PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. anyone have ct 5lug conversion on ek hatch? need some awnsers.
  2. who makes lime green rear lower control arms
  3. general suspension questions
  4. $1000 what to do, what to do...
  5. GC Tophat question???
  6. Replaced sagging springs
  7. sluggish handling
  8. DB1 Vibrates and Pulls under Acceleration?
  9. ITR rear lcas work with asr endlinks??
  10. installed coilovers and caster is off after the alignment
  11. Lowered Car...Remove Wheelwell?????
  12. Function and form type 1 input please..
  13. 5 lug conversion questions ?
  14. Re-Installing End Links
  15. Wilwood pedals/ proper set up
  16. car sits lower on one side
  17. **Quick help please what mods(links)(axels) and such for slammed particularly EGs**
  18. aftermarket vs. oem endlinks
  19. 94-01 integra front brakes vs. 00' civic 9.5" (interchangeable on the knuckles?)
  20. Suspension setup
  21. Energy suspension polyurethane bushings
  22. What front swaybar on eg
  23. extended top hats?
  24. Suspension Frequency Calculation
  25. Bust Engine mount.
  26. How do you do with this one on your slammed EG
  27. Progress $600 Coilover!!
  28. 23T mounting bracket on what model legend
  29. Steering wheel shakes 80 mph
  30. can i just buy ground control sleeves?
  31. what kind of rotors are you guys runnin?
  32. Can tire size affect shock travel ?
  33. Rack & pinion swap help!!!!
  34. where to find rally suspension
  35. car sit lower on one side with new shocks&springs
  36. How bad of an Idea is this- Ej1 Kybs
  37. lowered car breaking axles?? input please
  38. X-tractor Rear trailing arm puller near Austin Tx
  39. dd suspension with slight drop
  40. best fixed height shock set up
  41. stock vx brakes question?
  42. AFFORDABLE Suspension setup ?
  43. rear end snaps ED6 "EF"
  44. little understeer?
  45. Problem with installation?
  46. suspension advice! please READ.
  47. ITR sway bars question
  48. something is wrong with my car now!
  49. help
  50. Blox Adj. Endlinks
  51. groundcontrol rates
  52. need centerbore size for 96 ITR 4 x 114 front rotors.
  53. EMUSA Adjustable Coilover opinion?
  54. EG and EK Suspension swapping.
  55. how to take struts out?
  56. bought rear lower strut bolts (dc2/eg)
  57. rear lower tie bar on 95 civic
  58. WTH is this *** weird rotor
  59. 92 HB SI, upgrade my brakes
  60. Wilwood 12.19" rear kitr on ITR w/pics
  61. brake caliper
  62. EF Drag suspension setups
  63. Where to buy dust boot/cover
  64. Cost to install springs?
  65. sway bars
  66. Bolts broke on skunk2 camber kit
  67. 40/40 99-00 civic si proportioning valve
  68. stainless steel braided master cylinder brake line
  69. Koni shocks adjustments
  70. Torque Industries Full coilover system opinion
  71. Will i have any issues putting 99 si suspesion on a 95 integra?
  72. do i need to roll my rear fender?
  73. Extended Top Hat for CRX w/Tein SS questions
  74. simple Ground Control question...
  75. Any Advice before I change my brakes?
  76. 92-00 civic bb/mc on ef fitment?
  77. Comptech subrame reinforcement + 24mm ASR sway bar
  78. 95 civic lean
  79. GC help!!!!!!!!!!!!!!!!
  80. asr subframe brace with factory sway bar?
  81. New Coilover Springs
  82. EF brake upgrade
  83. Cutting Springs
  84. Rookie Question
  85. stripped the nuts on my rear koni yellows =(. is what i'm doing safe?
  86. Camber/Tire Wear and drop concerns..
  87. How long does it take for springs to settle?
  88. Hardrace bushing install/review
  89. Suspension setup planning - Stiffer ITR rates on a GS-R
  90. Sway bars/lca
  91. having a problem with my alignment,wondering if anyone could help?
  92. Got a set of free Porsche 996 Turbo front calipers!! Can i make em work on my honda?
  93. thump noise
  94. Stiffer front/rear rates..
  95. rear drum to rotor swap without spindles
  96. Anyone else experience this after ASR install?
  97. dust boot questions
  98. ctr sway?
  99. A-Sports adj. upper control arms?
  100. Need input... new springs for Tein SS coilovers
  101. 00 gsr mc/bb on a 99 civic ex
  102. Smallest master cylinder available?
  103. Need suggestions for 4th gen Prelude suspension
  104. Koni/GC helper springs
  105. Opinion on H&R coilovers
  106. suspension HELP
  107. Rotas!
  108. H&R civic/integra race v H&R ITR sport spring rates?
  109. control arm w/ ball joint or ball joint camber kit
  110. wheel bearing crooked?
  111. My suspension setup
  112. ASR brace
  113. Having DC5/EP3 Front LCA bushings removed? how difficult?
  114. new coilover setup what do i need?
  115. DA Parts on EF 4dr?
  116. Brake Caliper
  117. which coilovers ride mostly like stock
  118. need help with my brakes
  119. Difference in coilovers
  120. ex front LCA
  121. swaybar.
  122. Neuspeed Race Springs
  123. whats? goin to stop
  124. what are the longest biggest springs
  125. Whats your opinon on these coilovers??
  126. reliable alignment shop in l.a. area
  127. omni suspension problem
  128. Help strut rod went thru hood!!!
  129. camber kit help
  130. Will DA shocks and springs be ok on a DC4?
  131. Dropzone Productrs!
  132. cant find bilstein sports for 92-95 civic coupe?
  133. need new shocks
  134. Did I boil my brake fluid?
  135. Harbor freight ball joint press kit
  136. upper control arm moves.. WTF?!
  137. hawk pads don't fit? wtf...
  138. soft vs stiff
  139. honda crx spring and shock question
  140. Koni shocks
  141. i forgot a part of my caliper do i need it
  142. Help with coilovers!
  143. bang for buck
  144. Constant Driverside Bearing problems
  145. Question about Prelude lowered suspension
  146. Would you trust these?
  147. Removing Balljoints from upper control arms.
  148. EG coupe ex w/ rear disc?
  149. Did groundcontrols ever go by any other name?
  150. Fastbrake owners, 15 inch wheel fitment??
  151. 91 Civic Wagon Rear Brakes
  152. Integra Mc bench bleed prcosedure step?
  153. Skunk2 sport shocks question
  154. Snapped the head off an LCA bolt.....
  155. car leans on one side
  156. Adjusting Coilovers
  157. Koni yellow adjustment
  158. oem bushing kits?
  159. So my Ksports finally blew
  160. Help me understand....
  161. skunk2 lowering springs question!
  162. Wich car belongs this MAster Cylinder? [Photos Inside]
  163. Adding camber
  164. Help need so answers..PLZ
  165. Koni SP3 w/ H&R race spring?
  166. Where to buy ball joints?
  167. 95 civic dx rear brakes
  168. ST VS. type R rear sway bar
  169. What to buy after shock+spring
  170. Civic vs. Integra UCAs
  171. anyone ever do a skid pad w/ gc/konis?
  172. Brake upgrade question
  173. 99-00 Si Fork Bolt
  174. skunk2 lca's
  175. Custom DC2 brake setup question. For experts!
  176. sway bars
  177. ASR subframe brace bolts where to get them?
  178. 4 wheel disk
  179. What are good lowering springs?
  180. Bushing X-Tractor Tool For Rent Near Southeastern PA??
  181. what's the purpose of preloading a suspension?
  182. GC - those in the know
  183. ebay rear sway bar
  184. ek rear conversion
  185. Tein RA
  186. Brake pad recommendations?
  187. Tein VS Koni+GC VS Skunk2 VS Tokico HP's
  188. something is bent i need some advise
  189. 1989 Honda CR-X SI coilover setup and spring rates
  190. Got my car back from being stolen...
  191. SPfab Spoolin Performance traction bars REVIEW
  192. 22mm rear sway bar-does it make ride stiffer?
  193. What are my BRAKE PADS trying to tell me? (pictures)
  194. Question about Ground Control Coilovers
  195. Weird problem!~
  196. screw on Polyurethane bushing? traction bar construction part.. HELP!.. pic inside
  197. used H&R race springs too high
  198. subframe weights?
  199. rear wheel hub vibrating and shaking at HPDE
  200. I failed...
  201. a good high speed suspension?
  202. why do my brakes suck?
  203. anyone tried using the DROPZONE coilovers
  204. whos using koni 3011 on the track ?
  205. Annoying brake problem
  206. okay to use cheap brake shoes on drums?
  207. SPRING RATE THREAD **searched**
  208. fast brake kit
  209. whats a good brake set up for my dc2?
  210. full OMNI coilover help
  211. Rim offset question...
  212. Where to take for alignment?
  213. new master cylinder - bench or gravity bleed
  214. any tokico blue user?
  215. hks coilover replacement parts ?
  216. hardrace...where to buy?
  217. omni power sport or buddy club N+ spec for h22 eg hatch
  218. do i need to lube??
  219. Help decipher my alignment sheet
  220. camber kits/ axles/ lca
  221. Strut Bar questions
  222. Looking to upgrade master cylinder and brake booster, advice?
  223. gr2 kyb
  224. Advice on Coilovers
  225. Best Motor Mount
  226. Anyone have experience with H Braces for 92-00 Civics???
  227. Lowering tein flex w/edfc problems
  228. Car Sitting Lower on One Side?
  229. Car Sitting Lower on One Side?
  230. Question about lowering springs?
  231. Full body coilover questions
  232. Tein Springs?
  233. axxis brake pads the same as pbr?
  234. coilover sleeve question
  235. Password jdm rear strut bar help!!
  236. Replacing my Skunk2 coilovers. What to get next?
  237. Delete please
  238. Difference between ITR and non-R compliance bushings?
  239. Motor Mount.
  240. Suspension Overhaul, Looking 4 Input, DC Koni GC setup on a DA?
  241. Tokico Illumina
  242. Has anyone ever blown a KONI YELLOW?
  243. Guys with TEIN SS, are my bumpstops on correctly?
  244. Someone have KYB AGX reviews?? *pic inside*
  245. 88-91 vs 92-00 Civic Shock Differences
  246. Function7 LCAs
  247. koni gc problem
  248. LCA Bling! Expertise needed!
  249. Energy Suspension? Yes or no?
  250. Suspension
