Drivers side rear drum not bleeding.....why not???
Like the title says, but the line itself is good, and other 3 bleed fine, but why wont this one?? Please help!! Thanks.....
Re: Drivers side rear drum not bleeding.....why not???
bleeding the brakes, and DR has no fluid AT ALL, checked the lines under the car no bends or kinks but who knows i really dont want to try n pus a new one of those in.......dont know what else.......
do you have any brake pedal resistance when pushing on the pedal? somewhat normal? or just goes to the floor?
unbolt the line to the drum. does fluid come out?
if so, replace the brake cylinder. if not, your problem is upstream. which would be a blockage in the hard lines or a problem with the prop valve. disconnect the prop valve, and see if you can blow fluid down the hard line.
yes, there is some pressure in the pedal it doesnt go all the way to the floor.........what do u mean by prop valve? sorry.......
crip
10
04-01-2010 05:14 PM
OKSolSi
04-20-2004 08:13 PM
