PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Ground Control Coil Questions
  2. brakes and funny noises
  3. Need opinions. ITR suspension.
  4. i need help
  5. Need Help: can't find bars
  6. Break Linesfor Drag Car Hard Line vs. Steel Braided
  7. what size are bleeder screws?
  8. quick ?
  9. Rear brake line, is this the part I need?
  10. WTB D2 Coilovers
  11. MKIV Supra Knuckle Modification~
  12. Clunking noise on my 03 civic EX
  13. My ever changing caster
  14. What brake pads do aftermarket big brake kits use???
  15. Question on drum to disc conversion 92-95 Hatch
  16. Skunk 2 Pro C's setup help please
  17. Eibach Suspension
  18. Acura EL tire size and suspension advice
  19. what kills struts, ride height or spring rates?
  20. Bent suspension component? 1 degree difference.
  21. Do brands matter when it comes to LCA's?
  22. Brake pad replacement
  23. BLOX adjustable end links
  24. BLOX adjustable end links
  25. Daily driver needs new suspension
  26. Car pulls all over the place, like a really bad torque steer
  27. Spring rates for 2005 accord 4dr
  28. stiffer springs for my tein ss coils
  29. probably a simple question
  30. brake upgrade
  31. Want larger brakes 2000 Civic SI
  32. D2 Full Coilovers & Raceland Coilover (swapping Springs) Spring-rate help!!!!
  33. password JDM rotors vs. brembo cross drilled ??
  34. NEEDED: Ground Control Spring Isolator Dimensions
  35. Del Sol c-pillar bar
  36. Corssdrilled rotors making noise
  37. pillar bars for ferio's
  38. Recommended Springs/coilovers for *hella flush Integra*
  39. Conversion from 4 to 5 lug. Honda
  40. Form and function coils are riding horribly DC2. Suggestions on repair or new setup?
  41. 99 Si - Shocks vs Coilovers
  42. brake upgrade questions
  43. Can anyone identity these 4 piston calipers?
  44. Does camber arm cause a need to be out of alignment?
  45. Whats DRAG?
  46. Can you give me your opinion on my alignment results? Scan inside
  47. eg6 lowering springs
  48. Coilover isolators
  49. eg6 spring length
  50. I need help with my Rear disc brake swap
  51. Civic EG8 92`95 model Parts Catalog
  52. Accord 32w Calipers on 1994 eg ex
  53. Apexi tmax shocks (for the og's)
  54. decisions decisions...
  55. ek hatch brake system problem
  56. Myth? or Truth?
  57. stock eg spring length
  58. Blox replacement upper ball joints
  59. does lower tie bar affect under/oversteer ?
  60. Cost effective setup for a 91 CRX
  61. Quick Coilover Preload Question
  62. 15" rims that clearn rsx brakes on dc2?
  63. Changing Steering Rack
  64. Honda Civic 2000 Si Lowering Question.
  65. 95 Integra SE Skunk2 Pro-S V2 Review
  66. Integra springs for 90-93 work for 94-01??
  67. suspension spring rates
  68. how do i adjust steering wheel?
  69. integra disv conversion
  70. Help!
  71. 4 door integra DB8 set camber?
  72. Ground control adapters for koni?
  73. front brakes dragging
  74. Going through front upper control arms like water.
  75. rear disc brake on 4 door civic.
  76. upgrade my itr brakes to TL or RL? need your feedback
  77. Loud click when brakes are applied?
  78. do i need aftermarket top hats?
  79. Mx3 springs in a integra.
  80. vibration under acceleration
  81. pass side front wheel not centerd
  82. Lower ball joints
  83. What type of alignment would i need
  84. best oem upgrade?
  85. Parts question Help?!
  86. EG/EK Owners: Koni NA presents their "Prepare to be Shocked" Promotion
  87. SO brembo blanks won't fit over hub...?
  88. CLICK HERE all of you curious about suspension setups and their costs/reliability.
  89. Vibrations problem?????
  90. 96-00 Civic Suspension Tips
  91. How can i make my CRX float like a Cadillac?
  92. 4X100 to 4X114.3 Adapters
  93. The best coil strut setup for the money on a dc
  94. noob question: camber kit for wagovan
  95. traction bars ??
  96. 1992 Hatch suspension question
  97. Steering Rack Jumping Teeth?
  98. Opinions/input 99 Prelude suspension question
  99. Weird Steering Wheel Slack Problem
  100. Koni struts + Tein springs
  101. Camber kit
  102. Megan racing on 96 ek
  103. HELP!!! removing lower control arm problem!!
  104. suspension advice plz help
  105. Questions for suspension
  106. 2ce brackets same as 3ep?
  107. Energy susp. trailing arm bushing
  108. Suspension tuning
  109. Dropzone coil over sleeves / skunk2 shocks for temporary use ?
  110. Tie rod/Alignment
  111. asr swaybar question.
  112. Turbo civic weak brake.
  113. need to know!!!
  114. clicking noise
  115. koni/gc, camber kit necessary?
  116. my 93 civic si
  117. pressure builds when pumping w/ motor off, but loses pressure when motor on
  118. anyone know any good coilovers for a del Sol ?
  119. Can worn RTA bushings cause snap oversteetr?
  120. best front camber kit to use?
  121. Oem top-hat installation?
  122. will blox or s2 lcs work with rear disc conv?
  123. DIY 5 Lug on a 2000 Civic Si Please read before deleting!!!
  124. correct conversion fitting for 1" MC swap
  125. Ground control coilover springs
  126. BLOX Rear LCA w/ ES poly. Bushings
  127. fender rubbing on rear pass side only
  128. air bag suspension question
  129. 1 broken lug nut stud OMG!!
  130. Godspeeds will not adjust... Help.
  131. Rear/Upper Ball Joints
  132. Bleeder screw won't bleed
  133. c-pillar bar install?
  134. clicking noise from LF during acceleration and braking
  135. drag racing suspension questions
  136. Rusty Coilover Remedies?
  137. Worst suspension components?
  138. Neuspeed 4 point strut bar on a 96-00 civic. Anyone used it?
  139. What years & trims had ABS standard or optional?
  140. Drum Brake question
  141. Coilovers making numerous clunks while turning
  142. slammed with wide wheels
  143. integra prokit on a civic
  144. Clearance issue, need advice on finding kit that doesn't lower car...
  145. ABS
  146. What do you think of these alignment specs?
  147. Integra DA9 & DB1 Springs & shocks Advice
  148. proper tightening for koni struts
  149. Best Suspension setup for ek coupe
  150. bad springs or bad shocks?
  151. NSX Caliper install Confusion
  152. How many tie rod end turns is stock?
  153. best ride for a del sol
  154. best breaks on del sol
  155. buddy club n + spec damper
  156. 2nd best next to koni yellows GC?
  157. Getting ready to install Koni/GC on EG, any advice?
  158. need help with noisy new suspension!!!
  159. lowering springs on ej6
  160. lowering sprig assistance needed please...
  161. Uneven rotor wear
  162. Motul RBF600 best online price?
  163. Can you use washer in front upper arms? 93 civic
  164. Soooo lost someone Please Help
  165. What do you think about this grease for Polyurethane bushings?
  166. 68mm inside diameter springs on a 70mm spring coilover
  167. Steering wheel not straight under hard braking
  168. miracle x bar
  169. Brake pedal keeps going to the floor- 91 integra w/ abs
  170. What springs are these?
  171. DIY skunk2 pro or blackworks upper ball joint for crx camber kit mod
  172. Inputs on Skunk2 Springs?
  173. ground control top hats
  174. Wilwood 140-6163 (12.19" Rotor/4-Piston)1
  175. is this caliper piston toast?
  176. da9(i think)springs on a ek
  177. EK SHOCKS/SPRINGS ON EF?
  178. Proper brake proportioning valve question. NSX content
  179. What brand of coilover?
  180. few questions on ES poly bushing/suspension install
  181. brake upgrade need some info.
  182. 97 Civic DX - Steering wheel jitter at ~70mph
  183. Blox adjustable VS. fixed end links - Do both work?
  184. ASR help!
  185. 92 Civic coilover options....
  186. How to adjust coilovers??
  187. Eibach Sportlines
  188. one bolt on dogbone ok ?
  189. unknown Eibach Springs
  190. Spongy Brakes??
  191. Sway bar noob questions
  192. Tokico HP Kit vs. Eibach Pro-System Kit (Shock/spring combo's)
  193. adjusting coilovers with preload
  194. Help with outer tie rod diagnosis.
  195. drag suspention setup
  196. Driver side axle removal?!!
  197. KONI STRUTS OR TOKICO STRUTS ARE BETTER FOR ENTRY LEVEL STREET USE
  198. Upper control arm ends cutting through. (pic)
  199. Anyone use Bilstein shocks?
  200. New Koni specific Ground Controls have adapter?
  201. Question about larger sway bars.
  202. Busted "top hat" bushings?
  203. Cutting Springs on a 1994 Accord
  204. front passenger of ef civic sits higher
  205. skunk2 sport shocks. whos got them?
  206. sway bar question
  207. Yonaka Coilover help
  208. Suspension problems: car leaning to a side
  209. alignment woes, shops suck!
  210. 15mm H&R Track Plus Spacers installed (now vibration) ?
  211. Soft pedal, then sinking slowly......help
  212. EG Suspension (LCA/Swaybar) Issues
  213. suspension for an eg hatch
  214. gc extended top hat issue?
  215. 91 teg f&f preload info needed
  216. front end sits to high after installing lowering springs
  217. Seized adjustment ring on apexi coils
  218. 94 gsr brakes problem help plz
  219. Strange Coilover. Experiences/Comments
  220. Poll: do you run stiffer springs in front or back?
  221. koni strt with ground control
  222. centric hub rings...necessary?
  223. how low will i go?
  224. Will EG shocks/springs be a straight fit into a DC2R?
  225. ABS light code. HELP!
  226. 94-01 Integra / 92-95 Civic Big Front Brake Upgrade 11.8"
  227. 94 ex coupe...gsr f/r brakes...which proportioning valve?
  228. 94 ex coupe...gsr f/r brakes...which proportioning valve?
  229. helper spring
  230. different front hubs
  231. Inner tie rods rotate?
  232. 91 civic si suspension HELP
  233. 1999 civic hatch dx struts fitment
  234. Need help dropping my 2000 accord sedan
  235. Ground Control Spring Number
  236. 99-00 Civic Si Front Sway on an Integra LS?
  237. +.::*HOW TO FIT DC2 SUSPENSION ON EM1; HELP*::.+
  238. Need help slamming integra
  239. Fenders rolled, rubbing issue (tire sticks out?)
  240. 4x114 Conversion help !!!
  241. How to remove this rust?
  242. Runing out of Brake With Wilwood on EK
  243. steering knuckle ? on my ef swap
  244. koni yellows or koni str??
  245. Lower Control Arm bushings 94 CX Hatch
  246. integra, front end and suspension questions
  247. Eibach Pro-Damper Kit and Tein-S Springs
  248. GC coilover kit and koni shocks good match?
  249. 1992 Civic Si w/ 5lug - what allignment specs and Bushing kit?
  250. need help with GSR front brakes on EG hatch
