View Full Version : Suspension & Brakes
- Camber wears
- I'm done with the suspension, check it out
- ???'s on d2 racing suspension
- new to suspention , NEED HELP BAAAAD!!
- HELP! Need outer diameter of Integra brake disc top hat
- Post up PICS of your skunk2 springs!
- recommended lowering spirngs for ek?
- Carbotech
- Opinions on Skunk 2 pro Series...
- ASR lca bolt length?
- 92-95 civic brake booster question
- will a gsr front sway bar bolt up to my 92 hb
- Street / Occassional Track Suspension Setup
- any mod needed to install gc coilover on koni shocks???
- I need some K sport Reviews
- LCA Shock Mount Bushing
- Master Cylinder does NOT fit EK Brake Booster!~!~!
- EG hatch - front brake options
- another GC+koni concern..
- Theese worth it?
- squeeking noise help
- h&r spring rate
- Q: Got my KONI but GC's??? = your advice
- Traction Bar ?
- How to slam a 00 Civic?. NOT a DIY
- skunk2 lowering springs, spring rates?
- VWs and Hondas use the same parts?
- do my suspension?or swap motors?
- H&R sports, Koni SRT.T pics and review on my 96 GSR
- stock top mount polyurethane bushings??
- rear brake conversion
- Camber Adjustment on Del Sol
- Civic vs. Mini
- bouncey rear skunk2 pro s why???
- I'm new to Strut bars+sway bars??
- Searched and couldnt find answer - GC Tops on S2 Pro-c
- Skunk2 springs...??
- D2 Suspension
- ej8 slammed...?
- GC+konis, or full coil set?
- Need help on deciding suspension set up
- integra Suspenstion
- help asap, trying to separate lower ball joint from control arm
- boosted tegs with traction bar
- brakes locked up
- Illuminas and Koni Yellows
- Tokico warranty
- tockio hp series
- Cusco or Ksport vendor?
- Installed tien coils and ABS light came on??
- brake pad
- Function and Form ?
- Stripped nut on trailing arm
- Skunkworks and ASR brace (part 2/update)...
- Suspension setup
- help please
- NEwb needs help on suspension
- Can I put ITR sway bars on my 95 LS?
- shall I give new springs time to settle on the car before I go for alignment ?
- adjusted rear camber on my 95 Civic. Did that change rear toe ?
- resivor swap
- help: replaced strut now noise
- removing abs got few questions...
- TEIN HA..needs rebuilt?
- Can anyone measure some calipers for me!?
- good combo with tokico illuminas?
- Rebuilding your own strut.
- SRR Coil sleeves
- d2 WOES :( Front strut messed?
- Please help!!!!
- Choosing new suspension
- people with 5 lug
- ebay vs. brand name
- pic coilover install questions
- INSTALLED: Eibach Pro Street Coilovers with GSR brake conv.
- Eibach sways require Brace on EG???
- LF specs: CG height, etc
- New suspension in the works...need ideas
- Tokico Illumina and GC coilover???
- ST suspension.. Good?
- Asr?
- Suspension Techniques crx
- Tein Stech Springs on Integra??
- wheel well noise
- skunk2 coilover sleeves???
- I need help! Eibach spring questions!
- Koni yellow + gc coils = rough?
- Which trailing arm bushing for 3G Integra?
- Lowering Springs on 2008 Accord Coupe 4 cyl.
- Brakes lines
- H22 Swap? Yikes I am lost.
- Need help choosing suspension in next 7 hours!
- front suspention problems on my dc integra
- Need Help Choosing Sway Bars
- I want my omnis to go lower
- suspension ?
- 95 civic brake problem
- Changing inner tie rods how to?
- Finished Suspension, uneven sides and camber issue
- 98 ex coupe - Buddy Club N+ COILOVERS
- suspension experts! which bushings for an alignment on an eg?
- koni yellows w/standard GC's ???
- where can i get oem CTR brake pads and rotors?
- lowering springs
- Koni Sport Shocks Denied Under Warranty!
- camber question
- D2 Question??
- cusco zero-two's,koni/groundcontrols or function and form type II's?
- strut problem
- Steel Extended Open Ended Lug Nuts?
- shock and struts
- I know i know theres a post somewhere... Help
- || Red Brembo ||
- preserving adjustable shock life (illumina, agx, yellows)
- will i blow tokico blues?
- help me get rid of this damn BOUNCE
- anyone try these & who carries it? Koni Threaded Spring Perch Sleeves?
- NOOB QUESTION: ground control tokico blues
- Just installed Ground Controls... Ride height isn't even
- 92-00 civic rear trailing arm bushing fit integra GSR?
- i want a full suspension job, help? :)
- good setup for da?
- Knuckle to GC Perch Contact
- Drum to disc swap
- 02 Civic SI struts installed on an '02 RSX.
- Best Lowering Springs with Smoothest Ride??
- Civic 4dr with Tein H-Techs....pic request.
- brake line fitting question
- help me please-93 civic lx.
- Koni Questions-
- Need Help With Stut Tower Bar Install
- Best caliper paint Picture thread
- GSR/ITR Master Cylinder vs RSX TypeS MC
- putting different springs on coilovers?
- Suspension Setup with Slicks
- 95 Coupe Dx to Teg Rear Brake Conversion
- Interesting Swap
- 1990 Crx, Booster died?
- Skunkworks 22mm and ASR brace...?
- skunk 2 pro s pics
- EK Brake Line Suggestions
- Need Help with Rear Camber
- choosing suspension, 94 hatch
- PIC vs. Buddy club
- Tein
- Rack end bushings clunking dangerous?
- ASR brace/21mm sway bar install questions
- Cambering to make low offset wheels fit.
- Urgent! which skunk2 camber kit? look
- sway bar question
- RSX suspension measurement needed!
- itr rear sway on ek?
- K-Sport question - whats this?
- hard or rough suspention
- Damper Kit question
- Super tight caliper bolts help!!
- Suspension problems.
- Legend Gs front caliper on 00 civic
- Got an email from Fastbrakes
- 02 RSX TypeS Front Brakes on a 00 DC2
- blox coilovers??
- Koni/GC's or Bilstein/Neuspeed coilovers??
- ebay camber kit?
- Quick Question
- new to this pls help
- Ground Control adjustment.
- Anyone daily drive with Wilwood brakes?
- Alignment for EG6
- Which is the proper ES D-bracket...?
- a couple questions
- have a question about shocks
- Brake Fluid Question
- BuddyClub
- Pic request
- anyone ever tried this setup?
- whats the ideal hardess/ spring rate for drag racing?
- Chassis and suspension Comparism eg vs ek
- Failed Inspection due to suspension
- tension wire?
- Feels like its plowing
- PCI Bronze Bushing Kit
- Skunk 2 Shocks
- Would I benefit from getting koni race...
- Koni Collar
- traction bars on daily driver?
- I need some top hats
- Modifying KYB AGX's to fit GC Sleeves?
- Em1 Full Coilover Suggestion- Heavy Trunkproblem
- Need help choosing...
- looking for crx firewall crossmember in madison wi
- Caliper Paint
- cross drilled vs oem ..
- abs or non abs bearings
- what dust boots do you use on your konis ?
- rear alignment, just replaced trailing arm.
- WHICH brakes DO i have? help please!!
- 2006 Civic Stock Squeaky Front EBd
- Do crx 1.6l16v springs fit on prelude?
- replaced rear brakes, now have bad pedal
- Wheel hop
- Bleeder valve snapped in half..
- What master cylinder to use and prop valve???
- JDM 5 lug conversion 36mm axle size question.
- 4/100 brake upgrades for teg
- ef setup
- Best front wheel bearing?
- 99-00 civic si h&r sport springs
- do i need new brakes?
- Please help steering/suspension problem
- Is it possible to switch ground control springs front to back?
- New Suspension setup for 97 Civic
- Super Blue Brake Fluid OK?
- think its time for a a new set of coilovers
- Spring ID
- what differences are tere in LS vs. GSR frnt brakes
- Ultimate brake setup for Civics?
- Ball joint
- Drum to disc converion????
- LCA problem?
- Problems with my braking???? Sink in when idling.
- Common Brake Upgrades?
- Abs brakes feel worse?
- benen front strong bar help
- rear drag suspension crx?
- anyone use blox coilovers?
- What can cause the toe to be off?
- anyone here using GODSPEED coilovers? share feedback
- can i still use my warranty for my shocks if do not have my reciept
- ctr calipers problem
- need help choosing suspension!!!
- Spring rate F/R for Apex'i World Sport Coilovers
- Fastbrakes review/feedback?
- Squeaky Breaks
- DA suspension suggestions help!
- Koni STR.T (yes I searched)
- No rear brakes???
- thinking of upgrading suspension. What are ur thoughts on these?
- GC Replacement Springs Questions
- 95 and 00 civic suspension the same?
- ***Need camber specs please***
- 91 integra suggestions
- Horrible sounds coming from brakes
- Hardrace bushings = FAIL
- Spring Perches Koni
- Ground Control Spring Rate Questions
- 00 Subframe swap questions
- Perch positions on Koni Yellows...
- A Couple questions on my brake setup???
- Help with suspension travel
