
  70. poor handleing in the rain
  71. dropping my accord
  72. KYB Boots + Eibach Springs??
  73. **sticky** prelude 5lug on a 92-00 civic
  74. what next?
  75. Are gsr and itr brake lines/hoses interchangeable?
  76. what brake upgrade will work on my del sol.
  77. Question about using stock dust covers with Koni shocks...
  78. BEST SWAY BARS FOR 89 CIVIC SI?? EIBACH ? NEUSPEED ? TANABE SUSTEC ? SUSPENSION TECHNIQUES ?
  79. DA Progress sway bar on a 98 Civic DX?
  80. SPRING RATES
  81. 96 accord 4dr suspension questions
  82. What lowering springs would you get?
  83. comments on neuspeed race springs
  84. koni yellow question
  85. Eibach Pro kit or Sportline? Been searching for weeks.
  86. [vid] spring sounds weird?!
  87. Cheap eBay shocks on lowered car.
  88. HOW TO CHECK SPRING RATES
  89. EM Racing 3 strut bar kit
  90. bomz
  91. Neuspeed Race Springs on 06 Si
  92. help on coilovers
  93. 90 CRX FRONT AND REAR TIE BARS.
  94. Street alignment: Are these numbers ok?
  95. trouble reconnecting radius rod/strut bar/torsion bar
  96. omni LCAs....energy bushings
  97. Tokico Blues
  98. Toe out of spec....
  99. Quick Poll!! Omnipower Shim Kit?? Worth It?
  100. Skunk2 vs H&R springs??
  101. Can i lower my car (honda civic 96 dx) without buying anything (ALL STOCK)
  102. KONI GC combo or KSPORT????
  103. 50 or 55 series?
  104. EK --> EF coilovers
  105. sway bars
  106. HT, give me some help with my setup!!!
  107. Koni SPORT package???? OR TEIN BASIC DAMPER struts & springs??
  108. suspension for the hatch... yay or nay
  109. Installed my GCs and Illuminas, broke 2 shocks
  110. EK suspension talk
  111. Will 96-00 coilovers fit on a 93 hatch?
  112. Koni Yellow - spin shaft to make stiffer??
  113. I need new springs
  114. Ground Control Springs different for Koni and Bilstein?? (see pics inside)
  115. 3" exhaust w/ rear sway bar???
  116. where to buy an adapter for 4x114 to 5x114***
  117. eg toe in problem?
  118. 96 ITR 4 lug w/ non-abs, can i use on my 91 integra gs w/ abs ?
  119. gc help
  120. tokico white with GC . sounds
  121. Spring rate question
  122. need new struts/springs, and got a few questions? help this noob out!
  123. Which NEW shocks for a lowered accord???!!!
  124. tokico illumnia/ground control install help
  125. Pre-loading OmniPower coilovers: necessary?
  126. Know how to install front tow hook ?
  127. NEED A GOOD DEAL ON BIG BRAKES
  128. 4 TO 5 LUG CONVERSION
  129. Coilovers squeeking
  130. JDM CR-X SiR tie rod in need!
  131. Question for Tein Type-Flex Owners
  132. n00b brakes question
  133. stock suspension... front higher than rear?
  134. Question about Left and Right Balance??!!
  135. OEM shocks / springs for sale
  136. someone recommend me a alingment shop in Fullerton , CA
  137. Coilover suggestions for EG hatch
  138. Koni yellow or KYB AGX
  139. OBX and others camber kits
  140. suspension - please help and vote!!
  141. questions on parts to get???
  142. GC sleeves
  143. DropZone Camber Kit
  144. can someone help me!!!
  145. How do you adjust ride height with D2 coilovers? [searched]
  146. help needed quick
  147. help!! question about my LCA and swaybar
  148. Most comfotarble shocks
  149. 91 integra suspension????
  150. coilover kits under a grand
  151. CAMBER KITS
  152. Koni Suspension? Do rears have metal rings over circlip
  153. Omni Power Full Coilovers for an EG
  154. Brake Swap/Size Question
  155. worn motor mounts causes vibration?
  156. skunk2 camber kit *help!*
  157. lowering spring question
  158. coilover sleeve rubber o-rings?
  159. KYB AGX's + H&R Race springs = good combo?
  160. I'm Stumped: someone try to figure this one out
  161. Is it worth it to overhaul Tein RS or buy new Coilovers, suggestions
  162. shocks with no built in nut????
  163. Eg struts on a DA?
  164. Question about adjustable struts
  165. Is this normal? H&R race/illumina install (searched)
  166. 06 RSX-S springs
  167. Progress Springs on Koni Yellows
  168. camber question
  169. asr with 22mm itr. handling PREDICTIONS NEEDED.
  170. Engine Mount Insert
  171. Buddy Club N+ Question??
  172. Megan vs. Omni (LCA)
  173. what suspension would you use for your 91 civic wagon???
  174. my tein ss FR shock broke yesterday
  175. bushing replacement
  176. skunk2 springs
  177. Skunk 2 Coilover Sleeves or Coilover Sleeves In General...Need Some Insight
  178. rear suspension question??
  179. 1992 accord front end lowerd camber off
  180. ----my suspension feels better when it rains------
  181. For Road Racing and AutoXin, no expense what suspension???
  182. Suspension setup on eg h22 recommendation
  183. What else should I add to my suspension setup?
  184. newbie to suspension....
  185. suspension problems on my 94eg
  186. H&R race for crx
  187. suspension suggestion?
  188. Thoughts about this squeaking noise.
  189. HELP!! Rear Lca bolthead popped off!
  190. Help : Tanabe gf210 or Tein S-Techs??
  191. ...ball joint question
  192. drilling 4x100 wheels to 4x114
  193. question on coilovers for 01 civicx
  194. My alignments specs let me know what you think
  195. coilover system for $830.00 and shipping is free!!!
  196. What shocks do you guys reccomend for 315/250 GC springs?
  197. Best Place To Buy CTR Sway Bars?
  198. Can anyone identify these?
  199. tokico white GC or ibach with skunk2 ?
  200. replacing dust boots
  201. Which coilovers will you use? HELP! VOTE PLEASE!
  202. Suspension setup
  203. which one would you use? give me some advice.
  204. pic requested: EG WITH TEIN S TECH OR H&R SPORT SPRING
  205. Ground Controls Koni combo....i got a question
  206. Subframe tear out EG vs. EK?
  207. removing NRG engine mount inserts
  208. ? about coilovers for race?
  209. Car pulls after putting my summer wheels/tires on. How can I fix it?
  210. ROD, RR. what does it do?
  211. Daily Driving
  212. tokico spring/strut combo??
  213. whats the deal with my 2 day old tokico illumina?
  214. Omni Power Question
  215. please help suspension prob and steering
  216. place to get teins?
  217. quick question on coilover for newer hondas
  218. Does anyone still carry kg/mm springs?
  219. apexi world sport damper
  220. Grinding with Brake Pressure
  221. Has anyone used D2 suspension on their cars?
  222. Call me a noob! How do you adjust the damping on Omnipower Full Coilovers
  223. just got my skunk2 and type sway bar
  224. 5 Lug w/o ABS... should I drill holes?
  225. Upgrading suspension on a 93 teg.
  226. pic request - 96-00 civic coupe + h&r sport
  227. why is my ride so crappy?
  228. PIC REQUEST EK with H&R Race SPRINGS!!!!!
  229. AEM Big Brake Kit
  230. My OMNI"S are very stiff, very bumpy ride!!!
  231. shit... i think my NEW shocks is blown koni yellows =/
  232. Blox Camber kit?
  233. Is this a good price
  234. Honda Access Suspension Integra
  235. Sagging spring or Messed Shock?
  236. dc5/ep3 inverted tie rod ends
  237. How do you drop Sway Bar in EG??
  238. brake lines???
  239. DC2 STRUTS???
  240. GSR brakes+ 2000 sir sway bars?
  241. switch shocks or not
  242. Omni spring rates
  243. What other parts to upgrade? 98 dc2
  244. rear disc conversion suspension changes
  245. Coilovers sold on Ebay?
  246. 96 civic ex, suspension
  247. Tein S-Tech Install.....Just a quickie
  248. Changed rear struts on car and it makes noises. what is it???
  249. un-modded suspension, lop-sided car?
  250. ksport vs tein?
