PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Tokico Illumina Adjustable suspension kit.
  2. Will a 99-00 si rear sway bar fit a 96 gsr
  3. Tie Bar/Chasis Brace
  4. question
  5. Adjustable top hats?
  6. Will a 96 LS rear sway bar fit 92-95 eg
  7. HELP! ground control bolts WILL not come off
  8. Tein 1.9"F/1.7"R or Tokico 1.4"F/1.4"R?
  9. Skunk 2 Struts and Springs Anyone have them?? Comments?
  10. blown shocks?
  11. Koni Suspension Perch Circlip MISSING! HELP!
  12. EM1 w/ITR RR. Sway Bar
  13. skunk2 pro series full coilover kit to low????
  14. problem with omni power suspension
  15. who's running d2 suspension chime in
  16. Shock/Strut Question
  17. Retarded question but have to ask....Neuspeed Race Spring on DA9
  18. need trailing brush arm extractor near jacksonville, FL
  19. what should i do?
  20. KYB or TOKICO gas shocks?
  21. Disk swap with bent trailing arm, Can I swap triling arms with drum setup?
  22. which brand of suspension are you using?
  23. was wondering if it fits
  24. DId the mechanics mess up?
  25. has anyone heard about dropzone shocks and coilovers...
  26. Adjustable suspension kit advise please.
  27. diy lowering help
  28. anyone know where to get jdm itr wheel hubs?
  29. Ksports?
  30. konis... and Da6..
  31. rear discs
  32. camber kit
  33. Will 96-00 Civic Rear Shocks fit 94-01 integra??
  34. Question about benen 3 point tower bars
  35. Function Form Type II or Tein Superstreet v.193945959
  36. Sprint suspension?
  37. 5Th gen prelude springs on 4th?
  38. DA Integra Suspension questions
  39. can brake pads re-bed?
  40. F2T2's or Ksports?!
  41. rear bushings
  42. H&R, Tokico 99 Integra LS
  43. NEX Type SS instaled not front bounces
  44. for anyone who have kyb agx...
  45. Intrax swaybars for EF? Anyone try?
  46. rear LCA spherical bearings
  47. HELP! Ground Control Perch Hex Screw Seized!
  48. Is KYB AGX shocks with Eibach sportlines lowering springs a good combo??
  49. Suspension Setup for a 4th prelude?
  50. will ITR subframe fit onto a EK sedan
  51. EK suspension on EG!!
  52. 97 civic. Brand new suspension issue
  53. good website to shop for brembo blanks and pads
  54. Energy Suspension Bushing kit??
  55. Caster is off by 2 degrees, will traction bars allow me to correct this?
  56. minimum length for bumpstops
  57. Tokico.....poo
  58. Lowering timeline
  59. does civic si struts and springs fit an integra ls?
  60. eibach sportline
  61. springrates *researched*
  62. OTHER shocks for GC's?
  63. adjustable struts : softer setting = lasts longer? koni, illumina, agx, etc...
  64. how fast do polyurethane bushings wear out?
  65. 02 Accord Alignment Specs
  66. Neuspeed sport on stock strut 95 ex
  67. Need Suggestions On Suspension
  68. what to do about lower ball joint.
  69. what is this called?
  70. PIC suspension: Just recieved... Initial thoughts.
  71. coil bind?
  72. Which parts are interchangeble from a dc2 and eg?
  73. have some question about integra shocks? please help me out
  74. lower ball joint rubbing against rotor.
  75. Any downside to going plus size rotors...?
  76. Suspension suggestion for EG (this is definitely not my forte)
  77. need your advice
  78. Tanabe NF210 Review
  79. Damaged suspension needs correcting...
  80. Front ball joints STILL creaking - at a loss what it could be :-(
  81. Question about Ground control coilovers.
  82. best spring rate for begin 3" to 4" low?
  83. Looking for a setup
  84. OMNI coilovers... 1st gen and 2nd gen... how do you tell the difference?
  85. Different spring rates?
  86. k sport coilovers
  87. H22 Swap 94 Accord- Coilover spring ratio
  88. will these springs work good on my stock shocks?
  89. I got robbed - i.e. 96 cpe suspension probs
  90. kg to pounds conversions?? how do they match up
  91. my factory springs? need help:<
  92. What other cars could these fit on??
  93. Universal suspension mounts?
  94. omni power coil over HELP!!!!
  95. DA coilovers on a EG hb - WTF happened>?
  96. L con traction bar
  97. Anyone using Megan R. "slip on" coilovers?
  98. ef forks on eg hatch
  99. Pic request for ASR 32mm ASB...
  100. shocks/coilover assembly
  101. Rear Tein SuperStreets Squeaking.
  102. Rear shocks sounding like 400pounds in the trunk
  103. What coilovers to choose?? Mostly street, some track...Tein/JIC/Buddy Club?? and where in NorthEast
  104. GC/Koni setups
  105. rear strut bars - opinions
  106. RICER QUESTION ABOUT MY EIBACH SPRINGS
  107. 96-00 civic spc upper arm info required
  108. LCA length
  109. Sway bar and Traction Bar Issue/Question
  110. Centering steering rack
  111. Question about MacPherson Struts...........
  112. Spring install ruined my shocks?
  113. Password JDM tower bar eg: hardware question
  114. Omni-Power Adjustable Damping Full Body Coilovers??
  115. OMNI POWER or TIEN
  116. spring rate
  117. Koni struts for 95 accord wagon???
  118. Increase tire pressure for better fuel economy?
  119. DIY: Installing Koni Yellows and Ground Control Coilovers (with pics)
  120. omni coilovers and tokico blues??
  121. Shocks & Struts- Need help!
  122. How to install my Coilovers on my Stock suspension struts?
  123. H&R vs Eibach springs?
  124. Where to purchase Miracle Type (2) cross brace for EG Hatch
  125. upper balljoint
  126. need help choosin suspension setup for EK..
  127. Sub-Frame Brace Question
  128. Buddyclub N+ in an EK -> uncaptive? [pics]
  129. 96-00 EK rear shocks on a DA
  130. how to make koni yellows stiff?
  131. Suspension help
  132. Questions about coilovers
  133. koni yellows
  134. Question about suspension setup
  135. different eibach sportline kits
  136. Front Squeeking... Suspension?...
  137. SKunk2 full coilover pro review
  138. Function 7 rear LCAs and OEM Anti-Roll Bar (Sway Bar) on EE / EF Chassis
  139. bushing help on skunk2 lcas
  140. Q's about Koni shock for DA9 and DC2
  141. DA Integra Motion Ratios?
  142. Illuminas and S. Techs
  143. rear LCA bolt connected to shock fork won't come off
  144. EK Hatch - DC2 ITR Sway Bar bushings wont fit with ASR Subframe Brace & Spoon Street backbox??
  145. Teain flex question
  146. Help with complex suspension geometry (long post)
  147. help with ksport coilvers for an EG but on gsr control arms
  148. groundcontrol upper mounts... Anybody use them???
  149. suspension help
  150. Tein Coilovers SS, basics matchig setup except springs
  151. Suspensions for accord 2005
  152. rear trailing arm bushings
  153. Is this cause of a Bad Hub??
  154. accord and civic coilovers
  155. Pinch bolt question on koni yellows
  156. Stock suspension, correct order of parts
  157. camber wonder
  158. 92 civic hatch rear brake conversion (from 91 integra) rear end sits high why?
  159. Koni/GC
  160. will EF struts sit lower my DA?
  161. Beaks kit w/ skunk2 lower tie bar for dc2
  162. Need opinions on custom spring rates
  163. Koni Coilovers
  164. Confused about spring rates??
  165. LCA BUSHING/STRUT mount problem! HELP ME
  166. Anyone tried the NEWEST Skunk2 front upper control arms?
  167. Need 5th gen prelude suspension tips! (strut bars, sways, ties)
  168. omni power vs ground control/koni yellow
  169. lca bushings
  170. need help from TEIN DEALER for honda crx
  171. What is better full coilovers or slip on coilovers?
  172. Any lowering springs/coilovers or any type of suspension parts available for 07 civic sedans?
  173. Ordered some KSport's...What else do I need?
  174. Goldline springs...good or bad?
  175. uneven ride height with old suspension and with new
  176. Question about adjusting ground control coilovers
  177. Two screws on rotors???? are they Neccesary???
  178. Fab'd up some new Top hats!
  179. Difference between 2 BD's
  180. which brands are good?
  181. Help with ITR Springs
  182. Front right wheel tilting outward...
  183. anyone have a comparison of front upper and lower control arms DA vs EF ?
  184. How to raise the car up an inch or two from stock?
  185. New to suspension, been reading up, but still lost
  186. ok so why wont the shop align my car?
  187. ASR Brace and Beaks tie bar?
  188. Beaks Lower Tie Bar on a DC2 Question...
  189. where to buy Energy Suspension Bushings?
  190. $*%&ing bushings!
  191. omni power v. Ground control/koni - for EF civic
  192. lowering without camber kit
  193. Skunk 2 coilovers
  194. New Tein spring install, question about the dust boot and bumpstop
  195. Skunk2 Proseries coilovers for a 92-00civic or 94-01integra...
  196. Recommend me lowering springs
  197. Can you tell me what blew?
  198. honda fit suspension
  199. NEED HELP ON SPRING!!!
  200. H+R spring question
  201. EIBACH sportline installation help!!!!
  202. quick help for my suspension
  203. Someone help me find the right suspension...
  204. 97 accord rear shock problem
  205. Camber kit bolts backing out skunk2 camber kits!! HELP!
  206. Your opionon please: Tein VS Eibach
  207. What suspension piece is this? "Dogbone?"
  208. bent an axel
  209. Possible suspension problem...
  210. Del Sol suspension
  211. Coilovers
  212. lowering springs
  213. camber question
  214. Koni Yellow Shock Question
  215. Don't have adjuster dial set up for 1 of my shocks
  216. Got my GC/KONI -- What to do next?
  217. Ways to prevent subframe destruction?
  218. SOMEONE clear this up once and for all - Camber kit or not?
  219. ASR on EK hatch with stock springs?
  220. Adjusting ride height
  221. Need info: have to replace front sway bar
  222. 93 LS rear disks on 99 civic ex?
  223. Brake line question
  224. help not sure what to do with suspension
  225. Squeek coming from the front of car
  226. Shock / Coilover install questions.
  227. Tokico Illumina Shocks HOW LOW?
  228. Spring rates for tokico springs on 94-01 integra?
  229. Best Suspension
  230. Question on GC coilovers
  231. COILOVER SET FOR 00 ACCORD
  232. I need info regarding Tein S-techs for EK Hatch
  233. ....Help with Subframe Damage....
  234. Ground ControL
  235. Neuspeed race springs or H&R race springs : with koni shocks
  236. PIC performance suspension: Ride height range
  237. tokico hp shock and springs
  238. Camber/Alignment on Turbo Car
  239. lower ball joint problem
  240. 93 integra springs on 94 civic
  241. EG SUB FRAME TEAR
  242. megan racing coilovers?
  243. Corner weights
  244. adjustable length coilovers
  245. busted up tie-rod boot??
  246. Dual rear sway bar (6th gen)
  247. HELP: strange noises out of suspension
  248. steering response decreased after suspension install???
  249. Blox front and rear camber kits
  250. KyB/gcs vs Koni/gcs??
