PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Weird Noises
  2. Prelude Eibach Springs for Accord
  3. tanabe sustec gf210 vs tanabe sustec nf210
  4. any buddy club N+ users?
  5. settings for Tein SSP's for a CRX
  6. vibration help
  7. Which is a good suspension kit??
  8. Ground Control break-in period. how long?
  9. this question is for the EJ8 drivers: suspension
  10. question about sway bar install
  11. Tokico illuminas + omnipower coils? opinions?
  12. 92-95 civic LCA problems.
  13. Suspension on the Civic
  14. Lowering: Best compromise
  15. Does 01 civic ground controls fit on 98 integ?
  16. coil over help
  17. Help needed on how to install Fastbrakes SpecR rotors
  18. skunk2 coilovers in winter
  19. Post GSR pics with tanabe Sustec GF210 drop
  20. kens kustoms
  21. Eibach prokit issue ?
  22. NSX brake upgrade... Info please!
  23. Loud clunking noise on passenger front?
  24. Tools/Press jigs that you use to install bushings/take out bushings
  25. fender is showing creases... why?
  26. Suspension set-ups for 95-EJ1
  27. Dillema on what direction to take with suspension mods on a DC4
  28. RSX/Civic Suspension ???????
  29. coil over trouble
  30. suspension decision
  31. Aftermarket Front LCA's?
  32. WHAT SPRINGS LOWER 1.25 OR 1.5 INCHES ON 98 INTEG
  33. what do you guys think bout cut springs
  34. Bushing: Shock Fork Mount --> How's it work?
  35. Function Form Coilovers VS TEIN Basic VS Skunk2 Fullcoilovers
  36. Ground Control Question
  37. sway bar question
  38. Need Help in Texas on lowering springs install
  39. Loud rattle, especially when turning. Bad shock absorber?
  40. spring rate for a d16 eg
  41. Koni yellow ext. adjustable shocks, in the rear what does "heavy" mean? stiffer?
  42. When i turn left my suspension makes a wierd noise?? help please
  43. skunk2 c/o and kyb agx shock/strut setup?
  44. Dual Piston Brake Upgrade question... please help
  45. Swaybar Theory
  46. spec spring rate
  47. Should i reuse these End Links? if not, where to get new?
  48. i need help with my coilovers
  49. How to adjust kyb agx?
  50. might be dumb question but.. can suspension be installed wrong way?
  51. crx and GC spring rates!
  52. Springs advice needed (Prelude)
  53. Omnipower front LCA pix
  54. Koni/groundcontrol
  55. civic/integra spring question
  56. HELP: My car's steering wheel doesn't turn back automatically when making turns
  57. lowering less than 1 inch is it possible?
  58. skunk2,Ksport, omni or function forum Coilovers?
  59. spoon progressive springs:
  60. Intalled ground controls/konis and something is not right
  61. rear disc 97 civic
  62. Need some help and feedback about a drop concerning my integ
  63. H&R Coilover - Swapping springs question
  64. Tanabe Sustec Pro SS type 2 VS Tein SS
  65. How to adjust Koni Yellows on my 88 CRX, should I use the mtel dust cover
  66. cant get the lca's to fit, are they too short?
  67. Just need the name of this part to help search for it...please help
  68. Front/Rear sway bars questions for EG coupe
  69. help: Koni yellows, or tein basics?
  70. Need help in determining how many deggres of chamber i should fix my car to.
  71. Need help with my suspension set up
  72. Back of car has suddenly lowered in height, while front has raised?
  73. Does anyone know anything bout the tien RH
  74. New suspension setup
  75. going stiffer with koni shocks
  76. Autopower install in my 91 civic hatch. Props to Charles @ Safedrives :)
  77. What is this part called?
  78. lowering springs
  79. Hond-Tech Special from Groun Control Question
  80. cheapest way to lower my eg hatch
  81. STI Brakes Front & Back On Civic Or Integra
  82. Quick omnipower suspension question.
  83. can a chassis be TOO stiff?
  84. 98 Honda Odyssey Coilovers??????
  85. big steering wheel problem need advice
  86. What booster/mbc with legend dual piston calipers
  87. anyone know where i can get some brake rotors redrilled in L.A./orange county cali
  88. lowering springs?
  89. SRR rear sway bar/tie rod combo. anti roll bar system
  90. install question
  91. DA/DB Suspension Discussion
  92. Front Civic 99-00 si sway bar on Civic 92
  93. Integra suspention ?
  94. honda civic lower?
  95. Brake set up...Is there a difference between Civic Si Calipers and GSR or ITR
  96. ITR suspension swap question
  97. loosing traction at moderate speeds.
  98. suspention mods
  99. Anti lift kits?
  100. DTM?
  101. opinions on itr bar and beaks kit
  102. prevent tire from hitting fender?
  103. suspension interchangability
  104. suspension mods for a rex?
  105. megan racing coilovers any good?
  106. JDM 4-lug Type R Wheels & Suspension ????
  107. best setup on 6th gen Civic Ek
  108. ek9....
  109. Should I lower my car before geting diffrent size wheels and tires?
  110. coilover and strut question
  111. del sol springs??
  112. Megan Suspension
  113. KYB or TOkico
  114. What best Suspension for Civic EK (6th Generation)
  115. Del Sol with DA suspension??
  116. Del Sol traction bar
  117. where to buy brake caliper?
  118. Need help connecting the tie rod end
  119. Integra Ground Controls
  120. 06 RSX-S bottoming out with tein springs & stock shocks?
  121. pics of suspension setup!!
  122. extended top hat problem
  123. Koni/GC for $500 or D2 Coilover for $600?
  124. 92-95? 96-00?
  125. BLOWN SHOCK!
  126. progress 22mm VS jdmR 23mm ??
  127. GC/koni question, most travel
  128. 1996-2000 autopower cage for a coupe does it fit a hatch?
  129. H-brace
  130. Clunking Noise in Drivers Side Rear - Driving me CRAZY!
  131. bushingsssssss
  132. skunk2 pro series coilovers
  133. Screeching rear brake? Help!
  134. ITR or CTR rear swaybar on an EK?
  135. Del Sol suspension
  136. Picking a shock
  137. Koni sleeve shocks material
  138. Wheel Vibration at 80-90 mph...Second Opinions wanted.
  139. 96 ITR 4x114 suppliers on EAST COAST?
  140. Struts on coilovers
  141. if i replace me lca(front and rear) bushings, is an alignment necessary?
  142. are these the koni ground controls or?
  143. Brake conversion questions
  144. Lowest set up for 6th gen?
  145. Where to get strut pieces?
  146. H&R Limited Edition lowering springs?
  147. Replace seals when changing axles?
  148. rear swaybar and spring rate question
  149. Need reference point setting for Ohlins Coilover on an ITR
  150. c-pillar bars/ harness bars
  151. Quick ? about lowering springs
  152. OH SHAT!!!!
  153. Name that sound...wierd noise that stops when braking?
  154. Shake in the steering wheel. NOT a dumb question... i think.
  155. Stripped the rear camber bolt/threads - torn bushings! What should I do? **Pic**
  156. Testing for quaife gear in manual rack
  157. What will work SPRING drop 18'' Wheels 06 honda accord coupe
  158. Neuspeed strut bar
  159. Question about the spring lengths for Ground Control coilovers...
  160. how to install buddy club n+
  161. alternatives to JimFab crossmember???
  162. Bilstein GC fit on Koni?
  163. 5 lug on an eg
  164. Positive camber and knocking sound
  165. Any good?
  166. ASR + 22mm swaybar endlink question
  167. Caster out of wack but not adjustable...
  168. Question about coilovers
  169. Tokico blue shock slightly dented
  170. 98 Honda civic Front right accident, Wheel pulling to the left, Help fixing suspension.
  171. Tokico Illuminas with skunk 2 coilovers...
  172. Will I Rub If I Lower My Car?
  173. Which end links????
  174. Ground Control / Koni 92-95 Civic install help! *Pics*
  175. D2 owners Beware (PLEASE READ)
  176. Camber question
  177. best setup on 4th gen preludes
  178. Quick question about top hat
  179. thanks for the help- suspension/brake setup works great.
  180. Helper Spring >> need help
  181. Koni Yellow Coilovers
  182. Too bad to put new rims on?
  183. Omni-Power V2 LCA's
  184. Koni: Red or Yellow?
  185. ive got a situation
  186. Two Quick Questions
  187. Blox camber kit
  188. Replace my old tokicos with koni yellows, not much improvement.
  189. Best ALL AROUND spring rate? GC coilovers...
  190. cut in new ball joint boot, bond rubber?
  191. skunk 2 coil overs
  192. skunk 2 coilovers ?
  193. Possible trouble with GC and KONI install.. Need HELP!
  194. Is this BRAND NEW Ground Control spring OK to use?
  195. Sustec?
  196. Suspension H Brace
  197. H&R springs, but BLUE
  198. Traction bar on daily driver?
  199. can i use 2000 civic hatchback spring for 2000 civic coupe
  200. Anyone have Alex Sway Bars?
  201. Question about my Suspension
  202. ek sway bar sizing ?
  203. Rear sway bar rubbing against exhaust hanger
  204. Need help on lowing my car?
  205. OEM Compensator arm -to- body connection
  206. should the rear hub spin effortlessly?
  207. how do you check for a bad upper ball joint?
  208. jimfab crossmember?
  209. In need of HELP with suspension!!!!
  210. tanabe springs
  211. Need Help with Bushing/Spindle?anyone know?
  212. Adjustable spring perches
  213. Caster Problem Causing Tire Wear???? NEED HELP
  214. body roll ?
  215. anybody bought illuminas off ebay?
  216. macpherson design
  217. 96--00 92-95 will it work?
  218. air cylinder 3 wheel anybody know how it works?
  219. Are these good enough.
  220. Tokico Illumina adjustment question
  221. Ordering suspension this week which full coilover for drag/play car help..
  222. Which is better KYB AGX or Tokico Illuminas??????
  223. Kteller Subframe brace?
  224. Rear clunking noise
  225. Koni question
  226. Clicking on the right side
  227. Best shocks for Sportline springs on EG???
  228. need advice to lower my car
  229. pic request and help installing st rear sway bar on 99-00 si
  230. Best place for Koni's?
  231. 5 lug question
  232. another spring rate question :P
  233. What Camber kit? Barely Tucking...
  234. and Rolling fenders...
  235. exhaust hitting the LCA
  236. Need Help on Suspension BAD....
  237. wilwood brakes
  238. Bigger rear swaybar or new coilover setup?
  239. Help i got 96-00 kyb's on my 92 hatch could this be my wheel hop problem??
  240. camber kit question
  241. I need to start over please help
  242. D2s for DC2?
  243. crx alignment
  244. Sway bar WITHOUT lower tie bar?
  245. Control arms rubbing: 92 Civic hatch...
  246. Bushing issue with OMNI rear control arms.:..
  247. Eibach ERS Springs question
  248. Anyone have this setup? if you do, please tell me what you think about it.
  249. Please help, what kind of coilovers are these and what do they fit?
  250. Where to buy Coilover wrenches?
