PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. who here uses omini
  2. Weird lower balljoint problem, please help!!!
  3. civic lca
  4. Does anyone have pics of the Eibach Pro Springs?
  5. S-tech Springs on Stock Shocks
  6. skunk 2 vs omni power
  7. Torque Specs Please.........
  8. Invidia Rear Sway Kit for EK's
  9. In need of some expertise
  10. Miracle X bars V.S. EM-racing bars
  11. Need help with Koni Yellows/GC install....
  12. hatch suspension
  13. CRX SWAY BARS
  14. TEIN SS . Higher spring rates ?
  15. cusco zero 2, with 4 dampening setting?
  16. ghettos thing to do.
  17. I want to change all the bushings in my suspension...
  18. whats a good set of...
  19. Where to buy a tokico shock
  20. 350whp on low boost need new suspension
  21. camber setups for daily driven some track use coupe
  22. will DC2 front LCA's fit onto EK chassis???
  23. Using GC Extended Top Hats with Strut Bar
  24. I need piston measurements from your 4 piston and 2 piston calipers
  25. Neuspeed 4 point strut bar install help please ASAP!
  26. Are the BSQ kits still available???
  27. TEIN SS All the way down ?
  28. Neuspeed/Bilstein threaded body coilovers?
  29. do i need a camber kit?
  30. need avertisements how to drop my 97 civic?
  31. Tokico Illumina's on my 92 Integra GS-R => what settings(#'s) are you running
  32. What Parts Get Re-used on Koni/Eibach Install for '00 Civic?
  33. Looking to lower my car, what kit?
  34. h&r or ground control
  35. brace bars, rear tie bars
  36. need help wit suspension ideas... chime in
  37. spring ID need help!
  38. Need some help with a project of mine
  39. dallas shops that adjust camber
  40. koni yellow.. need spring seats
  41. Alternative to removing brake line bracket for Koni install?
  42. 91 int to 92-93 int
  43. GSR or Si strut bar on an EX?
  44. would you buy this?
  45. Highest spring rates on stock 93 Accord Shocks?
  46. 2001-2005 Civic people.....
  47. I need help PLEASE!!!
  48. Traction bar help
  49. alignment question
  50. help, lowering/raising omni power full adjustable coils
  51. Suspension washer on upside down
  52. BEST REAR CAMBER KIT MADE
  53. Will suspension technique sway bars for dc integra fit ek hatch?
  54. ek9 rear subframe part no ?
  55. rear springs
  56. Ball Joint Replacement..?
  57. GC extended top hats with omni coilovers ?
  58. Searched but no answer found....Will 205/50 have a softer ride then 195/50 profile tires?
  59. K Sport spring rate
  60. sway bars
  61. Wheel shakes a lot at highway speeds. NOT a wheel balance/warped rotor issue.
  62. Coilover sleeve is stuck on shock
  63. extended top hats
  64. tein vs buddyclub
  65. FRONT WHEELS PUSHED BACK!!!
  66. sway bar help with 02 civic
  67. [Searched] civic Brake question
  68. Koni snap ring vs GC coilovers
  69. Koni, Ksport, Function or D2 Coilovers . Help me choose
  70. camber kits... opinions... serious ones
  71. suspension setup
  72. need help ! coilover problem on my civic
  73. Koni/GC Combo - What is the Default Ride Height?
  74. What the hell is that noise? Wheel bearing problem?
  75. kyb gr2 help
  76. what you think about my set-up?
  77. ground control with koni or stock?
  78. skunk2 full coilovers
  79. What coilover kit should i get??
  80. coil overs
  81. help - Spring anti-compression thingie
  82. SHOULD I LOWER MY CAR MORE???
  83. Will a EK Skunk2 Camber kit fit a DC?
  84. LCAs
  85. Some Ground Control install questions.....
  86. Tein SS warranty? Lifetime? Year?
  87. which do u prefer?
  88. i searched, and i didnt find
  89. how much?
  90. I have questions on the total rehaul of my suspension
  91. coilovers jammed help
  92. need basic springs, what would u recommend?
  93. Kyb agx install ?
  94. A Spec Racing ASR reinforcement installed with 22mm CTR sway pics and comparison
  95. 22mm Sway in Teggy
  96. Koni Yellows with what springs on EK?? Help info needed
  97. jacking distoring alignment?
  98. problem..
  99. Wheel/Suspension Questions
  100. skunk2 full coilovers
  101. Would this cause damage?
  102. 87 CRX torsion bar mounts????
  103. 3 way adjustable shocks for EG?
  104. Tokico w/ GC's?
  105. progress springs with tokico illuminas?
  106. body roll pt.2
  107. JDM ITR 23mm rear sway bar with Civic SI endlinks
  108. apexi n1 dampers for sale
  109. how to install endlinks?
  110. Koni Red (Special)
  111. camber
  112. Tokico Dspec R
  113. Got a question on Koni's w/GC
  114. tokico illuminas or koni yellows?
  115. D2 Coilovers on EG daily driver
  116. will em1 suspension fit 95 hatch(searched)
  117. skunk2 full coils
  118. has anyone has subframe tear in an integra
  119. Loering on KYB GR2's?
  120. Suspension for my del sol
  121. What would be a good aggressive camber setup for a DC2?
  122. WHERE CAN I GET ENDLINKS FOR AN EM1 AND WHAT KIND?
  123. fitment question
  124. So...has anyone broke aftermarket LCAs yet?
  125. will a SPOON tie bar fit on a ASR subframe?
  126. Type-R Sway Bar
  127. Koni Neuspeed SP3 or Koni Yellows?
  128. MAJOR suspension overhaul for an 88 CRX Si. Help me gurus
  129. prelude endlinks
  130. 99 Civic Ex rear disc conversion (searched)
  131. anyone know if 94+ integra shocks will fit into 96+ civic??
  132. rear shock, must stop the squeak!!
  133. Super Racing Spec Circuit Master Type N1
  134. HFP and A-Spec Suspension on 2006 CM8 "Facelift" Accords
  135. coilover help
  136. how hard is it to remove and replace old bushings with new ES Bushing Master Kit?
  137. pic request: 96-00 civic coupe 16s on eibach pro-kit
  138. Ground controls
  139. H Techs Anyone?
  140. HOW BIG ARE YOUR BUMPSTOPS!
  141. Lenso's...
  142. help: is this a good suspension/camber kit setup?
  143. How do I re-connect my sway bars?
  144. rear alignment problem
  145. steering wheel alignment
  146. body roll
  147. Kyb Agx's and Neuspeed Race
  148. Need Help Completing My Sway Bars!!!
  149. 99-00 SI Suspension/Brakes onto 92-95 Civic Sedan
  150. Energy Suspension
  151. 97 Integra Suspension/Alignment/Camber problems
  152. Is it a stupid idea to put Spoon calipers on a daily driven car?
  153. will a rear sway bar from a 92 hatch fit my 92 4dr
  154. A caution about brakes
  155. type r suspension on a DA
  156. bilstiens or gab?
  157. Good suggestion for stock shocks replacement?
  158. what type of lube???
  159. Rear disc brake conversion
  160. Koni "yellow" with H & R race spring users
  161. ST sway bar... reinforcement
  162. ES bushing differences???? RED vs. BLACK????
  163. Coil Spring Booster
  164. [color=green] what is the difference between Koni red & yellow? [/color]
  165. recommended struts
  166. Suspension settings
  167. QUAIFE STEERING RACK
  168. suspension install problem
  169. Best suspension for a 97 gsr?
  170. Spax Coilovers?
  171. quik question
  172. suspention problems
  173. blown shocks
  174. GC's
  175. del sol what shocks to buy
  176. Bent rear "K-frame" or "rear crossmember" but where do i buy a new one????
  177. Wondering About Right Front Lower Control Arm for CRV
  178. CHEAPER WAY TO RUN 5-LUG???
  179. dc2 tein s. tech springs
  180. kyb agx or koni for a daily driven car
  181. ST rear Sway bar for Integra Gsr! need some inputs for subframe...
  182. wheel alignment question
  183. Tokico , Blistien , KYB , Eibach , koni
  184. EK Suspension, Help me pick
  185. your opinion...traction bars
  186. Question regarding D2 coilovers and lowering wrenches... thanks
  187. Lowering Springs
  188. DC sports front and rear upper shock tower braces?
  189. 2001 Honda Civic EX suspension set up HELP!!!!!!
  190. ATTN: Suspension Guru's. Need input on these.
  191. h&r race rates on eg
  192. ALIGNMENT EXPLAINED GTG(GET TOGETHER)
  193. Could I use 92-95 Civic Front LCA, shocks, springs on my 94 Integra?
  194. GAB Revo stroke problem
  195. stock shock question
  196. Post pics of drop
  197. Sway bars
  198. advice on susp
  199. Need feedback for Apexi, Tein, and BuddyClub Coilovers....
  200. 94+integra ground control and 92 civic Kyb AGX's?
  201. Silk Road coilovers?
  202. prothane bushimg kit on my 91 civic
  203. Eibach or BC?
  204. SEARCHED
  205. Whats the cause?
  206. h series springs for my eg
  207. where to find top fuel b to c pillar bar?
  208. Using CRV hubs for a 5-lug conversion on a 99 em1?
  209. D2 36-Way Adjustable Full Coilvoers
  210. Suspension Decisions!! HELP!!
  211. I got some serious problems with my suspension and i'm asking for any help!!
  212. H&R Ultra low full coil-overs question or reveiws...
  213. Progress rear sway bar
  214. obx coilovers with koni yellow
  215. RSX Front Strut Bottom Out?
  216. Steering jerk, Axle, c/v, steering rack, what????
  217. Question on Eibach Springs.
  218. tanabe springs review?
  219. Help me decide on a setup! Urgent!
  220. Drop Question?
  221. what honda vehicles use 32mm axles in a 5-lug configuration?
  222. BLOWN SHOCKS!! Front or Rear blow FIRST??
  223. GC coilovers (length?)
  224. how do i run my integra w/o the power steering?
  225. Front swaybar installed and now having trouble shifting into 1st and 2nd..
  226. Extended studs in front without using a press?
  227. How to preload megan coilovers?
  228. Repairing stock gsr lcas.
  229. RS-R Springs? Need input
  230. Tein springs, need new shocks and bushings
  231. Decent struts
  232. Omni vs Tein
  233. Koni Yellows ?
  234. Just installed coilovers. Car sitting crooked
  235. 3pt vs 2pt front upper
  236. Need help finishing my sway bars!!!
  237. suspension setup for a bb6 TypeSH, suspension gurus come in and help please
  238. coilovers
  239. Need some advice on a set up.
  240. eg front lower control arms
  241. Tie rod causes vibration? Please help
  242. helm end-lniks (function 7, ASR, etc)
  243. apexi n1 dampers for sale
  244. How to test or check for damages from a set of used shocks
  245. need help with tein ss
  246. asr subframe reinforcement kit with thermal 3"
  247. does the kyb gr2 come with protective boot?
  248. Whats the difference in 18k Omni Coilovers and solid bar suspension (rear)
  249. Spherical bearings, poly bushings, oh my!
  250. rear sway bar installation w/o subframe reinforcement bracket
