PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. eBay coil springs
  2. Megan Racing Coilovers, any good?
  3. What do you guys think? Advice and suggestions please!
  4. Omni Power Question?
  5. where to buy Sway bar hardware
  6. ABS brake problems
  7. EJ1 front and rear bar recommendations...no love?
  8. OEM axles or NO?
  9. oem bigger break upgrade question
  10. HELP! on rear brakes
  11. unknown Function form type two model
  12. clunking while accelerating.
  13. Help Choosing Budget Coilovers
  14. Questions about alignment specs.
  15. What are good struts for a lowered 99 civic dx
  16. coil overs vs lowering springs
  17. Parking Brake Rear Caliper Kit?
  18. How do I lower my car?
  19. Bolt problem while replacing RTA bushing HELP!!!
  20. H-Tech Tein Lowering Springs with Stock Struts on EK?
  21. Ground Control Stock sleeves to koni sleeves
  22. Gc Spring rates for my Ej
  23. cut out strut towers
  24. TEIN SPRINGS
  25. Tein Damping Setting
  26. NSX Caliper on ITR (Quick Question)
  27. Help!!!Brake pedal gets hard after driving for 10 minutes
  28. Adding camber kit, will it change toe?
  29. New Struts/Shocks for SH w/ Skunk2 Coil Sleeves
  30. Do these RTA bushings look O.K. to you?
  31. Installing a strut brace...
  32. Can't tell what brakes
  33. spring rate for del sol
  34. Car maxed out low on one side but not the other.
  35. F2/Function form
  36. top of stud on tokico shock
  37. skunk2 drag launch kit. what shock combo
  38. 2004 accord lx sedan dropped ~1.5inches
  39. Prelude SH lowering
  40. Air Suspension
  41. going for BIG DROP! whats the best coilover/setup?
  42. AGX vs GR2 vs Koni Yellow vs S2 Sport vs Tokico shocks
  43. need help with itr 5 lug suspension back wheel bearings please!!!
  44. clunking noise with new eibach sportlines with eibach shocks?
  45. Brembo Jaguar S-Type R calipers work?
  46. Shocks and rear disk break conversion
  47. 89 integra brake problem
  48. take a look drop on eibach sportlines
  49. ST Drop Fork help and questions
  50. Rear control arm bushings
  51. whats the coilovers
  52. 500f/350r spring rates...input needed
  53. How many inches off the ground are you?
  54. 11" Prelude Front Brakes on EG?
  55. New Project
  56. Warped rotors? (95 civic ex)
  57. HX wheel braking options?
  58. suspension choice
  59. Toe Out?
  60. which sway bar to buy??
  61. Brake pads??
  62. *Question about ASR spherical endlinks*
  63. Coilovers?!?
  64. 2.7 Degrees of Caster on Integra gs-r
  65. dc2 lca bushings to a eg si lca??
  66. What Springs go where??
  67. Extended top hats?
  68. Civic Drop Spindles
  69. Getting my crx lower its already on coilovers
  70. koni str.t shocks
  71. brakes squealing while driving and braking
  72. Rear Brake is tight
  73. Help fix rear tire wear
  74. what would cause my front pass. tire to get more wear then the rest ?
  75. 5-link rear suspension...toe curve?
  76. Is it necessary to break in my new rotors?
  77. Ground control spring rates for 96 hatchback
  78. GSR swaybar and endlink question
  79. Spongy brakes 95 Odyssey
  80. Bump Stops
  81. cut tein springs on my crx?
  82. converting power steering rack to manual (full conversion possable?)
  83. Lowest Drop
  84. ef ground controls on da?
  85. Where can I get Ground Control Koni sleeves?
  86. HELP!! 95 civic front lower control arm bushing bracket bolt SNAPPP
  87. More steering angle possible?
  88. 93 EG Hatch suspension upgrades from 95 EX
  89. Skunk2 Sport struts question
  90. Replacement parts
  91. any difference between da and dc front calipers?
  92. Koni Yellow or Koni STR.T?
  93. Blown Coilovers?
  94. Nsx Calipers
  95. Camber Kit Problem?
  96. DA running 98 ITR suspension. Rear sub frame brace?
  97. 94 civic k-sport suspesion setup j32a2 for drag
  98. what else can i go to lower my 92 civic hb more???
  99. Lowest but most comfortable lowering springs (04 Accord)
  100. 89 civic road race suspension
  101. wago
  102. spoon calipers on EG
  103. Alignment question w/ camber kits
  104. Ground Control size and fit help
  105. HELP ! What Coilovers kit should I buy ?
  106. Daily Warrior
  107. Should the slider pins have some "spring" in them?
  108. Best spring/strut combo for '97 Accord Wagon
  109. Which Coilover Would Be The Best?
  110. Megan lca ?
  111. which 2 buy?? D2 type-rs or Function form type-2
  112. Ride height change after installing front swaybar
  113. where to get alignment done in mn
  114. Aftermarket LCA's with stock sway bar.. Input needed
  115. aftermarket V forks for civic
  116. Lowering and shocks questions.
  117. ASR on EKs
  118. Affordable drilled/slotted brake kit for 92 Civic EX Coupe?
  119. Best suspension setup for 92 Civic EX Coupe?
  120. Steering is off. Suspension?
  121. Lowering Breaks Axles?
  122. post lowered del sol pic
  123. neuspeed race springs
  124. Steering Rack bushings need replacement?
  125. LOW suspension with stock or better ride?
  126. Help Rear Brakes
  127. Eg Coilover sleeves
  128. my front suspension is bad please help
  129. questions on drag setups
  130. Need some advice on my Tein SS-Ps
  131. koni yellows w/ eibach pro kit?
  132. 89 ef sedan suspension suggestingss??
  133. LCA's...blox or...stox?
  134. question regarding suspension techniques
  135. skunk2 for eg hatch fit my em1?
  136. Suspension advice from all the experts
  137. help with GC top hat with KW ver3
  138. EJ COILOVER ON EG HATCH?
  139. QUICK RWSPONSE PLZ
  140. Stiffer OEM rear shocks for EF?
  141. Creaking Suspension after replacing both front lower control arms and drop links
  142. Buddyclub N+ damper adjustment for EK?
  143. suspension
  144. revalving question
  145. HELP!!-Koni Yellow Pushing Bushing out of Top Hat
  146. hawk hps pads not working good please help
  147. Opinions of this suspension setup
  148. what is purpose of shock tower extension????
  149. has any one run oem da lca and uca on an ef?
  150. I need help
  151. suspension suggestions..daily driven Acura Integra 1991
  152. DC coilovers in a Ef
  153. Rear Suspension Springs for 1990 Acura Integra
  154. anybody know what car does this shocks fit?
  155. What do i need to make this Plug and Play
  156. I need help the with my Function & Forms
  157. Coilover Question! for EM1
  158. Eg hatch 2 or 2.5 inch drop
  159. Eg hatch drop requests.
  160. aliignment / steering wheel help
  161. Stripped fitting on brake hard line
  162. 91 civic ef--> front end rattle
  163. accord to civic
  164. 97 Ek civic rear toe left side is WAY off?!
  165. Camber kit question
  166. Replacing trailing arm bushings
  167. JIC Magic vs TEIN suspension question
  168. koni str.t and eibach sportsline??
  169. What kind of disks are these?
  170. Car pulls hard to right??(Integra)
  171. Help! Squeaky front left suspension?
  172. Alignment, vancouver wa/portland or area
  173. coilovers or springs ?
  174. skunk2 full coilovers
  175. Installing coilover sleevs
  176. Skunk2 Sport Shocks & Blox Lowering Springs?
  177. What's a Good Race Track Suspension?
  178. 2000 Civic DX Parts
  179. Steering Wheel Shakes, plus Intermitten Body Vibration
  180. Stering wheel shakes, plus acceleration vibration and car shakes at higher speeds
  181. need help on 5 lug setup
  182. Need alignment or tire problem?
  183. ITR brake setup and rear disc brake conv.
  184. Tokico Blue and H&R sports springs??
  185. New to honda/acura's... rear bushing question
  186. Questions about Energy Suspension coil spring Islators
  187. 96 ek oem suspension questions
  188. 2001 civic /Acura brake problem
  189. How to have a smoother ride?
  190. Front Caliper Rebuild: both??
  191. Front Upper Control Arms Installation
  192. Front Upper Control Arms Installation
  193. Broken rear sway bar end links
  194. Mileage on civcs?
  195. Bilstein B6/B8 Monotube INVERTED shocks
  196. need help!
  197. Tokico Illuminas -- which setting?
  198. What brand coilovers are these?
  199. DC2 Shock and spring on DA9
  200. Spring rate identification from part #s
  201. Stock Height On Coilovers?
  202. Another Koni yellow question (NOOB)
  203. Diff between 92-95 and 96-00 Civic springs?
  204. brake/new axle issue
  205. Half-assed brake job
  206. camber bolts question/comparison
  207. Bushing recommendations - PRO Input Needed
  208. question about ebay lca
  209. GR2 Struts with Megan Springs Please HELPP
  210. I hear all bumps inside car....why?
  211. 92 civic VX rear disc brakes
  212. What kind of suspension!!!
  213. Opinions needs on Rear Sway Bar, to Add or Not to Add
  214. EK Suspension Help
  215. Honda Newbie: EK Suspension Help
  216. What are wrong with these GC's?
  217. Skunk2 Adjustable Coil overs?
  218. Weird Question for the Pro's
  219. Suspension advice -- Illuminas, Eibachs, H&R?
  220. Cross camber/toe? Tires bad? Bad bearings?
  221. 95 civic EX equipped with ABS?
  222. interchangable suspension parts between 89 civc & 98?
  223. recomended suspension for an accord
  224. when do my endlinks need to be changed
  225. Skunk2 coils, adjustment wrenches
  226. Best coilover for dual-purpose EG6?
  227. Do I need shorter/lowering springs with Bilstein Sport?
  228. Anyone know if Bilstein Sport is compatible with stock springs?
  229. wobble when turning
  230. prelude BB/MC on civic?
  231. Ground Control sleeves
  232. Anyone ever used one of these camber/caster gauges?
  233. SUSPENSION PROBLEM
  234. koni with generic coilovers
  235. 4040 proportioning valve install..?
  236. koni setup
  237. Koni Yellow +H&R race 99 cx
  238. Brakes went from mushy to super stiff
  239. DROPZONE GEN II Shocks and Coilovers
  240. Any idea what shocks these are?
  241. ruined MC?
  242. Anyone used Racing Gear JTC N1 Circuit Coilovers before?
  243. OEM Spring life EH2
  244. Possible bent suspension components
  245. how to adjust koni shock back to soft..
  246. Camber Kit
  247. koni/ ground control combo
  248. LOUD POP from rear going over bumps/uneven ground
  249. tein s tech springs
  250. energy suspension bushing into ksport lca?
