View Full Version : Suspension & Brakes
- Anyone use Advance Auto's GS-P new CV axles?
- How do I identify stock springs (fronts/rears)?
- used koni,gc questions
- Koni Yellow/Eibach Pro-Kit Assembly Problem??
- Question about dc integra top hats
- Spring Rates Progress Series II Coilovers
- Please help me ID a sway bar - green, but not Suspension Techniques
- Brake upgrade help
- brake gurus!
- EG with 4x114 type R conversion questions?
- EK suspension in dc2
- Another GC/Koni thread..
- Koni Strt's. Worth it?
- 16" Rota Grids, what size rotors?
- Brake Fluids
- Whats a good slammed susp. setup for a Rex?
- planning out suspension setup need opinions
- 90 Civic Si w/Legend front calipers and 10.3" rotors
- need help on stopping power
- KSports feel way too stiff? (was: is it just me)
- Koni + GC = Bottom Out?
- Koni and Ground Control Sleeve Question
- Will H&Rs(51865) fit DC2?
- 94 integra rs brakes upgrade
- Biggest headache suspension related
- What's the difference between Koni SP3 and Sport?
- Making Dropzone coilovers work.
- 97 Civic Drum Adjustment Problem
- Function & Form or Blox full coilovers??
- ground control question
- 92 Civic CX Front Sway Bar?
- Wheel Spacers
- Ground Control extended top hat/Strut Bar Issues
- wilwood pad and rotor replacement
- 1997 Accord EX ABS Brake Modulator?
- Will Prelude Vtec rotors fit S2000 calipers?
- 15/16 OR 1"...which would be better...?
- NON AN brake line tuck? pics... comments....
- 06 civic si brakes into 01 gsr?
- ITR Rear sway size difference
- Am I measuring total TOE right?
- LCA's worth it?
- Lowering my crx!
- Koni & Ground Control Question
- Extended top hats necessary?
- front shock fork diffference??
- HELP! can't make up my mind.
- coilover sleeves inquiries
- gsr brake question ( quick answer needed )
- Pic coilovers or k-sports?
- Chassis bracing galore
- '92 4door civic *help*
- Brake ?
- Odysey Caliper Whit Corado Disc on DX Knucle.
- comptech help
- ST Suspensions Reviews
- Aftermarket 5 lug conversion
- Comments and Suggestions on my Suspension Plan
- new left side bearing stiill humming
- Considering EBC Ultimax Blackdash Slotted Rotors
- Need Help ASAP for 97' Civic Upper Control Arm
- buzzing ABS unit
- what rotors and pads to go with
- ebay "Type R" knockoff strut tower bars?
- ride too bouncy?
- how do I go lower? **pics**
- difference between ITR and GSR suspension?
- Rotors for my crx?
- 95 civic power to manual steering rack
- Is this kind of camber kit safe?
- What kind of bushings to use with BLOX LCA
- Lowering a 98 Accord Sedan
- 11" rear brake upgrade or stock itr??
- Koni shocks experts - please confirm
- 92 civic rotor/caliper stamp?
- Brake Pedal Sinks to floor / 95 Honda Del Sol SI
- full bleed needed?
- newb+skunk2
- which lowering springs would you choose
- megan coilovers
- OEM ITR springs on Skunk2 shocks?
- 02 TL Humming Noise rear hubs maybe??
- Function7 rear lca upgrade to spherical
- KYB GR2 or Tokico HP
- anyone know where i can get new
- Wheels getting super hot after driving ??
- My Steering wheels are not straight?...
- Progress Competition CSII Coil Overs
- Rear Disk Hub Swap
- Brake Upgrade
- sway bars
- JIC FLT-A2 Rubber Bushings?
- obx camber kits
- air ride setups
- What front and rear sway bars can I use on my EG8? 4 Door?
- Used Tien SS or Brand new koni yellow/GC?
- EK Alignment question
- New color for K sports coilovers
- ASR subframe and sway bar question
- will EJ DX calipers fit on EG EX/Si spindles?
- No brakes??
- rotor wobbling?
- How do you tell what shocks will fit with used GC's?
- 96 itr 4x114.3 rear hub replacement
- Low Offfset Wheels Question on EG 4 door
- new master cylinder and still no pressure in lines
- Replacing shocks on EM1 HELP!
- stiffer spring for my function form coilover
- Official Honda brake fluid
- Grinding/Stiff Steering
- xxx lb spring = xxx k spring
- dx brake caliper questions
- will 90-93 integra s2 pro coilovers fit an civic 92-95?
- What brake pad are you running?
- HELP ME FIND OUT WHAT SUSPENSION IS THIS....
- Front UCA bushings for EG/DC?
- Not as low lowering springs?
- Hardrace RCA
- Updating eg suspension
- Function & Form Type 2 Feedback?
- function form type 2 extended top hats
- Function7 rear brace ??
- EG upper ball joints
- K SPORT suspension ?
- Brakes Arent working fully when quik stopping.
- i need help...
- 92-95 Civic Si Suspension Differences
- disc brake swap help plz
- tenzo r big brake rotors
- wheel hop help
- 94 civic eg. lookin for coilovers
- can someone identify these coilovers i just bought skunk2
- aftermarket suspension parts...Beck/Arnley, Moog vs. OEM?
- Wilwood 4 Piston BBK Questions- Several
- buddies EM1 SI brakes over 5lug Itr brakes... weirdo
- wheel fitment with big brakes
- rusted function 7 end links
- Source for Single or Pair Ground Control Sleeves.
- Spoon calipers with 4x100
- ek & eg lca bush Q
- 4x100 vs 4x114?
- prelude suspension ques
- Bseries gator axles and hubs
- Rotora drilled & slotted rotors
- GC coilover top plate issue...
- wheel/fenderlining clearance Help
- integra MC on ek BB
- EBC Rotor and brake combo!?
- NEED SPRING RATES
- Spring Rates on the SLAMMED rides?
- Anyone try these this out?
- Pic selects: figuring out spring rates. Opinions
- Function and forms coilover tighten perches
- Tokico Dspec Coil overs
- do they fit..Eg6 onto Da9 coilover springs
- questions: please help. 4x114 onto EK
- Polyurethane Bushings!
- Susp. Bolt removed?
- Alignment issues help
- Endlinks, when to replace?
- Gsr springs on ITR shocks???
- new bushings
- Time for new suspension
- stock shocks
- Caliper Paint Color
- brake is locking up
- H&R SPORT SPRINGS w/ KONI SPORTS
- Getting New Suspension setup...
- Blox Competition Coilovers?
- crx rear suspension
- brake masters i need your help
- EG Rear LCA Strut bolt head broke
- Suspension Idea/Help
- Use Honda Super Hi Temp Urea Grease on brake pads, is it ok?
- EK Uneven drop question
- Big brake guys how often u replace your pads?
- skunk2 coilover kit opinions
- my brake set up
- Civic springs tend to sag, where to get replacement?
- Godspeed coilovers, non dampening adj. Anyone heard or using these??
- Wheel bearing replacement without press
- Buddy Club N+ Damper // EG install Question
- Q: FUNCTION/FORM type 2 collar stuck ?
- pics of your low del sol or eg civic
- bouncy rearend with h&r springs but im thinking its the struts
- has anyone ever bought these shocks for their 96-00 civic
- Brakes recommendation?
- BLOX camber kit?
- I have a little camber wear up front..How should I fix it?
- rebuildable shocks?
- GSR Disc Brakes on EG
- Sway bar end links
- Ebay suspension kit Ball joint, Tie rods ECT(?)
- Need camber help
- Help Picking New Suspension
- megan racing front camber kits
- 11" rear rotor?
- prop valve location?
- Fluid options?
- question bout front lca for ek
- What do I have to remove in order to replace the steering rack?
- EK civic: ASR subframe, ASR 24mm swaybar + OEM 99-00 EM1 endlinks?
- what is best dragracing suspension for a delsol
- D2s or Ksports ???
- Opinions on my dd suspension setup
- Sway Bar ID
- ITR brake Master question.
- PLEASE....HELP...TOKICO ILLUMINA W/ GC COILOVERS...OPINIONS
- Hardrace?
- 99 si MC and BB in a DC
- tein ss or tein flex?
- Every heard of these?
- Alignment/Toe question
- sway bar
- Skunk2 sport shocks Polyurethane bushings (wtf!)
- KYB AGX springs.. Lost in a sea of spring rates.
- 4 lug type-r suspension????
- Civic 00 Suspension
- blox coilover ?????
- coilovers
- Shock Brand
- steering wheel trouble
- Brake Disc Screw Stuck -- 94 Civic coupe
- camber question.
- 1998 honda civi manual rack and pinion question
- 1979 Honda Civic CVCC Hatchback
- Rear Disk Conversion! Help
- Ground Control Top Mounts & D2 Coilover
- skunk 2 eg/dc coilovers pro c
- need some feedback on brake setup
- Beaks Products -- Test Cars Needed
- New StopTech Trophy Sports Look SICK!!!
- 99 si front sway on an integra?
- 96 spec brake conversion on 95 civic lx 4dr. what proportion valve and bmc to use
- ef spring VS eg spring
- rear brake caliper need help asap!!!
- Question about stiffness for suspension gurus
- Skunk2 sport shocks Part# confusion
- wierd noises from suspension area
- DRivers side sits lower than passenger...WHY?
- Skunk Springs
- ground control tops hats
- Best strut/spring combination under $500
- EK front sway bar on EF ??
- Skunk2 Sport Shocks - Question...
- Anyone know what kind of bar this is....
- Brake seizing, how hard to replace calipers myself?
- Cutting ebay springs
- Rear Brake Calipers - ITR vs EP3/DC5
